View Full Version : Engine
  1. 8 new coils, Inj ring kits, NOW WHAT?
  2. no starter crank
  3. Need help!!!! Is this a Freeze out plug that need to be replaced?
  4. 2002 4.6L DPFE Missing???
  5. anyone usiing a bbk throttle body?
  6. service manuals
  7. wierd noise...help identify
  8. Oil Gauge Problem.need Help
  9. 5.4 stalling at startup
  10. Fan Clutch
  11. help! 97 smog stuff
  12. Service Engine Light
  13. Engine swap question
  14. 1994 F150 4.9L fuel economy
  15. EGR and IAC cleaning
  16. HELP engine running lean on bank 1 and 2
  17. mileage and the f150
  18. I need a bigger carb
  19. Problem found...
  20. cleaning EGR ports & TB
  21. Performance Upgrades??
  22. do i have a chip or not
  23. Mechanics Stethoscope question...
  24. System too rich (bank 2)
  25. engine identification
  26. 1988 F150 302 fuel mileage
  27. 6 cyl missing
  28. misfiring at all RPM's
  29. [HELP] What's wrong with my truck?
  30. COP's (how hard to replace)
  31. sluggish!
  32. Cel 4.2l V6
  33. Oil Leak-Head Gasket
  34. Exxon gas and Ford Injectors...
  35. AC mode changes at half throttle to Defroster mode...
  36. Adding Lightning blower and getting smogged
  37. P0171 & P0174 But NO vaccum leak!
  38. Life of the 5.4L 3V engine
  39. Newbie w/2004 4.6L Question
  40. Replacing O2 sensor
  41. OIL and oil filter questions.
  42. Do you need a PDFE sensor?
  43. New guy with prob.
  44. 5.4L Redline
  45. Oil Pan on 1995 F-150
  46. Misfire detected #2 Cylinder
  47. Indeterminate 5.4L problem
  48. Cleaned air intake/throttle body, now CEL
  49. 94 bronco idle, shift, start problems
  50. Mass air flow sensor?
  51. Leaking injectors 04 f250 FX4 super doodoo Lariat
  52. Lean Condition Bank 1 & 2
  53. low idle after running
  54. Pinging and knocking proublem solved!
  55. Pinging and knocking proublem solved!
  56. Pinging and knocking proublem solved!
  57. 96 EGR Code
  58. 1997 f-150 engine removal
  59. timing a 302?
  60. running out of ides...ignition
  61. sick of the misses
  62. 2004 5.4 V8 Oil Filter
  63. Found out something very interesting today about the 4.2 V6's...................
  64. P0171 & P0174 after plug change...
  65. Spark plug change
  66. hesitation while accelerating
  67. Head Gasket
  68. Triton v8 question
  69. New 5.4 in Expy??
  70. Belt squeal
  71. Why is my truck running lean? how do i fix it?
  72. seafoam good or bad?
  73. Will this hurt my engine?
  74. Slightly OT, back in the saddle again.
  75. Engine miss
  76. rough idle
  77. Any confirmed mileage gains with intake kit?
  78. Other brand help? EGR Probs...websites wanted?!
  79. Po141
  80. 97 4.6 - Stall and Buck
  81. Cylinder Numbering
  82. Oxygen sensors?
  83. slight surge, and sluggish take off
  84. anyone want to buy a truck
  85. 2004 Engine swap
  86. Stock Fuel Injector size
  87. o2 sensors replaced still have light. Now what?
  88. possible thottle body whine
  89. Battery light flashes on at high RPMs. Any ideas?
  90. Anyone Notice This
  91. who makes the best dino oil?
  92. Building a CAI system
  93. Cost of an engine swap
  94. how cheap?
  95. a toughy?
  96. apc intake
  97. 86 F-150 Egr
  98. High idle after port and polish?
  99. Rough Starts
  100. 98 4.6L Triton V8 Misfiring
  101. When it rains, it pours...
  102. Fuel Injector problem
  103. Coolant change - Temp gauge up slightly
  104. intake kit or airbox mod?
  105. Expedition engine swap
  106. Same Ol Same Ol
  107. Rough idle after highway driving
  108. CEL P0401 Finally fixed. Not the way you think!
  109. Weber 2 barrell on 300 inline 6?????
  110. EGR (P401) Problem Fixed!
  111. hoses.
  112. Big tps problem
  113. well I guess i shouldn't have come here for any advice......................
  114. engine miss, # 4 misfiring & running rich.....................
  115. Mustang intake Swap for 150 4.6
  116. Help!!! won't start
  117. 1988 F-150 won't start
  118. Coil problems
  119. engine stalling
  120. Just got 1999 f 150 long bed...
  121. 5.4L rough idle/stalling fixed
  122. Air Intake
  123. Question about head bolts
  124. 5.4 Replacement Spark Plugs #'s
  125. Low one quart after oil change!
  126. 10w-30 or 5w-20
  127. 2001 5.4L MISSING BETWEEN 1200rpm and 2100rpm
  128. Bad idle, low performance, fuel milage, dealer CND
  129. Whats better...
  130. question for people in north carolina?
  131. DPFE sensor, where to get?
  132. Motorcraft Filters... cheap!
  133. Time serts or not?
  134. Check engine code
  135. howling noise
  136. 300 sputters and stalls
  137. changing oil without filter?
  138. K&N question
  139. Crate engine for a 1990 f150
  140. won't idle need help
  141. rear main seal
  142. Blocks interchangeable?
  143. INtermittent high idle
  144. P401 Troubleshooting
  145. Please help: intermittent P0401
  146. Sea Foam substitute??
  147. Question for Labnerd Regarding Motorcraft and Chevron Oils
  148. CarChip data chip
  149. Electrical Problems!!
  150. Electric Fan Questions...
  151. interchange
  152. Oil change questions
  153. Dynamometer
  154. gear swap
  155. Temperature problem
  156. Power Steering Cap
  157. 2000 Lightning Engine miss (please help)
  158. Who makes the Best Engine Oil?
  159. lightning engine for sale
  160. Weird vibrating noise coming from behind pass headlight in 5.4 expo?
  161. Why does my truck keep dying?
  162. v10 smokes on start up
  163. Higher amp alternator bad?
  164. K&N Oil filter
  165. question on tuner chips?
  166. pics of my engine & truck
  167. V8 verses the V6
  168. Air conditioner not working - remove?
  169. Where are the coils on 4.6L?
  170. another spark plug replacement question
  171. smog pump
  172. Cant figure this out!
  173. gas mileage at high alt.
  174. fluid changes
  175. Gas Mileage
  176. Ole Blue still sick
  177. Help choosing a mechanic
  178. How does this engine sound?
  179. Can You Solve The Mysterious Hunting/idle Fault 96 Escort 1.8si?
  180. Making a noise that is difficult to explain...
  181. 300 6er, high gears, little time.
  182. vacuum hose routing
  183. Clicking
  184. 2 gas tanks but one doesn't work
  185. Poor acceleration up to 2500 rpm
  186. BAAAAD Gas Mileage
  187. http://www.turbonator.com/
  188. Cold Air Intake
  189. 6.8 V-10 will not ide when cold...sometimes??
  190. Need help on error codes
  191. 97 F150 4wd
  192. F150 O2 code
  193. 160%thermostate a mastake?
  194. Check Engine light won't turn off
  195. 2000 Ford Expy engine troubles??
  196. Boost Gauge
  197. 4.6 vs. 5.4
  198. Previous owner used Pennzoil in my Screw!
  199. VSS location?
  200. Ideas on how to maintain your truck/add HP
  201. Burnt valve?
  202. ignition problem
  203. Houston We Have A Problem
  204. gas mileage
  205. where did my oil go?
  206. Best place and price to get remanufactured 4.6L engine?
  207. f150 tempature guage
  208. Anyone have the instructions for timing on this?
  209. Engine exchange
  210. Need Help Please !!
  211. 89 302 heads
  212. Belt slipage on 4.6
  213. It's Still a FORD!!
  214. Alternator questions, please help
  215. 6.2L for F-150 dubbed Hurricane?
  216. p0401
  217. In need of your advice...
  218. Injector Swap
  219. Not exactly non-Ford...
  220. need help with non-ford ?
  221. 1998 F150 "won't start"
  222. 1997 F150 4.2L Head Gasket Leak
  223. Engine sputtering????
  224. 5.4 24 valve engine noise
  225. 97 F150 5.4 L belt routing
  226. alternator with clutch?
  227. Bad alternator, makes whining noise?
  228. Need help with fuel injector noise
  229. Spark plug numbering
  230. Valve covers
  231. Cleaning MAF sensor
  232. sluggish,no power
  233. code p1151 1998 ford contour
  234. reset switch?
  235. Oak tree mechanic and newer trucks
  236. 1997-f150 4.2
  237. Air filter
  238. Spark plug coils
  239. Head Absorbing Oil
  240. Mega fuse where are you
  241. 2002 Screw FX4 Radio/Light problem
  242. Setting engine timing
  243. Spark plug torque spec 1998 4.6L Windsor F-150
  244. 2003 Triton engine in 1999 F250??
  245. 97 F150 engine swap
  246. thank you
  247. 77 F100 302 2bbl
  248. Out of ideas....
  249. Ok guys... serious top end question... Neal and other veterans here
  250. Possible Gas tank problem
