View Full Version : Transmissions
- My Axle code on door is 19
- 4r70w electronics...
- Recall The 4r70w Part 2
- Tranny in Storage
- 4R70W TC shudder or Differential ?
- Need an advice: what's the best way to fix the leak???
- can someone tell me how to rev-match my manual
- Shift RPMin 4LO on 4X4?
- 98 Escort Auto Tranny
- Tow Package or Not?
- overdrive light flashes
- New Tranny Drain Plug
- AT-Coasting in Neutral???
- 4:10s! a good idea?
- Push-starting a manual question
- Found on road dead? Driver returns on foot?
- Torque Converter Drain and fill ?
- 5 speed manual tranny
- Slip?
- What oil to use in 4R70W tranny?
- adding fluid in 5 speed
- Recall the 4R70W!!!!!!!!!!!!!!1
- flashing overdrive light
- weak 4th gear shift in a 5 speed?
- No Six Speed Available?
- Open Your Eyes To The Five Speed!
- tranny prob.
- Cruise Control
- Hey 5-speeders, fluid change questions...
- E4OD converter, where to buy
- ?Trans Problem?
- Trans Mods
- Best Location for a drain plug?
- Which Tranny?
- Mercon V vs. Universal Fluid's???
- Strong thump from transmission when upshifting anyone?
- Changing trans fluid for dummies
- E40d
- Factory_tech Valve Body work in 4R70W
- Will a 4R70W bolt up to where my manual used to be?
- Just bought truck...Advice on tranny.
- 5 speed Q's
- Is Amsoil the only full synthetic ATF that meets Mercon V requirements?
- Which Transmissions will fit on a Ford F 150?
- ? for you ford driveline specialists...
- Won't come out of park!
- Rear axle code?
- What about this method of changing fluid?
- Recall the 4R70W ?
- Transmission Shudder
- For anyone who's removed the "Extension Housing"
- trans or converter shudder
- No Downshifting While driving uphill
- SuperCrew Trans Fluid Change
- 5 speed towers need help
- clicking noise? chatter
- 1993 E4OD shudder (again)
- Expy 4R100 & Factory Tech
- 5.4L and tranny.
- Mercon or MerconV for 95' W/4R70W
- 4R100 fluid fill
- Factory Tech! 4r100 kit
- Very confused-Please help
- shift kit?
- I need help finding out what gears I have
- Trans Fluid
- Rebuild or replace tranny in '85 XLT? (4WD)
- tranny
- Trans Question for Factory_Tech
- why won't it downshift
- Transmission Failing?
- 4R70W Valve body upgrade
- 4R70W, 4R100, E40D trans. & fluids
- 5 speed Tranny for a 92 f150
- Converter lock-up question??? (that funny half downshift thing)
- B&M Shift Kit?
- Trans suddenly slipping
- 4r70w rebuild@140,000
- transmission
- Trans. Flush on 5.4 Expedition
- Transmission Fluid Change in Taurus
- What gear is this
- $119 for 60,000 mile service good?
- Level 10 Performance Trannys...anyone heard of them?
- Level 10 Shift Kit???
- '01 F150 4sp Auto Trans Problem
- Lightning E4OD question...
- 2000 F150 Yoke Broke in Half
- Transmission Fluid leak
- Factory_Tech ? Expy 4r100
- 96 F150 rear end replacement
- Where to get speedo gear?
- Screw tranny bites the dust
- H.d00 Trans Upgrade
- Techs., need help determining which tranny I have.
- TransGo/Sonnax/Cooler/Temp Gauge/Drain Plug
- Quick curiosity type question for any of you 4R70W experts>>
- 97+ Hurst shifter update (good news!)
- '02 SCrew OK for towing campers?
- overdrive
- Transmission Won't Go In Reverse Without Grinding!
- four wheel low clunking noise
- Tranny Slip when Speed odometer jumps
- Strange sound
- Shift kit for a 4r100 or e40d tranny
- Cooler standard equipment?
- Auto Tranny Maint. & Upgrade
- 4spd or 5spd manual???
- Manual Transmission Shifter Knob
- What transmissions fit?
- What Gears?? 3.73 or 4.10?
- Tramsmission
- gear lube in tranny
- Mobil 1 ATF & 4R70
- 2002 4r70 ?
- F-150 auto trans downshifts like a manual!
- C-6 fluid type and leaks
- 4r70w bites the dust.
- Quick question
- Can a tork converter make a clicking noise?
- question for tranny techs
- M5OD, syncros, again! techs?
- Old Transmission
- 4r70w made to tote kids and pick up groceries?
- Transfer Case
- Early model 97, AODE or a 4R70W
- Temperture bypass valve?
- F150 ESOF stuck in 4L
- ID my tranny: e4OD or 4R100
- transfer
- Help with tranny shifting clunks!
- Question for Factory_Tech & others
- Downshifting-making em scream!
- Transmission Service Question
- Tranny Problems??
- what shift kit fits 4r100 tranny
- Please Help
- What transmission do I have?
- New Fluid, but Old Filter
- Grind???
- Transgo?
- Heavy clutch effort after long drives???
- F250
- Trans clunk during quick stop
- 2001 S'Crew tranny & seat probs
- Changing fluids
- mercon V change interval...
- Trans sticking in gear while in cruise?
- Shift knob
- Jerking/kicking when coming to a complete stop..
- Clunk sound when shifted into reverse
- 99 Exp-Replaced torq conv at 42k
- leaking-pinion seal
- clunk during turn
- How do I empty my torque converter?
- Transmission Leaking?
- Decision help?
- Aod
- Manual Trannie Upgrades
- shifting problems
- problems going into reverse...
- 4R70W service manual?
- Tranny Temp Gauge installed
- sliping
- Working on Short-Throw shifter
- tranny swap
- Shifting Problem
- Automatic tranny lost Overdrive
- Play in driveshaft where it exits tranny?
- Strange Thing happened
- When should you change fluid in manual trans???
- help me go faster
- fluid chant
- Now What's Going To Blow...??!!
- Tranny Probs.
- Fluid Amount?
- Fluid!
- rear end posi lube question
- Did i blow up the tranny?
- Bad TQ Converters in new 150's????
- anyone install a Buaman shift kit in a 2002 4R70 yet?
- slipping?
- Are the E40D any good?????????
- Calling Factory Tech: Problem, not sure how to explain it
- Can anyone recommend
- hhhh
- Are autos stronger than manuals?
- Baumann Shift Settings
- I did the Tranny fluid change
- Redline?
- non-limited vs limited slip xmission
- New Tranny
- New truck and I have questions...
- something amiss???
- E4od 4r100 Rebuild Questions
- hard to get into 3rd gear
- slipping
- Trans info needed
- Shifting Delays
- trans in a '92, F250, 300 six?????????
- Manual Transmission Shuddering
- thumping under truck
- anyone tried this?
- Pressure loss on clucth pedal
- What are the rear end codes for 99 f150?
- Shift RPM Question
- Slight vibration @uphill startup
- Rear seal fallout
- 96 clutch pedal slip
- stutter/miss after OD TC lockup
- 4R70W Fluid Capacity???
- What Transmition Do I Have??
- Tranny Shudder?
- Fittings on Transmission Cooler
- New (Ford reman)Tranny for My Expy
- What brand of MECRON V fluid???
- TC draining ?'s
- nyone installed a Hayden Rapid-Cool transmission cooler?
- Transgo
- Best Tranny Cooler...Recomendations???
- Tranny service questions
- E40D vs Mazda M5R2-C
- Transmission Won't Shift
- TC shudder back after fluid change
- Torque Converter
- Oil Cooler
- 4R70W pan
- hard shifts with chip
- $1,000 Transmission service at 49K Miles - OUCH!
- clunking noise
- Incorrect Gears?
- Baumann Install Experience (long)
- buying trans-go???
- 187,00 on tranny
- Changing transmission fluid
- Towing and tranny coolers
- Clutch Replacement...
- tranny?
- ? on which tranny and a noise in it
- Transgo Help Line
- T-5
- Ever seen a tree hit a Cheby??
- Most miles with TRANSGO?
- Anyone have experience with the Jet Power Shift Kit?
- Transmission Problem?
- need a tranny?
- aftermarket manual shifter?
- Tranny questions
- gears for a 4.6 auto?
- Changing Fluids
