View Full Version : Engine
  1. fuel pump keeps running
  2. Be Careful what you post/emails from ????
  3. NEW!!! 2001 King Ranch
  4. Best Synthethic Motor Oil?
  5. long tube headers
  6. pulling 2000# boat will I get better mileage w/OD off or ON ?
  7. o2 sensors when putting on headers
  8. when do i change my spark plugs?
  9. Best, most current TSB site?
  10. Burning Oil!!!!!!
  11. Custon FIPK
  12. Buying a 1997 5.4L 4x4 extended cab
  13. Switched to 180 degree Lightning thermostat...any possible porblems?
  14. k&n gen II kit
  15. Blown Brothers, NOS...is it possible??
  16. just got back from towing, elec fan update
  17. Which type/brand of spark plugs for a 4.6L?
  18. More on not so super "Super Cooling" package
  19. advice on trade
  20. K&N FIPK Whistle HELP!
  21. Anyone using Power Pulleys?
  22. NEW RADIATOR ON THE WAY !
  23. XLT EXTENDED W/SUPERCOOLING ON ORDER
  24. Mobil 1 or Motorcraft Oil Filters???
  25. fuel system codes
  26. Helix Power Tower
  27. Oil on spark plugs
  28. K&N air filter change
  29. How does my burnout compare to yours?
  30. Filter Injection Performance Kits
  31. Mileage
  32. water pump 4.6 help?
  33. MPG Increase with FIPK,'s, Velocity Tube?
  34. New radiator
  35. New Radiator Situation
  36. check engine light (yet another one)
  37. Kenne Bell Blower Update
  38. AIR FILTER FELL OFF !!
  39. 5.4 L Tapping@1st startup
  40. oil cap
  41. 2001 4.6L 240hp
  42. How do you calibrate speedo. for 4.10 gears on '97 4.6L?
  43. MagnaCharger Question?
  44. Stock Air Box
  45. Need help selecting a chip?
  46. Exhaust done....what's next?
  47. Service Engine Soon
  48. Mobil gas
  49. Warranty/Piston Slap
  50. exhaust issues
  51. Super CHip
  52. Update: Pinging '98 F-150
  53. Supercharger lacking power
  54. Put this in your gas tank.
  55. '97 4.6 F-150 leaking coolant below thermst
  56. dont need a locking gas cap on new model Fords
  57. No Guts with AC Compressor engaged
  58. Horsepower 2002 5.4
  59. It came in!!
  60. Time for a locking gas cap?
  61. check engine light
  62. Smoke After Oil Change
  63. fuel filter
  64. Poor Performance Now That It's Hot
  65. Could the oil filter be ANY tighter?
  66. Lightning Engine in ORP????
  67. Location of TPS??
  68. next mod ?
  69. Is PROLONG Engine or other aditives good or bad?
  70. I need Ford confidence
  71. advantages of EFI over carb?
  72. rear emd
  73. Need Advice On Ext. Warrenty Purchase.
  74. FORD did a oil change
  75. Which synthetic oil???
  76. REDLINE
  77. Picked up my new SCrew today...Radiator Question
  78. HELP!!! My truck is in for head gasket replacement!!!
  79. Check Engine light -Fuel cap?
  80. Platinum Spark Plug ruins Cylinder Head
  81. best exhaust for 5.4?
  82. Efficient Oil filtration Recommended
  83. 4.6 power
  84. What is the best way to break-in new car for best performance?
  85. Airbox mod's PLEASE HELP!!!
  86. Warranty running out soon, what should I look for?
  87. '01 Alarm instaled on F150 '85
  88. Oil Leak On Pan, Going Back to Dealer Tomorrow.
  89. 4.55 to 308
  90. 2 Strange things on 1st Oil Change
  91. O M G !!!! NOT G00D .........
  92. FIPK install pictures, trying to deside on one
  93. Draining the radiator
  94. Another Airbox Mod. Question.
  95. Dynos in north central Ohio?
  96. Velocity tube?
  97. "PI" Heads, attention Neal & JMC
  98. Thank you contributing f150 online members
  99. Bosch + 4's
  100. 60,000 mi tune-up
  101. radiator upgrade
  102. OBD-II scan tool - Getting a STEADY light ?????
  103. Wrong Rad on 2000 F150
  104. HELP K&N or airaid?
  105. Want to increase your gas mileage?
  106. Gears?
  107. Redline 5w20 synthetic oil
  108. F-150 vs. F-150
  109. 98 EXP. TROUBLE CODE P0171 & P0174
  110. Rice burners
  111. Going to the track to run my truck tonight!!
  112. 4.6L engine ticking sound
  113. where to get info on older f100's?
  114. The Meaning of "Yeah, That's normal"
  115. Poor mans turbo
  116. 5.4 Smoke???
  117. X Plan...how much again??!!??
  118. I just checked the rear diff on my 99 F150 w/9000 miles
  119. In-line 6 mot0r
  120. Just spoke to my Ford service mgr re: problems between 1999 4.6 and 5.4 also read thi
  121. Qualified best oil
  122. I say not
  123. O2 sensors
  124. 94 F150 5.0 with bad pinging? Please help.
  125. Oil filters...what's good.
  126. Please help! Blowing starter fuses like mad
  127. ???19 MPG WITH 5.4L ??? THATS BULL!!!
  128. What is the next best oil filter???
  129. 5w20 at Walmart.
  130. Need help PLEASE today, Is this a good deal 1999 XLT for 1999 Lariat...
  131. Amzoil and Piston Slap
  132. Fuel pressure regulator
  133. Need 460 Fuel injected help
  134. Auto and Manual Trans???Horsepower eater!!!
  135. Radiator exchange done-now the tranny cooler
  136. Rough Idle
  137. K&N FIPK . . . really sucks . . . !
  138. TSB'S AND RECALLS
  139. jstang
  140. Drain your OIL
  141. anyone towing with 3:31 ratio rears ? will this be alot worse than my 4.6 with 3:55's
  142. WMS Velocity Tube VS Air Force 1
  143. rebuild kits?
  144. fan probs need help NOW!
  145. Lifter noise on start up!!!!!
  146. TOO MANY MILES ON 99'...they said
  147. Speed Limiter??
  148. what can i do to get about 260-280hp?
  149. New Airaid Intake
  150. Air Force 1 air intake system
  151. Belt Squeak Resolved. (Must Read)
  152. HELP - Dangling parts
  153. re: gear ratios
  154. GM Duramax Woe's
  155. Turbo race engine in Mustang 1800Hp
  156. V-6 Diesel in New F-150's Great Mileage
  157. ? on Rebuilding a 2 BL Motorcraft Caburator
  158. How much Stock HP in 4.6L
  159. Hesitation at 1800 rpm
  160. Need Feedback on the WMS Velocity Tube...
  161. Fuel tank size
  162. 2nd head gasket leak on 5.4 w/in 5k miles
  163. 4.6L s/c
  164. exhaust
  165. Where can I buy a crate motor?
  166. Just replaced # 4 coil pack
  167. Living on rice and water to pay for truck?
  168. Oil change warning...has this happened to you?
  169. Do Mobil 1 filters have anti-drain valve?
  170. 2001 4.6L Oil Leak? Need opinions.
  171. High pitch whistle
  172. AirAid Installed, One Question?
  173. ENGINE STALLS
  174. Need a Ford Engine Tech....
  175. WRONG RADIATOR AND DEALER WON'T REPLACE IT TRY THIS
  176. 5W20, knocking, warranty
  177. Blown Motor @ 85k
  178. A question for SUNDAYNIAGARA69
  179. 4.6 V-8 in 1998 F-150
  180. Whasup with the Fan Pulley?
  181. Does anyone make a supercharge for a 2000 F150 V6
  182. BigBadRedLiftedFordMan
  183. 5.4 engine
  184. need help!@!@!@!@!!@
  185. Thermostat instead of Superchip
  186. K&N Cleaning & MAS filiment?
  187. i have a quick question
  188. look
  189. Is it true the Chevy 4.8 has 270 HP , whats my 4.6 got ?
  190. power steering
  191. 351w for sale
  192. decisions decisions...
  193. I've got a baaaad feeling.....
  194. engine knocking
  195. K&N FIPK and Waranty ?
  196. AMSOIL synthetic motor oil?
  197. 5.4 HP
  198. Oil Filter Question
  199. HELP? anyone know this code?
  200. Too much air or not enough fuel?
  201. How to identify a 428 FE v.s. a 352/390 block
  202. supercharger
  203. Hey JimWright
  204. a/c and heat prob
  205. Clacking noise?
  206. Does anyone make an elec. fan kit for 4.6 truck?
  207. what is TPS tuning and how do you do it?
  208. Engine Bay Cleaning...help
  209. Possible to put V10 in F-150?
  210. WEB SITE Specificaly for SOHC 5.4L ?
  211. ?s for Neal
  212. 5.4 or Diesel
  213. PI head swap
  214. supercharger/turbo
  215. Which Oil to Use
  216. Advice!
  217. MIKE IN LA HELP!!!!!!!!!!!!
  218. Looks like synthetic 5w20 is here
  219. Finally fixed my pinging problem!
  220. OBD II Scanner
  221. 5.4 vs. 4.6
  222. Just got a K&N air filter
  223. obd 2 system
  224. F150 4.6 Vs. GT 4.6
  225. what size fuel pump
  226. how the #### do i change my spark plugs?
  227. Please help with Engine trouble on '98 4.6L
  228. Any way to turn off the antilocks?
  229. Change Fuel Filter @ 15,000?
  230. 5.4l oil leak
  231. Is this true about synthetics???
  232. Proper TPS resistance range
  233. ABS System
  234. K&N Generation II FIPK for 97-00 4.6/5.4...$199.95
  235. SUPERCHARGER which one
  236. Blower voiding warranty work ?
  237. I did the Diagnostics test with the trip meter button and a code 5284 showed up ??
  238. 2001 radiator
  239. New Engine/Loaner Car Help!
  240. 5.4l on Desktop Dyno
  241. Desperately seeking help!
  242. Codes on Radio Display???
  243. radiator fiasco: good/bad dealer list
  244. Something to remember!!!
  245. 1/4 mile times of 5.4L engine?
  246. Engine missfire under heavy load
  247. K&N FIPK GEN II...where is a cheap source?
  248. recommendations on new wheels/tires for '01 F150
  249. Rough idleing
  250. Where to find 5W-20 oil
