- Fuel Injectors
- block coolant drains on a 4.6L??
- Any opinions on deep cycle batteries?
- Leaf springs
- Cam for 5.0L
- Okay guys,
- Electric fans. Step in a tell your story!
- oil gauge 97 4.6
- ECM Chip
- 5.0L firing order
- 5.0L supercharger questions
- went to dealership for spark plug replacement...
- Starter or cellonoid going bad?
- Where to start ????
- Engine shot at 42,000 mi./ Detonation!
- I think it's the belt stretching out.
- Question about Triton engines....
- Question for poweraid owners or throttle body spacers
- Throttle Body - MAF Sensor or BOTH
- Changing Cam in 5.4
- WEAK Starts...
- Gms Maf?
- Lighter Side
- Wires and Plugs
- Re: What is your best kill?
- thermostat change?
- Oil temp reading?
- First Oil Change since FQR motor
- having engine probelms at 63,000 miles
- Calling Superchips_Distributor!
- Neal!
- oil gauge and light
- Questions
- help need info
- exhaust smoke on start up
- Surprising Fuel Mileage!
- Breather Cap?
- Titanium sparkplugs?
- Recommended ATX Tranny fluid???
- Temp Gauge Running wild
- I want to use the fender inlet with my K&N Gen II...
- Maybe Now Finally Some of These Quality Problems Will Be Addressed
- Where can I get Royal Purple in Puerto Rico???
- Piston Slap
- Missing cylinder
- P.O.S Ford...flame all you want, but Im sure some will know what im talking about
- What is your best kill?
- My New Truck!!
- Aftermarket Air Intake - K&N, Air Rad, Velocity Tube??
- Piston Slap problem
- Pully's for 99' 4.6
- More Enigneer idiot ideas
- Sensor ???
- 88 F-150 Oil Pressure
- Ford confirmed wrong radiator size via email
- 5.4 Runs Rough on start (not an engine miss)
- Will my engine hold up?
- 5.0 EFI Tuneing Guru Needed
- Question for some of the Modular Experts Out There
- Idle Miss Fixed
- Class action lawsuit ,ref Tow Package
- Trans Mount?
- 4.6 vs. 5.4 air intake
- Oil leak?
- blueovalnews article
- New Truck
- ANOTHER starting PROBLEM!!!!
- Which gas??
- ok..now I am confused....
- I would like to ask you guys.....
- What is tearing my engine up?
- Gas Additives
- DTC Code??
- number on block
- Gas Mileage Update
- Well Well Well
- Synthetic Myth
- Amsoil and legal support
- cobra throttle body in a truck?
- Ford F150 Very high idle.
- Synthetics?
- F-150 performance truth's and myth's
- Low fuel light
- MAF Issues
- can your filter do this?
- Inlet Heater Hose Replacement-- Piece of Cake
- Resetting Factory Computer
- Air Force One installed Today
- Hmmm What do ya'll think???
- Metal Button for Alarm... Where is It?
- need info
- Coolant leak In 97 F150
- Engine Upgrades
- Ford Alarm System
- F150 Problems
- Question about ASP's Underdrive Pulleys
- 35+ MPG on a V8?? It's possible...
- Ford alarm sytem
- Engine Missing out
- New Motorcraft Filter
- Noticible crack in top of block
- Horrible gas mileage
- Top speed?
- Help! Engine revs when in park
- Low Idle Sometimes
- Air Force One Filter Question
- foglight mod?
- new enging?
- Much better 4.6 gas milage
- 2001 Summary of Problems
- Ticking Noise
- towing with 4.6
- Piping fresh air into the airbox area?
- Slip Yoke Service Anyone???
- Wow! Bosche Platinum And Mpg!!!
- 4.6 Belt Replacement
- Tach "jumps"
- Check Engine Light
- 302 Rev Limiter?
- Where is the oil pressure sensor?
- Mixing synthetic with reg. oil
- i can't get it!!
- 1997 f150 4.2l lack of power at operating temp/ fuel compsunption /miss
- 160 Thermostat?
- Plugs, Fuel Filter
- JET underdrive pulleys ... do they suck?
- Intake questions...
- Truck won't start - need help!
- how much gas have you put in a 30 gallon tank?
- 4.6 Questions
- Thanks to all
- If You Have Cold Start Knock You May Want To Try This
- 4.6 cams?
- Temp Gauge
- 2002 X Limited
- Stock Horsepower and Torque for '97 5.4L
- Poor 5.4 w/slap owners...
- Diablo Chip? I wouldnt!!
- Actual Hp Gain?
- 4.6 5-speed Bad Idle Fixed
- Engine Miss Around 1500-1700 rpm
- Lawyers & Car Companies
- Odd Occurrence after WMS Velocity Tube Install
- 97F150-Engine won't crank
- Radiator
- Air Box Mod, Does it work??
- Non-Invasive Power?
- 4.6 Head Gaskets!!!
- gas
- Ref: K&N
- 351 vice 302
- Fuel Filter 2000 Expy
- have small rad
- rad problems
- High Idle, Miss And No Low End?
- 99 5.4l, any problems with motor mounts??
- My check engine light is on!
- Horsepower of 351 ci engine?
- Cheap MAF upgrade!!!
- Chevy Web Site?????
- $112.80 for a 5.4L coil pack
- 5-30 Oil Too Light?
- Has anyone used hypertech power programers?
- " NOS " Yes or No
- " NOS " Yes or No
- Engine Knock 2001 X (PS?)
- Options
- oops...
- Turbo whine from non-turbo engine
- 4.9Liter 300cid. Inline Six Info/Modifications?!
- Lost all low end...
- Help with seeping output seal on '01
- Syn Oil
- Calling Matt90GT
- 5.0HO intake from mustang in a truck
- WMS Velocity Tube Report
- Pinging at light acceleration?
- K&N air filter...Not in my truck!!
- Trans. size in 99 4.6
- Two different spark plugs stock?
- Dual remote oil filters????
- Piston Slap and FQR Engines
- Fastest repair list
- IT WAS THE COIL PAC...
- good idea
- F*ing 5.4l ignition setup
- gauge questions
- Is Amsoil API certified?
- AIRFORCE 1 ??
- Help!!!
- More -> 4.6L idle Surge
- Amsoil Question
- K&N vs. Airaid
- Neal - question about your electric fan set-up
- K & N FIPK Question.
- Will this madness ever end??????
- Where can I find a Electric Fan for Cheap?
- 3:55 compared to 3:73
- 5-20/30 AMSOIL Synthetic
- 5.4 AND BOSCHE PLATINUM +4
- Change your plugs before 48k !!!
- Off Topic, but related to Wrong Radiators
- my bro needs some help...
- Low End Torque Loss
- Service Work & Aftermarket Parts
- 1999 5.4L Engine Shutoff???
- When to switch to synthetic oil?
- HELP!! Fuel Pump Problem?
- Lifter Tick?
- new guy
- intake, exhaust, header...
- 5.4L Clatters Since Filter Change - Why?
- Sold my P.O.S F-150
- Air flow analysis software.
- 5.4 Low idle...
- Engine "bucking"
- trans. temp. gague
- Crotteau's body lift? Ya out there?
- Ford's Oil Pressure Gauge, I mean Analog Dummy Light
- confused: 5W30 or 5W50?
- Engine Shut-Off at Startup
- factory throttle body size?
- FIPK's???
- How long between synthetic oil changes???
- Does anybody know
- Spark Plugs and Wires
- rpm question
- rattling noise when starting
- My truck is sick....
- intake?
- Help, my new truck!
- Ticking 97 F-150
- 4.6L Mustang
- Break-in Oil
- Break-in period-synthetic oil
- EVAP P0455(2) Diagnostic...all read
- Spark Plugs for 5.4-Real Life Expectancy
- two radiators in my truck?
- amsoil dealers
- Lighting Engines in F150
- Helix Power Tower
- ram air & water
- Bad gauge?
- Engine humming noise
- Exhaust
- Radiator Suit Info
- 4.6L gas mileage for reg cab, short bed 4X4s with auto, 3.55 and ORP
- How much oil in 5.4L?
- 2000 XL Over Idle
