- Help!, big problem with my spark plugs
- AC Compressor Noise
- burning oil
- 4.6 in Grand Marquis... really...
- Check Engine Light
- 5.4l sucks!
- Engine wont start
- Newbie with a question...
- HP loss at higher elevations...
- Twin Turbo on a 4.6
- Is It True?????
- fuel line connector
- Stumble during acceleration
- engine exchange
- Ford stroker crankshaft kits..
- Cuts out @ 40 to 55 mph
- Vacuum Reservoir is popping
- Check engine light on
- converting 4.6 to 5.4
- MODS galore!!
- Nitrous for Non-L's
- Attention S.Crew owners: please help
- PI Heads...what are they?
- Code P1131
- High idle
- throttle cable?
- Occasional Rough Idle...
- Has anyone seen this?
- 331 stroker kit
- Engine Temperature
- AC loading
- Just installed a cold air kit
- Question for those with FQR's?
- missfire!
- 5.4 noise
- oil on spark plugs
- HEC switch?
- radiator noises
- Oil Film
- Very Low idle
- Flushing cooling syestem
- wheel discoloration
- accelerator pedal vibration
- f-150 supercharger
- What should I use...?
- 5.4 or 4.6?!?
- Anyone have pics of the IAC valve?
- 5.4L ignition coils
- Need help replacing fuel filter!
- Ticking Noise coming from the Passenger side of the motor
- 2003 Expedition 5.4L
- Braking Distance
- what if...
- homemade FIPK?
- When to drive in 1st, 2nd, etc...
- What does it take to change spark plugs?
- Wrong Radiator
- Code 174
- Rough Idle after cleaning engine
- Rumors of 5.4L Recall??!!
- head problem ,coolant?
- Extended Warranty
- Replacement Filter ?'s - K&N / AIR RAID etc..
- Anyone ever used "fail-safe" cooling?
- What to do first
- K&N FIPK Compatibility
- Plug Wires
- 4.2 engine swap to a 4.6 or 5.4
- no spark on 89 6cyl
- Off Topic-Price on new truck, what do ya'll think?
- Coil & spark plug changing.
- My truck won't start, and I bought it today
- Which ignition system?
- Odometer diagnostics
- I was having fun, but my Truck now has a miss.
- Air Intake Kit
- What exhaust manifolds same as 88 302?
- My darn smog
- Which Octane Gas?
- code 304
- 4.6 code FOU1 finally started knocking at 60K miles!
- Crank Case Filter
- High mileage 4.6 97 4X4, mpg excellent
- 2.3 Turbo question
- Going to drag strip, any harm?
- loss of power in my 97 f150 4x4 4.6l
- Msparks...What about Prolong???
- Black box?
- How to locate the cause of "that noise"
- Which Spark Plugs to Buy??
- replacement engine due to piston slap
- 1978 Mobil 1 Advertisement!
- 4.2 L cam position sensor
- Engine Modificaton
- Coil Packs
- Question for those that have installed dual electric fans.
- Service Engine Light
- Last 3 analysis 97 F150
- What is this ticking noise from??
- Remote Oil Filter Installed With Pictures
- Lean on Left and Right Banks
- how do you find out your hp?
- V6 Explroer question
- engine code 1443
- Resetting Check engine light
- 5.4 How do I know?
- 4.2 longblock
- Combustion Chamber Cleaning
- 1998 5.4L High Idle
- Heater core replacement...
- Bad news for K&N
- Oxygen injection?
- Bronco engine swap
- Gas oktane
- Question on dashboard removal
- 96 to 89 owners - how long are they lasting????
- swapping 4.6 for a lightning,HOW?
- Changing the fluid's in my 150
- v6 mustang Question????
- P1147 Diagnostic code help
- JBA Headers
- Haynes or Chiltons?
- How the heck do you get this lousy thing off?
- Natural Gas V8???
- intake and head swap for a 99 4.6
- Intake Theory????
- My V8 was a V6 more than it was a V8
- 4.0L V6 firing order
- Rear fuel pump
- Recommend someone to re-finance?
- 75,000 Mile Service
- K&N FIPK installed!
- Still no cure..4.6 knocking
- is it possible to pull the check engine light codes without going to the dealer?
- In need of help.
- lightning engine in a reg truck
- Pulleys and what they do....
- L6
- Still Looking
- Motor sat for 3 months.. have questions
- Warrenty Question??
- V-6 Diesel may be out by 2005!
- FIPK and intake temp
- HO2S Sensors
- What to learn more about Oil and Lubrication?
- For xl owners
- What warranty to get?
- oil issues
- engine oil leak
- Check Engine Light Came back on
- Clunk noise 5 seconds after startup??
- Top 10 reasons to own a CHEVY
- Engine bogging down, loss of power.. Need Advise!
- Electric fans on at what temp
- Camshafts
- Nitrous yes or no?
- Maybe distributor problem
- sources and prices for plugs/wires
- Gene Louder's prices???
- Another Question of Storage
- PPI Duel fn Kit
- Firing Order
- EBAY Intakes
- Mass Air Conversion Kit????
- lightning engine
- Stupid question on oil consumption
- Problems, Help
- tornado
- 92 mustang motor to a 88 f 150
- Gas filter, cleaning injectors
- Remote Oil Filter Mount
- radiator / engine fluid temp gauge
- Rough Idle question... tech help needed...
- engine longevity
- leaking heater hose
- Redline for 5.4L?
- These engines really suck!!
- Raced a GT (to 60)
- are all 351w's the same?
- Gas v/S diesel
- trucks shakes while idling...
- Code 401
- Testing picture
- Terrible Engine Miss, HELP!!
- Resetting the computer
- Helix Power Tower
- re-beat a dead horse
- AJRAGNO.......Help!
- common causes for CEL?
- Door Cracks
- Some 5.4l 20-50mph run videos..
- Racing an MR2 tomorrow...
- Ringing Sound
- Driver side door RUST!!!!
- Getting a new truck...which to choose?
- Code P0301Cylinder Misfire
- Removing Fan Clutch: Left or Righthanded Thread?
- New coil for a '94 302 engine, what to choose ????
- Synthetic blend in a new engine?
- 4.2 L V6 removal issue
- Which Oil????!!!!!!
- 5.4 throttle body
- 5.4 Triton Rebuild
- Major Tune up time questions
- What oil to use in a 5.4L?
- Fuel Mileage Drop Off?
- CHIP or No CHIP??
- Almost a catastrophe
- what are the disadvantages of having underdrive pulleys and electric fans installed?
- online performance shops
- 5w-20 Centistroke Viscosity
- Need advice on purchase of 97 F150
- how do i change the pcv valve
- Help
- Electric supercharger
- 5.4L noise
- testing ignition coil
- Truck Storage
- Quakerstate 4x4 oil anygood?
- Engine Swap
- Denso IT16 Vs. IT20
- A little survey for clutch pedal squeeking when you push it to the floor.
- Like a Rock
- EGR Troubles
- Fan Clutch replacement
- Sluggish 5.4--Intermittant
- Anyone tried lowtemp t-stat for pinging?
- Warrenty Question
- Best oil filter removal tool?
- just won't start
- FREEDOM FORD IS FULL OF CROOKS! major vent
- mountaineer 5.0 awd upgrades
- cylider#4
- what oil you runnin' in a 4.6??
- not getting cool air into engine
- Heater Hoses
- Intake
- best possible HP #'s without a supercharger
- Help! Trouble Code P0442: Evaporative Emission Control
- 302 rebuild w/ a HO351 Cam ?
- Mustang GT 4.6 vs F150 4.6
- Can't get gas
- Fuel Gauge Problem
- Engine Swap
- Just bought truck...advice?
- The Idle talk again
- 0-100 Km
- If the dealer hooks the computer up to my truck
