View Full Version : Engine
  1. Call me a woos- SPARK PLUGS
  2. Water In Spark Plug Holes!!!
  3. milky engine oil at the filler cap
  4. NEED HELP (codes & problems) please
  5. '97 4.6 died today
  6. engine shuts down
  7. Check Engine Light - '97 4.6
  8. Squealing from engine bay? (in cold)
  9. Bypass Oil Filter
  10. Thermostat Question???
  11. F-250 with 5.4
  12. Look what I found when fixing "P 303"
  13. 1987 F150 4.9 hard startup
  14. How many here really use Walmart Supertech oil ?
  15. Maybe someone can help me?
  16. engine codes
  17. Best HP gains for the buck??!
  18. Anyone lost an engine because of oil?
  19. need help
  20. Plugs For Nitrous
  21. Question about durability
  22. Starter/Flywheel Noise?
  23. changing plugs on a 4.6
  24. 2004 F150 Heritage 4.6L Programer??
  25. P0175 Code
  26. Coils!!!!!!!!!
  27. '97 5.4 rocker arms
  28. Gas pedal sticks at first...
  29. idle problem associated with battery
  30. aux fan noise
  31. Oxygen Sensors?
  32. 1998 4.2 rough cold starts
  33. 1990 f150 engine view
  34. head gasket problem? HELP!
  35. Filling new Oil filter w/oil
  36. Couple more questions on P0401 (EGR)
  37. Biggest Gas tank to fit a Supercab Shortbed?
  38. 2 questions, please help
  39. WD-40 freezing point
  40. 300,000
  41. ok a repeat question I KNOW-what are best plugs
  42. 4.2, rough cold starts
  43. What triggers the P0171 error ?
  44. #3 Misfire - Will this fail smog?
  45. Code P401?? Check engine light on.
  46. Conventional vs. Synthetic Oil?
  47. 19 # injectors
  48. can't find my after cat O2 sensor E350 van
  49. Oil Filter Solution
  50. Took her to the repair shop today
  51. transmission fluid in gas tank
  52. #3 coil replacement tricks for 99 5.4
  53. coolant additives
  54. new fuel pump for rear tank 92 f150
  55. o2 sensor, best price?
  56. P1401 Code F150 2001 4.2 V6
  57. Cylinder head distroyed: need advice
  58. 3.8 SC engine swap
  59. Please help
  60. mass air conversion for 1993 bronco 5.8 e4od
  61. Do you need to pull the engine for a head swap?
  62. Getting more horsepower out of the 4.6
  63. Cold engine dyno numbers
  64. MAF size question
  65. Electric Fans & Snowy Weather...Part II
  66. Cold start humming noise until warm
  67. code P1451
  68. Yet Another Ridiculous Oil Subject Thread
  69. f150 Diesel?
  70. TPS voltage?
  71. P0303 #3 Spark Plug Misfire
  72. 2003 supercrew mini overhead console wiring
  73. Remanufactured break-in period...?
  74. 86 E150 Has Weak Injector Signil Want Run
  75. Oil pressure problem at during cold outdoor temps......
  76. Head Gasket Leak, how do I know
  77. 5.4 SOHC to DOHC swap
  78. Low oil pressure in fresh rebuild 5.4
  79. Oxygen Sensor
  80. roller motor
  81. Older Ford Parts
  82. 4.6 to a DOHC 5.4
  83. P0301 misfire
  84. Has anybody heard of.......?
  85. bad gas cap= bad mpg?
  86. High Idle
  87. F-150 engine accerates with clutch is depressed
  88. 2003 4.6L Oil leak
  89. 5.4 Engine Questions
  90. 1999 F250 vs 150 Whats the difference? HELP!
  91. 98 Romeo question....
  92. v10 engine
  93. 99 F150 replacing the heads
  94. didnt start this morning
  95. What radiator should I buy?
  96. Spits and Sputters when cold Please help!
  97. 1988 302 w/AOD tranny into 1981 F-100
  98. Timing adjuster for F150 5.4?
  99. What build date did they make a change on the spark plug holes
  100. Engine stalling
  101. best place to get gatorback belt?
  102. Water in #7 & #8 spark splug housing
  103. Help/Head Gasket/How to approach Ford
  104. Need start up info
  105. '02 '03 4.2's still POS's ???
  106. 1999 Expedition 5.4 How Much Nitrous to safely Spray?
  107. Oil Level at time of oil change
  108. Home skillet
  109. Ignition Timing Specs '96 5L F-150
  110. The 4.6 V8:what should I know?
  111. PI heads and increased compression ratio...
  112. 5.0 rebuild injector question
  113. injector cleaning
  114. How do you change PS fluid?
  115. running rough
  116. F150 5.4L engine - When for F250/F350
  117. Service Engine Soon light on
  118. mpg has dropped alot, cant figure out why
  119. PI Heads and Mustang intake
  120. 2003 Screw 5.4 clear coolant ? 6750 GVWR Pkg ?
  121. Is it worth it ?
  122. Remanufactured engine cost...?
  123. high idle, torque conv engage, disengage
  124. ps whining
  125. check engine light
  126. 97 F150=dead?
  127. 1 Double Plat Plug 7 Single Plat
  128. high revving on startup
  129. Rising fuel $
  130. How to improve 5.8L Gas milage?
  131. Testing oil every 1,000 miles - Results for Mobil-1 synthetic
  132. Big Trouble in Little V-8
  133. Foreign object in cylinder???
  134. Testing COP
  135. How do you....
  136. skipping at low rpm's
  137. Denso Iridium plugs on a 4.6
  138. swap '83 GT 5.0 into '95 F-150
  139. coil pack replacement
  140. Do all spark plugs need to be the same?
  141. Cutout at 100 mph - governor??
  142. Slight kind clunky noise in front end
  143. Loctite on Spark Plugs
  144. How to get center pin in trailer plug to be "hot" henin reverse
  145. Plug and Wire board preferences
  146. 97 4.6 pcv port
  147. Fuel pressure test port
  148. Fluctuating / Erratic Oil Pressure Gauge Fix
  149. OBD II scanner?
  150. vibration problems at stoplight in gear
  151. transmission
  152. Engine injectors
  153. Fuel injectors
  154. why do coils go out?
  155. 4.6L MPG and lifespan
  156. HP gain for adding PI heads to a 98 5.4?
  157. Does Mobil1 make a type S filter?
  158. Headers Installed
  159. misfire cylinder 2
  160. 4.6, ready to kick bucket?
  161. Comp Cams/ Anyone install?
  162. Difference in Dyno's
  163. Some more info
  164. 91 F150 cranks, won't start, EEC codes pulled
  165. Strange noise in Subzero temperatures??
  166. Chip Plug-in point on ECU
  167. Replaced only one spark plug
  168. Running Rough - Any Ideas
  169. engine oil cooler
  170. PCV Valve Replacement
  171. Need help/ engine miss
  172. 351m
  173. Starter frozen?
  174. 99 f150 starter replacement
  175. Replace or rebuild?
  176. Espar Diesel Fired Engine Coolant Heaters
  177. Aqua-tune
  178. Anybody know of a website link with photos on changing an EGR Valve?
  179. Leaking head?
  180. Stay away from Bosch plugs
  181. Adjusting TPS to .99
  182. JBA Shorty Headers Bolts
  183. Electric Fans and Snowy weather...
  184. loud knocking when cold
  185. *SPAM* Ebay Item
  186. 2003 Roush Mustang
  187. 5.4 The final word. Techs Please Read
  188. "Check Engine"?- 1998 5.4
  189. engine specs?
  190. Wattage Draw on Block Heater
  191. Slight Vibration at 39MPH &...
  192. Is 20w-50 Oil in a '98 4.6 a good idea?
  193. Code Scanner
  194. 98 F-150 4.6 Intake Info??
  195. oil sending unit
  196. Valve Cover Torque Specs?
  197. High Idle Speed, 1990, 5L, 40,000 Miles
  198. problems with new 351
  199. problems with new 351
  200. problems with new 351
  201. Fuel filter frequency
  202. Cold Starts
  203. Ford GT Engine information
  204. TERRIBLE Clatter
  205. check engine light on
  206. Miss Firing, Sputter, Hesitation
  207. Sticky Throttle Body, What To Do?
  208. Better Gas Mileage
  209. A litte troubleshooting help please?!?!
  210. 86, 460, Cranks Then Sometimes Starts
  211. 5.4l Block Heater
  212. Head Recomendations
  213. Stumble at 1300-1600 RPM
  214. Doing your own tune-up on a V6
  215. Platinum plugs required?
  216. 50,000 inspection tips
  217. 2003 Lariat center console addition - also chip
  218. hooking up a tach to a '98
  219. Opinions Please!!
  220. F150 Ignition Problem
  221. Does anyone have a 5.4l?
  222. Loosing Coolant
  223. Loosing Coolant
  224. Loosing Coolant
  225. Loosing Coolant
  226. Where is the fuel pump reset switch for a 2000 F150 5.4l engine?
  227. 2004 f-150 engine noise
  228. oil filter relocation
  229. Has anyone done a step by step on replacing the EGR valve?
  230. Water in engine
  231. New tires, need a little motor help
  232. Odometer Question
  233. The Engines Black Hole...
  234. Service engine, code 125
  235. 98 F150 Failed %CO in VA Emissions Test
  236. Fuel injection to carburetor
  237. 351W Stock Hp
  238. A couple of dumb Q's
  239. 4.2 V6 gone?
  240. Whats the best f-150/truck to pull the 351 out of
  241. Rough Cold Start
  242. Random / Multiple Cylinder Misfire
  243. 40 w oil
  244. Cruise Control not working on a 97 F150 4.6
  245. 1994 F-150 trade???
  246. 1998 engine cutting out
  247. need input from performance buffs
  248. When to change spark plugs?
  249. Fx4 with a 4.6?? What Gives?? Please read!
  250. Seafoam
