- 1990 trans. hard shift and ticking noise
- 01 exped flashing overdrive light
- Replaced torque converter, now truck won't stay running
- hurst shifter rattle!!
- Cooler line Pressures
- Pressure Testing
- what do you think?"
- 4r70w Problem
- E4OD fluid change
- Highway shifting (possible) problem
- Roushcharged 3V Owners, Hard Shifts?
- getting ready to pull a transmission
- Shifter Components
- Vibration
- Possesed Transmission
- best shift and valve body upgrade for 97 f-150
- 4R70W Issue Found - Just For Future Reference
- Auto to manual tranny change?
- 4r70w mercon/merconV what gives?
- Output Shaft Speed Sensor
- Troyer's Tranny Stuffs
- Towing question?
- Is this a 1-2 accumulator problem??
- Trans cooler fittings
- Dipstick Hose?
- 96 F-250 5.8 tranny getting hot???
- BG transmission flush service fluid question
- Supercrew Tranny Slip
- Clutch
- Ford E4OD Transmission
- 5 speed manual /whine / synthetic fluid
- transmission trouble, Help!
- Yay! (Almost) Free Gear Ratio Upgrade!
- Yet Another 4R70W Fluid Change Question
- Trouble with 1st gear
- valvoline max life.
- Transmission Leak
- need a tranny
- Confused on transmission type codes
- 4.6 manual trans problem
- Something wrong with the trans. shifter!!!
- Missing Tooth on 4th Gear - HELP!
- O/D Jerks at 1.5 rpm
- Which transmission in 4x4 5.4 2002 150
- atf... what kind?
- Trans control module/ dash guage fuse
- Question from a guy who knows nothing about tranny's
- Gotta a question?????
- Transmission Or Rear End Problem?
- SuperCrew won't "coast", any ideas?
- 1993 E4OD tranny clunk and shudder....fluid change?
- dropped the pan and found a part in the pan ???
- Newbie Question
- Automatic Transmission drive or reverse engagment problem
- OD light flashing, did a search on this forum
- No Third GEAR!!!
- Mercon III instead of Mercon IV?
- 4R70W question
- transmission question
- Towing w/new F150
- VR70W NEED A MECHANIC"S HELP PLEASE
- Tranny Question
- Clutch Slave Cylinder Leak in '02 F150
- I need serious help!!
- Increased performance and milage from new torque converter...
- convert to 4wd
- New Accumulator Springs and Piston; same problem
- NEED HELP. fixin to replace ATF fluid. Got some Questions
- Need Help w/Trans Codes
- No 5-spd with 4.6
- Manual Transmission Leaks After Fluid Change
- Reading Dipstick
- Hard 1-2 Upshift, O/D off Light Flashing
- Transmission names
- 4x4 switch
- Trans howls when hot outside
- 1992 F150 2wd Auto trans reverse not working
- What Transmission do I have?
- replacing stock VSS gear, what color would it be?
- Will this hurt my transmission?
- Smooth or Hard
- Dead Escape tranny w/low miles - repair suggestions?
- 2003 5.4 trans ID
- e4od – can’t disable overdrive
- converter slippage in D1
- random rev in rpms
- Transmission shudder questions
- slippage after installing cooler
- What speedo gear do i need for 35's?
- Tranny Plug Usage
- how to tell if U joints are bad ??
- Transmission Diagrams
- Question about RPM's
- Upgrading the clutch
- Flushing The Transmission
- 4r70W spring color codes
- Chattering/Clanking Sound
- New 1-2 Accumulator Spring, Now won't shift out of 1
- Do I have a problem?
- Stuck In First Gear.
- Not wanting to start
- Newbie Question About 4WD
- Transmission Life
- Transmission Oil Plug Drain Installation Location
- Upgrades for 4r70W?
- Truck shuddering after new clutch install
- Clutch Master Cylinder
- Rebuilding Engine, Need new Clutch kit, Recomend?
- Worried about my 4R70W
- Anyone Know Anything About E4OD Shifter Linkage?
- What transmission type in my 1999 f-150 4.2 5 speed?
- Automatic Barks 2nd!!!
- Torque Converter Lockup Signal
- Another Slip Yoke Thread
- e40d
- 4R70W vs 4R100
- Transmission Fluid/Filter Change
- Yet another question for dirtyd0g
- 2006 Lincoln Mark LT, Transmission Kicks a bit, and Question about Brakes too
- Limited Slip?
- 2 much trans. oil
- Anyone installed the Hurst on the M5OD?
- Noisy clutch fan!?!?!
- Part found in Trans. Pan
- Torque Converter
- transmission "jerk" at slow speeds
- 1995 F150 4x4 manual transmission--can't get it out of 2nd gear
- Changed Out MPLS - Now It Won't Turn Over
- Oil change in manual transmission
- Gears!!
- Urgent help needed!
- Expedition tranny slip
- 1993 A4OD Acting strange
- Hard shift into 3rd - only first few times
- Is this the right seal?
- 1997 4r70w
- accumulator spring 2-1 downshift question
- Swapping a 4R70 for a 4R100
- Is my tranny causing this
- Question: AOD flexplate on e4od (e40d) tranny.
- low-reverse slippage, cold
- The ultimate final solution?
- Looking To Freshin Up The 4R70W A Little
- M5R2 no reverse
- Torque Converter Lockup & Trans Cooler
- OD Broken or Light Not Working?
- Blinking Overdrive Light
- Help with fluid/filter change
- 94 f-150 4X4 question?
- Transmission Repaired
- A Hitch in my gitalong ???
- Transmission Noise
- F-150 Tranny slipping since day one
- Got a tranny ?
- Transmission fluid change question
- E4OD blinking OD light and reading code P0712
- Transmission Problem?
- Is this the tranny going?
- Tranny Problem
- 4.6 manual scraping/whine sound
- aftermarket tranny temp gauge
- Trans codes
- Trans code PO714, HOW BAD IS IT? HELP!!!
- Cooler installation
- shifter problems
- speedometer correction question
- Upgrading Gears?!?!
- transmission code B
- '93 F150 Crippled!!!!!!
- TC drain, for the women DIY’ers
- Can we swap in T5's in place of our manual trannys?
- Tranny is in gear when shifter is in neutral!!!
- Need Urgent Help from Tranny Experts
- The Right Stuff
- Help! 2nd tranny problem, '04 F150 2WD 4.6L; something beyond valvebody??
- My truck has a problem
- Tranny Swap
- what tranny
- Tranny temp while towing
- Converter plug???
- Factory Tech B Plate install Question..
- Manual Trans whines
- 4:88's
- Transgo Shift Kit Problem
- HELP!!! Just finished the FT Separator Plate install...
- plastic gear shift handle broke
- What temp does the sensor come on at?
- TODAY is the DAY...Separator Plate install
- Auto Tranny in 97 5.4 ext cab
- Sticky Shifter
- changing the clutch.. is it hard?
- M5OD to ZF tranny
- '01 5.4 SuperCrew Stuck in Park
- Transmission Problem, HELP
- Help!
- Delayed shift 1st/2nd automatic 1999
- Help! Popping in rear end after idiot loaded truck with forklift!
- Lucas Tranny Additive
- can someone help me with my truck
- found a tranny but will it work
- Transmission downshifting
- Trans swap
- m50d or ZF
- "clunk" sound under hood
- What Stall???
- Shifter is hard to move
- Intermittent Trans Slipping...
- Another 96 f150 hard shifts/blinking od light
- Do I need a deeper pan?
- wanted to get a few things straight on trannies
- 4R100 Rebuilt again
- Tranny oil change on 2004 F150 4.6L
- Did the Slip Yoke Search
- Replace the 5-Speed with a F250 6-Speed
- Finally in the shop
- Factory Tech Valve Body Install.
- Shift lever loose; O/D doesn't work
- Modified Hurst Short Throw!
- speedo not working, fixed but need part help
- 97 F150 4.6 OD light flashes above 70 mph
- 4R70W shift question
- Confussed
- 4R70W 4X4 Can the transfer case bolt up to a 4x2 tranny?
- Tranny trouble resolved: OD fail, '04 F150XLT (4.6L, auto)
- Hurst Short-throw comes loose constantly...
- Another Shudder problem
- Which way to go, any advice please?
- E40D fluid change
- 5 Speed Hard Shifting, Now No Shift
- 01 screw trans problem
- Overdrive doesn't turn off ??
- odometer not working
- clutch loosing pressure
- does it sound like a trans problem
- 4r70w Monster Box
- clutch slipping?
- Delay in tranny downshifts from 3rd to 2nd or OD to 3rd...
- 4WD sticks a bit - what to do?
- to have flushed, or to do yourself
- Flushing Auto Trans
- 97 F150 Tranny Trouble
- Help with tranny swap
- 2004 F150 Screw sliiping in 1st
- Rebuilt 4r70 - too much engine braking
- e40d tranny gone bad?
- Truck got towed to dealership yesterday - in case you didnt know info
- New trans or rebuild in Dallas/Ft Worth area??
- 4R70W Lost 3rd while towing
- Manual Trans Issues
- Trans leak
