View Full Version : Engine
  1. 5.4 engine problems - need help
  2. Performance mods for a 4.6L??
  3. Question for ML on Piston Slap
  4. Possible for self-made tubing for intake?
  5. Check out Ford's new supercharger!
  6. Re-3000RPM Idle
  7. Fuel Injectors
  8. PCM code readout on odometer?
  9. What is the HP Gain from Polishing a stock intake.
  10. Problem with K&N FIPK intake tube -- help needed...
  11. What else?
  12. Battery, Alternator/Reg., Short ????????????
  13. Is it worth it?
  14. Why I changed radiators???
  15. searching a 5.8 esi Engine for f150 1990
  16. 1998 Engine Swap?????
  17. has anyone tried the APC intimidator FIPK?
  18. actron obd scanner
  19. Does anyone have over 150,000 on a 5.4?
  20. 2000-1 Speedo correction?
  21. Firing Order For 4.9L I6
  22. Towing Temps
  23. F150's Have Bad Starters, etc.
  24. 1997 F150XL V6 4.2 Coolant Leak
  25. Think I got piston slap
  26. check engne light, black smoke, miss firing,trans acting up EASY FIX!!
  27. AM I Losing power?
  28. Hesitation when hitting the gas.
  29. What is this?
  30. truck shakes like crazy!
  31. ProCharger?????
  32. Lariat Engine?
  33. K&N system
  34. 5.4 blowing smoke AGAIN!!, need help!!!!!!!!!!!!
  35. which mobil 1 oil?
  36. My Truck Is In The Shop
  37. mustang 302 into a 92 f150?????
  38. ring gear on flywheel
  39. oil in air filter box
  40. Headers on a 98 4.6
  41. Superchargers
  42. Lightning Cold Air Box for the Regular F150?
  43. Oil leak when hand-tightening filter...?
  44. Spark plugs ??????
  45. NEW 5.4 Heads
  46. 5.4 high pitch sound 1-2 shift
  47. Lightning in a Cobra
  48. What is FQR?
  49. Killed a Tundra
  50. fuel filter question
  51. Powrer and Brake-specific Consumption?
  52. specs on the 4.6l
  53. Wrong Battery in the 00 & 01 Tow Package 3 ?
  54. 5.4L specs
  55. Chevys great pages
  56. Electric Fan
  57. Response from K&N on FIPK performance during hot weather...
  58. Power Pulleys
  59. K&N FIPK warranty issue
  60. Hesitation when hitting the gas from a stop.
  61. How do you tell if engine is FQR?
  62. mix syn with dino ?
  63. Trailer Pkg. Radiator (Help)
  64. Early Maint. on my 98??
  65. what could i do?
  66. efficient upgrades for xpedition
  67. Oil Brand & Fuel Mileage
  68. Replaced Exhaust Manifold with JBA Headers
  69. Triton 5.4L - fourth year on the 10 Best Engines list.
  70. Has anyone got a straight answer about using 5W-30 in 2001's?
  71. Minor engine Surge
  72. navigator rims for sale
  73. V10 Mileage
  74. Clutch,Flywheel and Pressure Plate?
  75. Ford not using real gauges for cluster panel? [A MUST READ]
  76. aluminum driveshaft
  77. silver & black flareside
  78. Ram Air?
  79. what to do first
  80. 4.6 L oil leak/motor replacement
  81. Lightnings
  82. piston slap question
  83. Changing Over To Synthetic "Question"
  84. 4.6 requires 5w-20?
  85. 5.4L Specs. and info?
  86. WHO HAS A PRO-M 80MM MAF?
  87. 5W20 Oil- Who makes it???
  88. Y2K piston slap
  89. Motor Mounts
  90. Fans in Fords
  91. Where to get a replacement 5.0L
  92. Am I alone?
  93. 4.10's from Ford Racing
  94. Check Engine light
  95. HELP!!!!!
  96. How many cubic inches is a 5.4?
  97. I beat a 2000 F150 w/ 5.4 How?????
  98. Mods and tow rating
  99. Yee Haw..... Just got my Airaid FIPK
  100. Amsoil Introduces Its 5w20 Motor Oil
  101. Engine Flush
  102. 4.6 vs. 5.4
  103. Intake mod. opinions? (Put cone on end of K&N drop-in.)
  104. Oil on "D" side oil pan bolts?
  105. What the heck do i need to do the job? come on you Lightning guys
  106. Burned my motor down
  107. What exactly is a TSB???
  108. Mobil not gonna make 5W-20 synthetic anytime soon.
  109. 3000RPM Idle
  110. Pics of engine!
  111. 98 EXPEDITION CODE P0171 AND P0174
  112. Battery not charging. Help!
  113. I hate Chevy's!!
  114. Need Help with Next Mod...
  115. Which air filter?
  116. 4.6L LACKING POWER
  117. Need pics of electric fan install: Flex-a-lite #250/260
  118. 1998 F250, need help identifying a couple of things
  119. Motor-Up, Prolong, Slick 50...worth it?
  120. Help, PLEASE!!!!
  121. Y2K Ford Piece of Sh*t!! Help!!
  122. Bosch Platinum+4 plugs cause engine damage?
  123. Went to the Track for the first time.... I got #'s
  124. Advice on 94 5.8 liter engine
  125. Some questions on the 4.9L
  126. engine leading oil from dealers.
  127. Looking to buy and build 150 XL
  128. I'm was told my motor is ruined....help
  129. Detonation
  130. Question about the 5.0........
  131. cam compatibility question for 1992 302
  132. How do you know if it's Romeo or Windsor?
  133. ATTN: Old Timer
  134. Ford Platinum Spark Plugs--Anyone get over 100,000 miles on them??
  135. Dealer Says K&N Caused Belt Noise
  136. Tundra Problems site?
  137. ?????
  138. what does your 5.4 get for fuel mileage?
  139. Low Idle with Air Cond. running
  140. Neal more questions for you
  141. Fuel Filter
  142. Corrrect idle for 2001 4.6 ?
  143. heater coil???
  144. ??Chevy problem sites??
  145. Lightning engine swap
  146. F*#^in Header Gaskets!!
  147. Engine Miss/Dies
  148. Inaccurate speedometer!!!!
  149. 2000 Source book
  150. supercharger info
  151. Fuel Filter Dilemma
  152. Question about the 5.8.......
  153. radiator
  154. INSIDE INTAKE
  155. HOW MANY MILES??
  156. Test
  157. Installing A/C
  158. shakey cold start
  159. Engine noise when shifting.
  160. v6-v8 swap
  161. Maybe my truck isn't so bad after all...
  162. Dumb oil question
  163. Mike I need advice!
  164. please help me
  165. 1401 Engine Code
  166. what do you think of a 1997 ford f150 extended cab 3rd door 2 wheel drive
  167. 5.4 oil leak and out of Warranty !#@!
  168. TPS setting on 4.6, what is yours stock?
  169. High Idle when cold - now Check Engine...Help!
  170. Weird truck problems
  171. What's this!!!!!!! Built Ford Tough ??
  172. Synthetic Oil
  173. 5W20 Oil???
  174. V8 or V6
  175. Getting rid of "high pitched" whistling noise from K&N FIPK
  176. SMOKE!! PLEASE HELP!
  177. oil on frame, crossmembers,block 99 5.4
  178. water run out tail pipe
  179. Pinging '98 F-150
  180. How many gallons are left when the "low fuel" light comes on?
  181. 5.4 Engine cold start knock
  182. TPS Mod
  183. Gasoline, what brand do you use?
  184. good laugh
  185. superchip codes
  186. First real competition
  187. Do I have a tow package?
  188. TPS mod (mine was already at 1.286???)
  189. An observation
  190. My 4.6 is only getting 12 MPG
  191. My 4.6 tops out at 95?
  192. Engine Temps
  193. Intimidator Intake
  194. Powerdyne Charger
  195. 5th wheel?
  196. why does battery icon come on?
  197. Jacobs ignition on 4.6L What is involved? Is it Worth It?
  198. Hey Neal...need your opinion please.
  199. Dodge Dakota in a race
  200. 2001 4.6 horsepower
  201. Another 99 5.4 Oil Leak
  202. Which spark plugs?
  203. Urgent to every F150 Owner! **PLEASE HELP**
  204. Engine coolant question?
  205. Attn: Screwit
  206. Octane Shorting Bar
  207. Need a 4.6l 1997
  208. Expedition Radiators?
  209. Are the F-150's going to change in '02?
  210. why does my truck keep dying.
  211. Hey Otterbob
  212. Exactly how similar is the F150 4.6 to the mustang GT 4.6
  213. Question for BBK/Edelbrock 75mm Throttle Body users
  214. re-setting computer?
  215. To chip....or not to chip????
  216. Lost money on trade because of FQR?
  217. 4.6 oil leak back after head gasket replacement
  218. How's your milage?
  219. Feedback on Haynes Manuals?
  220. Trans shudder fixed with higher octane gas - needs knock sensor?
  221. Charging a 4.2 6Cyl...will this work??
  222. Mass air sensor
  223. Estimate on horsepower?
  224. 4.6 vs. 5.4 L ??
  225. Ported Heads anyone have?
  226. SD limo
  227. 5.4 v-8
  228. Check engine light
  229. When to trade??
  230. 2000 Expedition Located in Rhode Island....Place to UPGRADE?
  231. Which engine
  232. Power Mirrors
  233. Update for "Ian.N" Engine tach.
  234. engine stumbling on acceleration
  235. engine missfire
  236. Question for Thf Freak
  237. Dyno results.......Again
  238. Sweet car
  239. Perspective, Patience and Pride
  240. what service stations/stores use Amsoil?
  241. Can Somebody Explain ?
  242. Was just wondering.Flareside or Fleetside??Why and Why not???
  243. Switch from Mobil 1 back to Valvoline
  244. K&N FIPK Installed -- feedback on noises?
  245. Piston Slap!!
  246. Crank Question?
  247. 04:04 PM
  248. Question about 5.4L fuel injectors?
  249. Installing a "real" oil pressure gauge.
  250. Performancs Mods for 5.4V8
