- 4R100 fliud change
- frustrated and nearly broke
- 2004 Trans fluid change?
- Please help.....i'm beggin ya
- transmission slips when staring out
- It's been a while and I forgot my fluid/additive info
- 2009 Transmission Question possible problem?
- 4r70W factory tech separator plate.
- 1997 4R70W transmission shudder
- 2004 heritage whinning tranny
- Need help!!! 4r70w swap not moving???
- Transmission Shifting Locked up! HELP!!
- What is this plastic "plunger" thing in my trans pan?
- tranny people help me out plz
- New issue on deceleration
- Remote trans filter - Yes or No to stock filter
- 4r100 Question
- Picked up a new-used cooler today but...?
- Tranny help
- Mag-Hytec WEB site stolen by impersonator
- Guys that have done a Lightning swap please look.
- seafoam as tranny flush?
- What trans. do I have?
- Transmission Shifting problem
- Trannys slipping
- I need Suggestions please...
- Fx4 2003 strange sound when taking off
- loud Squeaking when Clutching down
- Tranny Trouble
- Stuck in gear
- 4x4 dash light not working
- bad tranny
- Transmission Trouble
- 2nd Gear Slippage
- Convert E4OD from 4x2 to 4x4
- shifts hard into 2nd gear
- City driving trans temp
- Difference between 97-98 and 99-03 M5R2?
- 2007 harley davidson f150 tranny shot?
- To flush or not to flush?
- Transmission Fluid Dump
- 4R70W Transmission: Can the Filter fall off?
- Return line on stock cooler?
- 95 F150 4.9 auto - bad leak!
- 98 F150 4.2/4r70w tranny slip **HELP**
- 97 4x4 with 4.6 and 4r70w repost
- 1997 f150 4x4 4.6 4r70w
- AT to MT swap
- changing over a 2wd 4r70w to a 4x4
- When Changing The Transmission FLUID.....
- 1997 f150 4x4 4.6 with 4r70w tcc code
- tranny mount bolt size plz
- 2005 f150 4.6 shifting strangly
- torque converter info plz
- My Truck dies when i put her in gear
- Park indicator
- TRANS FAULT o/d light blinking
- 08 Transmission Problem - Hunting or Searching
- DriveShaft For a 12 inch lift
- any tips on removing a trans
- Vibration felt when converter unlocked
- Toque Converter Lockup Indicator (and Switch)
- 4r70w swap help plz
- Flush Transmission at 30K for $189?
- 05 f150 shifter button
- Do I have a transmission problem?
- Shift kit in 93 F150
- 4r70w swap questions.
- Burning the clutch
- Can the pan be hotter then the fluid?
- 4r70w shift soleniods
- Hurst 5 speed shifter
- 97 f150 auto trans shifter lever sliding problems
- trans trouble
- Heavy-Duty (7-lug) F-150s have larger transmission cooler?
- 5spd problems shifting?? HELPPPP
- should i change my fluid?
- J-Mod on truck?
- 04 F150 What tranny will fit
- Mileage due for tranny fluid change/flush
- '08 Fluid in Torque converter question
- Supercharged 5.4L 4x4 What shift kit?
- is there a way and would it be worth it...
- My tranny keeps kicking out of 5th
- Vacuum plunger to engage 4X4 97 F150
- New Noise 97 F150 4X4 w/auto trans
- Adding a fan to stock trans cooler??
- ? On the side of the Road - Trans Failure?
- I suppose there is a reason for no tranny drain plug
- 1999 F150 Auto
- How can i tell
- transmission swap
- Transmission getting to hot
- not sure what tranny
- Shift Selector suddenly hard to move
- Adding B&M supercooler
- Does anyone have a tranny temp gauge installed in the pan?
- need pic of starter*for 5.4L-4R100 tranny removal
- How can I tell if my torque converter is locked or unlocked?
- resistor?
- tranny service
- Transfer case grinding - HELP!
- Buzzing/rattling from transmission
- Over-Drive Light Is Flashing
- transmission swap.. doesnt engage till 2000 rpm HELP
- stuck in 2nd
- What transmission do I have?
- 97 Manual 3-4 Shift Forks Gone?
- Transmission removal on a 2000 5.4 4x4
- 07 4.6 Tranny Swap!!!
- What'd your last clutch cost?
- 87 f150 97 f150
- Mercon V
- WOT shift sound
- 37" tires with 4.56 gears
- Less Parasitic Loss
- Lubegard Platinum
- 85 f150 1990 aod
- torque converter
- 1978 automatic safety switch
- YES we have no overdrive!
- Well everyone, i smoked my tranny
- Adding an Aux cooler [Write up]
- ???What's with these Ford transmissions???
- high pitches grinding sound at 2500 rpm
- Rear Ends
- my transmission
- IWB Solenoid TSB
- Gauge is in, where did you mount your temp-sensor manifold?
- Trans fail light and really sluggish
- torque convertor issue?
- Do I have a tranny cooler?
- Reverse Lights
- 4x4 issues
- 75mph in 4x4
- Cracked Extension Housing
- Troyer Auto Valve Body
- rattling noise at idle
- blown trans
- Taurus transmission problems question
- grind sensation at 2500 to 3000 rpms
- Tranny noise on an '07
- trans revs only in OD
- Burnt Clutch/Brake smell.
- Weird shift
- Ford dealer flushed with no filter change 99F150 4x4
- 1996 5.8 E4OD no 4th gear
- 1992 Ford F-150 Tansmission leak Help!!
- Transmission
- Ford F150 Tranny
- ? a tech could possibly answer
- Quick spike in RPMs
- how much fluid??
- Trans swap
- flushin tranny???
- Tranny/Transfer Case Whine
- Shifting issues
- tranny question
- Reverse Gone
- Transmission output shaft seal
- console shift upgrade?
- Misfire or TC Shudder?
- where to get reasonable perfomrance 4r70 parts?
- OMG !!! What's UP ???
- ---4r70 3rd gear "shuddering"?---
- Shifts into 2nd at 70 mph ????
- 4R75E factory pan capacity
- bent shift fork maybe? 88 F150 stuck in reverse
- Transmission Fluid Swap
- Normal Operating Temperature
- 2005 Tranny replacement question
- magnet
- 01 F150 Tranny service question
- Windstar tranny question
- Yellow plunger sitting loose in tranny pan ???
- ???help
- Painting transmission?
- HeLP!! 5.4l transmission out. What will interchange?
- another thread about swapping 4R100
- Need Advice on how to add second tranny cooler
- 4R70W and 205transfercase
- Revs up first then tranny engages with a bang?
- 4R70W Won't Upshift?
- Automatic transmission can't find 3rd gear
- My new truck is slipping
- GM 4L60E trans leak?
- 4r70 do i need hardened hard parts
- 4R70W Normal Operating Temp
- Awd f150
- Transfer case leak?? HELP?
- Stock trans cooler to PS cooler
- Ford F-150 Transmissions
- Tranny Swap
- Transmission won't shirt to high gear
- 1-2 RPM flare, help please
- Torque Specs
- how is my driveshaft yoke lubricated?
- SuperDuty T-case on F-150 manual trans
- Anyone put a c6 on a 5.4?
- 2002 SuperCrew Tranny is TOAST
- 97 f-150 trans help
- How to tell is trans service is performed
- Transmission Compatability?
- 4r70w tranny
- Supercharger/Transmission Advice
- changing transfercase fluid
- Thump and Jerk at 5 - 15 mph
- Who has done the Jmod?
- Code P0715
- trans cooler
- can a e40d fit in my 00 f150 4wd (4rw70)
- 97 5 speed manual
- 30750 miles and trans is slipping...BAD
- Somethings not right
- OD light flashing yay!
- Installing a transmission temp gauge.
- 4wd works fine, but the indicator light doesn't
- Wheres the Sticklys???
- Finding out what kind????
- Code P0715
- Wire in transfer case
- Reverse Only!
- Swap Computer for 2001 transmission
- Shifts into OD by itself
- 95 f150 trans changes gears back and forth and wont stay in gear unless I hit the gas
- HELP -Stalling @ stop lights
- Transmission or something else?
- Strange Noise
- 98 F150 replacement transmissions.
- I really want to swap in a standard tranny
- converting 4wd transmission to 2wd ?
- New Transmission Problem after Rebuild
- Torque converter
- Clutch and Hydraulics
- No reverse, Help!
- Driving a 4x4
- Yea for 4X4 going out again
- 4r75w O.D light blinks and problem with first gear.
- Slip Clutches
- 99 4r70w into a 98.
- Clutch/Transmission how-to
- help with tranny bolt
- 92/96 AODE in a 98
- Fresh rebuild on 4R70W
- Lookin for input!
- Speedometer Odometer & transmission
- 00 Crown vic tranny into 00 F150
- Does this sound like a synchro problem to you?
- Transfer Case Motor Replacement
- Won't start
