View Full Version : Engine
  1. need help ASAP.. spark plug thread size
  2. Auto Repair DVD
  3. Is this a good setup? and am I dreaming?
  4. Are these the same? will they work? Fuel injectors...
  5. Motor's not knocking
  6. 07' F150 spark plugs
  7. PCV Grommet
  8. 2000 F150 5.4l No Power :(
  9. 2001 F-150 SC 5.4L Cruise Control Not Working
  10. V8 Swap
  11. check engine light is on
  12. Engines and mileage?
  13. Check engine light at 50,000 miles
  14. Cam Phaser
  15. Synthetic back to Conventional?
  16. very werid...misfire?
  17. 1997 engine id
  18. Anyone know where the HVAC Vacuum Canister is on a 97 E350?
  19. Hoses to dpfe valve?
  20. Calibrated for Ownage
  21. A/C and Trany ??? little help here please..
  22. 98 4six oil pan drop
  23. Do you have to remove the fuel rail to change COPs on 5.4L?
  24. Getting very aggravated!
  25. interesting website - eco mod
  26. 04 camshaft woes
  27. Low Idle
  28. p0175 ( yes i searched )
  29. 5.4 swap??
  30. Tire Upgrade Suggestions
  31. Engine misfire - no CEL
  32. hesitation on kick down
  33. No Oil on Dipstick, Fresh Oil Change?
  34. new truck,new member
  35. smoke
  36. Will this gauge pod+gauges fit my truck?
  37. Poor performance with '98 4.6l
  38. Crank/ no start
  39. More questions about a 300
  40. Crank but no start issue
  41. need engine info
  42. starting issues?
  43. Fail Safe Mode
  44. Are Global Autos Coils/COPs Good Quality or ?.
  45. If a COP is bad the SES / CEL come on?
  46. Bucking or Body Shake when in overdrive and just touch the gas pedal?
  47. Belt squeel only under load
  48. Plugs
  49. seafoam
  50. Anyone heard of Hesco Reman Engines?
  51. Gasssecret.net - fuel additive - scam or real?
  52. Just looking for some opinions...
  53. Engine and Transmission swap
  54. Help Diagnose Noise
  55. COP'S and A/C ???
  56. Vacuum line missing it's home
  57. Thanks To Everyone That Tried To Help . . .
  58. 1997 5.4L P0174 Lean Bank 2. Where to look first?
  59. Drivetrain Shaft, Throttle Sensitive, Noticed more at higher speeds.
  60. Pulley squeak?
  61. Does anyone have a picture HVAC Vacuum Canister?
  62. 04 3V cam swap
  63. misfire
  64. 4.6l engine rebuild
  65. o2 sensors
  66. A/C stops blowing at face when under load? Vacuum Leak?
  67. 4.6 Upgrade question
  68. motor swap
  69. Question about OD
  70. 4.2 gas conversion to propane
  71. still need starter help . took advice still no go .(jbrew wrong)
  72. Thermostat question
  73. Fast idle only when rolling in neutral?
  74. Lenore, how to modify Mark VIII shroud.......???
  75. Teased!
  76. Diagnostic Codes and Cam Sensor
  77. DYI Cam Phaser Replacement
  78. Fuel gauge sending unit on 94, 4.9 inline 6
  79. I think I blew a head gasket
  80. My truck started missing today!!
  81. how to start your starter with screwdriver ?
  82. Engine Oil Level Question
  83. Oil Question
  84. Ya saw this coming didn't ya.....Ford delays
  85. how to put a starter on 2000 f150 ? please help asap
  86. Problem with my 98 4.6L Sputters/CEL
  87. ok gang I need some help did I get ripped off ??
  88. Vacuum Leak
  89. Radiator Coolant Leak
  90. 4.6L vs. 5.4L, looking at trucks so opinions appreciated!
  91. Idles down/sputters at stop lights - code P1131 - Please Help.
  92. k i didnt know where to put this so i choose here
  93. Fram vs. K&N
  94. SYSTEM too lean code! Drving me CRAZY
  95. A.E.S. patrol (another engine swap)
  96. P0305 code and a few questions
  97. Tune up on a 2000 F150 5.4L V2 XLT ???
  98. P0300 and P0174, Steer me in the right direction
  99. Sparkplug blew out!!
  100. Weak and shacky F150
  101. How much for Junkyard Fan???
  102. 05 F150 FX4 5.4 Cam Phasers
  103. Code 542 on 94 4.9, inline 6
  104. hho car kits?
  105. 4X4 & Low range light keeping poping on
  106. Oil Leak 5.4L Expy XLT
  107. Truck cranks, but won't start - ideas??
  108. 3V w/95,000 miles successful home plug change
  109. efan controller dccontrols or spal???
  110. Cleaned the throttle body
  111. Adjustable fuel pressure regulator???
  112. Rear chain guide assembly?
  113. how to put on starter solenoid ?
  114. SuprCharger Vs Port/Cam/LongTube and...
  115. going through oil in my F150 2000 5.4L
  116. Spark Plug Change issues after please help
  117. Long block or just heads
  118. Engine shutting off
  119. 2004 F-150 (5.4l)
  120. 04 5.4 idles real low 3-4 hundred rpm`s ??
  121. Cam??
  122. Just replaced my fuel pump - no luck
  123. MPG question
  124. Intake Leaks/Gasket Question
  125. 99 expd a/c and heat???????????
  126. Slight tick...does this always mean its a plug coming loose?
  127. missin' again, help PLEASE!
  128. 2000 for f150 a/c wiring diagram
  129. 5.4L 3V plugs!!!
  130. Are the dreaded "seized spark plugs"... ???
  131. 99 5.4L DPFE Replaced, Now What??
  132. Ordering a new belt tensioner
  133. When is the next group buy Troyer Efans???
  134. Timesert 5553 kit vs 5554
  135. 2000 5.4L f150 ignition coil
  136. Newbie with a 2000 F150 XLT 5.4 ???
  137. are the 3.5 & 4.6 the same
  138. 4.6L Oil Pressure Flutter
  139. E-85...to use or not to use??
  140. Call me stupid, but it has to be done
  141. How's ur truck runnin with Champion 7989 Plugs??
  142. Keyless entry system help
  143. Cooling Fan Running all the Time
  144. Won't run when hot
  145. NBS 4.6l spark plug change
  146. Coolant flush?
  147. Loss of power.. Bad converters?
  148. Need engine info help! Mustang guy!
  149. Po402
  150. Water for gas ???
  151. EGR Move
  152. I Love Ebay!!!!!
  153. Using the PM-3 to help with spark plug removal
  154. Coilover Plugs, which one?
  155. Rookie mistake after Spark plug change. Deposit build up.
  156. Funny knocking noise for 15 seconds after starting truck
  157. 1993 F150 valve cover change out
  158. what air intake do you have?
  159. egr valve . . .
  160. Oil Pan Gasket
  161. advice engine swap and general upgrade project - hopeful show truck project
  162. What happened to built54?
  163. truck jumps and dies at slow speeds and at stops
  164. maf cleaning
  165. chirping sound at idle........Help!!
  166. seafoam
  167. Belts
  168. 2004 5.4
  169. Code P0174 only
  170. Anyone Experience This Problem
  171. oxygen sensor help
  172. F0te-d5b Or F0te-d1a Injectors. Will They Work??
  173. Fuel Rail Installation (help asap)
  174. new TSB flash=GOOD stuff
  175. Thottle body spacers
  176. idling low
  177. Plug change recommendations?
  178. What is this?
  179. Truck runs like crap when its hot out
  180. rebuilding the 4.6
  181. missing
  182. Rattle @ 2000 RPM
  183. My EGR Yuckfest
  184. Oil Drain Plug stuck help!
  185. Engine loses power and dies, but not at dealer :(
  186. F 150 Engine Problem
  187. JBREW Question
  188. Quintin/FordTech1 plug change tips......
  189. 4.2 thermostat
  190. Spark Plug Removal
  191. CEL on after Gotts Intake and Throttle Body Spcer.
  192. Cam Phaser replacement?
  193. tickin noise
  194. Synthetic Oils ?
  195. 5.4 spark plug removal problem
  196. 5.4 Fuel Filter location
  197. egr valve . . .
  198. Engine died like i was out of gas...
  199. engine noise.
  200. 1996 F250 5.7L no power under load condition
  201. Difference between 4.6L Mustang and 4.6L F150 ???
  202. Lifters knocking on startup?
  203. 2 valve sparkplug part number
  204. ECM Differences from 02 Supercrew and 03 Lightning
  205. power tuners
  206. O2 Sensor
  207. E-fan question
  208. ASP underdrive pulleys
  209. Very Strange Fuel System Problem
  210. Remote Oil Filter question
  211. Hydrogen HHO set up Yes or No?
  212. whats with the tapping???
  213. Mobile 1 Best Oil?
  214. A/C delay
  215. tranny cooler lines
  216. Finally Its Gonna Happen
  217. To carb, from EFI
  218. Ace Hardware Oil Special month of June
  219. Picked up an "Actron"-It read ~
  220. Best year for a 'new' used truck?
  221. 160 thermostat
  222. Plugs change
  223. Blue smoke apon start up.
  224. Equus gauge oil pressure accuracy??
  225. ford part number lookup help
  226. water pump o-ring question
  227. 001 4.6 throwing strange code
  228. p0171 only
  229. Radiator
  230. new plugs n coils but...
  231. Desperately Need Advice, Please Read & Help if you can
  232. general ?
  233. New Plug TSB - No more warming engine?
  234. Injectors compatable?
  235. Rather poor gas milage problem
  236. Trad in?
  237. More Supercharger Questions
  238. Slight Miss
  239. Half thread plugs vs. full thread plugs
  240. Bg Moa
  241. 97 4.2L overheats unless heater is on
  242. Disappointed with towing...
  243. Little help please!!!
  244. More horsepower
  245. Will 03 manifolds fit a 98 (5.4L)
  246. 125,000 Miles, 3v Plugs CHANGED!!!
  247. fuel injector ?
  248. what is IAC
  249. Didn't anyone miss me lol ?
  250. Engine Problems
