View Full Version : V8 Engines
- 1986 distributor question
- CAn someone please tell me how to loosen the belt?
- New Cat but new tick - HELP
- I think I know what it is,,,,but
- 97 5.4 idles gr8t stutters on acceleration
- Oil change after head gasket change
- Has anyone updated their computer codes?
- "service engine soon" light
- codes 1132, 1151, 1152, need help
- Check Engine Codes 171 and 174
- Thanks!
- Whistling Noises
- Check Engine light constantly on. ABS light intermittently but frequently coming on
- Highway Speed
- What socket do I need to change plugs?
- Darn truck
- DPFE Sensor
- knocking sound
- have dead spot in accelleration
- 4.6L Heads/Engine Replacement??
- 5.4 exhaust manifolds
- Need to replace EGR valve
- Flexalite 270 Warning!!!
- oil pressure guage problems
- Siamese Coil Packs?
- Who makes powerstroke?
- sputtering 97 f150 4.6
- alternator problems
- 1987-1991 2WD - Can oil pan be dropped?
- Anyone Using Scanguage?
- Rough Idle, Grinding in Rear End, Check ENGINE light
- Cruise Control not working - No light nothing
- Good one!
- Flying sparkplugs
- Loud Metal Grinding Sound
- Just changed plugs and wires and had oil in wells
- 1995 F150 stalling out
- 200 miles to a tank?
- 5W20 or 5W30?
- Occasionally won't start
- Changing the Fan Clutch problems
- resetting computer after installing a kn filter
- Any Heating & Cooling Guys in the house?
- Blown Spark Plug
- lost a cylinder
- Changing head gasket
- In the market for an F-150
- Gasket and Grease Question
- Clean intake, how?
- This a bad EGR?/Pic Enclosed
- 1996 V8 5.8 L ticking
- 8 new coils, Inj ring kits, NOW WHAT?
- no starter crank
- Need help!!!! Is this a Freeze out plug that need to be replaced?
- 2002 4.6L DPFE Missing???
- anyone usiing a bbk throttle body?
- service manuals
- wierd noise...help identify
- Oil Gauge Problem.need Help
- 5.4 stalling at startup
- Fan Clutch
- help! 97 smog stuff
- Service Engine Light
- Engine swap question
- 1994 F150 4.9L fuel economy
- EGR and IAC cleaning
- HELP engine running lean on bank 1 and 2
- mileage and the f150
- I need a bigger carb
- Problem found...
- cleaning EGR ports & TB
- Performance Upgrades??
- do i have a chip or not
- Mechanics Stethoscope question...
- System too rich (bank 2)
- engine identification
- 1988 F150 302 fuel mileage
- 6 cyl missing
- misfiring at all RPM's
- [HELP] What's wrong with my truck?
- COP's (how hard to replace)
- sluggish!
- Cel 4.2l V6
- Oil Leak-Head Gasket
- Exxon gas and Ford Injectors...
- AC mode changes at half throttle to Defroster mode...
- Adding Lightning blower and getting smogged
- P0171 & P0174 But NO vaccum leak!
- Life of the 5.4L 3V engine
- Newbie w/2004 4.6L Question
- Replacing O2 sensor
- OIL and oil filter questions.
- Do you need a PDFE sensor?
- New guy with prob.
- 5.4L Redline
- Oil Pan on 1995 F-150
- Misfire detected #2 Cylinder
- Indeterminate 5.4L problem
- Cleaned air intake/throttle body, now CEL
- 94 bronco idle, shift, start problems
- Mass air flow sensor?
- Leaking injectors 04 f250 FX4 super doodoo Lariat
- Lean Condition Bank 1 & 2
- low idle after running
- Pinging and knocking proublem solved!
- 96 EGR Code
- 1997 f-150 engine removal
- timing a 302?
- running out of ides...ignition
- sick of the misses
- 2004 5.4 V8 Oil Filter
- Found out something very interesting today about the 4.2 V6's...................
- P0171 & P0174 after plug change...
- Spark plug change
- hesitation while accelerating
- Head Gasket
- Triton v8 question
- New 5.4 in Expy??
- Belt squeal
- Why is my truck running lean? how do i fix it?
- seafoam good or bad?
- Will this hurt my engine?
- Slightly OT, back in the saddle again.
- Engine miss
- rough idle
- Any confirmed mileage gains with intake kit?
- Other brand help? EGR Probs...websites wanted?!
- Po141
- 97 4.6 - Stall and Buck
- Cylinder Numbering
- Oxygen sensors?
- slight surge, and sluggish take off
- anyone want to buy a truck
- 2004 Engine swap
- Stock Fuel Injector size
- o2 sensors replaced still have light. Now what?
- possible thottle body whine
- Battery light flashes on at high RPMs. Any ideas?
- Anyone Notice This
- who makes the best dino oil?
- Building a CAI system
- Cost of an engine swap
- how cheap?
- a toughy?
- apc intake
- 86 F-150 Egr
- High idle after port and polish?
- Rough Starts
- 98 4.6L Triton V8 Misfiring
- When it rains, it pours...
- Fuel Injector problem
- Coolant change - Temp gauge up slightly
- intake kit or airbox mod?
- Expedition engine swap
- Same Ol Same Ol
- Rough idle after highway driving
- CEL P0401 Finally fixed. Not the way you think!
- Weber 2 barrell on 300 inline 6?????
- EGR (P401) Problem Fixed!
- hoses.
- Big tps problem
- well I guess i shouldn't have come here for any advice......................
- engine miss, # 4 misfiring & running rich.....................
- Mustang intake Swap for 150 4.6
- Help!!! won't start
- 1988 F-150 won't start
- Coil problems
- engine stalling
- Just got 1999 f 150 long bed...
- 5.4L rough idle/stalling fixed
- Air Intake
- Question about head bolts
- 5.4 Replacement Spark Plugs #'s
- Low one quart after oil change!
- 10w-30 or 5w-20
- 2001 5.4L MISSING BETWEEN 1200rpm and 2100rpm
- Bad idle, low performance, fuel milage, dealer CND
- Whats better...
- question for people in north carolina?
- DPFE sensor, where to get?
- Motorcraft Filters... cheap!
- Time serts or not?
- Check engine code
- howling noise
- 300 sputters and stalls
- changing oil without filter?
- K&N question
- Crate engine for a 1990 f150
- won't idle need help
- rear main seal
- Blocks interchangeable?
- INtermittent high idle
- P401 Troubleshooting
- Please help: intermittent P0401
- Sea Foam substitute??
- Question for Labnerd Regarding Motorcraft and Chevron Oils
- CarChip data chip
- Electrical Problems!!
- Electric Fan Questions...
- interchange
- Oil change questions
- Dynamometer
- gear swap
- Temperature problem
- Power Steering Cap
- 2000 Lightning Engine miss (please help)
- Who makes the Best Engine Oil?
- lightning engine for sale
- Weird vibrating noise coming from behind pass headlight in 5.4 expo?
- Why does my truck keep dying?
- v10 smokes on start up
- Higher amp alternator bad?
- K&N Oil filter
- question on tuner chips?
- pics of my engine & truck
- V8 verses the V6
- Air conditioner not working - remove?
- Where are the coils on 4.6L?
- another spark plug replacement question
- smog pump
- Cant figure this out!
- gas mileage at high alt.
- fluid changes
- Gas Mileage
- Ole Blue still sick
- Help choosing a mechanic
- How does this engine sound?
- Can You Solve The Mysterious Hunting/idle Fault 96 Escort 1.8si?
- Making a noise that is difficult to explain...
- 300 6er, high gears, little time.
- vacuum hose routing
- Clicking
- 2 gas tanks but one doesn't work
- Poor acceleration up to 2500 rpm
- BAAAAD Gas Mileage
- http://www.turbonator.com/
- Cold Air Intake
- 6.8 V-10 will not ide when cold...sometimes??
- Need help on error codes
- 97 F150 4wd
- F150 O2 code
- 160%thermostate a mastake?
- Check Engine light won't turn off
- 2000 Ford Expy engine troubles??
- Boost Gauge
- 4.6 vs. 5.4
- Previous owner used Pennzoil in my Screw!
- VSS location?
