- 4R70W Fluid Change
- Tranny fluid level HELP
- E40d Will Not Go From 2nd To 3rd??
- After much searching, I think I've found the 4r70w transmission for my truck.
- AOD Shifting Problems
- popping at low speeds
- help. transmission/transfer case dead?
- For those with FTVB
- OD light blinking, please help
- trns leak
- trns leak
- Question for Neal
- What can My OEM tranny take tq wise?
- Transmission question for Neal
- Strange 1-2 shift...
- Transmission manufacturing date
- new noises from 5 speed tranny
- Expedition: Manual transmission
- Trailer effect w/o trailer
- slippage!!!!!
- Transmission Temp Gauge Wiring
- E4AOD problem
- Manual Transmission Swap
- Flex Plate or Converter for Lightning swap
- 5-Speed Shifter Question
- A question for Mark Kovalsky, Factory tech or anyone who can help
- 4r100 modify
- Aftermarket Trans. Pan
- Mark VIII torque converter in a F150?
- Factory Tech VB HELP! PLEASE!
- Repair Bill....
- Ideas about trans problems? E4OD
- just got new 4.10s.... plus a ticket :(
- Update on 2000+ 3rd-2nd downshift Clunk
- 5 Spd Manual - Warpage?
- manual transmission F150 1990 shifting problems.
- 5Spd better shifting after lube change
- E4OD To AOD Tranny change
- Aamco MerconV Syn blend
- How many quarts of ATF?
- Hurst Shifter
- Tranny problems, please help!!
- 98' E4OD Exped. Towing Durability?
- tranny swap
- E4OD harsh engagements & shifts
- first impressions FT valvebody
- Tranny fluid warm up (gauge question)
- Clutch problems
- Trans. drain plug and gauge install
- Hard shift from 2nd to 3rd
- Won't upshift while towing
- Speedo Gear chip
- ATF level
- tranny flush?
- Bearing pieces in tranny pan!
- synthetic replacement for mercon v
- Change tranny fluid at home???
- How do I indentify the tranny I have????
- Clutch Question
- tranny oil
- good 6 speed trany ????
- Squeek/Clicking while Accelerating
- F150 1998 transmission + Flywheel trouble
- Autometer Gauge Pods
- I was told by two transmission shops NOT to change my transmission fluid. What Gives?
- aod to c6 swap info
- manual transmission swap
- grinding
- Opinions on Tranny Temps
- How do you adjust transmission linkage
- Diference Between 4r70w And Aode
- 46,000 miles
- 5 Speed Upgrade
- Shuddering / Bucking problem
- Is expy factory tow pkg adequate?
- Has anyone tried to put a Ratchet shifter in their truck?
- Gear indicator slipage
- Who's right? (E40D question)
- 4R70W question
- 4R70W Tranny Question
- tranny slips in and out of gear
- Is is possible to disable automatic 4-wheel drive???
- Need to Know Ratio of 1st. gear in 4R70W
- Transmission durability
- Trans-Go Shift Kit - with or without video tape
- Truck rolls in Park, truck rolls backward in Drive
- 6spd manual/clutch
- WTF is going on
- Tranny slipping?
- Shift Improver woes
- OD...on??...off??
- Tranny change tip
- tightening the driveshaft... more torque??
- F150 Auto Trans Problem
- What tranny is in my 99 expy and what shift kit do i buy?
- Checking fluid level
- Transmission Torque spec HELP Please
- To change or not to change...
- Changed tires size...? about the # of teeth in spedo gear
- F150 Transmission Troubles
- 2002 Transoil change ?
- Sea Foam
- c6 tail shaft
- 2003 F250 V8 6.0l tranny problem
- Transmission model type
- Lightning Monster Box
- 2001 shifting issue
- clunking rear end? solved
- when to service transfer case.
- nO OVERDRIVE
- Trans service
- Factory Tech VB
- Will Bigger Tires = Transmission Issues
- ATF change w/unsure sevice record?
- Help with vibration diagnosis
- Please help ASAP! A4LD trans not going into gear! Must fix SOON!
- Man 5 spd shift feel Update #1
- Think my E40D just blew a seal. Help
- No passing gear?
- What are the manual tranny sensors?
- Faster truck!!!
- Jumping Transmission
- Trans-Go Shift Kits
- Mounting a trans temp gauge
- 15,000 mile transmission service/dealer gouging
- Wont go into any gear.....
- Shift Kits???
- F-150 Will not go into 4h and 4L?
- Trans Range Selector
- aftermarket tranny pans?
- Flashing OD Light
- Slight hesitation when under 2k rpm
- Transmission whine?
- Is my torque converter going bad?
- Upgrade from 4R70W to 4R100
- code ?
- 94 F150 AODE Trans Problem?
- I Keep Blowing My Tranny?? What's Up!!
- how to change my transmission fluid?
- HELP!!! my lightning is making noise in third
- Shift Solenoid B
- Grinding 3rd gear
- 5-speed took more than 3.75 quarts?
- Whining Tranny
- Jumps out of 4x4
- Tranny vacuum??
- 2001 F150, no 4X4L
- Factory Tech 4W70R VB Kit
- E4OD transmission question
- adding a tranny cooler.
- Auto tranmission adjusting for towing
- B&M Trick Shift and Red Line Fluids
- Shudders only when turning from a stop
- jumping tranny
- torque converter refill
- how do i tell if i have limited slip?
- Torque Converter
- Yet another quick question...
- Motorcraft Mercon V
- Differential oil change, What kind?
- Need help.
- Transmission Pans
- Slip Yoke location?
- How to install a drain plug in 4R70W pan
- What is this?
- Quick Question
- E4OD "shuttering"
- tranny compare
- Transmission HELP
- overdrive off at all times
- Manuel shift to 1st from neutral
- Somebody help me please
- removing valve body
- Check you A/T Fluid Levels!
- Shifters?
- No O/D
- transmission,transcase,shafts4 sale
- max mitchell
- help-ford in trouble
- Atf+4 Fluid
- HELP - FactoryTech
- How many miles on your clutch?
- GM Tranny question
- E4OD Not shifting into gear!
- "lazy" shifts
- tranny problems
- noticable hesitation on 2 - 3 shift
- Need a 4r100 transmission
- How much hp can the tranny handle
- Factory Tech and 2001 Expedition??
- Attn factory tech E40D 5.4
- How much power can the transfer case handle?
- Speedo Recallibrator
- Bad transmission???
- gear installation kits... which one?
- replacing 5spd w/ auto
- How much HP is too much???
- How much is too much?
- Transmittion cooler
- ******* My Clutch
- Code 628 excessive converter slipage
- FYI on fluid and filter changes
- Solenoid change Help
- FT valvebody being installed right now...
- schaeffer oils
- Fluid flush/change..How much??
- 2002 F150 Supercrew FX4 -> 4L
- transmission selenoid
- Houston, Tx Peeps inside...
- firmer shift problem
- rebuilt tranny
- Which Tranny
- 93 lightning spiting out trans fluid
- Hurst Short Throw!!!
- Wiring for Derale Active Tranny Cooler?
- Service intervals
- What Tranny?
- New Trans Pan
- attention--"FordMasterTech"
- How To/Is It Possible To Flush Cooler & Lines
- Transmission Fluid Change
- cooler installed
- Factory Tranny Cooler
- Shift Kit
- Tranny Problems
- 95 F 150 6 Cyl Clutch & Flywheel Question
- shifter assembly
- Pros and Cons of a Transgo Shift Kit
- Sluggish transmission?
- Harsh shifting at part throttle?
- Gearing, did not know where to put this one
- Shudders on Downshift
- Torque Converter
- doesn't always downshift at WOT
- Clunk when braking only in Overdrive
- Problem with my transmission
- I am about put a slug in my 5 speed...
- Tranny Cooler
- Can't get it out of Park
- Electric Shift Motor 4X4
- '97 4.2L gettin' 3rd Tranny
- Ranger trans ???
- Diagnose My 4R100
- Truck sat for a year. Tranny growls when put in reverse. Q's
- OD light blinking
- Is my 4R70W up to the task ?
- Lock up in reverse
