View Full Version : V8 Engines
  1. cylinder head installation help
  2. Timesert kit
  3. Dealer replacing both CATS under Emissions Warranty
  4. Swap 97 F150 4.6 with 99 F250 5.4
  5. COP coil from ebay
  6. 2009 2010 5.4L Sparkplugs
  7. 2004 f150 5.4l v8
  8. 06 5.4L Running Really Bad
  9. Need advice on engine swap
  10. Champion Plugs
  11. losing coolant
  12. Plug change should I?
  13. Triton Becomes a 4cyl???
  14. Project F1-500 Video
  15. Spark plugs---03 5.4L---PLEASE LOOK!!!
  16. 02 5.4 l misfire
  17. Spark plugs 05 5.4
  18. Wierd Noise?
  19. Drop in MPG
  20. 5.4 Build.
  21. Wow...a blown head gasket.....
  22. cant get the fuel filter off
  23. Motorvac
  24. Clicking Noise
  25. blew a plug
  26. Intermittent rough/smooth idle
  27. fuel pump modulator question
  28. Yet another lean bank 1 Question...
  29. Replacing all Fuel Injectors? EBay remanufactured?
  30. 3v w/full bolt on's
  31. I give up!!!!!!!!!!!!!!!!
  32. Blown Plug in 02 5.4 Need help finding timeserts
  33. Heater host Inlet vs Outlet
  34. Dealership blaming noise on Fram Oil Filter
  35. Blue smoke (08 FX4)...
  36. What does this mean
  37. 2002 ford factory 5.4L 2V cam specs
  38. 97 4.6 Spark Knock, Need Help!
  39. People clame to bark'em easily. Am I running bad?
  40. puting with white smoke
  41. PI heads
  42. A challenge to the gurus: Intermittant fuel pump issue
  43. Fuel Filter replacement---how to de-pressurize lines
  44. Idler Pulley on 5.4L
  45. Blinking check engine light
  46. Question about no Cats!
  47. misfires and oil in well
  48. Starting problem (delay in cranking)
  49. Engine wont start
  50. Need help with TPS-P0122
  51. code 5284 ?
  52. Whistle noise comimg from under hood.
  53. 04 Econoline 5.4
  54. Carb Vacuum Line Issue
  55. small red hose from firewall??
  56. Fan Clutch?
  57. 97' Expy w/start up engine noise
  58. 01 F-150 Code P0354 - cause bad PCM?
  59. 4YR/48K extended warranty
  60. Coil Pack testing
  61. 98 4.6 stalls
  62. Got an oil leak..
  63. Starting Problem
  64. Clunking noise in engine.
  65. 00 plug gap
  66. sometimes I get a high idle
  67. Rough idle and fluttering RPM's
  68. Which coils for 2004 F150 NBS 5.4L
  69. 97 Expy engine options
  70. Clipless wire set?
  71. 07 5.4L Misfire Problem
  72. new addition..
  73. Fuel vs electrical problems
  74. need a replacement engine
  75. Startup issues 2005
  76. Timing Chain Tensioner Loud
  77. 02 Screw 4.6L V8 .... smoke?
  78. Changing Spark Plugs who's used these
  79. ATK Engines. Any review would be great!
  80. Need a little help
  81. 98 F-150 weird missing situation??
  82. 2000 F250 5.4 No towing power????
  83. Oil changes based on time, not miles
  84. 5.4 Rough idle? or normal?
  85. Oil Pickup Tube Differences
  86. 5.4 Liter Problems. any suggestions?
  87. Engine noise
  88. Do 5.4's in vans have the plug problems?
  89. Engine Rebuild(best Cams)
  90. Sputtering on start up?
  91. 05 F150 Ticking Noise Help Needed!!
  92. Been wondering about this
  93. Dorman (Help!) 49812 COP boots/springs for 3V 5.4L?
  94. how can I tell if the computer (PCM) is bad
  95. pully kit?
  96. head ?
  97. service engine light
  98. 351W air 'in the head' or 'in the manifold'?
  99. mod help!
  100. Alcohol in the gas?
  101. gotta problem that needs a quick solution
  102. For real blown head gasket
  103. 5.4l v8
  104. Can someone point me in the right direction?
  105. A little help please!
  106. She's a squealer!
  107. 2wd to 4wd conversion?
  108. Timing chain HELP!!
  109. 1997 Expy OD light flashing, transmission slipping
  110. Blown Head Gasket?
  111. In Every Great Difficulty Lies Opportunity?
  112. 1997 Expedition EB on Castrol 10W-40
  113. Blue smoke...
  114. 2001 Occasional Misfire
  115. '06 kingranch fuel gauge problem
  116. 97 F150 hard to start when temp drops below 30 degrees
  117. 1995 f150 v8 4x4
  118. coolant leak knocking out cop's
  119. too slow?
  120. oil leaking from crank pulley
  121. Making my oil line
  122. 1997 4.6 EGR insuffecient flow
  123. raising compresion
  124. Just changed the fuel filter...
  125. coolant leak
  126. pcm
  127. loud screeching!!
  128. cobra shortblock
  129. Mostly successful 5.4L 3V spark plug change
  130. 00 5.4L Running w/ no power. Bank 2 Lean Code..
  131. Electric CHoke ??
  132. f150 problem
  133. 1997 F150 4.6 engine options
  134. Putting a LS6 in my F-150
  135. 5.4L Burning oil pretty bad!
  136. Have code 1405 coming up
  137. Darn water puddles
  138. engine turns but wont start
  139. 302 won't start, pretty stumped!
  140. TB questions
  141. CEL issues, Battery problems, Throttle Body - Please help!!
  142. What Do These Symptoms Sound Like To You? (Engine Problems)
  143. 200,000 mile club
  144. Mpg help!!
  145. idle problem
  146. Bearings???
  147. ticking sound
  148. Another P0104 EGR Insufficient Flow Code Problem
  149. 2001 4.6L Expedition - Fuel Pump Relay?
  150. 2004 f150 Jerks/Shakes Hard to steer after spark plugs replaced...
  151. Fuel Injector Question
  152. Miss 5.4 SC Harley Davidson. Please help.
  153. 99 Intake on 02 5.4?
  154. Truck sort of eases into being started?
  155. paschal stroker kit
  156. Engine squeaking..
  157. finally figured out whats wrong with my daddys truck....maybe
  158. 1999 4.2 to 5.0 swap
  159. Problem:COP's or Injectors? Plugs changed recently.
  160. crankshaft sensor removal 5.4L V8
  161. bad oil change
  162. can anyone help me out finding where my spark plugs are on 97 f150
  163. spark plugs
  164. Please. Help me find my drain plug!
  165. help me with my alternator
  166. 331,180 miles engin getting noisey
  167. RPM dropped while running 60mph
  168. fuel filter change
  169. Steering assist...
  170. oil drain plug problem
  171. How do I know If plugs have been changed?
  172. blew my oil line last night
  173. How long can I go with my plugs?
  174. Choppy on startup
  175. 08 f150 detonating 5.4 l
  176. F150
  177. Flush for power steering & brake fluid
  178. Burning Smell
  179. Idle fluctuations
  180. Boggs down at shift point
  181. City and HIGHWAY mileage about the SAME???
  182. P0174 and P0171 4.6
  183. 5.4L 3V Constant Loud Ticking at All RPM's
  184. Who's in the 200k+ mile club
  185. 2004 5.4L over bore
  186. Problems With a 97 4.6L
  187. Sudden loss of MPG?
  188. 2005 and up motor in a 1997-2003??????
  189. 5.4 2v rear main seal
  190. high idle in 93
  191. 302 swapped to a 351W....help
  192. Borg Warner spark plug wires?
  193. Crappy sitution with a worse endind! WTF
  194. whos using champion plugs??
  195. Starting problem, need some help
  196. What would cause.....
  197. platinum vs nickel alloy...
  198. what piston should i use?? 5.4
  199. 5.4 replacements?????
  200. 10w30 oil?
  201. What purpose does a underdrive pulley serve?
  202. Injectors and Plugs
  203. Need some advice
  204. 97 4.6. Coolant in #5 Plug hole
  205. More power
  206. Smooth idle miss under load
  207. Code help
  208. Engine Hesitation
  209. no spark no fuel pump...help
  210. 2v vs. 3v
  211. Power steering fluid change? Yes/No?
  212. Can't erase trouble codes.
  213. I broke a cop bolt (pic) 97 5.4
  214. No throttle response
  215. broken idler pulley mount
  216. Yellowish Water/Oil Condensation in Oil Cap
  217. Another Ford engine failure
  218. 04 4.6 Where's the PCV valve? Thanks
  219. 99 expdn 5.4 whats the problem???
  220. My trucks performance --2
  221. Jerking at WOT
  222. starter removal
  223. 1998 F150 wont start
  224. Heater core... is this my problem?
  225. Help with DTCs
  226. is this a good deal for a lightning drivetrain
  227. Champion Plugs...Real Problem Or Not?
  228. SES light and codes help please
  229. No fuel. Injectors not spraying.
  230. Spark Plug change
  231. vacuum solinoids
  232. Preemptive plug strike...
  233. 06 5.4L Power Drop @ 4K RPM
  234. 04 5.4L with bad right chain worth?
  235. leaking oil and No oil pressure on cold mornings
  236. 4.6 - Lightning 5.4 swap TOO many questions!
  237. Intermittent no start condition
  238. gasoline engines - Ford 6.2L -vs- Chevy 6.2L
  239. 1998 4.6 romeo intake torque sequence/specs
  240. Victor Reinz Head Gaskets: Any good?
  241. cruise control no worky
  242. cold screeching belt noise
  243. What The .... Codes HELP
  244. MPGs---how to get them
  245. Smooth idle, rough on accel
  246. I hate to ask more plug questions but...
  247. Bg moa
  248. v10 swap harness questions
  249. Spark plug change
  250. Nickel Anti Seize
