View Full Version : Engine
  1. THANK YOU... Please READ!!!
  2. 1990 5.0 Ho
  3. Changing plugs 5.4
  4. can someone explain this code to me
  5. 97 4.2 Engine idle
  6. 4.9L Engine Upgrade
  7. Need help choosing new f150
  8. Emissions warranty question
  9. cold air intake
  10. Ignition Coil 1997 Expedition 5.4L
  11. ethanol??
  12. gas mileage... 17.2 mpg hwy... any comparisons?
  13. Need 2nd opinion on starter problem
  14. diesel replacement engine
  15. I have a leak, need some help please!
  16. Harley-Davison
  17. No Fuel Pumps ...only during Cranking..Help!
  18. soot in the tail pipe
  19. 1997 4.2L E250 Ford Engine Probs
  20. 1997 4.2L E250 Ford Engine Probs
  21. What kind of HP?
  22. Melting spark plugs in # 8 cylinder
  23. Is there such thing as break-in oil?
  24. Dodge Kills Them All!
  25. 4.6 stuck valve???
  26. 03 red lightning
  27. 2000 california warranty specs
  28. 4 Bad Coils At The Same Time????
  29. F-250 u-joints?
  30. V10 1/4 Mile
  31. Check engine light.....NEED HELP.....ran diagnostic..
  32. K&N air filter
  33. timing chain
  34. 98 Expd. 5.4 loss of power towing-Help
  35. california emissions warranty
  36. Check engine light
  37. Underdrive Pulley Belt?
  38. dealer trying to shaft me
  39. '95 Bronco Timing Advance- ***HELP***
  40. Power Pullies and Water Pump.
  41. What's wrong with Dexcool for F150?
  42. Anybody ever tested a coil pack for function?
  43. What is the effect of sustained boost on a s/c engine? (long post)
  44. piston slap question?
  45. Unidentified Equipment
  46. 4.6 V8 running rough
  47. F-150 died while driving
  48. Missing oil ?
  49. P0455 and P0401
  50. Intermittent 300 6 cyl
  51. Lean condition on a 96 windstar
  52. help!!!!!!!!!!11
  53. oil pressure drops at high rpm
  54. I sure hate to say this but....
  55. Having problems with my Tracer....need help.
  56. do they make an intake for my ranger
  57. Real life cost of ownership...
  58. Need Help!!!
  59. need more torque out of a 4.6
  60. Hesitation!!!
  61. Radiator Flush
  62. Question about FIPK mod?
  63. Do these times sound right?
  64. Fuel Pump
  65. ebay intake opinions...
  66. 4.6L Rough Idle
  67. OIL oil OIl, sigh, growl, vomit
  68. Yet another oil question...
  69. 4.6 L V8 Reputation And A Question?
  70. Boneyard parts 4 mass air convert?
  71. Need help quick on Oil ? - Please
  72. Does the K&N fipk work on the 4.6 V8?
  73. Heater Core on 99 F150
  74. Oil Filters
  75. OBD Scantool
  76. Oil Change Question - 5.4 Engine
  77. ford power in mercedes
  78. need some help on a 4.6
  79. BBK air intake????
  80. Fan clutch? How tight should it be when cold?
  81. No start, 5.4L.......
  82. Still want comment on the 4.0l V6
  83. F150.com
  84. Thanks F150.com
  85. synthectic oil and oil additive question
  86. My favorite Ford
  87. Dumb Question.
  88. horsepower increase?
  89. Larger Gas Tank?
  90. Advice on engine swap needed.
  91. Question about intake air options...
  92. Throttle Body Spacer
  93. Oil Consumption
  94. I'm new. Need intake advice!!!
  95. Where to buy a 5.4 Long Block
  96. engine noise
  97. 351W in a 2002 F-150??
  98. Royal Purple synthetic, Comments?
  99. How many are in the 200,000 mile club?
  100. Best place (price) to get Mobil1 Oil and Filter
  101. What Next?
  102. Need your opinions on noise please
  103. Oil Light coming on
  104. door rust
  105. Air filter mod
  106. ford vs. chevy
  107. died 3 times this morn on way to work
  108. '97 5.0 swap
  109. Powerdyne S/Cer question for a 5.4
  110. 5.4 vs Lightning
  111. Can't solve EGR (P0401) problem
  112. 1991 f150 stalls at take off
  113. 5.4 spark plugs
  114. Oil analysis question:
  115. Coil problem?
  116. ?
  117. oil viscosity
  118. 2000 Expedition 4.6 idle searching
  119. 1983 F150 Thermostat Location
  120. Mobil 1 0W-20 Analysis
  121. head gasket concern
  122. F150 Pcm
  123. intake HUM/WHINING (LOUD)
  124. Streetsmart Design Intake??
  125. sparkplug & wire choices
  126. building a 5.4 monster ?
  127. Losing coolant, can't find any leaks
  128. To Cut Or Not To Cut
  129. Battery Light Flashing
  130. 5.4 possible PCM woes
  131. blown spark plugs
  132. First post-need help
  133. Please Help!
  134. rough idle and even worse at 20-40 mph
  135. How do you check a injector?
  136. Supercharger
  137. Engine won't crank - sometimes
  138. Oil additives in new trucks?
  139. Race: Got Whipped :( Wanna win next time
  140. 5.4 plug replacement tips
  141. Harmonic Balancer
  142. Restore Automotive Products
  143. no start problem help!!
  144. duel tanks
  145. surging
  146. 4.6 hesitation when cold
  147. Cold air intake, filter digs into hood insulation?
  148. air diverter valve?
  149. water in my front diff
  150. Fuel Cell
  151. Screching noise at start up????
  152. Multiple Thanks
  153. Ignition Problems
  154. Lack of power/engine noise
  155. F25o Super Duty Problem
  156. ignition switch bad?
  157. Anybody broke a timing chain on a 4.6L?
  158. ignition switch bad?
  159. How do you program the key ?
  160. '82 F150 Engine swap
  161. Cyl 4 misfire
  162. Anything wrong with using 10w40 oil?
  163. Computer Code on my f-150
  164. 5w20again
  165. Got Nitrous?
  166. intake noise
  167. Help With Idle
  168. 4.6L Performance ????
  169. my pinging 5.4 cured?????
  170. Oil change pnuematic pump
  171. Need to look up some part numbers
  172. truck wouldn't start
  173. Lightning Rebuild
  174. help for an old guy.
  175. High Altitude
  176. Sometimes it hesitates, sometimes it dies
  177. Carbon Build up
  178. Testing '97 F-150 4.6L Oxygen Sensors
  179. synthetic oil manufacturers
  180. HELP!! Fan clutch went out
  181. What Do You Get For a "Tune-up"
  182. tb spacer
  183. Starter stays on after key off
  184. Wix oil filters
  185. Resetting Computer after Upgrades & Mods??
  186. aftermarket throttle bodies
  187. Synthetic 5w-40?
  188. anyone considering.....
  189. 4.6L runs rough @ idle & coast - after tune-up!
  190. Pulled my 2 codes.....
  191. Mass air flow sensors
  192. Feel soft off the line
  193. Gasoline smell while driving
  194. 5.4 starts but immediately stalls ???
  195. synthetic vs dino in low miles truck
  196. what's the difference?
  197. 18,000 MILES: not a single problem
  198. 5.4 Pinging. Diagnostic says bad Knock Sensor
  199. Spark plug boots
  200. saw a 2004 f150
  201. Adventures in Oil Changing
  202. got it wet, now has miss
  203. Sluggish Acceleration
  204. performance upgrades
  205. Help! Code - P0307, F150 '98 4.6L V8
  206. Installed AF1 now wont idle
  207. oxygen sensors look inside...
  208. towing with a 4.6
  209. 4.6 pinging
  210. thermostat
  211. Spark plug question
  212. What kind of other cars used same oil filter as 5.4L Supercharged Engine?
  213. Strange temp problem? (atta3 you out there)
  214. Cleveland Engines?
  215. AIr Force One Help
  216. P0453 code
  217. Mods impact on durability. Let's hear it, both good and bad!
  218. 1997 f150 4.6 liter can any one tell me if this is an interrupt engine?
  219. high100 octane fuel
  220. How can I improve gas mileage?
  221. rear tank fillinf problem
  222. V-10 no-start
  223. www.cybrrpartspro.com/chiltonautolibrary/root/
  224. Engine Swap
  225. Using oil 5.4
  226. Engine
  227. EGR or DPFE?
  228. Bigserts
  229. How to store an engine?
  230. '01 Screw over heating
  231. year, model and enter...
  232. Hesitation
  233. will not idle when hot
  234. 97 5.4L won't accelerate
  235. Torque Curve
  236. Oil Recommendation, 2003 F150 5.4L
  237. New Airfilter--Finally
  238. 4.9L L6 oil questions
  239. DPFE or EGR or ???
  240. Check Engine Light is on blinking
  241. Question on my Model?
  242. Check Engine Light & MisFire
  243. Spark Plugs, Bosch, Ford
  244. running out of oil
  245. Engine Swap
  246. Spark plugs
  247. first time f owner
  248. Dashlight - battery
  249. 4.10 Gears in F150...Can you bald the tires?
  250. AC not working well
