View Full Version : Engine
  1. Diagnosing electrical problem without check engine light - HELP
  2. cruise control..
  3. new owner of 133k 97 scab - nuts or what
  4. Power Improved heads? HP gain?
  5. Underdrive Pulleys....price?
  6. what is the best engine
  7. Tachometer redline
  8. Anyone read USA today yesterday: might explain pinging...
  9. Timing Chain 5.4
  10. Diagnostic Trouble Code 5284
  11. gears and gas mileage
  12. 3.73's and a chip I guess..
  13. Getting ready to drive cross-country..
  14. New owner, Ugly engine parts!!!
  15. Plug wires
  16. Help-Engine performance
  17. O/T 460 V8 Questions?
  18. squeak when cold
  19. fuel in the north
  20. Sefi
  21. noisy fuel injectors
  22. 5.0L vs. 3.0L
  23. 8 spark plugs on a 4 cylinder ranger?
  24. Changing the Belt
  25. Crank Pulley Help
  26. Oil Change Info
  27. changing engine from v6 to v8
  28. battery light flashes with acceleration
  29. opening up the air box
  30. what is the best supercharger?
  31. 14's in a new 5.3 chevy
  32. harmonic balancer / serpentine belt pulley
  33. 4.6 performance
  34. 1997 4.6 uses oil
  35. Royal Purple Products
  36. clicking
  37. Knocking
  38. engine sounds hollow
  39. O2 sensor
  40. Reset the ECU
  41. poor mileage 4.6
  42. Piston Slap and Lemon Law
  43. Check for limited slip 3.55
  44. Fast and the Delerious?
  45. 3.73s or 4.10s
  46. Reoiling K&N Filter
  47. Underdrive Pully
  48. Any one know Alt amps?
  49. Short Throw Shifter
  50. Tachometer
  51. Fuel Mileage
  52. Engine Code 1131 Need help
  53. Iridium Plugs????
  54. Dual Electric Fans
  55. New Owner!! Noise Question.
  56. Cobra water pumps,
  57. Lightning motor in MY F150
  58. Need help with speedometer gear install
  59. ? about 5.4L and rear axle
  60. Oil Additives
  61. 4.6L w/ 3.55s or 3.73s
  62. rear diff changing
  63. AOL post about oil changes
  64. Where are the EGR and IAC valves???
  65. Oil Capacity - Ford Spec.
  66. Quick question - engine rattle at 1600rpm
  67. '98 4.6L died
  68. Canadian Fuel
  69. cooling fan question
  70. Oil capacity for 99 5.4
  71. how often in adding Techroline
  72. High Performance Oil Filter
  73. Neal...
  74. bored 30 over engine help
  75. Engine Ping fix for my 4.6L V8
  76. STP valve Cleaner??
  77. 5.4 Cooling system failure
  78. Squealing Found!
  79. Alert!!!
  80. Throttle body
  81. Engine HP
  82. Freakin Oil Change
  83. 5.4l
  84. 2002 Explorer V-8
  85. F150 vs the "other" three
  86. Why does MN4x4 drive Chevy!!!
  87. South Padre....lots of fun...lots of gas!!
  88. Oil pressure fluctuation radical
  89. spark plug change on 5.4
  90. Engine problem...HELP!!
  91. idles ruff
  92. ?'s on adjusting Throttle Position Sensor
  93. Best plugs, wires and coil???????????
  94. Strange noise at warm idle. HELP!!!
  95. 30,000 inspection @ my local goodyear
  96. Where to buy Hayden E.F. control unit?
  97. Oil In the Airbox
  98. Check engine light
  99. please help
  100. Horsepower?
  101. electric fan?
  102. Knocking 5.4L Help!!!
  103. new thermostat
  104. Supercharged 4.6 V8
  105. Rattleing noise in drivetrain.
  106. changing sparkplugs
  107. Can't hit full boost?????
  108. Spark plug swap on a 5.4L
  109. engine trade
  110. ELectric Fan Wiring Help!
  111. Dual Electric Fans
  112. Changed Belt, Strange
  113. Where do I buy Cd-2 Engine Cleaner?
  114. Which FIPK is best?
  115. Fuel Filter
  116. Quaker State Synthetic
  117. Oil Change documentation for self maintenance.
  118. HP Question
  119. Mitch150
  120. Swaping engines
  121. Air Force One HP increase
  122. What temp does you're engine run at?
  123. 4.6 pingers need to read this bc i don't get it.
  124. Check out this truck
  125. mac air system? or extra for air raid ect?
  126. What Gas do you like?
  127. preffered gas grade
  128. TSB Oil Leaks - Head Gaskets ???
  129. misfire problem
  130. Anyone ever seen a writeup on the piston slap problem?
  131. Lift the cab to change Valve Cover Gaskets?
  132. Oil Pressure Guage intall?
  133. Cylinder Heads?
  134. OBD 2 code P0300 Random / multiple cylinder misfire
  135. Chev 5.3 versus Ford 5.4
  136. 4.6 vs 5.4 mpg & reliability
  137. Question on Slick 50
  138. FA1634 or FA1632 What is the difference
  139. check your fan bolts
  140. throttle body build up
  141. The Dealer forget to tighten my tail shaft...
  142. Mustang motor swap in..
  143. Bad gauges or what?
  144. F-150 spark knock problem
  145. Hp from bolt ons?
  146. 4.6L and 5.4L head gaskets
  147. Bad misfire at 55,000 miles.
  148. Diesel V6?
  149. Changing 4.6L to 5.4L
  150. synthetics?
  151. why only 10mpg?
  152. Build up on Spark Plugs
  153. Firing order of the 5.4 engine
  154. What to do with $800?
  155. Weird Idle At Startup
  156. horsepower ???
  157. A/C system not working properly... ?
  158. Black oil inside throttle body
  159. Foam Air Filter
  160. 5.4l Piston slap
  161. Thinking of replacing/rebuilding the engine
  162. Ticking Noise in engine
  163. new radiator question
  164. How much power can I get?
  165. '98 F-150 piston slap woes. Need Help!
  166. which oil filter?
  167. Quick!! Please help - Need firing order for a 302 in F-150
  168. Oil Sender problem
  169. ECT problem? looking for insight
  170. I am new here, just got a 91 F-150 w/ a 5.0L
  171. 7700 lb. GVW radiator
  172. Fuel additive gone wrong. Please help!
  173. for any of you guys who have aftermarket headers
  174. Fuel System Cleaner??
  175. Love my Truck, Hate my Dealer
  176. S.O.S. to Neal "the HP Freak" Newman
  177. 1998 Romeo; clogged cat. converter or "Hydrostatic Lock"
  178. Moaning sound after engine is shut off
  179. Rough start-up(cold)?
  180. extended crank on f-150
  181. ported and polished
  182. Exhaust Steam
  183. Diesel in f150 for 2003
  184. Will this work??
  185. Realistic Maximum Trailer weight
  186. very bad smell
  187. Do I have Limited Slip?
  188. Very weird vibration/shake at 40mph
  189. Fuel Pump, Need Help
  190. Blower motor
  191. Misfire cylinder #3
  192. Now available
  193. 5.4L head gasket oil leak 2nd time
  194. Royal Purple Full synthetic
  195. What Oil Should I Run
  196. Diesel in Gas engine
  197. K @ N Air Cleaner Voids Warranty
  198. Carb./carb. intake for late model engine?
  199. Engine Swap
  200. fan clutch
  201. Need K&N filter part # on K&N FIPK
  202. Electric Fans Should I or Shouldn't I
  203. charging problem
  204. F150 Engine Swap
  205. Service Engine Light
  206. Mass Air
  207. dual exhaust?
  208. horsepower?
  209. Horsepower on triton V8-5.4 liter?
  210. fuel milage loss with air box mod
  211. Discount ESP Dealer
  212. Replacememnt Oil Dip Sticks
  213. What size engine did the 97-98 F-250 have?
  214. were can I find complete tsb for my truck?
  215. 1992 F-150 No compression on # 8
  216. 5.4L Oil Consumption
  217. "Bucking"?
  218. Engine compartment cleaning...
  219. WTF is up with my F150!!!!
  220. spark plugs, interval for changing?
  221. Oil change troubles
  222. 3 MON or 3000 miles, Which one?
  223. Where was my 4.6 built???
  224. Maf
  225. Wicked Squealing At Start-up
  226. Rate Your F150 By Year
  227. throttle bodies
  228. New Radiator?
  229. Are The Triton Engines the Quietest?
  230. Looking to get an SHO
  231. truck dies when coming to a stop-HELP!
  232. could i have messed anything up??
  233. Colored Engine Hoses
  234. Head Gaskets 5.4
  235. Whats wrong with my truck ?!?!
  236. Please Help with Noise
  237. Does anyone know?????
  238. Superchip and FIPK
  239. Has anyone recieved there new radiator?
  240. Tap at start
  241. Bad noises from my 4.6
  242. K&N plug Question???
  243. increased performance
  244. More Horses
  245. spark plugs
  246. 5.4 Liter #6 - No compression
  247. power steering leak
  248. Headers?
  249. Oil pressure glitch
  250. Gas mileage
