View Full Version : Engine
  1. Missing, shuddering, pinging all around 99,500 miles..
  2. I have a problem with my idle can someone help?
  3. Amazing!!
  4. Ford may not offer new V6 diesel
  5. Help 01 Screw died on me twice tonight
  6. Idling At Start Up And Oxy Sensor, Shocks Too !
  7. thermostat question
  8. mpg help?
  9. How do you change the antifreeze?
  10. 4.6/5.4 I need recommendations
  11. 1-2 shift, engine hesitation
  12. Gas Mileage loss, reving engine
  13. Ignition Coil Pack
  14. Rough running 5.4
  15. blown plug
  16. Spark Plug Blowout in 5.4 Triton Engine
  17. ? about changing oil pump and stuff on oil cap
  18. Ticking noise when first starting up?
  19. E-bay Air Intake
  20. Has anyone heard of Nology HotWires
  21. Code 0174
  22. Serpentine belt
  23. Fix For Bad Heads?
  24. Cause of BOTH P1131 and P1132???
  25. Maybe someone can help me clarify something.
  26. new plugs(wow)
  27. 5W40 Synthetic?
  28. cold start problem 4.6
  29. 5.4L CNG engine same as gas engine??
  30. Rattle sound on 4.6
  31. Looking for a mat to park my f150 on in garage to catch water?
  32. Oil, Lower Pulley
  33. AFE intake kit!!
  34. sticking accelerator
  35. HELP - Exhaust question for 1993 F150 FlareSide with a 5.0 motor
  36. Any thoughts?
  37. Supercharger gone - Installed KNN Air Intake in 99 F-150
  38. 4R70W with Lightning 5.4
  39. Who here is COLD today
  40. Help !
  41. Filter Change Only, How Much Oil????
  42. having problems with my 4.6
  43. Idle speed
  44. W type engine?
  45. '97 4.6 to '00 32v Navi 5.4
  46. Won't start in park
  47. Raced a V10!
  48. Throttle Body cleaning
  49. 3 valve 5.4 liter - availability?
  50. Changing plugs this weekend, what other things do you guys recommend?
  51. Rough idle for 15 seconds
  52. Making Speed
  53. So I still have a problem with my 4.6.
  54. Just finished changing plugs...
  55. Lightning Motor upgrade
  56. Head Swap
  57. Power Steering RIP
  58. motor swap
  59. Should this worry me or not?
  60. Any One DYNOED there Truck 4.6/5.4/6.8
  61. Does the 4.6 hold 6 full quarts of oil?
  62. Warranty Concerns
  63. interesting article about oil
  64. my truck with hard starts
  65. MAF size
  66. 02 HD Stalling
  67. V-10 Superchargers?
  68. Service engine soon light
  69. velocity tube??
  70. Cold Weather Knock Knock
  71. Added K&N now check engine light on
  72. 1999 f-150ownerswiththe5.4pleasereadthisandthethread"BLOW N PLUGS,DAMAGED CYLINDERHEAD
  73. FIPK on SD didn't work...
  74. Helix Power Tower...BAH
  75. Powerstroke?
  76. New DPFE sensors are absolute junk
  77. Change engine oil every 3,000 miles or every 3 months?
  78. Fuel pump location
  79. Pinging
  80. Ready to install 2000 LIncoln Fan ...
  81. 94 F150 Overheating
  82. PowerAid Throttle Body Spacer for 5.4L
  83. Throttle Body build up?
  84. How do you get sludge out of an engine?
  85. OBDII Question
  86. truck is running like crap
  87. To Cam or not to Cam?
  88. Suggestions on Headers Please!!!!
  89. test
  90. Motorcraft double platinum plugs
  91. piston slap??
  92. Help! Changed wires, missing worse than before!
  93. 80,000 Mile Tune UP
  94. High Idle after mud bogging
  95. What constitues warranty violation?
  96. where could the oil be from?
  97. Driveline vibration??
  98. Moaning sound from FIPK????
  99. Synthetics seem popular
  100. quick release oil drain plug
  101. HELP Quick!!
  102. Oil pan question?
  103. going from dyno to synthetic????????
  104. AEM Brute Force
  105. Gas Line anti-freeze?
  106. Pics of your Ram Air system
  107. Need pics of Amsoil dual remote set-up on F150!
  108. AMSI Air Filter Kit
  109. No Start: what could have happened?
  110. Any prevention for blown plugs?
  111. Purolator oil filters?
  112. Po133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
  113. Amsoil vs Mobil 1
  114. dry start up
  115. Havoline synthetic
  116. Need Recommendations on Scan Tools
  117. 2003 Engine Whine
  118. Making a 4.6 150 faster
  119. 2003 Mustang heads on 4.6 f-150
  120. Dyno Test
  121. Air Flow
  122. piston slap not fixed on 2002!
  123. Mobil1
  124. Idle Surge
  125. Which engine sells most?
  126. What Engine??
  127. Mobil 1
  128. Help! Excessive EGR flow on 4.6L!
  129. New Plug Wires, Whoooooo! Also, coil pack ???
  130. Buzzing Noise Behind Dash
  131. mobil 1 useage on older motor
  132. Larger size oil filter?
  133. Any help on the way for the 4.6?
  134. Oil Leak
  135. New 5.4 coming
  136. Need some help please.......
  137. Gas in vapor cannister, vapor lock?
  138. 2001 HD F150 Engine question
  139. Borken fuse box latch...need cheap fix
  140. Belt
  141. FLushing Coolant Question-------->
  142. 235 vs 260 HP
  143. 4.6 4wd Overral Mlg 15 Over 2 Yrs
  144. Need to vent...
  145. 5.4 Oil filter removal
  146. My 4.6 needs help
  147. Power steering fluid change
  148. stoking out a 4.6 L..
  149. Engine Coolant Gauge
  150. Got my new engine
  151. Smaller Pully's, Warranty, Throttle Body Spacer
  152. Irratic Idle
  153. PS issue and 4.6L questions
  154. Oil Vicscosity Consensus
  155. Spark plug...Heat range
  156. any suggestions on cleaning the IAC?
  157. K&N Intake
  158. Question about engine ping
  159. DPFE sensor at Autozone
  160. Oil Filters
  161. JBRIII or anybody else with Motorsport wires
  162. MAF Mod
  163. Bad Gas Milage
  164. Rough running
  165. What to look for 99/00
  166. What is "Failsafe Cooling System"
  167. Ok guys this decision is killing me,new Chevy or new F150?
  168. coolant leak?
  169. Broken Studs on Wheel
  170. computer codes
  171. need info on rough startup,PLEASE!!
  172. Just cleaned my MAF, question now.
  173. Computer Chip
  174. Do thunderbirds have distributors??
  175. New Guy, I need some Q/A....
  176. new '03 engine question
  177. kinda cool
  178. Spark Plugs. Which are best?
  179. '97 F-150 4.6
  180. oxy sensor testing?
  181. Muddy Engine/Slight Hesitation
  182. spark plug trouble
  183. power steering??
  184. Wierd Smell
  185. Who has N20
  186. How hard to change plugs in 1999 5.4 expedition?
  187. Starting problems!
  188. I need help...quick
  189. Start Problem
  190. Plus 4's
  191. Speed sensor....where is it help please
  192. Pinging 5.4
  193. Yikes! 500.00 for a tuneup?
  194. 11.8 Wtf???
  195. Adding a REAL Oil Pressue gauge, drain first?
  196. crazy oil pressure gauge
  197. cooling system / heater core
  198. Fuel Additives for carbon removal?
  199. Ebay Repair CD's
  200. '03 Power Steering Noise
  201. Truck Problem
  202. 03 motors/tranny's
  203. flashing check engine light
  204. Mobil One 0w-20 Synthetic is on the way
  205. P0153 & P1151 fault codes
  206. 95 f-150 specs
  207. Burning Oil?
  208. 2002 5.4L cold engine knock
  209. Any 6.8L Triton V10 owners out there?
  210. Help! What is this sound?
  211. Can omission of di-electric grease cause rough idle?
  212. Fuel Filter
  213. New Torqshift trans info
  214. PING or KNOCK.
  215. New Triton 3 Valve Info
  216. First Review of New Power Stroke / Power Tor
  217. Water on my dipstick???
  218. Formal Intro (I'm a newbie)
  219. Never Buy A Dead Mans Truck!
  220. If you 4.6L is pinging, make sure you check this out.
  221. need fuel filter help
  222. Thought I'd ask!
  223. help with blown sparkplugs?
  224. What type of P/S fluid?
  225. Engine noise gone
  226. inserts or helicoils for heads?
  227. Piston slap again. Need help.
  228. Buying A New F150
  229. replaced head gaskets again
  230. Why Does This Thing Run Out Of Gas On Hills!?!?
  231. Ford Baby Diesel aborted...
  232. P0402 EGR - installation question
  233. Any maintenance things I should do now?
  234. Click...Click...BOOM?
  235. Is This Anal Retentive.......
  236. Remote oil filter problem?
  237. I'm about to do a tune-up on my new truck for the first time....
  238. Fuel filter replacement
  239. engine trouble, got codes
  240. 1997 f150 won't start, just clicks
  241. more power
  242. IAC or TPS
  243. Weird noise in cabin
  244. SVT models
  245. Modding drop-in K&N...
  246. plug killer
  247. throttlebody install
  248. Electric Fans Question
  249. Air Box Silencer Removal?
  250. Engine Stutter, Power loss
