View Full Version : Wheels, Tires & Brakes
- 315X70X17 with daystar 2.5 leveling kit, will this work?
- Bad Vibrations
- more brake noise
- Tire & wheel ratio
- I need a change.
- Big tires
- Bearing ?
- determining rotor thickness/warpage
- Bridgestone Dueler A/T
- Bigger Tires
- Sizen it up
- Torque value for F-150 rotor retaining nut
- 305/70-16, 305/70-17 or 315/75-16
- 2 lift or not 2 lift
- Master cylinder problem?
- got to replace rear brake pads?
- help with tires
- Tire question...
- 315/70R17 on stock SCrew
- gas mileage
- BF'godrich 265/75/16 for my Expy
- Best rotor and pad setup
- Stainless steel braided brake lines
- 33x12.50 R17 no rubbing?
- 39's???
- 285's on 16x10 wheel
- My New 22s
- Cross-Rotating Tires????
- Will 15" rims w/35 BFG's ride?
- F 350 Rotor removal
- stock rims
- Brake sensitivity
- Lost spare tire & rim at 70 mph
- Left rear wheel locks up
- Balance & Rotating Tires?
- 305/70/16
- Cheaper Revos Than @ Tire Rack
- Rear shoes
- weight of tires vs. size
- Nitto Terra Grapplers
- tire size
- Max Tire Size for 2004 F-150 STX 4x4
- Hub won't come off!
- need rim....
- Harley F-150 wheels
- Pics of 2004 f150 supercrew with level kit and 35's
- Boyd Coddington Wheels
- Need pics of 16x8, 16x10 & 17x9
- *PINK FLAMES* 20 inch Chromies
- The dreaded ABS light...
- Max tire size for a 2004 F150 XLT Reg 4X4
- Thumping, before and after rotor & pad replacement.
- Brake Dust
- dangling hose on axle..help
- EBC Brakes
- Winter Tire ? - Screw
- Tire size for f150 2004 factory wheels
- Largest tires for Expedition
- Changing Front brakes for first time...
- Brake Dust?
- 29.95" to 30.45" on 2004 F-150
- Brake fade when turning right
- 2004 F-150 tires
- 2002 Tire size????
- Cant decide between MT Baja MTX and Revo
- brake squeal
- 35's
- KODIAK A/T tires
- Bigger Tires
- Brake(s) thumping?
- 4ABS problems
- Newbie here, brake question
- Replacement Calipers
- Goodyear MTR vs BFG AT
- 33's with no lift
- 2004 supercrew wheels and tires
- need help, wheels stuck.
- ABS light fixed
- Overinflation tire wear pattern
- 4 Wheel ABS?
- Rear rotor stuck ebreak
- Any feedback on Continentals
- New here and got a question....
- anodized rims
- 2004 front brakes dust!!
- Tire swapping Question.
- Which Is Better???
- bigger tire size for 4x2 lifted f150
- Tires
- Wagner ThermoQuiet pads????????
- I love AND hate 4wheelparts.com!!!
- abs and emergency brake lights on
- 2 ?'s Lug Pattern on an 04 heritage / anyone have experience with wheel adapters
- 305/70/16 mud terrains
- Brake wear
- Tire Size Question
- Speedometer - Recalibrate
- Sidewall Spliting on Michelin tire
- Tire pressure question....
- Wheel Size?
- Eagle Alloy Series 178's...
- Slotted Rotors for a SuperCrew
- 18" wheels for off roading?
- Stock Goodyear Wrangler side wall seperation??
- Bridgestone REVO's and opinions
- '03 Rear brake "groan"
- 2004 F150 33' tires pricing
- Please help me on tire/rim
- Tire Help! Wandell, Anyone
- Gonna need new tires soon
- Rotors are warped, what do you recommend
- How much lift to fit 35's
- 35x12.50/17 Trxus STS
- Repacking wheel bearings
- ABS and warped rotors
- Nitto Grappler A/T's
- 2004 F-150 wheel size
- lee ridge runner tires?
- 01 f150 e brake issues
- 20 inch rims
- Emergency brake not working
- SVT 18" pics on a 4x4????
- Off Road Tires for 22's
- Revos, BF, Dunlop, Highway, AT, MT?
- Which tires . . .
- Biggest tires for stock 86 F-150
- 2001 Superscrew
- Aluminum Wheels Stuck On
- VSS Gear question.
- using 88 bronco mags on a 79 f150 ?
- Front Rotors!!
- actual miles driven with bigger tires?
- 17x9" wheels
- Need HELP removing my F250 Rotors
- Checking speedo calib. against engine rpm's w/larger tires
- Need help with Tire/Gear sizing
- 3" lift. 305/70-16 or 315/70-17? Help
- 4x2 Front Brake Questions
- BFGoodrich g-Force T/A KDW-2
- 16" wheels for Older F-150's
- big brake upgrade
- Frozen Rotors are on the way
- 2002 F150 SuperCrew bolt pattern
- 256 70 r 17 and Spare Tires
- Weld Stonecrusher's on Nitto Terra's
- Blinking Anti-Lock Brake Light-Cannot engage into gear!
- parking brake
- ABS problems
- Rim and tire combo??
- 20's on a 4X4
- Another speedometer question.
- new wheels vs. ride quality
- 4" lift with tires smaller than 315s?
- LT265 Diameter = P265 Diameter?
- Brake Squeak
- Goodyear
- toyo open country m/t wear?
- Machining new rotors before 1st use?
- 35's on a Ranger?
- Abs Light
- modular wheels?
- Need brake pad recommendation??
- center wear on rear tires
- Rear Drum Adjustments???
- Speedo Calibration with size change
- Anyone Heard of Maxxis Bravo HT Tires?
- whats the bolt pattern for f150's
- 285 - 60 X 18 - 51 psi?
- Whats a good disc pad replacement?
- Truck Vibrating
- BFGoodrich AT 285/70/17s available anywhere?
- HELP ...will someone help me...
- left brake hose is rubbing tire when turning
- American Racing
- Easier stuck rotor removal
- 88' F-150 Backspacing needed for a 10" rim?
- Rear Caliper Torque Specs?
- Terra Grapplers or BFG ATKO
- rotors from carquest
- ARE 7-bolt Mag's 4 a Ford
- 20'' 04 Screw wheel upgrade.....
- 285/70/16 bf goodrich ko
- 04 Screw 20'' Wheel questions...
- Stud's shearing off!!
- What tires do you recommend?
- ProComp Sale
- Stock 16" aluminum wheel size
- Need 1 Dunlop SP-9000
- What tires do i buy?
- Body Lift!?!
- Brakes Pulling To The Left/right
- Gear Ratio
- 16 in stockers, take a look if you want um
- Wheel Bearings
- I have some stocker to get rid of, take a look.
- Need Pics of 285/70-17 BFG and 3" lift
- Wheels for slicks
- Brake smell???
- 5 inch lift!?????
- Lug nut and stud replacement
- Any of you running BFG AT's 265 or 285 on a reg cab...
- 2004 F150 wheels fit on 2000?
- Stock 17" rims are 7" or 7.5" ?
- Vibration....
- Warranty Concern
- advice for new wheels and tires?
- Bigger Wheels?
- 92 2whl dr drum brake problems
- 16" or 17"
- Need help deciding on MT or AT
- Front brakes and rotors
- Mud Terrains
- 16x9 pics please
- Cooper Discovery H/T
- Tire size change and speed recalibration
- Correct tire pressure for LT265/70/17?
- Disc Brake Conversion
- Stud Conversion
- Weird noises...
- P series tires vs. LT series
- Squeeling problem part 2
- speed loss with bigger rims?
- rear brakes
- bigger than stock tires, speedometer is off
- F250 tires
- 315/70R17 tires
- mud terrains for 18's?
- Brake noise
- 16x9 wheels
- Anyone running Parnelli Jones Dirt Grips yet???
- Rotors
- bleeding question
- 16x10 4" Backspace/ Lift question
- Question on Harley 03 stock wheels
- Good deal on MSR wheels?
- Planning ahead
- Uniroyal Laredo AWT Tires
- 2004 4X2 wheel/tire size recommendations
- what is this
- Wheel for my 150/04
- Need Some Advice
- chroming wheels
- BF Goodrich Tires
- How do you figure tire height?
- gearing
- gearing
- Brake question
- 97 F150 Front Brake Problem
- Pictures of 35's or 33's!
- what tire pressure?
