- 4.6 Misfiring: Clueless: Help Needed!!!
- how do you rate the 4.6
- computer code
- moaning noise after intake install
- Is this normal for a 2001 F150
- Gas Mileage
- oil level
- Ordering new - Can I do 4.6 w/ LSD?
- Fumoto Drain Valve
- Remote Filter
- Vehicle inf. from VIN number.
- Choke?
- What fluids to change & when???
- 5.4 Head Gaskets
- Air force 1 filter replacement
- Want to add Headers
- Starter doesn't engage
- 5.4 Rear Main leak.
- Obd-ii
- proper engine break - in
- F150 4.6L engine surging/drops out of overdrive
- Still a chance on piston slap.
- Replace belt driven fan with electrc unit
- removeing intake silencer, + air box mod, anybody do both?
- airforce One Installed
- water pump blues
- stupid fuel filter tool
- now i'm leaning towards the f250 power stroke
- A question about factory moonroof
- Thanks To All
- Where is the silencer in the air intake?
- Aftermarket oil pan for 5.4?
- Engine Belt
- Airforce 1 maintenance
- 5.4L Water Jacket Question
- Need help!!! --'99 5.4L SOHC -- Gettin' to the plugs
- Tsb for 5.4 head oil leak
- Ticking noise when rolling?
- No Start Condition
- Chip Or Programmer?
- Please Help!! I need opinions...
- Air Compressor
- Good or bad idea splitting off to true dual exhaust
- Which side is bank 1 ?
- O/T Brake Controller in Engine Bay
- Question regarding Tune ups
- Where to begin?
- 4.9 oil pan questions
- 5.0 to 5.4 swap
- engine light came on. whats the deal?
- How I Wont To Die
- Dodge
- 460 Cid
- sparkplugs
- Painting the plastic in the engine compartment?
- Would like aftermarket oil cooler
- 2003 cobra
- Improved do it yourslf fipk
- Maf Sensor Mod
- 97 5.4L, eating oil WTF?
- 300 C.I. (straight 6) What do you think of the motor?
- New engine for the Screw
- battery or belt?
- tachometer
- After Market Warranty
- traction bars
- Engine Oil Cooler
- what to do with $450. please help.
- High performance heads on `99 5.4??
- spark plug wires???
- Wish List from Ford
- 5.4 vs. 4.6
- 5.4 enough?
- MTBE & the future of gasoline. IMPORTANT
- 5w-20 oil info.
- Coolant Change
- TFI recall
- rebuild 4.6 or swap to 5.4?
- What works best to clean and shine engine compartment?
- Shock Advice
- Need input for aux oil cooler install
- Any advice??? Truck is in with a leaking head gasket.
- ?? for Neal
- how long before tightening?
- Rough Idle 5.4
- Upgrades
- 1994 5.0 Throttle return spring ?
- New TSP, now wont change gears right
- Does Piston Slap still occur? Are they still replaced when it does?
- I got kicked out of the Pinger's Club!
- Need Info. on Triton Engines
- 5w 30 or 10w 30
- AMSOIL 2-STAGE air filter
- AF-1 with winterization?????
- tune up
- 4*4 track times
- TB mod. / replacement???
- Coolant Replacement
- Is occassional ping normal operation??
- Check engine light on @18k
- Performance Upgrades for 4.6 modular engines?
- 89 F150 5.0 EFI misses above idle
- New engines for 2003. Can someone explain what they mean?
- Oil Filter Tightness
- Need to change coil & spark plug
- This time I need some help...
- Metal Chips in oil
- New Coil Packs
- air box and maf mods
- Need Headlight HELP!!!
- Anybody watch the Winter Olympics
- Instrument cluster ?
- Gas filter tool
- f250hd check engine light
- Which Is Stronger??
- New computer with new motor?
- engine miss @ low RPM
- Hey White Elephant, I tried emailing you about your pinging question,
- 4.6L Knocking
- Ideas on what to do with my 'old' radiator?
- Track times??
- high idle at start
- my Ford 360
- Dekstop Dyno
- #2 Coil Pack Out 3kmiles after replacing #4
- 2002 Supercrew 4X4 4.6L Oil leak
- Oil consumption in Chevy 8.1L
- Insulation on underside of hood?
- NEAL!!!! I need your help!
- underdrive pulleys ??
- Air filter kit?!!!
- Head Leak, what's the date of the engine?
- Check engine light came on flashing?
- Lightly modded Excursion running 15.2sec 1/4
- PKRWUD where are ya?
- Chinese Proverbs
- Rebuild info?
- How Much For A Wreck??
- Oil Leak
- airbag is a no-show
- thought y'all might wanna see what a 300 hp 5.0 looks like ..lol
- Help, ignition is crossfiring
- Do Radiator Fans work
- My new F150 made it one week...
- CONS of FIPK???
- Underdrive pulleys & Electric fans
- Headlight adjustment
- fuel sender open circuit
- Rough Idle Corrected
- Help, Code P0302
- Search engine down, need some info on Elec. fans.
- Bye Bye K&N
- JBA headers
- I'm back again
- Best way to clean coolant out of cylinders.
- I wanna be like Neal!
- power steering noise
- The heck w/ a 5.4L
- gas hose?
- Vibration in gas pedal
- How to tell build date of truck/engine?
- forged pistons crankshaft?
- When to change oil filter?
- oil filters? What do you use?
- Setting TDC without the crank pulley
- Speedometer & underdrive pulleys
- 5.0 vs 4.6 vs 5.4
- Extended Warranties Not Ford
- Bad news for the synthetic cult!
- Heater Problems on 95 F-150
- Ethyanal Gas, Good or Bad
- 5.4 question
- 89 F150 inline 6 cyl.
- runnin w/o tailgate
- Do I change 1 head or 2?
- How often do you change oil?
- 4.2 question...
- turbo or supercharger
- Cleaning Idle Air Control
- How hard to hook up oil pressure gage
- Does anyone have any experiences with Auto-Rx engine flush?
- dies after starting / rough idle
- Coolant flush ???
- Chilton CD Rom Q
- Not too happy with Amsoil
- Nothing but hot air . . .
- when is it time to replace plug wires?
- 4.6 swap to a 380hp 5.4 ?
- Didnt know where else to put this, but I need advice
- Ratatat tat How about that thermostat?
- Diesel 150?
- smells like silicone?
- Wrong Engine Oil
- tachometer install help!!
- Stalling on freeway
- Spark Plugs and spark plug wires
- 360/390 Vacuum lines
- Failure on coil pack #4 - info needed
- What is Ford's response to common problems?
- Any one put a 4.6l in an 85F150
- Remove spark plug and coil.
- 5.4 and 4.6 heads the same?
- Oil Pressure/Pump Question
- remote oil filter line leaks
- engine swap outs
- Gas mileage..
- Phenolic TB spacer? (NOT the darn Poweraid...)
- Any Tips??
- Castrol Syntec VS Mobil 1
- Fuel Milage
- My 92 has a miss
- loud clatter at idle
- New Motor Cold Knock
- Zex Nitrous Kit
- Sick 4.9L
- antifreeze smell
- Price paid for spark plug wires!!
- Help !!!
- Rolled over 50K now what?
- Surging at stoplight
- 4.6l Oil Leaker
- Error code 653?
- 5.2 vs 4.6
- WARNING for all FIPK owners
- Magnetic drain plug
- Engine Noise!!! GRRRRR!!!
- puff of smoke?
- ? Lot of rattle on start up?
- Bought Autolite Platinum Pro Plugs, which wires to buy?
- V-10 Swap in F-150???
- 1993 F150 Xlt 4x4
- Coolant Capacity with New FOMO Radiator
- F-250 more hp?
- Nowhere
- Big Engine
- Synthetic Oil
- Check out this virtual dash.
- grrrrrrrr
- 538 code
- When should I replace the EGR?
- Bad milage drop.....
- Granatelli MAF for 4.6?
- How do I know...
- Punctured Radiator!!!!!
- Airforce 1?
- Dealer Put In Free Engine Same Problem
- When to change Oil the first time.
- 4.2l running lean?
- engine spec
- query on '93 5.8 Liter
