- What kinda Deals did everyone get?
- STAND ALONE FUEL SYSTEM for 5.4 2001
- spark plugs/PCV
- Slight pinging
- Air Force One intake
- Programmers
- i have no codes flashing and no spark
- Check engine light going on for a day then off
- fram oil filters
- Spark Plugs And Wires
- oil disappearing
- Alternator Problems
- Engine light turns comes on at restart
- OBDII and throtle position indicator problem
- Oil on top of Valve covers - 2002 5.4
- Seafoam...sieze / lockup the motor?
- MAF Sensor
- whine.....cant get an answer
- P0401 After Air Filter Change
- 95 and 02 SCREW Q's
- spark knock
- Sparkplugs.com
- Am I missing something? (Pic)
- 2001 4.6 SCrew Plug Change
- '97 triton4.6 F150 oil pan removal (maybe)
- Fuel Pressure? 302 5.0 Fi
- Airaid
- Throttle Position Sensor
- problems??
- Plastic clicking sound when turning engine off
- Engine Hesitation
- P0174 code
- What ratio roller rockers?
- Engine dieing in gear
- Truck has hesitation under accelleration
- ok, who knows about side mirrors, question..
- Where do the Vacuum Lines come out of the firewall?
- bad missfire at all times
- 5.4L PI Casting Number all the same? Expert help needed!
- v6 or v8
- odb2 171 and 174
- Cobra R Water Pump
- Thought I had a bad Idler pulley
- Denso Spark Plugs?
- code 1401
- CarFax Help Oasis?
- 302 eng. turns but no start
- Rough Idle
- Coil Issues.
- Engine Noises
- Errors while check engine light off?
- 4.2 to 4.6
- F350 running very rough please help
- Let you know about mileage after 0171,0174 solved
- Bingo! Throtlle, Steve and all you guys
- synthetic motor oil
- New engine
- Truck dies when driving
- Synthetic
- Hard on the engine?
- How many RPM's? 4.6L
- engine swap
- 5.4 Triton O2 Sensor
- 1986 F250 Diesel, info needed
- O2 sensors bad, should I replace or clean injectors
- Got codes: p0171=bank#1, p0174=bank#2
- 2002and2003 5.4
- 03 Expo 5.4L rough idle intermittent
- Collapsed PCV Elbows
- Engine nearly dies when stopping
- Are the Cheby's really that bad ? Man they are giving these things away
- engine ground from batt. sparking
- Sea Foam uses and suggestions
- piston size
- Save your receipts boys and girls
- whats the best plugs and wires? 4.6L
- Bad pcv, how to tell
- Turn off computer reporting
- 2004 Lariat 5.4 3v Rev Limiter?
- 4.2l V6 with 38,000 miles bad rod
- EGR Valve and Solenoid
- Failed smog.. and the codes are.....
- Poor engine performance
- 4.9 shredding belts
- Check Engine light is on code P1451 5.4 F-150
- '98 F150 4.2 Intermittent Misfire
- Loud rattle at startup
- plug/wire question
- PCM and EGR Valve????
- Noise in Engine, dealer won't tell you! Ford Knows why!
- Check engine! what to look for
- F150 no crank no start
- PO125 OBD2 code
- 5.0 Power
- truck died while driving today
- Oil filter relocation kit...thread size?
- Are my sensors bad?
- 302 Trouble code
- Code P0141
- 2000 4.6 cutting out
- check engine light - on again, off again
- Engine swap question
- funny cool down sound
- 98 f150 spark plugs and wires
- Wife's Taurus won't start after warming up
- Heater Hose Replacement
- A/C Compressor coming on with heater?
- Door Ajar sporadically kicks on while driving
- 5.4 missing at idel
- XLT & Styleside whats the diff ???
- Draining oil
- " Rattle " snake of an engine, Help.
- Seafoam in Canada
- Rough idle and loping
- Howl from engine compartment
- Spark plug and wire help 97 4.6L F-150 Vin 6
- okay, how do you get the filter off?
- gas mileage
- Gas milage and air intake???
- Starter dead, sparks flying, help please!
- Is a larger radiator possible?
- where can I get a 7 pin round trailer wire plug for my 2003 Screw
- Noise when engine off and cooling down
- need help!
- ACTUAL Gas Mileage
- Does Ford even care? PLEASE READ!!
- 1993 F-150 Almost Dead!
- Oil for the f 150 help
- 91 F150- IAC, EGR, Junk??
- Re:
- Fan clutch nut removal
- 5.4 coolant temp sensor-where?
- Questions for Factory Tech
- bad EGR valve
- Another IAC question
- whats my aprox hp?
- what size motor is the 4.6l V8?
- 4.6L Windsor/Romeo
- New 2002 F-150 owner !!!!!! opinions?
- Anybody work at an SVT dealership
- what do i need to pull a chevy?
- blue and red vacuum lines
- Seeing if I have PI Heads
- Rubbing Noise from Steering Wheel
- Plug wire, injector, coil?
- Headers on a '83 f150 4.9
- 79F250 300 6 cyl. to 351m engine swap
- 4.6l engine removal
- '93 302 w/problems
- 5.4 Plug Boot Removal Trick
- New 5.4 coil resistance sub-par.
- running fine.but ticking sound
- rear end hum
- Poor fuel economy...?
- 5.4 Dohc
- Air intake problems
- spark plugs
- two problems "engine service soon" and blinking light
- backfire? and now it has a mis>
- intake noises and rattles
- Creamy stuff on oil cap
- hesitation,miss,studder
- Who Makes Walmart Super Tech Full Syn Oil
- Any one know of a place that can do Motorswaps In San Diego
- 2000 F-150 Fuel Filter Replacement
- Low oil presure
- Spewing Gas out of filler cap
- throttle body spacer
- Engine missing and running rough under hard accel.
- Fuel Filter Replacement Problems
- anyone have crane 2030 cam and SD?
- my new truck has oil consumption probs?? help
- p0171 Lean on Bank one
- stuck spark plug
- i6 to v8?
- P0307 Code Problems?
- Piston Slap 5.4
- 300,000 mile to 400,000 mile questions
- overdrive?
- Electric Colling Fan
- misfire on cylinder three code p0303
- Remote Filter Oil Leak
- 92 F150 Ecm
- Air Induction Systems
- 2001 5.4L F150 Super Crew with a bad miss
- Oil on spark plug?
- Skip or Miss
- starting somewhere on engine mods
- Do it yourself electric fans???
- Insufficient flow related to misfire?
- need some ideas,Please
- Rich Codes.......P0174 and p0175
- Easy question Need help quick
- gas cap (sucking noises)
- clunking tranny in a 5.4
- Engine Swap help!
- Anyone know this code?
- Lighnting Blower on 2000 5.4
- performance mods? - 95 4.9 6cyl
- 90k miles ???????????????
- Seafoam users, need some help
- TPS Adjust Question
- whats going on with my truck?
- Please help...
- Cold start clatter 5.4l
- Is a 99 motor a direct swap for a 98 motor?
- Fuel Additives
- Antifreeze / water mix???
- Are the heads on the 4.6 and 5.4 the same?
- Hello!! And 5.4 L question
- Heavy Duty Radiators??
- 5.0 surges after rebuild
- Higher Idle In 4WD Low??
- Need a new starter??
- 89 F150 I-6 start/run problems
- 1997 with hesitation/miss
- Misfiring and Oxygen Sensors
- Overfilled Oil
- 99 5.4 won't crank
- exhaust leak and missing?
- Can't believe nobody knows anything about this
- Coolant Temperature Sending Unit...
- Truck dies, need help!!
- Fast idle when warm?
- Electric Fans
- normal clunking noise?
- saw a blk truck the other day with the emblems outlined in gold,who does this
- 2003 Screw gas cap light on in the dash
- engine rebuild
- battery light flickers after changing serpentine belt
- Oasis Anyone? Carfax?
- lost power
- Help, Cylinder Location
- Mustang guy got his first F150 (1992, F150, 302v8), what are some mods I can do?
- 4.6 at WOT
- Engine upgrade
- Whats in a name ?
- Engine shakes violently
- Fuel pump kicking on when motor off?
- engine swap
- '01 Explorer V-8, AWD, Advice please
- '93 F150 Cruise control not working!!
- Noise from gas tank
- blue smoke
- Step by Step on 4.6 PI Head Swap
- 5.4 V-8 rocker arms
- Oil Sending Unit
- Zex Nitrous Oxide
- Coils
