View Full Version : Exhaust & Intake Systems
  1. Advice On K&N
  2. single to dual
  3. Exhaust and Header system
  4. Need Opinons on Exhaust
  5. Question regarding large tips
  6. TBS useless???
  7. Already have gryphon... Banks or re-gear for 35''
  8. LT install
  9. Exhaust Confusion
  10. So, drone in the cab
  11. question
  12. O2 Sensor Help Needed
  13. Roush exhaust??
  14. Advice needed, help please!!!
  15. Is this correct??
  16. magnaflow exhaust
  17. Please Help loud rattle from air filter
  18. Dynatech-Magnaflow Install Question
  19. Anyone Running MBRP SIDO on a 2009+
  20. Exhaust change, need input
  21. Magnaflow...round/oval...sound difference?
  22. does k&n air intake give you better gas mileage?
  23. new system up and running
  24. Exhaust upgrade, no drone...
  25. Nate's True Dual Thread
  26. Help me out
  27. Help me out
  28. Please Help
  29. Cut my pipes off today
  30. CAI+Throttle body spacer+throttle body
  31. Intake Question
  32. True Dual xpipe vid??
  33. opinion on exhaust setup
  34. 2010 Ford F150 V8 AEM Intake
  35. Straight pipe video
  36. BBK shorty headers? Go or no go?
  37. dual in/dual out muffler?
  38. Want back pressure,but loud,what muffler?
  39. o2 sensor after rear cats
  40. exhaust pipe size
  41. Saleen dual side exit exhaust
  42. my recommendation
  43. Flowmaster 50 SUV vs Delta flow
  44. how bad is the drone with the Banks intake?
  45. Dumped with tips pics?
  46. Opinion on dual exhaust on lariot
  47. 04-08 5.4 3V Long Tubes
  48. So much popping?
  49. still don know whats wrong
  50. My exhaust is finally done!
  51. Probably a BIG debate thread...
  52. Help, problems after installing magnaflow
  53. Double exhaust on each side???
  54. Cold Air Intakes
  55. No Cats Question
  56. Dual Exhaust
  57. Oxygen sensor help!!!
  58. Bullets/Low End Torque Loss?
  59. Dynatech header Y pipe question
  60. Gotts intake on 4.2L V6 question...
  61. cold air intake
  62. catalytic muffler?
  63. muffler
  64. exhaust and warranty
  65. Dumped Flow!!
  66. 07 Harley S/C
  67. Resest ECU after new exhaust= better MPGs??
  68. CGS exhaust
  69. CGS exhaust
  70. 4" straight pipe!?
  71. Mig settings to weld a muffler?
  72. Do you keep your stock muffler
  73. looking for input
  74. 4.6L exhaust
  75. Banks vs K&N Air Intake
  76. I plan to install true dual hedman headers with mangaflow exhaust no cats.
  77. FlowMaster 50 Series
  78. Torque Numbers with 11" vs 14" Magnaflow
  79. 02 F-150 Cat Delete
  80. Magnaflow Duals, Rear Cat Delete Broken in
  81. Anyone in Seattle know a good shop?
  82. I did the deed!!!!!!!!!!!!!!!!!
  83. Discount Codes
  84. Question on Tips
  85. L MAF on N/A 5.4L Lariat?
  86. Where to buy??
  87. Stripped studs on factory 05 cast iron manifolds
  88. MIL eliminators from a mustang
  89. So, can i do this?
  90. Exhaust and MPGs
  91. What To Do With My Exhaust?
  92. what to do with my exhaust
  93. Help me find the right sound!
  94. Dual Magnaflow 2.5 in/out and low end
  95. engines fine. now what?? it only leaves one thing..
  96. Magnaflow question, critique, gripe, and praise.
  97. 4" tip?
  98. Cracked Exhaust Manifold, Let talk Headers!
  99. Which magnaflow is comparable to the fm 40 series???
  100. What?!?!? Dual COLD AIR INTAKE?!?!
  101. high flow cat pipe size 2.5? or 2.25?
  102. super duty exhaust tip
  103. ideal exhaust system
  104. Performance: Out Back vs. Side
  105. Flow this...Magna that...Mella WHAT???
  106. Kinda disappointed with new magnaflow cats...
  107. SVT Lightning exhaust
  108. Airforce 1 CAI----what replacement filters?
  109. High Flow Cats
  110. Which Cold Air Intake For '08 5.4? Heard of "knock off Flowmaster Super 44s"?
  111. How to install Vacuum Gauge?
  112. Plastic inner fenders
  113. confused what to get??
  114. Oxygen Sensors.
  115. Quick question regarding an intake
  116. Dynatech headers here monday!
  117. What CAI to run?
  118. Cold air intake problems, help out a old timer!
  119. Avfrog's Flowmaster videos!
  120. Black tips
  121. P0053 and P2195 on 07 5.4 Flex
  122. Decided to get exhaust!!
  123. Black Exhaust Tips
  124. Is this right??
  125. Neede exhaust recomendations
  126. Some general Q's about exhaust.
  127. Online o2 supplier
  128. So confused!
  129. Dual Side Exit? BothSides?
  130. Exaust manifold replacement help
  131. High flow cats or not
  132. Exhaust and intake questions!! need help please
  133. Picture Request...Dual Side Swept
  134. Should i remove my precats?
  135. Why 2.25 and not 2.5?
  136. super 44s vs slp lm2
  137. to ceramic or not to?
  138. tips? no tips?
  139. DANG...passenger side manifold leak!!!!!!!
  140. Need help !!! Headers
  141. Help!!!!!!
  142. intake/exhaust advice
  143. Very PO'd right now
  144. AFE intake syatem for 2009 5.4L
  145. Magnflow High Flow Cats
  146. Magnaflow and Borla Volume...
  147. factory cats on 99 f150
  148. Magnaflow 16522 Installed!
  149. What's the best exhaust setup for performance?
  150. Muffler
  151. new exhaust finally
  152. Looking for Custom Exhaust Shop (Allentown, PA area)
  153. Dumped Exhaust on v6
  154. URGENT!!! HELP!! TB clean, poweraid delete
  155. Deleting The Back Cats
  156. lightning upgrades??
  157. Dynatech header kit just installed - video!
  158. O2 Sensor eliminators?
  159. I want a new exhaust
  160. trying to remove muffler
  161. True Dual Straight pipe
  162. Exhaust Mainifold
  163. chrome tips
  164. high flow question
  165. Need new exhaust (Help)
  166. Question bout rear cats and stright pipe
  167. Cold air idea induction
  168. Different ehaust route
  169. anybody else
  170. Help plz
  171. loud idle
  172. Cheap exhaust option...
  173. Getting work done Saturday!!!
  174. Selling Cats
  175. Where is the support for the 09-10s
  176. Took everyones advice and got bigger tips!
  177. How much did you pay.....
  178. pacesetter long tube headers
  179. Cat question?
  180. What type of exhaust on 1995 L6
  181. lightning long tube headers
  182. which magnaflow
  183. Someone Stole my Tip?! Pics.. lol
  184. Help---want nice deep rumble, but no highway drone
  185. Hottexhaust coupon code
  186. How to headers
  187. Exhaust wanted but dont want to spend $1000 for the magnaflow kit
  188. Just ordered my new Magnaflow!
  189. 3" cat back with Bullet, dumped?
  190. no sound out of my right exhaust pipe??
  191. 97-98 4.6L Ford f150 PI head swap
  192. exhaust modification questions
  193. Help!!! Magnaflow cats installed
  194. Us Flowmaster guys...
  195. Magnaflow Muffler model number?
  196. I want an exhuast but i dont know what im getting into
  197. hi-flows installed!!
  198. Thinking about a new setup, have questions.
  199. Air Filer
  200. ford lightning JLT Vs. JLP air intake system
  201. Is my CAT leaking or clogged?
  202. Question regarding 03 vs 06 exhaust manifold
  203. Throttle Body???? Help!
  204. Long tube headers VS shorties
  205. high flows
  206. Aluminum intake manifold
  207. Throttle Body Spacer
  208. Ridiculous Price from muffler shop...PART DEUX
  209. What should I do now? (wanting louder)
  210. Help please!! Straight pipe dual outlet off the Y-pipe drone question
  211. Good price, yes or no?
  212. 4 tips
  213. Black Exhaust Tips
  214. Ford f150 pi heads stock?
  215. True Duals VS SIDO
  216. F100 exaust?
  217. Ravin (Raven) Mufflers.
  218. Playing it safe
  219. too hi flow or gut thats the question
  220. true duals on an '09
  221. Blew out exhaust manifold gasket, possible?
  222. what does this mean??
  223. Single or Dual, Dumped or not?
  224. chop exhaust from muffler back 07 F150
  225. Wait to add roush intake?
  226. Staying Legal---question on Cats
  227. Can you still use catylitic converters with long tube headers on an 03?
  228. Dumped Exhaust?
  229. Flowmaster to Magnaflow...some questions
  230. dual exhaust on an L6?
  231. Needing some help.... opinion on PI heads
  232. Hey guys thought i should share.. OBX
  233. need opinions on roush off road interior noise
  234. Exhaust????? Which One?????
  235. New Duals today!!! (with video)
  236. New Exhaust from the headers back
  237. Good quiet muffler?
  238. Thunderbolt Highflow cats?!?
  239. Exhaust Manifold NIGHTMARE
  240. SI/DO What size pipe should I use?
  241. Cherry Bomb Catalytic Converters?
  242. New Exhaust
  243. All the same?
  244. Best sound 4 the Money?
  245. Finally posting an exhaust Vid
  246. K&N VS Volant - CAI
  247. CAI differences Performance wise
  248. Throttle body spacer
  249. Does this sound high.....thanks
  250. pipes straight out the back or on the sides
