- transmissions
- short throw shifter for the 5 speed?
- 5 sp. Shifter Replacement
- Factory Tech Shift Kit ='s Chip Reburn???
- Mounting trans cooler??
- Auto-tranny problems - What is Job 1?
- HELP!! Truck stalls in Reverse
- AODE died- swap or rebuild
- Torque Converter related to chip?
- Will AOE40D run w/o ECM
- overdrive.
- Failuer code P09
- HELP!!! Need transmission advice.
- new truck transmission
- Shifting Firmness
- Late Shift
- Stuck in 4 wheel drive!
- Speedometer change with 30" tires
- Looking for TransGo Shift Kit Part #
- who gets 4R100 trans?
- Tranny ID question
- O.D. Trans. has shifting problem
- 1992 & 1993 F-Series Automatics ???
- New transmission
- What's Ford's official position regarding phasing-out manual transmissions?
- how do you know what trans you have
- Newbie.. Ford make 2 autos?
- Well I Finally Figured Out Why My Overdrive Was Working Only Sometimes!!!!!!
- zf transmission
- Hooking digital speedo to old tranny
- Which speedo gear?
- Can't Brake Stand!!!
- Auto Overdrive Clunk after FQR Change
- Better manual trans fluid?
- Auto Trans Linkage
- 98 E4OD 4 Sale
- AOD slipping?
- Auto Tranny Likes
- will a new speedo gear really help??
- Transgo, go, go
- transmission or Clutch?
- shift linkage adjustment
- all 5-speed users
- whats the ratio for all the gears in a 5 speed?
- hard stop thumping
- Stuck in Park! Again! How do I defeat interlock?
- Speedometer not working.
- Installed "Factory Tech" Valve Body.
- Which tranny do I have?
- ok
- 4X4 sticking and then fine.. WTH??
- No new tranny for me
- ok thanks
- B&M transpack for 4R70W?
- Transgo Kit
- Rear of Transmission Leaking??
- HP loss from flywheel to tires
- how much hp can the f-150 4.6l tran hold
- Precision Industries torque converter......
- metal shavings
- A bump as it goes into 2nd gear.
- 65K tranny shot!!!!!! What the heck!
- Where is the serpentine adjustment?
- Factory Tech, Anybody? Asking again
- i need a new clutch
- Fluid change
- Transgo! Shift Kit Install - 4R100
- Hydrolic clutch bleeding
- ATTN: GAH...questions
- Torque Convert Questions
- whining noise when iout of gear
- Getting Ready to Install Transgo Kit - 4R100
- ford460 fit a 351 tranny?
- strange noise
- Level 10 kit for durability? Neal?
- Attn. Factory_Tech
- Shift Kit's or other mod's and Towing
- strange 3-2 downshift?
- Anybody installed a Tremec T-5?
- 2000 5 spd is junk
- Changed out trans fluid
- Stalls when put in reverse, what could it be?
- Force Shifts on Automatic?
- Whats this sound?
- Hey Guys? Check this out!! Shudder fix?
- Stacked Plate Vs. Finned
- Figuring Stall Speed for What size Torque Convertor
- What Stall Speed Convertor
- 4.10 in an f-150
- Bad news @18,217 miles
- 4.10 Gears in Dallas???
- Overdrive lockout
- 2nd gear from a stop??
- Transmission service @18,000
- Tranny fluid flow direction?
- Easy to install shift kit?
- I found something really WEIRD!!!
- Tranny slipping after 34K??
- tranny question
- HelpFast! Transmission Slipping
- What do I need????
- Should I have it flushed???
- 4 x 4 Question
- Stutters going from 2nd - 3rd
- New Temp Reducing Tranny Pan
- draining the convertor
- Valve body replacement?
- better shifting 5-speed
- Tranny Slips in OverDrive
- OverDrive Button is going crazy on me?
- Question about switching to synthetic
- Need E4OD Help
- Help! My Trans Killed my Transfer Case
- Transmission Oil Filter
- Calling Factory_Tech
- B&M Tranny cooler GP!
- Jammed shifter?
- Baumann or Transgo??
- Speedometer correction
- changing tranny oil?
- Yet another Torque Converter ???? NEAL
- Front seal leak
- quicker shifts ? Factory_tech
- Trying something for my shudder.
- Bad Transmission
- Help, Factory_Tech, a question
- Transmission slips only occasionally
- B&M Transpack
- Finding out which trannie i have in my truck
- weird tranny
- 4r70 Vs 4r100
- Neal -- torque converter question
- tranny knock??
- tranny knock??
- Swap Tranny ????
- Tranny problem?
- Possilbe transmission problem?
- Installation of shift Kit how hard?
- Baumann kit: unimpressed
- Rear seal and bushing blew out
- Shift kit or Trans shift reprogramer
- so do you actually gain mileage back from regearing?
- Transmissions
- TQ Converter Stall Question
- Tranny Trouble. Please Help!
- Fluid Level.....overfill at factory?
- Do I need to change Trany oil ?
- Gear Ratio
- Level setting question for Baumann shift kit
- tranny prob blamed on re-gear
- Gear ratios for 5-speed?
- C6 ? What will it bolt up too?
- Help! Attn:squanto
- What's the differance?
- Why can't we install a drain plug in the Tranny pan like the oil?
- Need help on 4R100 trans and transfer case
- Changing from Auto to Standard
- A bump going into 2nd gear?
- Help 4R70W or 4R100
- Transmission fluid change out questions.
- Found a Fix for transmission shudder!
- Aftermarket Torque converter
- ?'s on checking tranny fluid.
- Transmission
- Transmission Help
- Letting off the gas at hwy speeds
- Shifter Knob
- B&M experience
- SIX trasmissions and TWO rear ends
- Wierd Noise
- clutch suggestions
- transmission help needed
- Transmission shudder?
- Which Tranny Fluid? Help!
- Overdrive Ratio
- '99 XLT EC Auto trans fyi
- Anyone damage their Trans with a kit????
- What kind is my transmission
- Baumann shift kit questions.
- Transmission Swap
- Slight Transmission Slip?
- Trans temp?
- Is my trany shot?
- Mobil 1 ATF in 5-speed, warranty, installation
- Transmission Fluid
- How much are the shift kits?
- aluminum drive shaft good or bad +/-
- Oh God It Broke
- Went with 5 (Baumann Shift kit)
- 1996 E4OD trans. makes hissing noise...
- Is it worth the extra $100 for Synthetic tranny fluid?
- Sluggish
- Gear choice (3.55, 3.73, 4.10, etc)
- Set of 4.56's
- Warning About Baumann Engineering Shift Kit And Intermediate Shaft Breakage.
- Palerider--message for you
- Transmission 4r70w
- Transmission Mount Installation Questions!
- Need a Sonnax Bypass valve?
- Shift Kit Help???
- 4.10 Installed...by myself.
- Fun at the dealer
- Question What type Tranny?
- Reverse out on 1993 F-150
- '94 - Intermittent Auto Trans Shifting
- When should your change stall speed on converter?
- Transmission Mount?
- tranny manufacturer?
- Fixed problems and new, 9K miles
- Auto vs. Manual Outlasting
- Clutch Problems at 19K
- My Tranny Is Out At 44000 Miles
- down shft too late
- Eratic Shifting Follow Up
- 1st gear auto-trans whine
- Is Limited Slip option worth it?
- B&M Truck Megashifter
- 5 Speed Grinding...
- Want to hear a joke?
- 93 Lightning won't shift 3rd.
- Installation of LED for TC lockup??
- New Clutch
- transfer case leaking
- Has anyone installed a centerforce clutch??
- Damage to transmission after big tires and no regear?
- Fluid leak, 2001 SuperCrew 4R70W
- F150 5-sp questions
- Tranny Finally fixed!
- tranny cooler?
- Attn: NEAL the H.P. Freak
- C6 bell housing
- 5-speed won't go into gear
- How many quarts in the trans
- Tranny noise in Park...
- Is the 5 speed crap?
- where to get tranny temp from?
- Weak clutch at 38,000???
- Rear End Thud!?
- Warranty Dilemma on LS Swapout
- Overdive Shifting Problem
- Problems with my '93 f150 auto tranny....surging...........
- trans temp. gauge
- Where did you buy your Trans kit ?
- Synthetics in 5-speed
- Ultimate Equations Page!!!
- Noisy 5 spd. Tranny
- Torque Converter
- 4R100 ?
- Crankshaft bolt size
- 1st Trans. fluid and filter change at 30k
