- 98SCREAMER For you only
- 1989 F250 5.0 Engine Probs
- What is that thing.(AC Related)
- Coolant "leak"
- Engine swap for a 302 v8
- buying a 2002 F250 4x4 SD R/C 5.4L EFI w/Electronic 4-Speed Audo Trans
- Cobra R waterpump
- 5.4L Block differences?
- Excess carbon in engine: how?
- 1999 vs 2000, 4.6L V8
- Does anyone no how much you can bore a 5.4
- Any Predictions
- Correct electric fan
- Oils Change [3000 miles vs. 5000 miles]
- Starting Problem
- Just my...
- Interesting Newspaper Clip for those with small rads...
- looking at buying a 2001 f150 that has the smaller rad. will i get a new one?
- Is there a digit in the vin# that tells what tranny ?
- Batterys & Reliability
- FYI..4.6 dyno
- oil leak?
- Camshafts for 5.4
- Coil pack retainer bolt snapped
- The pinging is gone, Sea Foam did the trick!
- Cam gear on a 95 F-150
- Eggs??
- Is everyone gettting their rad letters?
- no spark after brake fluid spill...
- Fuel too lean
- Cleaning engine compartment??
- Cleaning Fuel Injectors
- OIl Change for Computer Geeks Part 2
- What would you do??
- Suggestion Wanted On Next Mod Please
- Oil Question
- screwed-up
- anyone know who carries un-oxygenated fuels ?
- computer reset question
- First oil change !!!
- Engine Pre oilers
- Help! Need Bosch O2 part number
- Anyone had luck ducting the air intake?
- 4.6 Pulls Hard and Runs Great!!
- Pulling Off Balancer
- MAF gutting and computer code
- Starter, relay, or cable problem
- sema show pics
- Mass Airflow
- Expedition,2000 XLT is this a god deal ?
- 5.4 reliability?
- Speed Limitor
- Blue Exhaust Smoke After Cold Start?
- Super hot oil change
- Trition V8
- New Engine
- Heater not working
- Replacing spark plugs in 5.4
- Harmonic Balancer Help PLEASE!!
- 2002 F150 Triton 5.4 Horsepower Question.
- 97 F150 5.4L error code P0171
- Just Got My Radiator Up-Grade Check in the mail! What do I do?
- engine question
- Oil Change 101 for computer geeks.
- Thanks Fellas....couple more questions...
- AutoXray OBD II scanners
- Did my computer reset work?
- how long will a 5.4L last?
- Need someone knowledgable with speedo re-gear...
- Synthetic Switch Help
- JET Performance Module vs. Superchip
- Engine/ Transmission Relationship Causing Lack Of Power
- Ethanol Gas?
- I can't find the post for carbon cleaner!!
- EGR Valve
- Can you do too much to an engine?
- Are the new Chevy V8's fast?
- k&n conversion
- Help! Blew up my Lightning engine...
- engine swap
- First start vacuum leak?
- My mpg is down by 4, need advice
- HELP!!! Coolant Leak from my 5.4
- Idle Problem 1998 4.6
- new owner here
- Please Help With Stock 98 4.6l
- Pulling #1 plug from 4.6L
- New Electric Fan Unit In!!!
- Changing to Mobil 1 Syn... but what viscosity... ?
- Navigator Heads
- Clicking injector?
- help me out
- what to do with 1400 bucks? HELP!
- Gas Mileage Report--5.4L
- "4.2 pinging"
- Engine problem?
- Where to get a new v-10
- Maintenance questions
- Steering column separation
- Radiator Upgrade - Who missed May5 date?
- After market products.
- reset your computer?
- Thought on rough engine...
- New Throttle Body, Body Spacer, Intake......
- New Poster Questions on 4.6L Problem w/ Coolant and Cracked Paint on Doors?
- 4.6L vs. 5.4L
- FIPK for 2002 F-150
- engine vibration @1500,2000
- Need HELP on new Gauge install Fast
- Help!!! I've Got A Oil Leak
- Aftermarket valve covers
- AirRaid FIPK??
- Third Head Gasket
- injectors
- Fqr???
- That choking sensation??
- The Witch Is Dead! Coup At Ford!
- Just bought F-150, What do I do first?
- 5W vs 10W-30 motoroil
- Bosch Platinum +4
- timing?
- 4.6 crank pulley
- Cheap 2000 XLT SC
- used 4.6l heads
- engine removal
- deal or not?
- engine swap
- what FIPK adds more power
- upgrades
- tied to a stump
- Axle Codes??
- EGR Valve
- bad ground?
- Squeaky Serpentine Belt
- Parts(the guts) for our motors
- ? for '98 4.6 owners, pinging related
- 2003 Trucks!!!
- Is This Normal?
- 88 F-150 dual fuel tank operation
- what if...
- Driving Problems
- Stupid Leak
- F150online-Radiator=Kicked F*ords A$$
- Air Raid or KN Air Filter Charger
- Autolite Platinum!
- more f150 wowes
- JBA 4.6L headers
- Engine Stumbles at 1500
- 94 sable not running
- electric fan modification
- Casting Number
- jump in idle
- Need Help Asap!!!... Electric Fan Mod (matt90gt))
- Got my Pacesetter FIPK today
- Engine
- Engine chatter or ping
- ATTN: 97-98 4.6 Pingers Club
- Bad idle after driving
- 1999 5.4 4x4 Off Road
- 5.4 Engine or 4.6?
- Octane Clatter Solution
- Any thoughts on the W-8 engine
- if you know anything about 5.0's please read!
- When an F350 just ain't big enough!!
- Bosch Plat + 4 -- Which One?
- Tug-Of-War With a F-350
- 7 cyl. 4.6 Help!
- Motorcraft oil Who makes it ???
- Question on New Gauge Installation
- major problem
- I think I've got the "Slap"! Need help.
- Engine Moans at 1100 RPM
- squeak Squeak!
- removing carbon deposits
- Spark Plugs
- 5.4l enough motor?
- spider gears
- Compression test
- how much $$$ ?
- Towing??
- K&N FIPK from 99 4.6 to 01 5.4
- to those that removed the coved on the MAF post
- deal or not?
- Great fuel line/filter tool!
- Help! 99' F150 won't start/or even turn and radio dead
- Which Wires?
- Chevy Silverado SS!!! Must read and REPLY!!!!!!!!!!!!
- L heads and SC for 5.4
- Snap, Crackle, Pop in Engine Compartment
- funny engine noise
- You Don't Need No Stinking Ram Air!
- K&N Pre-Charger/Outwear
- fan shroud
- 5W-20 or 5W-30?
- Another MPG posting...
- Electric Pedals Creep Back
- Tornado fuel saver
- Where's my rig?
- code scanners
- My Cheap Plastic Gas Peddle Broke!!!!!!!!!!!!!!
- Fumotovalve torque specs?
- engine oil consumption update
- Valve Cover Leaks
- Lev??????
- oil leaks
- Any 99/00 owners thinking of getting 02's with these deals?
- Engine?
- screech when accelerating
- Does anyone have a spec sheet for....
- towing capacity
- Low RPM HP
- engine
- Omg, Iac, Wtf?
- Help! Leans out at 3000 RPM's!
- Knock Knock, Ping Ping who's there?
- Check Your Six (spare)
- Gas filler pipe overflows...
- Front end rattle?
- What is wrong???
- oil? on underside of hood
- Know of any F-100 Sites?
- in tank fuel pump
- Does 98' 4.6 have a barometric sensor?
- Valvetrain noise.........
- thermostat
- someone teach me about pistons...
- Lightning motor in mustang
- O2 Sensor
- lightning to regular f-150
- Which oil works harder
- Airbox Mods
- Diesel V-6
- shuddering
- New Guy with pinging 4.6 engine
- Oxygen Sensors
- Porting Throttle Bodies
- Nedd Some Help
- Bosch Plat. +4 Spark Plugs??
- 300 to 351W
- Low EGR Flow
- New Plug Wires, or Not?
- sept. 11 and real men
- 5W-30 "Bulk" ?
- 5W-20 in a '98?
- Slow page loading
- Engine dies when raining
- Engines, Gas Mileage and Costs
- Larger oil filter wanted
- 2001 Off Road Expo PICS
- oil pickup tube hitting??
