- Ping and rattle
- 2003 5.4 engine
- Parts chromed?
- More Power
- F 150 Guru's in here! Need Purchasing help!
- Truck surges forward slightly during cold start warmup
- 4.6L Pinging HELP!!!!
- normal to lose MPG in cold?
- Truck wont drive
- 5.4l Engine Mods?
- clunking sound every couple minutes, thermostat?
- oil burning
- Remote Starters
- Air Modifications
- 4.9L engine won't start
- XLT or XL? How do you know?
- Engine vibration 1500-2500 RPM's?
- Engine dies while driving
- 4.6L sucking water/coolant into intake
- Question on cleaning throttle body
- Problem with keyless entry....
- Knocking Pt 2
- Slick 50 ???
- Code P0455, How to troubleshoot?
- Stuck ring? Or worse?
- Fuel flow questions...
- Hood Release Cable Broke
- Engine dies out, but recovers... REPEATEDLY!
- 1997 5.4 with 150K buy or not?
- Has anyone tried to duplicate the ....
- Oil usage question on 5.4L
- 5.4 Reliability?
- Not the IAC..what is it?
- check engine light
- fuel pump?
- Missing, pinging + check engine light
- '04 cold Start
- Question for Neal
- Modular engine?
- Many Codes, Please Help!
- Water leak, not the water pump
- what kind of cam
- Mass Air conversion
- egr vac line
- Hello. I'm new and have a few questions.
- What is R/R?
- Engine stalling while driving
- Engine Wont start
- Amsoil, a MLM Cult ?
- 5.4s intake regulation motor ?
- Why?
- my ford is dying
- 94 F150 motor troubles
- mobil 1 oil
- squeaking 4.6L
- Lost the alternator twice in two days.....
- Can Someone Help
- anyone w/5.4 and 195 thermostat
- P1131 Comes And Goes?
- VIN Check Please Please
- Ratle Sound at Start up
- Piston Slap - Not just for Fords Anymore
- new 2004's how are they
- oil burning smell? help needed
- should i disconnect the battery
- 81 inline 6 barely runs
- 6.0 Excursion reliability
- 1999 5.4L, 5W-30 or 5W-20?
- Horsepower
- new 4.2 pwner
- Fill'r up (oil)
- All Data DIY
- diesel engine exhuast
- Possible Starter?
- new rebuild
- Oil change question
- timing belt change
- 4.6l gas mileage
- EGR-EVP codes 327&328
- Spotting Blown Plug Damage
- 5W20 and the lottery
- Anyone have this remote start? Command Start 2400/2500
- Headers
- Ran w/ oil cap off, engine now running badly
- Tornado insert?
- 98 Expy Oil Leak - Question
- How much horsepower??
- 5.4 compression ratios
- low oil pressure on fresh re-build
- Ignition coil D primary secondary circuit malfunction
- Changing The Oil Filter
- Another Ford w/ a bad idle
- Oil analysis
- maf
- Radiator
- motor finally went
- Dull chrome intake?
- 4.6 or 5.4?
- Knocking
- Installing a Motorguard Bypass Oil Filter
- electrical mystry
- Forged crank ?
- o2 sensor
- o2 sensor
- Fan Clutch
- Check Engine Light trouble solved
- Mobil 1 synthetic oil and coasting
- Best Air Intake?
- Stupid Heater Question..HELP!
- Bank 1 too lean
- spark knock/detonation?
- CA Emissions
- question about clatter
- idle trouble!
- Start synthetic at 60k Miles?
- #4 Coil on the 5.4
- high rpm sqeak
- Synthetic Oil Question
- Weird Engine or Something Else
- rpm
- 2004 5.4L F150 underpowered?
- Piston slap
- Newest Mod...
- Headers for 5.4 Help
- More Power
- EGR valve cause engine die?
- Platinum vs copper plugs??
- Underdrive Pulleys Installed ( pictures )
- Performance
- uhhh...IAC?
- Need recommendations
- question
- Timing chain (when to change it?)
- Black smoke & Poor starting
- Loss of power after truck warms up?
- Fuel Delivery Upgrades
- Changing Spark Plugs
- New to site - with too many miles
- Air Intake Systems -vs- Replacement Air Filters
- Tornado Air Management System
- Changing Fuel Filter?
- 2002 4x4 what octane fuel?
- Check Engine after GMS MAF install
- Hit from behind. What should I expect?
- 5.4L SOHC V8 (2V) Underdrive options
- smoke and loss of power
- Mobil 1 racing oil soon to be released!
- Thermacter air pump???
- 1989 F150 codes question, please
- V6 vs. V8
- Compression Test
- Idle air control valve location?
- Underdrive pulley how to??
- 5.4 misfire?
- 1989 f 150
- Rad Size
- Woo Hoo 1/4 Million Miles
- thoughts on 2004's
- 5.4 cranked over but wouldn't start.
- Aftermarket fans
- Head Gasket
- Electronic motor mounts question
- new truck break in
- 5.4L Engine block drain plug
- pan leak/o2 sen.
- Injector's and Colors...
- 5.4L Question: How much can it take?
- Gatorback or any other belts
- what the-what the....iac
- canister between spare tire and rearend
- New 04s, anyone got MPG data
- Drain plugs on the engine block
- IAC voltage????
- weird turn signal
- Gotta say one more thing about that 241k 4.6...
- '97 F150 oil filter location
- idle at start up
- 4.6 q's
- supercharger?
- Tips for finding source of vibration???
- hypertech hp/torque on my 98 F150?
- gas mileage
- Volant
- more miles per gallon pleeeeze
- 5.4 starting problem
- Low on oil !!!
- Vibration?
- 1999 F150 Airbag
- 1989 F150 fuel problem
- Update on that high-mile 4.6L F150...
- mass air flow sensor
- Mobil1,WalMart and 18.88...
- Idle on startup
- new truck, advice
- Checking coil on #1 cylinder? 99 5.4
- 93 Octane
- Fluttering
- Honda Accord Question sorry
- 4.6l not kicking in to passing gear?
- Heat diverter?
- 97 F150 4.6L 213,564 miles,low idle,idle surges,weird air/fuel mixture
- HELP !!! Check Engine light
- Need help with 4.6 wiring
- Strange heater
- Intermittent Rough Idle
- no heat
- door locks going bad
- Bad bearing noise stops when fan engages . . .
- EGR Problems...I think
- Defective heads Question on '01-'04 4.6L's...
- 4.2 to 4.6
- misfire after a heavy rain, only under a load
- 5.4L Rebuild Questions.....Bear With Me Please.....
- #5 Plug in 4.6 : Threads Rusty!
- Fuel filter help with a twist
- Check this out...new on Ebay
- Cold Air Induction
- thanks guys bad voltage regulator
- swap 5.4l to a ford lighting engine?
- New spark plug?
- bad idel
- Hmm break in period on Reservoir & Valve?
- Maybe wrong forum but...
- oil filter change
- Check engine light
- Thermostat
- 6.0 diesel
- MPG with a 5.4
- Defective heads on '01-'04 4.6L's...
- Coolant Leak Help
- Engine Strain With Heat On
- Helicoil spark plug hole insert
- Holy Grail of MPG
- anyone got a pic of the IAC on a 99 4.6 ?
- battery light flash's on @ redline
- Spark plugs changed
- Selling my F-150
- 5.4 idle miss acceleration stutter
- Jamaican Chapter
- Misfire and loss of power
- OIl Pan Magnet
- Resetting computer always clear code?
- Oil pan
- hesitation/code 172
- Need help bypassing my A/C pump
- Head gasket replacement
- Knock sensor
- Throttle body/butterfly adjustment
- intake manifold
