View Full Version : Engine
  1. Knock sensor
  2. Throttle body/butterfly adjustment
  3. intake manifold
  4. 5.4 oil analysis
  5. engine swap or supercharger
  6. oil pressure
  7. How do you clean the iac ??
  8. 4.6 engine knock
  9. Repair manuals on eBay
  10. code 172
  11. Gas Mileage?
  12. Need final advice on plugs & wires
  13. need help, where to get an iac?
  14. Winter Air intake applications
  15. KN Filters
  16. check engine light flashing! help
  17. Redline on 5.4??
  18. gt-40 heads will they fit?
  19. why does my 99 4.6 quit while idiling durring warm up
  20. Where to get plug change?
  21. finance
  22. 4.6 vs 5.4 ?
  23. Aftermarket parts for 2004 "carry-over" 4.6 engine?
  24. Coolant Freeze Plug?
  25. Insufficient Torque
  26. 3 Bar MAP? What ford comes with one?
  27. 89 5.0 Code 12-- Need help, Please!
  28. when to change plugs
  29. 97 f-150 starter problems
  30. Repair Manual
  31. 4.2 reliable?
  32. AC drain hose? how does it go on?
  33. code 0171 and 0174
  34. Need Some Advice
  35. Studder!
  36. old f150 fuel pump (?)problem
  37. 03 5.4 Maf
  38. FI to carb conversion
  39. Wicked Starting Problem
  40. High-mile '97 F150 4.6l update
  41. how's this price sound from dealership?
  42. AC stalls Engine?
  43. 1997 6.8L V10 HP versus 2000 model
  44. 5.4L engine ticking noise
  45. 350 Built in a F150?
  46. Would a code 31 cause an engine misfire?
  47. new amsoil air filter installed
  48. Powerstroke Vs. V-10 in an F250...?????
  49. DPFE Sensor???
  50. Water temp gauge install...
  51. Check engine light
  52. Underdrive pulleys
  53. Hands Down best bolt-on mod available today!!
  54. To much?
  55. head gasket on 4.6L @55K
  56. Rubber Valve Cover Gasket
  57. supercharger conversion requirements
  58. An end to the pinging
  59. Mod suggestions for 5.4
  60. check engine code!
  61. Hydraulic lifters
  62. Oil Quanity for 5.4L
  63. Coils on 1997 4.6 L
  64. Check Engine Light
  65. N/A E.T.'s
  66. 90 F150 302 PS pressure
  67. buzz in radio
  68. Please help with random backfire
  69. Superchip Or Hypertech
  70. Weird problem
  71. 10 MPG typical?
  72. 4.6 gas mileage
  73. 03' F150 4.6L - flutter / ticking noise
  74. Excursion V--10 OIL Recommended ?
  75. Rough Idle on my 2000 F150 with 4.6L Engine
  76. Ugh, help. Pulled a "My Bad"
  77. Valve Lash
  78. Re-Gear
  79. need help 86 bronce wont run
  80. 1990 5.0L SD-EFi - throttle body size?
  81. Where and how to change oil sending unit
  82. 5.4L V8 variety
  83. Oil type
  84. Emission results from NJ
  85. Is the "new" Ford commercial on the net somewhere?
  86. Pulley ribs???
  87. Emissions System Diagram
  88. P1151, what to do?
  89. Chirping /Squealing
  90. a scary story
  91. 97 4.2L Valve Lifter Tap
  92. compare intakes hp/torque
  93. When to change coil packs?
  94. 2001 4.6L with P0304 Code
  95. clutch fan replacement suggestions
  96. how about the 4.6
  97. Power steering whine
  98. OBD available by turning ignition On/off?
  99. reply
  100. big problem need help asap
  101. Info on rough 5.4 engine idle.
  102. odd hesitation/shutter
  103. Service light
  104. New Engine???
  105. volant intake filter system NEW
  106. Coolant flushing
  107. looking for parts
  108. Tsb?
  109. Switching to L 5.4 $$$$$$$
  110. daytime driving lights suck
  111. 98 power locks
  112. Buying, what should I be aware of?
  113. K&N or Accel?
  114. IDM circuit failure?
  115. cold start clicking
  116. Help with battery &/or other situation
  117. new engine???
  118. another oil question
  119. Replaced coils, wires, and plugs
  120. Stuborn Fan...
  121. My new intake!
  122. Need help with '95 F-150
  123. Odometer-error code 3
  124. horse power
  125. Got the Codes EEC-IV
  126. Dyno test
  127. Timing Chain Deflection in 302
  128. Amsoil air fiter questions!!!
  129. Oil level Problem
  130. Carbon buildup
  131. Won't idle
  132. Finally changed the original factory fuel filter!
  133. Barely starts in cold and/or rain days
  134. Engine vibration?
  135. Ram Air
  136. oil consumption
  137. 04 5.4 Track times
  138. PCV Valve change out
  139. How do you get the fuel filter to come out?
  140. Help with Oil pressure indication problem
  141. 95 MPH cut-out
  142. `Enhanced DTC` code?
  143. Conflicting Codes
  144. 2003 5.4L hp/torgue chart
  145. 2001 4.2 constant light pinging at cruise
  146. Havoline Synthetic ????
  147. coolant in the oil
  148. PO303 Cylinder #3 Misfire
  149. Power Steering noise
  150. strange noise
  151. Thanks
  152. Bought Excursion--OIL ??
  153. Truck Stalls After AF1 Fix?
  154. 1994 - F150 Engine Light
  155. will a V8 fit in a V6 truck?
  156. ppfftt,ppfftt,ppfftt...
  157. Oil in intake
  158. Check Engine Light Problem Fixed
  159. Misfire...again!! AGHHHHHH!!!!!!!!!!!!!!!!!
  160. Engine Humming
  161. PO455 Code
  162. Part ID, 2002 FX4
  163. could rumor be possible?
  164. Hissing noise under hard accelleration
  165. Coil pack diagnosis/troubleshooting
  166. Thermostat hmmmm
  167. blue exhaust smoke
  168. I am having Oil level problems
  169. How much for an engine swap?
  170. 1998 F150 4.2L P0401 Code
  171. DPFE sensor voltage
  172. K&N FIPK For 2001 Expedition (Kit #)
  173. Lifter noise
  174. Speed mods
  175. 1994 F150 302 Starts and runs till hot
  176. Question about mods for Bronco
  177. Perplexed about engine ratings for the new 2004 F150 and F250
  178. Changing oil filter on 99 4.6
  179. Build Sheet??
  180. Rear main seal
  181. rusty sparkpugs
  182. 97 4.6 missing
  183. Help - 5.4L Cranking problem
  184. Is this notch supposed to be in the water pump backing plate?
  185. IAC valve?
  186. anyone mess around with the 4V heads on an F150 5.4?
  187. Check Engine Light
  188. Engine Stutter
  189. Broken Exhaust Manifold Stud ('97 F-150)
  190. 4.2 v6 reliability
  191. 93 Tracer periodically dies....?------>
  192. Water temp gauge installation in heater hose...Which one??
  193. Spark plugs?
  194. Modding the stock airbox
  195. Help Whats wrong
  196. 5.4L Power Ratings
  197. used Sea Foam...Nothing, not even the white smoke
  198. high mileage '97 f150-what can go wrong?
  199. 87 EFI Stalling
  200. Question for Neal...
  201. 1988 300 (4.9) motor in to my 1994?????
  202. PIP in Distributor??
  203. Great Deal on Airforce One
  204. Got a Code....need help.
  205. Might Buy F150, would appreciate help and advice. Plese read
  206. Changing plugs--any special tools?
  207. How much would you pay...
  208. Hum or Whine under the hood
  209. draining radiator
  210. Code Scanner
  211. plug wires
  212. Engine Swap From 4.2L V-6 to 5.4 L Triton V-8
  213. additives ?
  214. Traded ol' Smoky
  215. Pedal rumble???
  216. Question for Mike Troyer
  217. Any bets on whether or not piston slap will still be here in the '04 models?
  218. blowin up the bow tie
  219. Rev limiter
  220. rough idle?
  221. Engine Upgrade
  222. How do i get a code,,,with out going to Auto Zone?
  223. trailer round plug,how do you get the center pin to be hot when in reverse ?
  224. code 8
  225. #4coil
  226. Oil Change
  227. Misfire Cylinder 4
  228. Specific Synthetic Oil Preference?
  229. Ported eaton blower
  230. Power Steering Noise
  231. 4.6L Problems
  232. Belt tensioner pulley bearing noise at 40k miles?
  233. First oil change
  234. i want to put a new cam into my expedition for more power where do i go to find one?
  235. Service Manual or CD??
  236. Just Noticed.?.?.?
  237. Head and cam swap from a 99+ GT?????
  238. New 5.4 owner
  239. O2 Sensor specifics
  240. Dyno Tune
  241. good 4.6 mods?
  242. Stock Throttle Body
  243. Arbitration concerning piston slap
  244. runs like crap
  245. Oil Question----->
  246. Any advice for Header install?
  247. Fuel Pumperooo
  248. 95 F150 Turns over but no start..sometimes
  249. What In The Heck Is This???
  250. New wires and plugs for my 4.6
