View Full Version : Engine
  1. Swap
  2. Compatible engine for '98 4.6?
  3. Oil Filter Please Help!!
  4. need help 2002 f150 4.6l idles badly
  5. Stuff to ensure long engine life
  6. Has anyone tried acetone in thier gas to save milage?
  7. Exhaust manifold gaskets
  8. went to track
  9. ? about cams/lifters/rockers
  10. Couldent get an accurate answer before, so here goes...
  11. vacuum leak test
  12. for what its worth...
  13. Clicking noise when in Idle
  14. chips
  15. Engine problem
  16. Oil pressure switch
  17. Spark Plug Gap
  18. just a joke someone emailed me
  19. Is it the exhaust or the motor?
  20. STRANGE: Replaced cap, rotor, plugs and wires...coil pack goes bad...
  21. 50mm Over bore pistons
  22. Recharge A/C Question on fluid
  23. '97-'03 Edge Programmers
  24. time for tune up
  25. Starting questions
  26. Rear main seal or oil pan gasket.
  27. rounded cylinder head bolts
  28. COPs changed - lessons and a question
  29. Anyone converted their truck to run on natural gas
  30. injector cleaners
  31. Engine knocking
  32. Help with PCV elbow/ Codes 171 and 174
  33. Plugging the Baffles in the Stock Air Intake?
  34. Engine Replacement Costs
  35. 4.6, 5.4 coolant temp sensor, Anyone with a OBD-II scanner?
  36. My 1997 F150 died!
  37. Easiest Oil Change ever!
  38. Royal Purple, Amisol, or Redline?
  39. Beware!! intermittent oil pressure indications
  40. 98 F150 has got a problem.
  41. 5.4 swap in NBS?
  42. High idle on cold start-up
  43. for sale: flex a lite efan 270 kit
  44. help bad engine
  45. help a friend in need!
  46. '97 5.4- 25% drop in fuel mileage...
  47. Battery Cable connection on Starter
  48. help-cylinder 2 misfire
  49. minimum CFM for E-fans
  50. To side gap or not to side gap?
  51. help with spider gears
  52. A strange misfire
  53. Static charge builds on DBW TB
  54. 1998 4.6L - Loss of Power
  55. HP valvetrain suggestions
  56. Is Royal Purple that much better?
  57. Air condition quits blowing through vents
  58. Power Loss
  59. Air intake system
  60. Both fuel pumps failing?
  61. Thud coming from A/C
  62. 4.6 to lightning engine swap
  63. High performance heads
  64. HELP!!! is there something wrong with my engine?
  65. I'll sue this Dealership if they don't cooperate!!!!!! your thoughts please
  66. 460 weight?
  67. Fuel Efficiency
  68. Recall 05 F150
  69. VT Competition short blocks
  70. What is this?? How can i fix it?
  71. Injectors
  72. Engine tick
  73. Boost Gauge Hookup Location??
  74. Plug install and reveiw
  75. plug recommendation
  76. Low Idle, Bad run
  77. Fuel pump quit I think
  78. energon mpg booster
  79. Codes
  80. Intake Leak
  81. The truth behond P0401
  82. obd II codes P1151,1131,P0316 and P0302
  83. 5.4 patriot stage II head install problem
  84. engine runs like it has misfire
  85. repeated DPFE failures and replacements
  86. Power steering ?, newbie here
  87. 0315 code?????
  88. Fail Safe Mode - 2004 F-150
  89. 05 5.4 engine knock
  90. Hum From Engine Compartment
  91. Looking for your help on sparkplug change 2004 5.4L 3 Valve
  92. Me 6 OEM PLUGS 2
  93. 1997 F150 5.4L : Bad EGR / P0300 Multiple Cylinder Misfire
  94. Low oil pressure
  95. F150 built 4.6L, looking for 24lb. Injectors
  96. 2003 F150 Sport info plz?
  97. 5.4l 3v engine mods????
  98. K Guys....
  99. Frost plugs on 97 4.6 F150
  100. Engine hiss on 2007 F-150
  101. truck died and won't start
  102. ? BG TB cleaning
  103. Idle problem..
  104. Help With Basic Maintenance
  105. Running lean and then running rich
  106. Rear Main Seal/Gasket
  107. Sqeak coming from driveshaft?
  108. Truck in water, now wont start???
  109. Upgrade spark plugs
  110. ECT sensor location?? on a 01 5.4
  111. Oxygen sensor
  112. best time to change plugs?
  113. Cold air intake question
  114. Misfiring under load.
  115. Starter issues?
  116. Recall on 2005-2006 F150's
  117. 97 f150 4.6 triton no power?
  118. 1979 Oil Pan
  119. How good is the extended warranty?
  120. Whats the est. horsepower to the rear wheels for this truck?
  121. Dipstick Help
  122. belt tensiner
  123. Codes
  124. 1999 F150 4.6 Misfire No Coeds
  125. Cast or Forged Crank (03 N/A 5.4)
  126. Help!! How do I remove the ac compressor on an 1999 f250
  127. Coolant leak
  128. Rod knock sound, really the cat converters
  129. Sunbird running lean
  130. Smoke coming from my exhaust pipes? HELP
  131. She said she smells gas...
  132. Vibration Question
  133. Seafoam in crankcase
  134. Mustang motor into F-150.
  135. intake air temp sensor relocation for more power
  136. F150 2005 0-60mph
  137. buying used longblock (Wrist pin noise)
  138. limited slip question
  139. '97 4.2 w/ P0161 Code
  140. Intake Manifold
  141. Intake and Supercharger Question
  142. do i need a SPECIAL SOCKET?
  143. 10% Ethanol Fuel
  144. 5.4 Shudder and Rough Idle.
  145. stupid is stupid was truck still no start
  146. Spark Plug Removal Fascination.....???
  147. Oil capacity question
  148. High mileage club... nearing 300k!
  149. 4.6l and 35s
  150. Need help finding Rattle noise?
  151. Police Interceptor motor, Contrary to belief...
  152. Chirping
  153. F-250 LD oil capacity
  154. pi head swap
  155. Lightning swap on 2005 and up 5.4 3v?
  156. I heard a bad ass 4.6L today....
  157. Getting truck ready for trip!
  158. Accel Coil Packs
  159. SES Codes How To?
  160. Sensor Location diagram
  161. Oil Preasure Sender - How do I get it out???
  162. So I think Ford is trying to screw me.
  163. I know everyone complains about gas....but
  164. fuel system cleaner
  165. 2002 4.6L Cylinder Heads
  166. Popped the block heater???
  167. 4.6l still idles badly
  168. '99 5.4L #6 plug - unable to remove!
  169. Have some money...looking for power...give me ideas
  170. "Uncommon" Spark Plug Blowout???
  171. low oil pressure
  172. 5.4 Engine 2003 with a 3-2005 Ford rebuild tag
  173. 2001 F150 OBDII P1451 Code
  174. New member
  175. Getting to the #7 plug
  176. truck starts loping??? HELP?
  177. Mobil 1 5W20 Vs. 5W30
  178. HHO conversion
  179. GO lil 4.6L!!! *overloaded truck*
  180. Gas-o-line
  181. Newbie question...whats the deal w/ the spark plugs?
  182. Problem with 1985 f150 (need Help)
  183. This Dealership need someone to sue it, right? please read and give your thoughts!
  184. Champion 7989 spark plugs
  185. Oil Preasure Sender
  186. Exhaust Manifolds
  187. Stupid is Stupid was/ won't start
  188. How much oil does your 5.4L 2v burn between oil changes?
  189. ruff running expedition
  190. 5.0 Engine Clang
  191. Replacement Coils
  192. Fuel Pressure, Injectors, MPG Mods: Questions
  193. Ford vs. GM
  194. check engine light
  195. Would you switch to synthetic after 100k?
  196. is this a common problem????
  197. Pinging Sound (exhaust leak)
  198. interesting article on/from Drudge
  199. Air Filter Change .. how often
  200. Strange intake noise 03-4.6
  201. Please Someone Help
  202. 90 I6 fuel injection running WAY rich, What have I missed?
  203. I Think its broke lol
  204. please help fast
  205. Need Help ASAP 4.2L high idle.
  206. What is the difference?
  207. Tapping noise
  208. Engine miss
  209. PCV Valve Hose Connections
  210. vacuum lines
  211. Spark plug or sensor?
  212. MAF Sensor
  213. fuel injectors
  214. fuel pump? saftey neutral switch?
  215. 2005 5.4 minor mods. Weird Noise?
  216. Bosch plugs bent the valve
  217. p0305
  218. Running Lean
  219. Metal on Metal Knock on Hard Acceleration
  220. Truck leaks oil, 04 F 150, 5.4
  221. i hate tocoma x runner
  222. its about oil and sparks plugs and coils let me know
  223. Radiator. Drain n fill
  224. Maintenence - Buying a BRAND NEW . . . . . . . . . .2001 Screw
  225. need help in next few minutes!! High flow cats
  226. Bad Coils
  227. FFV Differences
  228. 06 F150 Powertrain Warranty?? Faulty Injector
  229. E^3 plugs?
  230. possible vacuum leak
  231. Reset Computer?
  232. 2001 4.6L idle speed???
  233. What wire is the ac clutch switch?
  234. map sensor
  235. F150 4.2l v6 pistons and rods - composition?
  236. What is running lean?
  237. Project vehicle, MOTOR IN !!!
  238. More Power
  239. p171 p174
  240. 4.6 Head Swap
  241. 99-03 4.6 to 5.4 F-150 conversion
  242. 4.6 to 5.4 conversion
  243. cam question....
  244. Get those recalls done.
  245. CAI + Catback = better mpgs?
  246. Differences in 06 & 07 5.4?
  247. 2004 5.4 3V with 45000 Km - Dealer recommends regapping plugs and re-installing them
  248. Idle goes low when I turn on the air condition on my 2005 F150 V8 4.6
  249. 07 Trition 5.4 with 9,000miles dead!?!
  250. What kind of mileage yall gettin
