- Is this normal?
- Shift kits/enhancers for 97 auto.
- Converting to synthetics??
- Tranny Temp Guage Install ???'s
- Torque converter drain plug question.
- Major oil spill.
- Anyone seen this intermittent shifting problem?
- Transmission Filter Change?
- tranny shudder
- cv boot repair
- Tranny temps????
- Factory Tech, Your opinion please.....
- An expensive lesson
- Vibration in 4x4
- Transgo arrived
- follow up to overdrive light blinking
- Another Vibration Question
- Which Shift Kit?
- need help ID'ing this transmission asap
- Anyone with a Transgo kit in a 2002 F-150 ?
- Noise on shift during hard acceleration
- Help - Trango Check Balls
- '01 SuperCrew Question
- B&M Transmission Pan??
- fluid change
- Newbie q on ATF change
- 1st gear trouble at WOT
- Radiator fitting size?
- Explorer question
- Question for Factory tech and members
- DOH! Overfilled the tranny
- overdrive light blinking
- shudder during down & up shifts
- Freeplay in clutch pedal.
- Hard 2nd shift - hesitation
- PA valvebody is here!
- WOT trouble ????? HELP!
- 1997 v6 auto slipping
- a few comments please...
- Tranny Gauge installation question?
- What to do with this damned 5-speed???
- Clutch replacement
- Help Quick PLEASE!!!!
- 4R70W Self-Destructs in Passing Gear - 3rd & 4th Gone in a blink!
- trans cooler size??????
- Truck Shuts off change gears
- Shift Interlock Bypass.
- Thinking about a tranny cooler.
- 4R70W Service - Warranty Requirement?
- no downshift b/w 65-85kph
- Trans Temp Gauge Installed....
- driveline? vibration
- Petro to Synthetic Questions
- hard shift on the 2 -3
- ATTN: SCrew owners...PLEASE HELP
- is it possible to change a 5spd into a auto
- Which shift kit should I choose?
- Can someone help me with TSB info please?
- Shifts with Redline fluid
- Adjusting the Shifter lever Ford 1993
- clutch question
- Brown fluid = problem?
- Need Help...
- Transmission Temperature Guage
- auto tranny shudder
- Sonnax Valves in new transmission???
- Shift kit, valve body, line mods, etc, etc?? What does it all mean??
- Sound of a Manual
- 4R70W Service Schedule
- Which Transmission? (Newbie question)
- 4wd shifting ?????
- Towing with 3:31 rear end and 4.6L Tranny effect??
- Trans fluid additive...is it safe?
- c-6
- ???Does it make sense to install TransGo kit???
- Hello, new here and have fluid ?'s
- put in the new trans cooler....
- burnt clutch smell
- Is 15,000 mi. too soon to change???
- 5-speed, strange noise...
- Slipping Tranny-Help!!
- What Tranny?
- Trans-go kit part number
- Speedo calibration..need help
- Read this before Transgo shift kit install
- transmission cooler
- Need help, fast!!!
- Redline D4 vs Amsoil ATF?
- 5spd Question
- How much $ do you think
- Truck back at dearlership for the 10th time in 2 months.
- auto tranny / transgo question
- E4OD noise....
- sonnax valves?? WHERE TO GET?
- Delayed upshift after passing
- question....
- Housing crack
- Anyone replace rear seal on a 5spd.
- Wtf .093 ??
- Baumann installed O.D. not working
- Cooler Question
- Whats going one, Help!!!!
- 4R100 slipping??
- clutch????????????
- trans flushed and still have shudder
- How tight to tighten 5 Speed Drain/Fill plug??
- 4WD Pukes Fluid
- My trans says MERCRON not MERCRON V
- Should T/C be drained w/ every ATF change?
- Transmission shop
- Trans Additive???
- What warranty to get? (5-speed)
- trans 5-speed
- Is my tranny fried?
- Trans leak?
- Question for AjRagno (or wht does that mean)
- My Axle code on door is 19
- 4r70w electronics...
- Recall The 4r70w Part 2
- Tranny in Storage
- 4R70W TC shudder or Differential ?
- Need an advice: what's the best way to fix the leak???
- can someone tell me how to rev-match my manual
- Shift RPMin 4LO on 4X4?
- 98 Escort Auto Tranny
- Tow Package or Not?
- overdrive light flashes
- New Tranny Drain Plug
- AT-Coasting in Neutral???
- 4:10s! a good idea?
- Push-starting a manual question
- Found on road dead? Driver returns on foot?
- Torque Converter Drain and fill ?
- 5 speed manual tranny
- Slip?
- What oil to use in 4R70W tranny?
- adding fluid in 5 speed
- Recall the 4R70W!!!!!!!!!!!!!!1
- flashing overdrive light
- weak 4th gear shift in a 5 speed?
- No Six Speed Available?
- Open Your Eyes To The Five Speed!
- tranny prob.
- Cruise Control
- Hey 5-speeders, fluid change questions...
- E4OD converter, where to buy
- ?Trans Problem?
- Trans Mods
- Best Location for a drain plug?
- Which Tranny?
- Mercon V vs. Universal Fluid's???
- Strong thump from transmission when upshifting anyone?
- Changing trans fluid for dummies
- E40d
- Factory_tech Valve Body work in 4R70W
- Will a 4R70W bolt up to where my manual used to be?
- Just bought truck...Advice on tranny.
- 5 speed Q's
- Is Amsoil the only full synthetic ATF that meets Mercon V requirements?
- Which Transmissions will fit on a Ford F 150?
- ? for you ford driveline specialists...
- Won't come out of park!
- Rear axle code?
- What about this method of changing fluid?
- Recall the 4R70W ?
- Transmission Shudder
- For anyone who's removed the "Extension Housing"
- trans or converter shudder
- No Downshifting While driving uphill
- SuperCrew Trans Fluid Change
- 5 speed towers need help
- clicking noise? chatter
- 1993 E4OD shudder (again)
- Expy 4R100 & Factory Tech
- 5.4L and tranny.
- Mercon or MerconV for 95' W/4R70W
- 4R100 fluid fill
- Factory Tech! 4r100 kit
- Very confused-Please help
- shift kit?
- I need help finding out what gears I have
- Trans Fluid
- Rebuild or replace tranny in '85 XLT? (4WD)
- tranny
- Trans Question for Factory_Tech
- why won't it downshift
- Transmission Failing?
- 4R70W Valve body upgrade
- 4R70W, 4R100, E40D trans. & fluids
- 5 speed Tranny for a 92 f150
- Converter lock-up question??? (that funny half downshift thing)
- B&M Shift Kit?
- Trans suddenly slipping
- 4r70w rebuild@140,000
- transmission
- Trans. Flush on 5.4 Expedition
- Transmission Fluid Change in Taurus
- What gear is this
- $119 for 60,000 mile service good?
- Level 10 Performance Trannys...anyone heard of them?
- Level 10 Shift Kit???
- '01 F150 4sp Auto Trans Problem
- Lightning E4OD question...
- 2000 F150 Yoke Broke in Half
- Transmission Fluid leak
- Factory_Tech ? Expy 4r100
- 96 F150 rear end replacement
- Where to get speedo gear?
- Screw tranny bites the dust
- H.d00 Trans Upgrade
- Techs., need help determining which tranny I have.
- TransGo/Sonnax/Cooler/Temp Gauge/Drain Plug
- Quick curiosity type question for any of you 4R70W experts>>
- 97+ Hurst shifter update (good news!)
- '02 SCrew OK for towing campers?
- overdrive
- Transmission Won't Go In Reverse Without Grinding!
- four wheel low clunking noise
- Tranny Slip when Speed odometer jumps
- Strange sound
- Shift kit for a 4r100 or e40d tranny
- Cooler standard equipment?
- Auto Tranny Maint. & Upgrade
- 4spd or 5spd manual???
- Manual Transmission Shifter Knob
- What transmissions fit?
- What Gears?? 3.73 or 4.10?
- Tramsmission
- gear lube in tranny
- Mobil 1 ATF & 4R70
- 2002 4r70 ?
- F-150 auto trans downshifts like a manual!
- C-6 fluid type and leaks
- 4r70w bites the dust.
- Quick question
- Can a tork converter make a clicking noise?
- question for tranny techs
- M5OD, syncros, again! techs?
- Old Transmission
- 4r70w made to tote kids and pick up groceries?
- Transfer Case
- Early model 97, AODE or a 4R70W
- Temperture bypass valve?
- F150 ESOF stuck in 4L
- ID my tranny: e4OD or 4R100
- transfer
- Help with tranny shifting clunks!
- Question for Factory_Tech & others
- Downshifting-making em scream!
- Transmission Service Question
