View Full Version : Engine
  1. O2 sensors
  2. Deja vu? IAC Valve out again?
  3. Engine
  4. Hypertech's Power Programmer III - Worth The Money?
  5. Ok guys, one more time with a DTC PO136
  6. Question about coilpacks
  7. Sputerring at Acceleration
  8. This is getting ridiculous
  9. Profile Ignition Pick-up (PIP) HELP
  10. CES Light but no Signs
  11. supercharger
  12. 4.6L F150 Sputtering on Acceleration
  13. Air/Fuel Gauge?????
  14. how to test ignition coils?
  15. plugs?????
  16. Powermaster 200 amp alternators
  17. 12.3 mpg on my 4.6L?
  18. torque specs for ASP pulleys
  19. 4.6 Misfiring/stumbling bad mpg
  20. Mercury Engine Swap
  21. Stuck & Need Your Help!!
  22. Mobil 1 vs. Motorcraft question
  23. missing 97 4.6
  24. Service engine light on after servicing filter
  25. Converting Engine
  26. Paper air filter v. oiled for intake system
  27. Bronco II/Ranger experts help please
  28. Please Help!!!!!
  29. 1 more question about plugs
  30. 4.6 Bashing
  31. 3 Valve 4.6 Liter Coming
  32. Apologetic GM tries to sell new-found quality
  33. 1994 f-150 engine surgeing
  34. P0306 errors and misfiring - Help
  35. Opinions
  36. Is an Overhaul over budget?
  37. EGR Valve
  38. Glycol in oil - how many miles left?
  39. Please Help! Coolant leak!!
  40. A New Engine?
  41. So many mods, please help prioritize!
  42. Mac3501??
  43. Dealer assistance on a P.O.S.
  44. air intake, hmm, idea!
  45. Engine experts, please help, please!
  46. injector ticking?
  47. What is this wire??
  48. No oil pressure
  49. blower
  50. Blue smoke on startup
  51. Coolant Leak
  52. Engine miss
  53. Need some help troubleshooting.
  54. Engine Vac??
  55. Not an exhaust leak.... What could it be??
  56. K&N= Service Engine Light?
  57. No Start???
  58. Need help diagnosing miss
  59. Engine ID
  60. Is this gas mileage jump possible?
  61. MAF Sensor Positioning
  62. Ditch my pinging 4.6L '98 & get the '04?????????
  63. What now, I have engine codes, I dunno what to do!?!?
  64. Replacing my spark plugs
  65. Sorry - Another Synthetic Oil ?
  66. 91f-150 run rough
  67. Can anyone help me find a Camry Forum as good as this one?
  68. engine misses/blinking engine light
  69. Turns over...won't start...HELP!
  70. Calculation of MPG
  71. What not to buy.
  72. Top Speed Limiter
  73. High idle at start up?5.4
  74. Rear End Noise & Vibration
  75. I'm confused! Help, please!
  76. Update:
  77. underdrive pix?
  78. update
  79. Problems starting/Idling
  80. Rattling, Ticking--What is this noise!!!?
  81. 5.4l misfire at 1500rpm's
  82. Airraid
  83. update
  84. injector question
  85. constant steering noise
  86. Thanks alot. Seriously this time.
  87. Engine Running Rough--Any suggetstions
  88. 2003 5.4 Engine Oil Coolers
  89. mxracer514
  90. What is your payment??
  91. Coolant Leak ***HELP***
  92. Thanks for nothing MF's
  93. Help w/ possible problems
  94. valve spring on 4.6
  95. Air filter
  96. engine swap
  97. Oil Leak
  98. Question about changing the sparkplugs
  99. Fitst Mods. What Should I Do?
  100. Trouble Cranking
  101. I need everyone's help!!!!!
  102. E4OD Problem...Not shifting into gear!
  103. Gutless Wonder!!!!
  104. How in the @#%@ do I get this out??!!
  105. 24# injectors
  106. Gas mileage???
  107. Rattling Noise
  108. PCV hose HELP!
  109. no spark
  110. Do i need a rebuilt engine? New tranny too?!?
  111. 5.0 timing for street
  112. 1st oil change done?
  113. How hard to change head gasket on 4.6?
  114. Need help locating a tool
  115. Vibration
  116. Mustang 4.6 vs F150 4.6
  117. Failed to Start
  118. Engine surging
  119. Engine specs
  120. 2nd best dino oil?
  121. Engine died
  122. Help, Dropped Bolt
  123. Head gasket leak,door crack & Cab paint cracking!
  124. Intake Systems
  125. mass airflow sensor-part#
  126. need v-8
  127. Best Mechanic for Mods in NC
  128. 03 Expy: Oil temps and Hard use?
  129. V12
  130. Engine specs
  131. Head gasket Leak
  132. embarrased to ask this but..
  133. Yet another idle problem
  134. WOT hesitating question
  135. Engine stalls
  136. question for LABNERD
  137. First post,changed everything & still misses on #2
  138. codes P0171,P0174
  139. Need Help!!! Dtc P0300, 0304
  140. Self-repairing truck?
  141. oil change
  142. Code Po401
  143. 280 miles per tank of gas
  144. Truck is skipping
  145. 2 stroke gas in truck
  146. High Pitched Whine
  147. Is straight weight oil, okay?
  148. 4x4 Schematic
  149. I Got One For All You Master Techs
  150. Doggy 5.4l in 70 degrees and up?
  151. new engine
  152. ranger oil question???
  153. Yet another MAF question
  154. cel po442?????
  155. #1 and #2 Plugs
  156. oil on #1 cylinder plug, threads, tip
  157. Banks intake, catback?
  158. Overheating !!!!
  159. Mobil 1 in the 5 Qt.jugs...
  160. ??? for labnerd
  161. engine hiss
  162. P0153 Dtc
  163. Ok,Its not an F150 but how do you change the tranny oil and filter on a 2002 Explorer
  164. Throttle body fitting on 5.4L
  165. Engine Hesitating
  166. 100k+ and K & N
  167. Is this about right for my truck
  168. maf question
  169. Check engine light bulb change
  170. Dtc P0141
  171. no start???
  172. trouble codes p0171 & 0174
  173. Engine Missing, rough idle
  174. Oil analysis
  175. 97 5.4 to 99 5.4 power
  176. Need info on 88 F250
  177. Flex a lite fans and CFM required
  178. If you change your own oil, read some of these stories.
  179. Track Times for the 5.4
  180. Stalling out
  181. V6 4.2L Engine Blown?
  182. What's Next, Cheaper Mods???
  183. Mobil 1 0W-20
  184. Summit says the DON'T have part # for GY Belt?
  185. Odometer trick code list?
  186. Amsoil oil test results, test kit cost
  187. emissions experts??
  188. Steering noise
  189. Score your local DEALER Good/Bad Dealer Experience, Stories & Ratings
  190. Electric Cooling Fans Mod - Lincoln LS
  191. Corrosion? on DPFE sensor.
  192. oil change interval
  193. What the heck is this tube for?
  194. Pinging Fixed
  195. 4.6 towing
  196. E40D Tranny Problem
  197. F250 question
  198. 97 5.4 ticking
  199. high idle, HELP
  200. Break-in period (Me and the Truck)!
  201. When should I have 1st oil change done ?
  202. Spark Plugs Blow Up
  203. power pulleys
  204. tempermental downshift at WOT
  205. cel light dpfegr
  206. Clunk sound when braking (only in Overdrive)
  207. Mileage question(s) on high mileage engine
  208. 65MPH at what RPM?
  209. Belt tentioner Replacement HELP
  210. fuel filter
  211. New Engine Price?
  212. What will happen?
  213. Plugs & Oil
  214. Help!! Engine Tapping?!?!?!
  215. AutoXray Pro-pack scanner
  216. 4.6L toughness??
  217. Mobil 1 Tri-Syn users
  218. Actron code scanners?
  219. Oil Pressure Problems ... 4.2L
  220. Engine miss
  221. is this an x plan pin? if not, does anyone have one available??
  222. Door locks hard to open
  223. Flex-a-lite fans
  224. IAT wire
  225. Fram SURE-DRAIN
  226. Power tower
  227. Driving with P0442 Small Evap Leak?
  228. Different take on squeaking belts problem.
  229. Gas Gauge
  230. Should I change my oil?
  231. New F150 owner, where can I get an eletric fan and underdrive pulley
  232. Air Intake
  233. HELP! CEL won't go away and I lost my socket!
  234. when i start up the truck white smoke
  235. Engine misfire
  236. Rear Main Seal Cause truck to burn oil?
  237. Electric Shift Motor 4x4 system
  238. PO307 and wires?
  239. Engine missing
  240. heater core... again!!!
  241. Cel ?
  242. Idle Stumble Problem
  243. help! truck won't start
  244. Larger TB, better performance?
  245. Cutting out...fuel pump or ???
  246. "engine racing"
  247. How do you remove the fan?
  248. Truck won't start!
  249. 1997 f-150 5.4 spark plug change
  250. Best way to fool the LOW OIL light?
