- 5.4 Screw transmission shifting OD Problem??
- Transmission Durability??
- 1996 150 "jerking"
- HELP! Made a mistake somewhere!
- How many have replaced with Cobra 6-speed
- 5 speed manual shifter changeout
- Shifts From 1st To 3rd??? Help!!!
- od light on, but no error codes??
- ftvb
- Drain or Flush
- Transmission Swap
- Just received a Hurst short throw prototype shifter...
- 4r70 or 4r100? & metal found in pan
- Speedometer stopped working, code 500
- tranny temp gauge
- 88 F150 swap to manual transmission, any guides?
- Tranny services in Sac-town ??...
- Auto Tran
- Trans Range Sensor OBD Codes PO705 and PO708
- 01 Tranny whistle through dash, changes with engine speed
- upgrading stock cooler(just cooler)
- Auto transmission service
- E4OD leak
- 2000 trany to 97
- I hate my E4OD
- Odometer out and ODL flashing.
- Difference Between 4R100's in Expy and Lightning
- warranty question
- 2wd to 4wd swap
- Extension Housing
- Where is the EPC solenoid?
- Question about Mark Kovalsky's procedure
- I Need Auto. Trany.
- Tranny question
- Transmission Fluid Change
- E4OD question
- slite delay when taking off from light
- Transmission problem
- How much for lower gears
- Differences in a 1997 4.6 tranny and a 2000 5.4 tranny?
- tranny problems... again
- Quick 5-speed question...here are the symptoms
- truck started slipping
- 2000 navi torqe converter
- Front end not engaging in 4 wheel drive
- slow going into gear
- delete
- transmission fluid leak
- broken truck, pls help
- TransAction Kit Installed-wont shift in OD
- e4od problem
- Anyone diagnose this?
- Drain converter
- Make sure you get the filter changed @service.
- zf 5spd interchangability
- cottman says bad reverse clutches???
- 2000 4x4 tranny slipping at 45k??
- mazda m5od can kiss my tail pipe
- Transmission or Hydraulic Clutch bad?
- 5-speed
- down shifting problem
- Won't go into overdrive when warm?? WTF??
- transmission o/d light flashing
- Overdrive Transmission Light Flashing
- 5 Speed Trouble
- clanking noise from front end
- what Gear Am I In?
- 96 5.0 Hard Shifts
- 5 speed issue
- Hard Shift 1-2 and 2-3
- 2001 Supercrew idle issue, 5.4L
- Which Transmission Is The Strongest?
- Ahh... the smell of burning
- what transmission
- opinion poll
- 2nd opinions help...
- Fluid change
- Strange sound
- Do I have a problem
- Tranny "thunk" at 30-35 mph.
- tranny shifts hard into 2nd (is it sensors????)
- Shift Kit on V6 for fun?
- transfer case noise
- '01 Transmission problem? Please help
- '01 transmission problem? please help!!
- what transmission?
- Problems with Shifter
- cooler lines
- Another Tranny Prob (OD won't disengage)
- P0743 '96 Cougar
- slipping clutch?
- 2000 4r70w in a 1997?
- new Hurst shifter
- Code 0755
- Clicking????!!!!?????
- 97 E40D just rebuilt. info
- Tranny Question
- New F-150 code "B" Transmission??
- '86 F150 Transfer case problem
- Gear shift lever jumps a position
- Clutch Pedal Bushing Issue
- B&M Shift kit ? Electric/In Tranny/Both???
- Need Help! Clutch Lever alignment Issue...
- NewB 4r70w strange issue
- Torque Converter Interchange
- Hurst short-throw???
- effects of not changing fluid?
- The Holy Grail: Trans clunk fix.
- Tranny problems
- Any answers to the E4OD hard shift problem?
- Trans slips in overdrive
- seeking replacement for 93 m5od tran
- Factory Tech Valve Body Install
- Transmission shifting funny
- Autometer tranny temp gauge temps
- Overdrive on or off?
- Linkage help!!!
- 2001 F-150 shifting problem solved
- Dealer recommends tranny flush.
- Shifter lever loose - O/D light flickers
- tranny's for a '95' f150
- Transmission Hunting
- 1988 f-150 tranny feels like it is in first.
- serious problem...need help
- hard shiftin' transmission........
- 99 Expy 5.4 EB 4x2 Shifting Strangely
- 2001 f-150 trans problem
- Tranny hard downshift code p1783 help please..
- need more low end
- 94 E40D SERIOUS shake!
- Transmission 500 miles after warranty!
- OD light flashing
- 1996 F150 2WD 5.0 L 4R70W tranny
- Aftermarket Transmission Cooler
- Driving question, auto transmission
- Trans Code
- what might be the cause of this
- Gear Selection for rear end 02' 2wd SCREW
- looking for a good but cheap computer upgrade kit?
- clutch to master cylender rod
- Aftermarket tranny pans
- What transmission do I have? (99' F-150 4x4)
- TC not locking up
- Transmission and Driveline Shop
- 4r70w behind (lighning) supercharged 5.4l
- tranny cooler line pressure
- few questions concerning performance valve bodies and the like (E40D)
- 4x4 won't disengage
- Tranny Dipstick tube to short?
- ooops! Wrong Tranny fluid?
- 1986 transmission problems
- Manual 1998 F150 4x4 not engaging
- Are the older manual transmissions reliable??
- 5.4 to NP 435??
- '99 4R70W line flush gotcha
- Shifter has come loose
- M5od no 1st or 2nd
- Shift kit
- 4 speed to C-6 conversion question
- Changing tranny fluid
- Another Stupid Question
- transfer case fluid Q
- just got ftvb
- Possible Transmission problem
- Transfer case oil change
- speed correction
- 1996 Ford explorer trans
- third gear is gone 2000 f-150 4r70w 49k miles
- Rebuilt 4R70W...won't go into any gear!
- 97 f150 4.6 4x4...which trans?
- Some trans issues at 60k
- Swapping Transmissions??
- no no speedometer /transmissions not shiftng properly
- trans code B?
- Changing rear end gears help??
- ? operating auto-trans w/4x4
- Can filter placement cause trans failure?
- Bellhousing differences?
- Transmission fluid change
- freeplay in clutch changes
- Wrong Transmission fluid?????
- Overheating in overdrive?
- 2004 5sp - Stiff Shifting
- torque converter question
- Ttorque converter clutch shudder or vibration...
- built-up 4r70w??
- Best 4R70W price?
- tranny cooler
- 1998 Ford Expedition 5.4L EB
- F150 Manual Transmission problems
- Where is the fluid for my manual trans going?
- Trany Slips, In Hot Weather?
- TC shutter? or engine miss
- Shift Solenoid
- Need to make quicker
- Where can I find an Ext. housing bushing
- Trans Maintenance & Towing Tuestions
- TC shudder or not?
- 1998 automatic jerking
- 2004 4R75W T/C drain plug
- Reset procedure after new overdrive switch?
- Oooops, forget to mention
- 1985 F-150 question about transmission
- 2003 4r70w Fluid Change Help
- Clutch Bleeding
- Possibly A Serious Transmission Problem
- Overdrive stopped working!
- F150 Manual 5 speed trany question
- transfer case cover leaking at the top
- Transmission problem in Supercrew
- Anyone else have a tranny rattle?
- Clutch Pedal to Master Cylinder Bushing
- Temp Sensor flashing O/D Light P1710-1712
- gears
- Anyone tow with a Factory Tech Valvebody?
- 4r70w weak d1 and locked up L1
- FTVB how do you like it?
- tranny leak!!
- Play in my clutch pedal...
- Its Amazing
- Deep Aluminum pan - What about magnet?
- Transmission seems to slip
- ISO.. shift kit for a 4r100 or E40D (97 F150)
- tranny dumped fluid big time
- E4OD question
- Stock 2003 4.2L ATF?
- Transmission Shudder???
- Switch on clutch petal
- Need 4R70W Flywheel Replacement Help
- Can I swap a Lightning 4R100 into my 5.4 Expy?
- ftvb valve body or shift kit
- Transmission Shifting
- Automatics SUCK!
- NEED HELP FAST. Tranny not engaging in ANY gear.
- 3.55 LS to 4:10 ? - what is needed
- Transmission swaps
- Fix For Overdrive button
- who makes the best shift kit 4r70w?
- Throttle Position Sensor
- How to install active cooler?
- Oil change interval on 4R70W
- Front end locks up in 4wd
- How can a blocked trans cooler line cause the TCC to lockup??
- 3.08 Gears To 3.55 Gears
- Transmission heat shield & inspection plate
- Manual Hard To Get in First
- 97F150-5.4 Transmission Shift Points
- 1989 automatic
- trouble engaging 1st gear smoothly
