View Full Version : Engine
  1. Diesel
  2. Non-L 5.4 plug launches?
  3. Check Engine...again
  4. Spark plug change mileage?
  5. intake exploded
  6. Need Help - Green Foam/Liquid ????
  7. I found one problem! O/T
  8. Anyone Noticing Filings in their oil?
  9. Need help with Crank shaft sensor
  10. Lightning Engine Dimensions?
  11. ~~~no Spark At The Plugs Help!!!~~~~
  12. Bown Spark Plugs, Stripped Cylinder Head Threads
  13. 1998 Rear Window replacement HELP!
  14. remote oil filter
  15. Morning engine noise, sounds like piston slap? Check your oil!
  16. A matter of bearings
  17. If im on a budget, what headers would you reccomend?
  18. Spark Plugs
  19. Spiral Max????
  20. Full of Crap
  21. radiator pressure tester
  22. Flex-A-Lite 270 Kit Installed...
  23. ASP Pulleys Installed...
  24. Minimum Idle Adj
  25. Under Drive Pulleys
  26. just goes "click"
  27. 5.4 info please
  28. Missing at 40MPH
  29. White Pasty Film On Oil Cap
  30. Plug & Wire Change on 97 4.6????
  31. New Aftermarket Intake System???
  32. oil loss
  33. Can you explain dealers to me?
  34. I have new Hypothesis.
  35. Poweraid
  36. Long Sleeve or Short Sleeve?
  37. Where did the oil go?
  38. Part numbers?
  39. Super Charge or Turbo
  40. Pinging like crazy!
  41. Thanks guys, the P0401 may be history
  42. low idle after driving 10 minutes
  43. Changes to K&N Air Filter Design?
  44. 6.0 diesel motors
  45. Intake manifold question
  46. Air Force One intake moan?
  47. FIPK questions---->
  48. Halo Plugs
  49. What is FIPK??
  50. 4.6 with 3.08 getting 26+ mpg
  51. Compression Ratio on 5.4???
  52. 5.4L A/C question
  53. single digit tempatures, do you warm up your engine?
  54. K&N Filter recall???
  55. water in the plug hole
  56. Need help with high end issues, please.
  57. cooling fan question
  58. another question / plugs and wires
  59. measured resistance of plug wires
  60. Engine stumble any help?
  61. Hesitation and stumble
  62. Iac
  63. engine vin codes
  64. Screw mileage
  65. P_Ferlow and Conner
  66. Thanks F150online!!
  67. 97 F150 problem
  68. Specs for 2000xlt
  69. Autotap w/Palm......
  70. Fuel Filter(s) for a 2001 5.4L
  71. Got a recall notice??
  72. Pep boys charges$80 for code or reset. Check Engine light still on
  73. timing belt
  74. wet oily sludge in my throttle body
  75. New MSD Coils, but still cutting out, HELP!!
  76. Ignition Coils
  77. filings in engine oil - 4.6
  78. Please help me out with this discison about oil
  79. Whew that was a scare......
  80. Just installed plugs wires and coil pack.
  81. Filter where oil tube connects in airbox?
  82. BEst bang for your $ on a 5.4
  83. Engine idle RPM
  84. Check Engine Light Constant Problem
  85. Head Gasket Question
  86. Ford to upgrade Triton V10 6.8L??
  87. 2001 f150 4.6l v8
  88. Replacement Engine Opinion
  89. Reset Check Engine Light
  90. Hey, Hapynzap
  91. Revving in idle with my '03
  92. Remember how I wanted a 302?
  93. Redesigned Spark Plug for 5.4L 3V
  94. 2000 F150 serpentine belt squeak
  95. Idle speed? 550rpm low?
  96. Ford engine specs...
  97. Engine Surging
  98. Rev limit on a 5.4
  99. Enigine help with 97+
  100. Help with oil change
  101. Changing Spark plugs
  102. Need advice on spark plug change
  103. The new 'burnout' thread!
  104. best plugs,wires, coil packs
  105. Gas mileage question
  106. Help with aligning the timimg chain on 5.4
  107. Strange squeal...!
  108. Engine Missing
  109. Low oil pressure light this morning
  110. Engine rattle under load - cold
  111. FORD extending EGR warranty & refunding.
  112. Funny smell
  113. Causes for low mileage?
  114. Charcoal/Carbon Canister?
  115. need some help with heads
  116. V10
  117. piston slap went away
  118. Tune ups!
  119. 89 f-150 cam question
  120. best motor
  121. Check Engine
  122. Regular vs Synthetic Oil
  123. Regular vs Synthetic Oil
  124. Regular vs Synthetic Oil
  125. part# for motorcraft double platinums?
  126. I think i figured out why the engine light was on!
  127. I think i figured out why the engine light was on!
  128. req"d maintenance
  129. Engine Problem..RPM's going waco..Please Help
  130. Burning oil after oil change??
  131. Fixing/Checking The Starter
  132. 5.4 oil consumption
  133. vacuum squeal
  134. 1998 F-Series Engine Displacement
  135. SSCULLY, need your help, please!
  136. Timing Chain 5.4
  137. where would the best place be to buy seats for F150 ext cab
  138. Anyone got an Aerostar or something with a 302, or a 305?
  139. What is wrong?
  140. When should I do these things????
  141. intake moan
  142. lightning supercharger
  143. Engine
  144. Firing Order Please
  145. Cables?
  146. Spark plug cables?
  147. EVR Solenoid
  148. I hate computers in trucks!!!!!!!!
  149. Engine light, Seems like a miss....
  150. 99. 5.4 EXP rear coolant leak
  151. Yellow Coolant
  152. horrible warranty problems....
  153. 5w30 VS 10w30 oil
  154. Tornado
  155. 4.6 Getting 25+ Miles Per Gallon!
  156. Motor Oil
  157. Another Classic save...READ!!!
  158. Which oil filter do you use??
  159. TAD Solenoid? Code 81
  160. K/N filter
  161. Fuel Additives?
  162. Is the factory Temp gauge real??
  163. Plugs stripping head during removal
  164. general choke question
  165. Lets see some HIGH MILEAGE DOMETER pictures!
  166. Iac
  167. Best fuel/oil cleaning?
  168. Cams
  169. Spring compressors
  170. Engine Whine in Drive & Reverse
  171. What do removed spark plugs look like?
  172. EGR Extended Warranty
  173. 4.6 to 5.4 switch?
  174. Loud whine at start up
  175. code p0401 possible vacuum leak?help jeff laws et all!!
  176. fuel filter
  177. Where is the IAC?
  178. Speedometer not working right
  179. 6.8 V10 Engine Swap
  180. Radiator Upgrade
  181. Engine Power and Performance Comparison
  182. EGR flow excessive, code #PO402
  183. Power Steering pump Major Whine!!!
  184. Help with start ups
  185. Cause for hard start ups when below freezing.
  186. Terrible Noise When Starting Up
  187. Spark Plugs question
  188. What is this part?
  189. Will a FIPK make my catback louder?
  190. IAC Part Number
  191. MAF Problem..Please Help!!
  192. Help with a driveshaft
  193. Air Intakes
  194. Chevy Horsepower
  195. 5.4 SOHC Engine height
  196. Anyone have an old Aerostar or somethin like it?
  197. Tryin to find out friends hp
  198. Fan clutch replacement needed?
  199. Cold Start Problems...hardly starts.
  200. What is the best coil pack?
  201. Bad motor or what??
  202. Po300, Po304
  203. $520 to fix Check Engine Light!!!
  204. Dead cylinder
  205. Fellow Windsorites...read
  206. Shake at speed 70MPH or under heavy acceleration
  207. adding coolant tank heater
  208. Does anyone burn french fry oil in their diesel engine ?
  209. Cold Morning Startups
  210. Check Engine Light on - $80 to run code???
  211. Trickflow/edelbrock Modular Hi/po Heads
  212. Whistling Engine?
  213. another motor oil ??
  214. O2 Sensors Question
  215. 4.6 or 5.4 which is better for towing?
  216. Question for those who have replaced cats...
  217. 1st "4x4" Problem in My 02
  218. HELP rattle at start
  219. DTC 9202-Fuel Sender Open Circuit
  220. Loud *thud* in 4Low
  221. How much oil?
  222. Another oil leak, 5.4
  223. 5.4 SOHC Intake manifold
  224. Engine popping under load
  225. A Must Read! Come See!!!
  226. Amsoil?
  227. What is normal engine temp?
  228. oil comsumption
  229. Takin' it in for Warranty Service
  230. New 2003 F-150 4.6 Terrible fuel milage
  231. Engine dies without warning
  232. egr low flow....... help
  233. Poll:: Who's switching to 0W20 when it comes out???
  234. 97 f150 6cly. headgasket
  235. anyone know what this code is? p0112
  236. New Drivetrain cost
  237. code po401 need help
  238. What mods won't void warranty?
  239. It's Official
  240. Update: Strange Noise Upon Shutdown
  241. 118K and praying
  242. Anyone have Perma Cool Dual Remote Oil Filers?
  243. Hard Starting When Warm
  244. 4.6 Performance Mods
  245. Strange Noise Upon Shutdown.......
  246. Whats more powerful?
  247. Rough idle while in gear
  248. Speed help...911!!!
  249. 1999 V8 5.4 Stats (1999-2002)
  250. Changing fuel filter
