View Full Version : Engine
  1. turbo
  2. Gears....
  3. Pusher or Puller?
  4. new engine noise on high mileage 4.6
  5. What's Hydrocracked Oil
  6. "SLOW" Motor
  7. missing when warm
  8. Does anyone race their F150?
  9. TPS question
  10. Calling jefflaws, EGR problem
  11. HELP - truck a no-start after driving fine today??
  12. plug wires mystery solved 4.6 mustang v.s. trucks
  13. egr system?
  14. Is this an error code?
  15. big engine prob
  16. Clicking noise in new 5.4
  17. Camshaft Position
  18. Whining Noise with warm engine....
  19. S'crew gas mileage?
  20. OBD/Scan Tools
  21. mid range miss
  22. Help don't know where to start!!!
  23. Dealer 1st
  24. Wierd Hissing Sound
  25. Timing question
  26. Electric fan kit for Sperduty?
  27. how much do these mods cost?
  28. engine stutter in 2001 5.4
  29. From Mobil 1 back to dino
  30. Timing
  31. Spark plug wires???
  32. Ford techs please
  33. Please Help Me
  34. Engine Emblems (ex.- 5.4L or 4.6L)
  35. Jl Intake Box
  36. anybody been through the head gasket leak problem?
  37. Where can i get Techron fuel treatment?
  38. Odometer information - how to get to the diag mode
  39. 5W20 oil
  40. This is cool
  41. 5.8 to 5.4... why?
  42. Camshaft swap?
  43. Flex-a-lite rocks!
  44. Over Head Cam Or Pushrod
  45. cobra heads
  46. What are some good mods?????
  47. Oil specs (lord, I really don 't want to start this again....)
  48. 5.4vsV10
  49. 99' 5.4 Stuttering, shuddering, missing, hestitating
  50. CMP Sensor Malfunction
  51. How to get TSB info????
  52. engine ping
  53. Ford to unveil new diesel motor and Excursion SUV
  54. oil pressure gauge
  55. Where are the plugs on my 5.4??!!
  56. Love my new truck
  57. code 311
  58. "Leak" search = 690 Engine topics?!?
  59. 4.6 vs 5.4
  60. Battery Dead After 2 weeks of sitting?
  61. 5.4 super crew Dead engine
  62. Glad I have the 5.4!!!!
  63. Time to Supercharge
  64. changing oil pan on 5.0
  65. 5.4L idling problem
  66. not shifting correctly
  67. engine is missing
  68. oil pressure switch
  69. GRRRRR.....JBA header won't line up!!!
  70. towing package parts
  71. V6 Needs More Power
  72. K&N Filter Question
  73. whining noise under acceleration
  74. Plugs lost their poop
  75. what happened to being built ford tough
  76. SEAFoam?? What and why?
  77. Anyone replace a waterpump on a 5.4?
  78. Are those CD shop manuals on ebay any good???
  79. Rough Idle, Motor Mounts?????
  80. idle problems
  81. Trailor Light Hook Ups
  82. 460ci engine won't start. Please help!!
  83. Anyone Replaced Their Own Fuel Filter?
  84. PI intake manifold
  85. Oil Filter Relocator kit
  86. Just bought a 1998 F-150, need help...
  87. 99 HP increase
  88. need some powaaa here!!!!!
  89. Thinking of pin striping my black s/c any ideas on color of stripe
  90. Heater Core Help???
  91. Mobil 1......Super syn vs Tri syn???
  92. engine swap
  93. Engine Help
  94. I Wanna Mac!
  95. Under Drive Pulleys
  96. which is the best...?
  97. Solving the rough idle problem!!!!
  98. top speed limiter
  99. New, and need some help
  100. ford replacement motor
  101. MAC intake
  102. 01 4.2 Leaky Head Gasket...info needed
  103. more HP on an 88 with a 302
  104. Dual 15 inch blades?
  105. Simple Green
  106. Brand new '02 4.6 turns over, then immediately dies ??
  107. Good 1/8 mile time....
  108. Pi Heads
  109. serpentin belt
  110. Need advise
  111. Hey "Home Skillet" ? for ya!
  112. Building a new 5.4 for power...
  113. Do all 5.4's sound like a diesel????
  114. Fuel brands, mileage, and engine cleaning...
  115. Anybody found a fix to this valve clatter problem?
  116. 0-60
  117. Got a new MAF today.
  118. How to tell if you have PI heads???
  119. "Intake Manifolds" are coated with oil
  120. Neal and other Modular motor guru's get in here!!
  121. 3 valves for the 5.4....
  122. Head Gasket TSB
  123. ?
  124. 5.0 L Water Pump R & R
  125. Any trouble with straight pipes?
  126. Valvoline Screwed My Thermostat Somehow Help!!!
  127. engine codes
  128. Interesting
  129. Which order should I do this in?
  130. Amazed at K&N filter...
  131. JET NON PERFORMANCE Module for my 1999 5.4 VERY Dissapointing!!
  132. goin from a 300 6 to a 400 v8???????
  133. Texas Emission Test
  134. Racing in the 5.4? Remove Spare?
  135. Stumped !
  136. Startup tapping, oil filters and so on.
  137. Disconnect fuel line from rail
  138. Newby Tow package retrofit HELP
  139. Air Filters
  140. K&N Filter Question
  141. I killed my truck - no longer starting
  142. Where to find Lightning Long block crate engine?
  143. Problem, not sure how to explain it...
  144. Gas/Fuel ABG vacuum line
  145. best mod
  146. Relieve pressure in fuel rail
  147. overheating '97 4.2 auto
  148. Noise when turning into a drive way
  149. Spark plug wire suggestions??
  150. How do you find out the "Inservice" date or the date your truck warranty started if y
  151. 97 F150 5.4
  152. 75 Mm T/b's
  153. Noise in 97F150 5.4 EGR valve
  154. Fixed- Buzzing under dash 97F150 5.4
  155. Engine knocking on startup - should I ignore it or make Ford fix it.
  156. Thoughts on CD-2 Engine Cleaner & Detailer
  157. Repair manuals for Superduty
  158. Where to get MAC Air intake?????????
  159. Vacuum noise when in drive and not accelarating
  160. Fossil to synthetic...Synthetic to fossil
  161. Oil TSB
  162. Low power at hot outside temps
  163. engine sensor mod?
  164. MAC fipk
  165. control box under bed?
  166. I have the lemon of all lemons...
  167. Goodbye and No Thanks!
  168. Poor 5.4l performance :(
  169. Ram air or open element?
  170. 1996 5.8L Ignition Problems - Fails to Run
  171. If you've used a "teflon" additive, don't use Amsoil oil?
  172. Adjustable FP regulator for 4.6
  173. What oli do you guys use?
  174. 1988 F150 Fuel Pump Problem
  175. MAC Intake Performance System
  176. How to check A/F ratio?
  177. Surge at idle?
  178. truck wont start
  179. K & N Breather Element
  180. Improving My F150
  181. '99 5.4 missing then quit?? HELP?
  182. 89' 460 ---Severe Knock & Ping Problem
  183. Fan Clutch question
  184. Idles very high
  185. My Baby Has Piston Slap!!!!
  186. Prepared
  187. F150 Problems
  188. Please tell me what to look for before i go for warranty work.
  189. P.O.S. Truck in shop for 5th time
  190. I smell antifreeze... plz help
  191. 93 Octane
  192. nitrous
  193. AC/Fan Problems
  194. intake kit ?
  195. Maintenance costs...
  196. Warranty Almost Out - What Problems Should I be Looking For?
  197. Idle Problems
  198. Please help...Rough Idle
  199. serpentien belt
  200. Rear End Id?????????
  201. Big Problems with my truck
  202. to reset or not to reset
  203. jl (johnny lightning) address?
  204. Error Code?
  205. Synthetic 0W30 Oil
  206. Stutter at WOT
  207. Hour Meter Location?
  208. Powr-flo Air Filter
  209. what are they doing about the 5.4L engine leak???
  210. Can you replace a 4.6 with 5.4?
  211. Knocking
  212. Finally ready for a Superchip
  213. Throttle body spacers worth it on 5.4
  214. metallic chattering??
  215. High Quality Stainless Gauges
  216. Is Mazda Ford?
  217. Starting problems.
  218. Running ruf
  219. Ford to trim content of next gen F-150
  220. Neal!! I found that %#@*!! Leak
  221. engine problems
  222. Check Engine Light Is Now On. How Can I Tell What It Is??
  223. Thermostat
  224. what tranny comes with a 5.4L?
  225. Wuh Duh Fuh!!!!
  226. Mobil1 15W50
  227. Changing to a vacuum advance distributor
  228. Idle Speed Screwy
  229. 5.4 Spark Plug replacement
  230. factory imposed power delay
  231. Ram air set up
  232. What Is This???????????
  233. what's your opnion about amsoil, how does it work for you????
  234. Truck stalling-Please help!
  235. blinking check engine light
  236. 5.4L and Bosch +4 Sparkplugs...
  237. Thermostat
  238. O2 Sensor
  239. Rumble at take off rpm
  240. Mobil1 0W-30
  241. Throttle Bodies and Cams
  242. Help...will not hold idle...
  243. Acceptable mileage???
  244. Fuel Guage
  245. Aftermarket Lighning parts on a normal 5.4
  246. Tune Up
  247. Fuel pressure regulator. What will it do?
  248. Pinging solved??
  249. Serpentine Belt Question
  250. My truck is a P.O.S.
