View Full Version : Wheels, Tires & Brakes
- help choosing Wheels+tires+lift kit
- Tire Size
- 7 lug 17" wheels
- galaxy's wheels
- Good place to buy FX4 wheels?
- 16" Wheels Fit?
- What is a good tire size for 16"?
- Anyone else have the 7 x 150 lug pattern?
- in need of a big brother
- 3" lift, what size tires/rims
- Brake swooshing noise when pressed
- 15's ???
- cheap tire alert, or i've gone crazy
- Brake Rotors?
- Bridgestone Revo
- 4 - 7 pin wiring harness
- Warped Calipers...Anyone Else?
- Need 17" 7 bolt wheels for my 2004
- BFG 285/70-17 and 17x9
- Best commuter/off-road tire combo?
- Just got my 4x4 screw, bfg/classicII pics
- BIGGEST tire for OEM wheels
- Nitto Terra Grappler 295/70R17 ?
- Lightning brake noise under hard braking
- 01 F150 XLT Screw 4x4
- Bigger tires
- Brake vibration
- Need opinions on tire size/truck height
- brush guard and lifts
- 'persuading' stuck drums
- Front bearings & rear wheel cylinders.......
- Which do you like better?
- Squeaky Friggin' Brakes
- Powerslot Rotors with Hawk Pads Free
- A LITTLE too BIG!! LOOK!!
- Will 285 70 R17 BFG T/A KO's work
- Rusted/Pitted rotors
- New brakes squeaky!
- Tire question
- Brake Pads
- Please show pics of 17x9's
- Wheel size options for 2004 4x4?
- Just in-case!!
- Allot of Discussion!!
- bfg's
- harley wheels
- Very squeaky rim!
- '99 F150 4x4 Tire Size
- New Tires
- whats the consensus for PREVENTING stuck rotors?
- 275 vs. 33" or 35"
- Power Slot Rotors
- WTB 16" wheels....
- I've searched the treads but no answer yet...
- Lift kit on my truck
- Brakes And Other Problems
- First Class Brake Shop
- Brake problems
- what size?
- Center cap Logos
- Where to buy tires online?
- 2003 FX4 Wheels and Tires......
- 7-Lug 17" Wheels
- Cracked brack shoes
- ABS Light still on
- Bridgestone Dueler AT 693 16" tire recall
- new here and have a ?
- I need Brembos!
- 285 or 315
- 255/70/16 to 265/75/16
- emergency brake cable coming off
- How long before changing stock brake pads?
- variable assist power steering not working
- 285/70-17 on 17x9 wheels
- Swept area?
- Front Brakes Dragging
- '04 fx4 18" mach cast wheels with wimpy tires
- Tread life buckshot vs pro comp
- 2004 SCrew Wheel Bolt Pattern
- HELP best winter tires to fit on lightning
- Center wheel Caps
- beadlock question
- advice needed please on wheels and tires
- Thinking about Cooper or Mastercraft AT's
- New Tires
- will it rub
- "Tire Price Matching" experiences
- front wheel sensor
- New F150 Wheels and Tires! come look
- larger or smaller speedo gear needed?
- Tires - best ride
- New Brakes Smell?
- Speedo & Tires Question
- 285/65/18 BFG ATKO _have a question
- Discount Tire having a hard time with my balancing.
- Advice on 20 inch Centerline wheels and brakes
- tire size
- BFG TA's
- Which Tires Do You Like?
- Bigger than 24s??
- 2004 f150 rear rotors
- Tires that fit 17's??????
- Bearing Nut - How tight
- New Rotor Suggestion
- Brake failure results
- Can anyone help?
- Can someone suggest a good Wheel supplier?
- interesting noise
- 17x9 or 16x10 with 3" lift
- New Tires Available from Hankook
- Finally got my wheels
- Brake failure
- getting new 38" any suggestions?
- 20 inch rims
- OK, I'v Done it: Got an Appointment to get Revos Installed
- lift, big tires, and gears
- Tire Storage
- Will these tires fit my rims?
- what offset/back spacing?
- Best Heritage 4x2 tire size, may lift later
- A little frustrated.
- ?? on tire size, mph, gas mileage...
- Crappy brake pads?
- 2002 rotors
- What type of Rims are these?
- Need help on tire/rim combo!
- Rotor recommendations?
- Dust shields for aftermarket wheels???
- Tech 1 Rockcrawlers for 2004 F150
- My NEW TIRES
- 2004 f150 supercrew rear brake rotors
- hub caps
- I need some recommendations on some rims!!!
- 18" Lightning rubber sizes, other?
- 35" BFG Tire/Wheel Balancing
- Wheel squeek!!!
- ABS light blinking and won't go into gear.
- Dunlop Rover RVXT
- Nitto Tires
- Where Can I Find These Wheels
- gas mileage and big tires
- question about rim balancing
- Help finding 7 LUG WHEELS PLEASE!!
- 97' WIth 3"Body Lift Tire Question PLEASE HELP!
- new wheels and tires
- FX4 wheels
- how big part 2
- El Cheapo Wheels---Need some help
- Aftermarket Lightning Wheels
- Where to find OEM 2004 F150 Steel Rims
- Widening my SCrew's footprint
- 16x10 wheel recomendations?
- Tire help
- Daystar with Welds33's No Cutting or trimming
- 2000 Lightning Rims W/335 ZR18's Tires
- 16x8 wheel backspacing question
- Mickey T Question
- ?? on wallyworld BFG tires
- New tires
- How big with 3'' PA lift?
- Just bough a 04 stx...need fx4 rims/tires
- Scored on some new wheels
- New BFG 35's
- How do you protect the underside spare?
- signal lights on mirrors 2004 f150
- New tires finally! 33" MT Baja Radials
- Soft Pedal
- wheels wont come off
- looking for a offroad wheels in 18" for 4X4
- looking for a offroad wheels in 18" for 2004 4X4
- 33's with Truck Masters air dam?
- Will they fit???
- 22 inch black wheels for sale with tires CHEAP!
- So many choices - need pics to help me choose
- 04 F150 wheel upgrade options?
- Bad luck with Wrangler AT/S tires.
- How big?
- wheelsfortrucks.com >> ok to buy from?
- new tires today too!
- Got My new tires installed today!
- HOw big can tire fit FX4 Screw 04 without lift?
- New Tires/Wheels Size Questions...
- corrosion on new wheels
- Wheel and Tire Question??
- Do Napa disc brake pads have good quality?
- Help needed; stuck wheel lock.
- Stock wheel backspacing
- Biggest?
- Performance - 305/70-16 or 315/75-16
- 285's
- New Tires??? 1997 F150 XLT
- Big Rims Cause Brake And Tranny Problems??
- 20 inch wheels for sale
- My 2wd is finally a normal size truck!
- calibrating speedo with new larger tires
- new tires
- master cylinder?
- Kumho Road Venture 825
- Just bought my new truck
- Is My Rear Caliper 'Frozen' ?
- do larger tires require speedo recalc?
- Changing Tires
- Changing Tires
- switching P235 70/r16 to LT235 85/r16
- Selling Factory Tires
- Noisy NEW tires - Destination LEs
- Need tire help-quick!
- 305/70-16 Bfg At
- stock steel wheels?
- brake problems
- 2k4 f150 question
- Bridgestone Dueler APT III tires ? anyone
- has any1 ever been off roadin w/ 35'' tires w/ no lift?
- Big Tires w/out a lift
- finnished brake job
- 305/70/16 on 15x10s......
- Question about stock center caps
- Finally ordered my tires and rims today!
- terra graplers
- tires/gears
- 17x10 Weld VelocitiXTs w/ 38x15.50 PJs
- Wheels for Lightning
- Do I have 12 or 14mm studs?
- Pro Comp MT or BFG MT
- Chrome or polished
- need wheels for 17"
- pics please
- Max Tire Size??????
- baja claw radials
- Max tire size???????
- wheel size
- What PSI for 285/70/17 MT/Rs?
- Bridgestone Dueler H/P
- 33"s on 16x8
- Pro-Comp X-Terrains
- Emergency AND ABS Warning Lights On
- Leveling F150 needing tire sizes please
- 305/70/16 on stock 16x7 wheels
- New Tires...finally
- New Harley Davidson 20"
- 35" Tires w/ 3" body lift!?!?!
- Left Turn Brake Moan
- Premature front rotor wear
- which mud tires??
- Lug spacers for larger tires?
- 3" body lift
- BIG Brake upgrade
- ceramic pads?
