View Full Version : Engine
  1. K&N Filter Question size??
  2. Engine Horsepower
  3. automatic engine oil primer
  4. 4.6 Power Change
  5. Oil Filter on too tight
  6. I've come to the conclusion that K&N Sucks...
  7. 01 5.4l Blue Smoke on Start Ups
  8. How oftern do you clean your K&N Filter?
  9. I've got it too!
  10. 4.6L Oil Filter
  11. Asp Power Pulley Fall Apart!!!!!!!!!
  12. diesel f-150?
  13. Holley Power Shot air filter?
  14. Rattling Noise on Cold Start
  15. Horse Power
  16. Winter Blend Differences
  17. Superchip on a 5-speed?
  18. AMSOIL dealers...need info
  19. Engine Flush?
  20. K & N filter replacement
  21. Weird idle or my imagination?
  22. What year?
  23. Hipo 5.4
  24. Can anyone help with ticking noise?
  25. Hesitation at acceleration
  26. 4.6 vs. 5.4?
  27. I heard that there is an F-150 radiator class action suit
  28. Has anyone installed a Helix tower of power? If so did you see any improvments?
  29. Fuel Filter
  30. AMSOIL 5W-30 or 20W-50
  31. cams or heads
  32. Swapping 4.6 into 4.2, can it be done?
  33. pining under light acceleration
  34. engine noise
  35. When was my truck made?
  36. Stalling after battery change
  37. Intake Silencer
  38. Pre-Luber
  39. Synthetic Oils
  40. airraid,kn.airforce, which is best?
  41. Advise for buying high mileage 92'?
  42. Piston Slap - I've got it!
  43. Where is the Engine Code?
  44. Cost of truck
  45. Towing with wrong 1.02 radiator
  46. flex fans
  47. Chip for 4.6L
  48. RECALL: Wiper motor
  49. Microchip in key
  50. Header information.
  51. Oil Leak
  52. Heads
  53. 5.4 equals what Cubes?
  54. Not just 4.6 rough idle, check this out.
  55. Truck shudders at 1500 rpm's
  56. A/c Pump Bearings Gone??
  57. I found new headers
  58. A/C Temps different ???
  59. 5W-20 synthetic from the factory?
  60. Who makes Motorcraft's new 5w-20 synth. blend?
  61. 4.9 litre 300 6
  62. Scan Tools
  63. Odometer Codes
  64. power steering seal leak
  65. New to this forum...leaking heater hose fix?
  66. Rough idle on 1999 5.4
  67. I finally did it...I GOT MY NEW TRUCK!!!!
  68. what e.t.?
  69. Follow-up 5w-20 Oil
  70. Radiator Nirvana!!!!!
  71. Regional Rep Phone number?
  72. Fipk
  73. Engine Stumble at Initial Start Up?
  74. noise after washing engine
  75. F150, 4.2 Engine Trouble
  76. Ford engineer says "OK to use synthetics"
  77. 5w-20 weight...what?
  78. Need some experiance
  79. How much $$ for machine shop work?
  80. Dispute Settlement Board
  81. supposed ping solution
  82. Superchip
  83. Easy But Effective Mods
  84. Anyone Make A Tb Bigger Than 75mm???????????
  85. Getting rid of the Governer
  86. Accel Coils
  87. oil pressure sensor
  88. FIPKs, Heat, and all that jazz...
  89. 99 5.4 HP rating
  90. Air Raid Vs. K&n
  91. Anyone in So.Cal had their 1.02 radiator replaced?
  92. Ignition Switch
  93. Hot weather hesitation solved.
  94. Not enough oil, or is the dipstick too short?
  95. FIPK and dealership service dept.
  96. Question on ASP pulleys
  97. Dum question on oil change.
  98. To much tranny fluid
  99. 4.6 engine knocking
  100. getting ripped off? (chevy question)
  101. Ignition ???
  102. US, Canadian Tow Packages are Different
  103. Looking for the Texas Ford guy who sells cheap ESPs
  104. idle
  105. engine miss
  106. F150 vs Silverado vs Ram vs Tundra (a Review)
  107. Synthetic Oils
  108. Engine "tick" and hesitation
  109. WARNING Mobil-1 Filter users
  110. 94 vibration
  111. Can't remove spark plugs help!
  112. Question about superchips for my new truck
  113. more power
  114. Oil Change Interval Using Synthetic
  115. How worthy is a 351M in regards to........
  116. 5.4L Oil Filter cross reference
  117. rattling noise at approx 1800 rpms.
  118. Left Oil Fill Cap Off; Check Engine Light ON
  119. Ford settles ignition lawsuit
  120. piston slap wav file
  121. What damage did I do with running 12qts. of oil for 6k miles???
  122. 1/4 Mile times?
  123. attn:rice haters
  124. How do you pull the slack in the throttle cable at the pedal?
  125. Where are the grease zerks on an 01 SuperCrew??
  126. The end of MTBE in CA
  127. engine parts online
  128. does the A/C really affects gas mileage?
  129. 4.6L design flaw?
  130. Heater Core
  131. FMS 9mm Wires and Ford Double Platinum Plugs
  132. Is there an easy way to improve HP?
  133. engine removal
  134. Best/Custom Ported or New Performance
  135. Which size radiator do I have?
  136. diferences between a 1997 4.6 and the earlier ones
  137. Concerns with M. Troyer-perf center
  138. Finally gonna get my dream truck!!!
  139. 4.6L engine reliability
  140. 3" Performance Accesories Body Lift
  141. Engine Starts then stalls intermittently
  142. Eratic speedo needle and weird shifting. Any ideas??
  143. Remote oil filter question..
  144. V6 - V8 Engine swaps
  145. coolant flush: one or two drains on block?
  146. Best Oil Filter?
  147. check engine light...
  148. California Fuel Fiasco
  149. Switching from EFI to carb
  150. Installed Electric Fan and WOW!
  151. 2.2 Radiator
  152. Shaking AND Vibrating....
  153. Its not a F150 but....
  154. 5.4 V8 in a 2WD RegCab
  155. 4.6l V8
  156. `Guys I need some help, Big Time!
  157. 2001 Expy 5.4L, Superchip, Airforce 1, Gibson, Y connector!!
  158. Longer lasting coolant
  159. Underhood Temps.....Big Difference in Performance
  160. Brake-shift interlock problem on 2001
  161. EGR sensor
  162. Does anyone know?????
  163. Tell me I'm Crazy
  164. 5.0 for the new body style F150
  165. Pinging on 4.6 V8
  166. V10 performance mods
  167. 4.6 changes between 1999 and 2000
  168. Consistency
  169. Slight hesitation in 5.4
  170. 4.6 Tire smoking??????
  171. service engine soon light
  172. Air Box Mod
  173. Check Engine Light On!!
  174. How do you keep engine from racing when first started
  175. 5.4L missing bad during accelleration (Help!)
  176. Questionable Engine Problem
  177. Lightning engine on ebay
  178. Pistons welded to bore...friend's car
  179. What's this Gen. lll and Gen. l stuff
  180. A/c
  181. 5W 20 oil
  182. Bad idle is gone!!!!!!!!!!!
  183. oil in air filter box
  184. Engine light comes on.
  185. rough idle & bucking
  186. HELP! 4.2L Surge @ 73 mph
  187. Wrong MAF sensor??
  188. maintance 200,000kms
  189. a ford with a heartbeat?
  190. Need Help! Short Question on Engine.
  191. Here she is....
  192. need opinion on purchasing a 2000 leftover
  193. need opinion on purchasing a 2000 leftover
  194. Whistling sound w/ Afraid TBI Spacer
  195. Why so rich?
  196. Newbie here!!
  197. 97 302 conversion
  198. inline 6 300 ci performance mods
  199. Air mod
  200. Ratios
  201. Speed limiter ?
  202. Fuel Filter Problems
  203. Bad gasket on heads
  204. Laptop - computer???
  205. Rear End
  206. Excellent 5.4 Fuel Mileage Improvement!
  207. Skid Plates
  208. Disgusted, here we go again,,,,,,,
  209. K&N FIPK Review
  210. Power Gains on Airforce Cold Air Intake?
  211. Tornado... Dont Waste Your Money!!!
  212. Can I Use mobile 1 10w30 instead of 3w30?
  213. 5.4l dead at 3500 miles
  214. Blue Oval Oil Changes
  215. 4.2l V6
  216. 4.2l V6
  217. warranty void?
  218. Dealer Alarm
  219. What happened to my engine?
  220. Ford's position on using synthetic oil.
  221. Factory Air Box
  222. Air Force 1- The way to go??
  223. 5.4L and possibly 4.6L Badges
  224. What a DOG!
  225. Service Manual
  226. '99 4.6 idle won't run...help
  227. Premium fuel on new 01 5.4
  228. Poor Poor Expy
  229. was going to trade the truck in, but...
  230. Injector problem ???
  231. Best intake for the money
  232. First oil and filter change
  233. Bad A$$ Trucks
  234. refilling coolant
  235. Dripping Noise at High Speed
  236. Airaid is now 50 state legal!
  237. A/C condensation leaking on exhaust
  238. Air/Fuel Gauges
  239. MT-10 Additive
  240. 22 mpg!!!!! It can be done...
  241. Changing plugs on 5.4
  242. 5.4 idel problems???
  243. Looking at new ones?
  244. Fast and the furious...
  245. Where is the Fuel Line on a 5.4L?
  246. AirAid
  247. Hesitating/Lack of power when accelerating
  248. What # fuel injectors do I have?
  249. Air Conditioning Noise
  250. poweraid spacers results on a 4.2
