View Full Version : Engine
  1. Thanks Steve!
  2. f250 v10
  3. Fuel Filter tool
  4. heads up on factory plugs
  5. Header Install Price
  6. Truck Specifications
  7. Belt Shriek after WOT?
  8. Problems after replacing 4.2L
  9. ERG Valve Operation?
  10. 1998 ford f150 4.6l 4x4 engine question
  11. Idling Problem
  12. Fixed 86 302, would stall when pulling off from a stop.
  13. Need performance enhancing advice
  14. Best Motor?
  15. WOW, this sucks.....
  16. 5.4L Engine Backfire
  17. Positive dealer experience
  18. Buzzing from top of motor
  19. Oil pan gasket question
  20. Ticking Noise From Engine At Idle
  21. Throttle Body Crud
  22. Quick 150 Question, Please Read!
  23. gas mileage
  24. Tensioner pulley, Ford says I don't have the one that's on my truck, what gives?
  25. 2003 Stalls
  26. Your Thoughts On Spark Plugs
  27. drain hole in muffler??
  28. IAC Valve Replacement
  29. paid mechanics
  30. Cylinder 5 and 7 Misfire Repeatedly
  31. Surging idle only in Park or N
  32. Helicoil w/ socket - now guess what!
  33. Advance Auto Brand
  34. egr gasket
  35. V8 to 6 Cyl Engine Swap?
  36. Blue/White smoke
  37. 93 F150 5.0 engine miss under light load
  38. 1700-1900 RPM Drone and Vibration
  39. E fans
  40. Code question on 4.6L
  41. For those of you that like to do this
  42. 1999 F150 5.4 lower radiator hose?
  43. Replace Serpentine Belt
  44. while changing the oil filter....
  45. Neighborhood Competition
  46. Changing to Synthetic
  47. gas mileage has gone to poop
  48. code 451???
  49. Missfire
  50. Best Oil Filter ?
  51. 4.6l 1 time miss?
  52. Still got the SES light
  53. Trouble code P1518
  54. power mods for the 94 4.9l
  55. Helix spacers?
  56. 97 5.4 gas mileage need help
  57. 1994 E4OD For a 5.8
  58. 4.6L misses at idle
  59. Where can I find it
  60. should spark plug easily thread
  61. How much HP/TQ can a 5.4 make
  62. switching engine oil, question
  63. 98 5.4L Block and crank.
  64. Leaking fuel from filler tube
  65. Changing spark plug on 1998 4.6l
  66. Overdrive on 4.6 V-8
  67. what is the diff between the 98 and 99 5.4??
  68. Superchips Microtuner
  69. Oil consumption?
  70. Cleaning IAC Quick Q...
  71. leaking freeze plug?
  72. Chips???
  73. what cylinder is #2
  74. anyone using a tornado ?
  75. Port/Polish questions...
  76. Ole Blue appears to have the flu
  77. hesitation after having truck detailed
  78. Pulleys & dimming lights?
  79. Intermittant Overheating...
  80. Head Gasket "sweating"
  81. non-F150 problem
  82. Low Fuel
  83. Y'all were right.
  84. Jerking under light load
  85. Warranty Repair HELP!!
  86. 5.4 Mileage improvements. Comments?
  87. 4.6L Power Mods
  88. pressure in cooling system
  89. 2003 4.6 Windsor
  90. ?EGR valve wrench - what size?
  91. fuel milage and bug shields
  92. Off Topic
  93. Humming noise at idle
  94. Replacing Head Gasket: parts list
  95. 5.4L Head, whats the skinny? 99up vs 98 back??
  96. mobil one help mpg?
  97. Throttle Body failure, fuel contaminated oil?
  98. E-250 5.4 cold start hesitation / stall
  99. Engine Kits
  100. 5.4L question Is it PS?
  101. Building a 4.6l
  102. biggest throttle body?
  103. 97 F150 Slight hesitation under load
  104. Code P0320 Troubleshooting....
  105. piston replacement
  106. Engine Troubles
  107. putting a diesel into a ranger
  108. 63k and already a bad oil pump?
  109. 4.6 engines
  110. 1987 F150 302 EFI Fuel Pump Failures
  111. Won't start in Cold?
  112. overdrive or no overdrive?
  113. 302 failure
  114. P1507 Code
  115. Tick Tick Tick
  116. Lookin' for a 1990 computer!
  117. 4.6 power mods
  118. 97,98 vs 99& newer
  119. 5.4L VIN Numbers
  120. engine stall
  121. Help Po401 Code
  122. Changing over to Mobil 1 today.
  123. oil question
  124. HELP asap!! re:4wheel drive
  125. Which Spark Plug?
  126. More Horsepower
  127. sensor
  128. Wrong Spark Plug - now what?
  129. The sweet smell of burning oil...
  130. What does a burnt valve sound like?
  131. Starter whine/squeal
  132. Non-electric fan options?
  133. Gauges
  134. Non F150 Ford Question
  135. High pich whining noise
  136. Strange stalling problem
  137. Cooling Fans
  138. Pulleys and towing?
  139. Going in for tune-up.....need advice----->
  140. Cool Collar?
  141. pulleys
  142. Engine Clatter
  143. Replace and/or upgrade fuel injectors?
  144. P0401 - summary and questions
  145. Engine Light is on
  146. 2001 XLT,I diot oil Press gage?
  147. Code: "Evap Gros Leak" ?????
  148. Need more horses!
  149. 4.6L crankshaft
  150. miss fire #3
  151. 1.7 RR's?
  152. When does the F150 get a diesel?
  153. Oil filter locations (pix, please) OEM or not
  154. Engine Sounds
  155. f250 v10
  156. Help! Antifreeze under intake
  157. 03 rough idle
  158. thin oil at change
  159. Overheating...
  160. **NEED HELP- 4.6 acting up at 95k
  161. squealing noise from steering(turning wheel)
  162. oil leak
  163. Weird Engine Noise
  164. Problem Starting expy
  165. 100mm trottle body?
  166. Metal grinding sound at any speed???
  167. cel po133 - help!
  168. Fluid Help Please
  169. Sputters and Pings when cold, please help!
  170. Rattle
  171. 5.4 turns over, but wont start, bells chime.
  172. Code P 1635??
  173. 4.6 throttle body / egr passage cleaning ;Pinging 90% eliminated
  174. 4.6 specs
  175. Autolite plugs
  176. PCV filter clog
  177. Wont start when hot,engine stall PROBLEM SOLVED
  178. Anyone installing a lightning block
  179. It ain't whistling dixie!
  180. need advise
  181. Cleaning MAS ??
  182. Runs terrible when cold, great when hot
  183. Service Schedule
  184. Possible IAC????
  185. now what?
  186. Mechanic says I got the wrong engine?!?!
  187. Engine swaps?
  188. more pinging/timing/egr..
  189. I hate to ask...but...
  190. Piston Slap
  191. Please Help
  192. pinging
  193. spark plugs
  194. EGR Valve
  195. Gears or Chips
  196. Aluminum engine
  197. will it work ???
  198. 93 F150 302 ping/knock/misfire
  199. Fuel Filter at 15k miles??
  200. 0-30 oil
  201. Mileage Mods: Conclusion?
  202. exhaust
  203. Philippine spec F150 Question?
  204. Can't find 5.4 Settle for 4.6? Please Read! Opinions Needed!
  205. can stang underdrive pulleys work on 5.4?
  206. Clearing error codes
  207. Fouling out plugs
  208. 4.6 Reliability
  209. 5.0 knocking
  210. Chips for 5.4
  211. Milky Oil
  212. Diesel F-150
  213. Engine Ping when temperature is cool/cold?
  214. My personal ping and rattle
  215. 4.6 constant misfires
  216. Damn Check engine light
  217. 88 ford 300 six cylinder help
  218. Throttle Body
  219. 10w30 to 5w
  220. Question for Pestco1
  221. plug wires rubbing
  222. About to rack up 6K miles...need advice
  223. 5.4 engine miss
  224. Coil pack
  225. antifreeze in #2 cyl
  226. Seafoamed Twice & Now Check Engine...
  227. thermostat
  228. Anyone have an AEM intake?
  229. Synthetic Oil, Truck Leaks again.
  230. Engine misfire, stumbles on accel, bucking.....etc.
  231. Install Headers?
  232. think i bought a lemon
  233. BAD Vibration, no apparent internal prob.
  234. Installing a 5.4L
  235. air intakes
  236. heater problems
  237. fuel injector cleaning
  238. speed density to maf????
  239. 2003 Hp
  240. mo power
  241. ? low idle, almost dies
  242. not able to use rear gas tank
  243. Troyer Fans Installed...(statement for Mike)
  244. Odbii 1451
  245. Fill up with Oil & Ck the gas?
  246. How many miles since 5.4 knock/tick?
  247. 1994 F150 302 SD or MAF System
  248. 2003 4x4 5.4
  249. No compression in #8
  250. Constant "pinging"
