- Leaking from????
- NEED TO KNOW..can I use a 98 4.2 in my 97
- 1997 F150 Oil Pressure Gauge Fluctuations
- Engine light is on
- Embarassing, but true...
- rusty gas tank
- 0W30 Mobil 1 availability
- Synthetic and modular engines
- crank pulleys
- New 2003 Svt Lightning
- Electric Cooling Fans
- Intake Air Temp Override
- Need a 5.0 For 88 F150
- dual fuel tanks
- Enige KNOCK
- Intake noise or Exhaust leak or ???
- What does the EGR do???
- V-6 Super charger????
- '01 Supercrew getting poor mileage???
- For synthetic oil users
- Air Conditioner Kicking in and out!
- HELP Seized 5.4 engine
- best oil?
- Aftermarket High-Flow / Cold air intakes?
- new 03 supercrew
- HP in a 351
- missing idler pulley
- 5.4L whining noise cont'd
- will use motorcraft
- metalic noise
- Powerstroke
- Stalling Taurus?
- coil packs and plugs
- Break-in period?
- Power Steering Seal Leak
- Ford Racing Spark Plug Wires
- Motorcraft or Champion oil filter?
- Cooling System
- Fuel Filter tool
- HeadGasket leak is Back!
- help i need torque
- Performance question: 5.4L
- 4.6 engine type??
- Fan Clutch always on.
- P0401 OBD code PROBLEMS...
- 4.6 hesitation above 3k rpm
- injector color
- Throttle Position Sensor
- Highway Mileage
- V8 or V6 Engine lugging, missing?
- Need help asap, what can it be?
- Need Help Fast!!!
- Need advice..truck still shutting down.
- oohhh oohh...2200 miles and the **** starts..
- Service Engine Light
- engine rpms
- 4.6L Bucking and hestitating - bad coil?
- JBA header s
- A/C & Check Engine (Relation)
- Need help with 302 buildup
- Mpg
- how many people have hod problems right before warranty expiration??
- k&n...turned into poor boy air intake.
- Oil change
- OT:need help w/ gm dealer service/tsb
- Rattle Noise just started - Help?
- Elec. Fans - AC Comp Clutch Wire Splice?
- New Member here.
- Your mileage at 4.6 gasket leak
- 03 F150
- How many miles on your F-150?
- 6L in F150's
- Poweraid spacer
- 5.4 sparkplugs + idlerarm
- Rough idle
- Someone Please Help
- Blownin a plug.
- 5.4 stalls after startup
- engine swap info needed
- new 3 valve 5.4
- Should i change my alternator?
- And you thought the 5.4 had bad piston slap..
- sparkplug wires 98 4.6 can they shrink?
- F*UK ME andthis Rotor
- Procomp FIPK
- electrical problem
- A/C question....
- 5.4L whining noise??
- Ford's new oil recommendation
- mod's ?
- What tools do you use for...
- Puking coolant (little diff from others)
- Did you ever notice how…
- Need advice on an oil leak
- Favorite Oil Filter???
- Esso 10w-30 Uniflow Any Good?
- engine rpm's and radio
- AC help
- Running Rough w/no codes
- Clattering every morning now.
- Oil Pan
- Any how-to's for 97 f150 front cover gasket and intake manifold gasket replacement?
- Finally, got 300 miles on a tank of gas!
- Melted plug
- Check Engine light...on.....off.....on.....off??
- Stuck ignition wire "boot" - Help
- choosing the right computer reprogrammer
- Ford vs. Chevy?
- code po156,will not go away.
- how many grease fittings on a 2001 f150 4x4 5.4 v8 ?
- Installing Ignition Upgrade
- Rod weight
- Spark Plugs Cracking
- flex plate?
- HELP-Bucking and surging engine
- P0171, P0174, and stumble at peak
- HELP, how much HP in a 289 Chevy?
- Correct Coolant
- heads swap
- Billet Throttle Body Cowling
- Engine Missing-Not lost..LOL
- Rocking Truck (please Help)
- 4.6 Liter, 2003 models don't have Hood Liners?
- Swapping 4.6 for a Lightning 5.4
- Engine won't crank & overdrive light stuck in "off"
- Oil Pressure
- Coil replacement
- Bigger Throttle Body
- H0211s Code????
- EGR and T/B
- 5W-20 or 10W30?
- Rough Idle
- dpfe sensor
- Power Loss with A/C
- Engine codes??
- engine swap
- bought Jacobs wires then returned
- New Mod ...
- Squeeze
- How often should I change my spark plugs?
- Banks Power pack.
- After Market or Ford Fuel Filter
- Ticking?
- Auterra's New Dyno Scan for OBD2
- heater hose post
- How hot is your alternator?
- Loving the Gas Mileage
- 03' Cobra 4.6 DOHC manifold on SOHC
- coil pack radio supressor
- How long do you guys let your trucks idle before driving ?
- Need Everyone"s Opinion
- Time to Modify
- serpentine belt
- Engine
- Plugs & wires
- Door Crack Question
- Was: Poor fuel mileage/and CEL
- Dealing with the dealer
- UGH...Head Gasket Leak and Tranny Housing Seal Leak!!
- "Air" noise between 2500 & 3000 rpm
- Dash removal?
- 93 f150 4.9 stumble and surge problem
- Engine Dies Off
- Blown Spark Plug Poll
- hesitation or 'missing' problem
- A/c on = smooth idle
- Dumb Question about oil change
- K&N FIPK Hisssss....
- Supercharger Suggestion
- Fuel Pump Reset
- Truck missing real bad. Please Help
- Sticky accelerator
- My dad's Diesel started Smoking?!?!?!
- How much hp can speed density handle?
- Thoughts on Nissan full size Titan . . .
- Check Engine Light
- Changing spark plugs
- Fuel Leak
- oil pressure
- Trouble code 1131
- How good are stock intakes?
- redline
- One more for the blown plug club
- P0100 and P0232 DTC
- Unusual Help Request- Serious
- F150 cooling fan
- A Headgasket Leak Consensus
- Has anybody ported their heads???
- Error Code PO123 TPS/Pedal Position Sensor
- Bad Coolant/Bad Heads/Bad News
- oil pressure drop
- Max Mitchel
- Going back for a third time
- Replace the fuel line or not?
- A/C quit working!??
- Buncha questions to fix my problem
- Knock sensor
- air kit
- Platinums?
- If you had a 97 that needed a new engine...
- Name a good message board for the powerstroke diesel
- harley davidson
- If not K&N - what paper filter ?
- Engine Light On
- I feel so dumb..where are the spark plugs?!?
- Airforce 1
- How fast can the F150 V8 go?
- enige hard to start
- Help! bad a/c evaporator and filter
- 5.4 engine hesitating below 2K RPM
- Throttle body
- dual function res.?
- engine hard to start
- Under drive pulleys pros/cons
- Fried cylinder coil
- Ever dropped anything in the intake area?
- Oil ?
- Intakes
- Anything to worry about?
- lack of fuel? no CEL
- Odometer working intermitantly
- help! my a/c is blowing hot air what should I check?
- 2000 5.4 Egr
- Heater Core Inlet Hose
- truck is bucking & missing
- PO430, Catalyst Efficiency Below Threshold? What to do?
- Exhaust Valve questions- Burning oil
- Dropping K&N, going back to paper!
- Inceficiant EGR flow (please help)
- 97 Oil Filter Re-Location
- 4.6 possible vacuum leak. . .
- Fuel Pressure
- throttle body spacers
- Charge Idiot light coming on
- 98 OBDII Codes- Help
- Indications to Clean Oil-Based Air Filters
- MAF Sensor
- engine problem? tranny problem?
- Air Intake, which one?
- HELP coil pack specs
- How much is too much (a leak)?
- Upgrading ingition 2.9L 177..Where to order parts?
- 98 heads
- Haynes, Chilton, CD, any manual will do for my 03
- Fuel pump replacement
- Mobil 1 filter
- 4.7L vs. 5.4L V-8
- mpg for a diseal
- Are there any tricks to removing valve stem seals?
- How often do you clean your K&N . . .
