- Rough Idle?
- V6 to V8 swap?
- leaking sending unit?
- It doesn't sound good for the V-6 diesel!
- Amoco or Texaco? (P66 or Conoco?)
- 120,000 miles, any advice?
- returnless fuel systems.
- 7.3 & 6.0 litre TD units
- O2 sensor location?
- Cheapest place to get WMS Velocity Tube or similar?
- Motorcraft 5W-20?
- 5.4 Internals..
- This clicking sound is pi$$ing me off!
- power steering
- K&N or FL820S ???
- What is the proper idle rpms in gear?
- anyone getting rid of stock airbox ??
- What's your average speed?
- How's your 5.4 doing?
- Block Heaters
- please help clarify head gasket on 5.4
- Loss of power and acceleration
- 4.6 plug change
- engine dies
- 1995 5.8 questions
- Not a K&N or Lucas problem
- Ebay intake with stock MAF housing & airbox?
- Engine Code PO455
- Head Warp?
- Increase Gas Mileage/HP
- High idle after decel w/no throttle movement
- Throttle Body Cleaner
- What is the lowest temperature thermostat I can safely use?
- cold air intake sensor? (on ebay)
- What do you guys think of Trans Co
- '99 F150 5.4 Service Engine Soon
- Belt chirp on first start
- L motor
- 1990 5.8 L for towing
- Ebay intake kit question?
- 1986 water pump schematic
- Where to get intake tube? Vaccume hose question?
- How many quarts?
- Fuel Master Installation
- Engine Power Curve for 1990 5.0L V-8
- Not Happy With Chip
- No Tire Spin
- PI heads Swap
- Any Other Folks Happy with Their 4.6L?
- Dyno testing in San Diego, CA.
- 1999 F-150 5.4
- MAF Question
- rev limiter
- EGR (EVR) Solenoid??
- whistling intake
- Superchip ??????
- Valvetrain problems?
- misfire
- coil packs
- error code 0174
- Decarboning engine ??
- Lack of 60mph power 4.6
- how do Iclean MAF sensor?
- Mobil 1 anti-return valve problem
- Ok guys,Screw or S/C,Pors and cons please!
- Help . . . truck falling apart?
- Odo DTC code
- Loss of power in Higher Gears
- Good ODBII Scanner???
- Fuel Pump
- On The Seventh Day!
- DAMMIT i got pulled over AGAIN !!!!!!!
- Burping??????
- Installing #8 coil Pack???
- Ignition Coil/ Idle Air Control Valve
- Throttle body spacers any good?
- rotten gas mileage
- Markmizzou-------->
- Need info on 1977 4.2 engine recall!
- Engine Overheating - HELP!!!
- V8 difficulties
- P1120 TPS Out Of Range Low
- 5.4 dohc swap
- Went over 5,000 mi. on oil change...
- 5.4L Spark Plug change.
- MPG Question
- Difference between 97/98 & 99- 5.4L
- Check Engine Code PO455
- I believe I have Pistion Slap
- What to do at 30,000 mi. service?
- i want my cel back!
- No Check Engine Light ????????
- Check Engine: insufficient EGR flow
- can oxygen sensor be cleaned?
- Dirty IAC at 32K?
- Air Box Replacement on 2001 Screw
- Strokers for Towing
- Brake pads.... which do you use?
- 97 4.6 misses at idle and in the lower RPM range
- Won't shift out of PARK
- Oil Pressure
- rough idle at start up?
- EGR code error---Bad Gas Mileage?
- Oil on the spark plug, wire,
- Oil Filter location change
- 1996 Dies after sitting for a few days
- How do you reset the computer?
- Speaking of gimmicks check this out
- difference between 2000 and 2002 throttle body?
- fast idle?
- Serpentine Belt & Tensioner ????
- F150 7700
- check engine lite..EGR Code
- steering noise
- Have clunking/dieseling sound????
- harley truck stalling
- Idle Question
- Engine wines in morning or when engine is cold?
- bad speedometer
- Engine/Exhaust? Noise @ Start-up
- My truck is Sick
- My 5.4 sounds like a diesel in the am!
- High idle
- thermostat questions
- Link to a guy who really knows his stuff
- Engine runs rough after sitting a few days
- tornado air intake
- MPG, computer/exhaust vs. heavy foot
- miss at about 3k
- Check Engine Light
- Royal Purple
- Spark plug changing emergancy!
- Billet Grille Need Help or Instructions Please!!!!!
- Install ?? for Plugs and Coil Packs
- deisel 150???
- Water in cylinder 8?
- Engine misfire on 4.6l
- Airbag light?
- frustrating 92 5.8 rough start
- Mustang engine: easy swap????
- Bad coil pack?
- abs light is flashing and shifter is stuck
- I used to think the 5.4l was fast...
- Knocking 4.2
- Got smoked by a ricer
- How much do you think its worth?
- Hesitation during hard acceration
- Beware, No Warranty
- Mobil Supersynthetic 0w30?
- Head Gasket Leak
- What Three Gauges Would You Choose?
- Handheld Superchips Tuner- YAHOOO!
- Heater Core or Head Gasket?
- Truck is in for the head gasket again
- Need help on mod?
- Radiator Hoses - HELP!!!!
- Which Engine
- 92 F150 Engine Swap
- 92 F150 throttle cable adjustment
- Airbag Code Flashing "32", Need Help
- 6.8L V-10 in a Expedition
- Any suggestions for auxillary oil filters?
- what is that steel tube
- Air Filters
- Help with Superchip
- Sparkplug wires arching
- Starting problem
- Question about Coil Packs
- K&N Upclose and personal
- Truck Stalled out.
- drove an 03 dodge 5.9
- Need help finding the?????
- Intermittent Slow Starting
- pcv valve
- Not all Fram Oil Filters are bad.
- MAF Removal
- Oil for engine,tranny,rear end Question
- What do they do with the old oil?
- Can't find the TSB for Sluggish in hot
- Oil pressure numbers...
- Battery & Idle Rpm
- Where ca I get this freakin part!
- 302 Intake selection
- Gas Guzzlers wanted (Habibi)
- Question about stock intake on 4.6L & 5.4L?
- Reflexxion Hood Intake
- Long Term Storage
- Loss of power
- Synthetic Oil's . . .
- BG 44K and Techron concerns
- Expedition 5.4 pinging
- Have you ever noticed?
- oxygen sensor
- Smoking after oil change?
- F-250 5.4L (99) starts but stalls right away...
- Chirp from backend on hard acceleration...
- Oil gauge bounces around at idle
- Don't mean to beat a dead cow, but...
- 4.6 and 5.4 emblems check them out.
- 308 stroker?????
- 4.6L missing as I accelerate
- What are plug torque specs for 02 5.4L?
- FYI Wal-Mart has Motorcraft 5w20 semi syn
- Why you should change your Spark Plugs
- 2000 F150 Coils Gone Bad
- Oil pressure warning light
- loosing power steering
- What type of coolant to use.......??
- Help! Hesitation
- does this work
- setting temp for electric fans
- Confusing eBay Auction
- 95 F150, Cranks but no start.
- underhood temperature dilema
- #4 coil
- RPM wanders in cruise
- belt tensioner
- All Lightning Owners - Help!!
- 302 runs crappy on cold mornings!
- ^&(%^$(^$(&*^%(*&%^()!!!!!!!!Belt squealing AGAIN!!!
- Please....Need advice for Pinging......
- This has me baffled!
- X Plan
- Mobil 1 0W - 30 Super Syn
- strange noise in '02
- 5.4 Problems
- electrical fires
- Which spark plugs
- Awesome easy engine swap!?
- difficulty starting
- '02 Screw, 4.6 Ping
- Fuel Filters
- uneven tire wear
- Important Question guys need help!!!!!!!!!!
- Is it synthetic blend from factory?
- 302 engine
- Poor Idle/misfires
- coolant flush/fill
- Engine Lobs at Idle, Needs Oxygen?
- off topic
- 302 question
- Engine Swap - Need Help
- Electric fan conversion - completed
- sorry
- Just Stalling Occasionally/ No Ping
- 4.6 info
- My 5.8L Pings at high speeds
- Cold Air intakes! Are they worth it!
- 100,000 Mile Tune up What do I need Done?
- Overheating - possible causes?
