- Tranny slipping after 34K??
- tranny question
- HelpFast! Transmission Slipping
- What do I need????
- Should I have it flushed???
- 4 x 4 Question
- Stutters going from 2nd - 3rd
- New Temp Reducing Tranny Pan
- draining the convertor
- Valve body replacement?
- better shifting 5-speed
- Tranny Slips in OverDrive
- OverDrive Button is going crazy on me?
- Question about switching to synthetic
- Need E4OD Help
- Help! My Trans Killed my Transfer Case
- Transmission Oil Filter
- Calling Factory_Tech
- B&M Tranny cooler GP!
- Jammed shifter?
- Baumann or Transgo??
- Speedometer correction
- changing tranny oil?
- Yet another Torque Converter ???? NEAL
- Front seal leak
- quicker shifts ? Factory_tech
- Trying something for my shudder.
- Bad Transmission
- Help, Factory_Tech, a question
- Transmission slips only occasionally
- B&M Transpack
- Finding out which trannie i have in my truck
- weird tranny
- 4r70 Vs 4r100
- Neal -- torque converter question
- tranny knock??
- tranny knock??
- Swap Tranny ????
- Tranny problem?
- Possilbe transmission problem?
- Installation of shift Kit how hard?
- Baumann kit: unimpressed
- Rear seal and bushing blew out
- Shift kit or Trans shift reprogramer
- so do you actually gain mileage back from regearing?
- Transmissions
- TQ Converter Stall Question
- Tranny Trouble. Please Help!
- Fluid Level.....overfill at factory?
- Do I need to change Trany oil ?
- Gear Ratio
- Level setting question for Baumann shift kit
- tranny prob blamed on re-gear
- Gear ratios for 5-speed?
- C6 ? What will it bolt up too?
- Help! Attn:squanto
- What's the differance?
- Why can't we install a drain plug in the Tranny pan like the oil?
- Need help on 4R100 trans and transfer case
- Changing from Auto to Standard
- A bump going into 2nd gear?
- Help 4R70W or 4R100
- Transmission fluid change out questions.
- Found a Fix for transmission shudder!
- Aftermarket Torque converter
- ?'s on checking tranny fluid.
- Transmission
- Transmission Help
- Letting off the gas at hwy speeds
- Shifter Knob
- B&M experience
- SIX trasmissions and TWO rear ends
- Wierd Noise
- clutch suggestions
- transmission help needed
- Transmission shudder?
- Which Tranny Fluid? Help!
- Overdrive Ratio
- '99 XLT EC Auto trans fyi
- Anyone damage their Trans with a kit????
- What kind is my transmission
- Baumann shift kit questions.
- Transmission Swap
- Slight Transmission Slip?
- Trans temp?
- Is my trany shot?
- Mobil 1 ATF in 5-speed, warranty, installation
- Transmission Fluid
- How much are the shift kits?
- aluminum drive shaft good or bad +/-
- Oh God It Broke
- Went with 5 (Baumann Shift kit)
- 1996 E4OD trans. makes hissing noise...
- Is it worth the extra $100 for Synthetic tranny fluid?
- Sluggish
- Gear choice (3.55, 3.73, 4.10, etc)
- Set of 4.56's
- Warning About Baumann Engineering Shift Kit And Intermediate Shaft Breakage.
- Palerider--message for you
- Transmission 4r70w
- Transmission Mount Installation Questions!
- Need a Sonnax Bypass valve?
- Shift Kit Help???
- 4.10 Installed...by myself.
- Fun at the dealer
- Question What type Tranny?
- Reverse out on 1993 F-150
- '94 - Intermittent Auto Trans Shifting
- When should your change stall speed on converter?
- Transmission Mount?
- tranny manufacturer?
- Fixed problems and new, 9K miles
- Auto vs. Manual Outlasting
- Clutch Problems at 19K
- My Tranny Is Out At 44000 Miles
- down shft too late
- Eratic Shifting Follow Up
- 1st gear auto-trans whine
- Is Limited Slip option worth it?
- B&M Truck Megashifter
- 5 Speed Grinding...
- Want to hear a joke?
- 93 Lightning won't shift 3rd.
- Installation of LED for TC lockup??
- New Clutch
- transfer case leaking
- Has anyone installed a centerforce clutch??
- Damage to transmission after big tires and no regear?
- Fluid leak, 2001 SuperCrew 4R70W
- F150 5-sp questions
- Tranny Finally fixed!
- tranny cooler?
- Attn: NEAL the H.P. Freak
- C6 bell housing
- 5-speed won't go into gear
- How many quarts in the trans
- Tranny noise in Park...
- Is the 5 speed crap?
- where to get tranny temp from?
- Weak clutch at 38,000???
- Rear End Thud!?
- Warranty Dilemma on LS Swapout
- Overdive Shifting Problem
- Problems with my '93 f150 auto tranny....surging...........
- trans temp. gauge
- Where did you buy your Trans kit ?
- Synthetics in 5-speed
- Ultimate Equations Page!!!
- Noisy 5 spd. Tranny
- Torque Converter
- 4R100 ?
- Crankshaft bolt size
- 1st Trans. fluid and filter change at 30k
- 1st-2nd clunking: Normal, Clutch or Syncros??
- yellow sticker on trans with tsb# 00-16?????
- E4OD trans to C6
- Stuck in park...
- Gear Ratios
- Transmission is Crap
- Vibration in drivetrain
- Speed sensor wire
- Tranny gone at 44,000 miles!! Engine seized at 36,000 What the hell is going on?
- B&M Shift Plus
- what tranny in xpedition?
- 4R70W tranny upgrade
- 5 speed shift issue-please help
- Erratic Shifting
- GEARS
- 94 Explorer Limited Trans.
- Bauman shift kit question
- Horsepower loss for 5-spd and auto
- Factory_Tech... I got a question.
- slave cylinder
- my first 5-sp failure
- tranny gasket
- Lost my tranny!
- Did you get the right auxiliary transmission cooler?
- Anyone replaced the shift knob?
- Front Drive Shaft Broke in 2.
- Uh oh.......
- Is it a transmission cooler? Larger size?
- Noise by flywheel
- Shortening throw on shifter
- Mercon vs. Mercon V
- Truck moves on it's own.
- Shifter or knob rotating?
- found out why my o/d light was flashing
- O/D Light won't stop flashing!!!!
- Tranny Shop You Can Trust, DFW Area?
- Bad Behavior When Downshifting Under Heavy Load
- 2001 Screw transmission cooler question?
- Transmission vibration
- Swapout of open diff for limited slip
- how to tell which Trans I have
- Factory_Tech - How is ATF pumped to radiator/cooler?
- Help, Confused about the overdrive?
- 4X4 Problem?
- Delay going into D&OD
- 98 jerking into drive
- please help
- transmission clunking/chuncking
- O/D Light Freaking Me Out!
- High pitch grinding sound
- Question for GAH--AT temp guage
- Transmission Failure
- Transgo shift Kit 4r100
- What tranny in '99 4x4?
- manual trans question
- Torque Converter
- Crawl Ratios?
- Trans Shudder while Towing?? Help!
- Slipping Tranny!
- Grinding 5 Speed...
- Torque Converter
- Perma Cool trans cooler with fan? - Neal the HP Freak!!
- Attn: Factory Tech - Mercon V in 4R100
- 4R70W 4 WD trans.pan ?????
- Aftermarket clutch recommendations?
- 1997 F-150 5-speed problems!
- synthetic fluids ?????
- HELP
- e4od woes
- Should I drain the torque converter?
- Engine Braking --> Please Help Me!
- Tranny/Torque Converter Problem?
- wheels and tires
- Draining the torque converter
- Breather Manual 5 speed
- 5spd and Expedition center console possible!
- Faulty 2001 4r100 trannies?
- VSS gear location
- Trans temp
- Question for GAH or ? Tranny temp guage install
- THE H.P FREAK FINALLY BROKE SOMETHING!
- transmission cooler question
- Buzzing in Trans When Key Off
- swapping c-6 w/overdrive
- Trans. cooloer fittings?????
- F-150 TRANSMISSION TROUBLE
- Cooling fan on trans cooler anyone?
- 1991 F150 E4OD
- E4OD shift selenoids
- E4OD problems
- O/D Button
- Shift RPM?
- Baumann Kit Instructions
- Synthetic fluid from factory?
- B&M Shift Improver Kit
- '86 F-150 auto tran downshift
- Transmission lags from take off
