- Cleaning Air Force Once FIPK
- Cold start noise Timing
- underdrive pulleys
- Oil Consumption
- 2001 4.6 Miss
- Problems?!
- Acceleration Problem
- Help with bad miss
- FORD DURASPARK ll SYSTEM SYSTEM-what is it?
- engine wont start
- Timing Question
- Low oil psi
- Coolant Above Spark Plugs?
- Switching to Synthetic at 64,000
- 2000 5.4l
- Bouncy idle with A/C on
- Rough Idle
- 4.6 rough under load
- Bad miss in a 99 5.4L F150...
- Can I see the FTP Sensor without Dropping Tank?
- 4.6 Tuneup
- 1992 Ford F-150 Custom
- Repeat Oxygen Sensor Failure
- Rings finally completed seating
- Starter question
- HELP-replaced starter, shifter this week
- Parking for 6yrs
- coolant mod = no more pinging
- Plugs - Platinum or Not?
- 5.4 sparkplugs
- Fram AirHog Air Filters
- Borg-Warner
- cooling system woes
- manifold dirty
- Oil change question (or lack of)
- $8.00 chip
- 04 5.4 F140 idle problems
- 4.6-5.4 swap?
- Looking at buying a 96 F150 5.8L ...
- Durability of a I6?
- Strange cause and repair for PO401 code
- Horsepower :-/
- Swapping a 4.9L
- 97 5.4l problems
- Hasn't anyone changed plugs in a 2002 v6 Explorer ??
- Steering squeel noise.
- 1994 351 W engine swap
- Removing gas tanks........
- Misfiring - 97 F150 4.6 triton v8
- Got 48K miles now, what needs to be done?
- Must see......
- Lots of oil leaks...why?
- intake removal question
- looking at a 2002 explorer v6 haw hard to change plugs ??
- 5.4 Liter Longevity?
- Bad COP #6, why no code?s
- 1990 Mustang Cam into 1996 F-150....not running right?!?!?! PLEASE HELP
- What's your M.P.G. with the 4.6?
- s4.6 EGR repair
- ? concerning 04 & 05 F150
- Will too much coolant vs. water hurt me this winter.
- Thanks for everything!!!
- best sparks,oil,tranny,wires,coils,etc (upkeep) plz respnd
- 300 FI auto to 300 carb manual
- hold my beer, I'm going in!
- BAnk 1 Sensor 2
- Accufab throttle body for Kenne bell 5.4 dohc
- blown spark plug out of head
- o2 sensor
- Blown up spark plug in tritons
- engine modifications.....
- Lots of problems. Needs lots of help
- Flex-a-Lite 270 Again
- Strange noise, please help
- Troyer Performance
- Boggs down on first acceleration
- MissFire Problem Solution *READ THIS*
- 1987 sluggish motor turn over
- 1997 f150 oil pressure??
- leaking oil
- Right PCV Valve
- runs like crap when warm!!
- Misfire in #7? Which one is that?
- 01 F150 XLT 4.6 ... questions
- DPFE P1404 Help
- Timing Problem?
- Do you recommend the 4.6l?
- Banging noise when make tight turns
- Coolant Leak Problem
- Auterra
- squeeking from drivetrain in reverse only, low speed
- what is
- my 99' is no more, hello 04'
- Pissin Coolant
- Where the Heck is the Oil Filter at?
- New Air Intake For 05 F150
- undersize rear oil seal???
- Realistic MPG '97 4.6l
- rear main seal leaking
- Oil question.
- what viscosity shoud i use with with winter coming on
- coils or injectors causing missing?
- Missing Oil
- Low Idle then Dies... IAC?
- DPFE Sensor
- 115k, time to up viscosity?
- Miss.. not noticeable at high RPMS but low very obvious
- coil packs
- itermittent engine miss
- Can I disable heater?
- Heater Core
- 5.0 comes a knockin '
- Bad radiator?
- `99 F-150 XL Sport question
- water temp gauge
- Engine Dying but starts right back up... then dies...
- Removing the Throttle Body ?
- New Engine
- Enging shutoff on highway ????
- freaking me out!
- Kind of off topic.. Chemical spray question
- clicking noise almost like a deisel on my '04 f150
- how many years?,
- Humidity rising from dashboard and all around console
- Weird Engine Problems Rough Idle Shaking Ect.
- 94 F150 MAP Sensor location
- how much should i ask for my pickup
- pulleys
- Help on first F150 purchase
- One for the experts...
- DPFE, EGR? very rough run intermittant
- 4.6 missing question
- Seafoam problem...
- Smoke on startup
- missfire problem caused by rain, please help!!
- '97 4.2L- No power in 4th gear?!
- Squeel form engine
- Powerstroke V6
- thanks for the 5.4 info, now need 4.6
- cold start problems
- oil grade question
- 1990 F150 Bucking
- No Compression on two cylnders?
- e-bay superchip
- after market air intakes for 04 5.4.
- help please
- 5.4 Question......
- Throttle bodies
- P.I., Romeo, and Windsor
- Another Newbie
- air bypass valve
- F-150 5.8L Huge power loss
- Intermittant high idle, need your suggestion
- 4.6 to 5.4 swap
- Gas mileage concern...
- Tapping / Weird sound during Acceleration
- Another 1997 4.6 misfire problem
- Strong rubber smell coming through vents
- new to thread and have a question on the timing gears
- Oiling air filter
- Crack In Manifold
- Could fuel tank be clean?
- Any ideas on how to reduce CO emissions?
- Fuel Tank Problems
- pi heads or non pi heads
- 4.6 L spark plug replacement thre easier way
- (different) rough idle problem
- engine knock at start up
- whining noise when engaging accelerator
- new bigger injectors
- new here and need some ideas
- 4.6 piston slap?
- Couple of oil questions
- 2002 4.6 crankshaft broken
- Help Missfire !!
- engine knock 5 L engine
- Sudden drop in performance @ 47K mi.
- Heater Hose
- More Power????
- Glowing Red Exhaust Pipe Need Help
- More PO171 & PO174 isses
- engine knock continued
- engine knock or tick constant
- Question about 4.6
- suddenly running bad, not driveable
- Hesitation
- Slightly modded 5.4 vs hemi??
- 5.4 longevity
- need help!!!!
- More Horse power
- So now what....... POW
- My 300 6cyl aint runnin good
- re-oiling K&N Filter
- Supercharged SCrew
- Code P 0401 EGR Low Flow
- my intake is eatin' hot air!
- FLASHING check engine light
- 98 4.6 "power band"?? Safe RPM??
- New Flex a Lite 270 installed
- Loud banging noise, running fine
- Different Bolt sizes for 4.6L Heads??
- triton v8 engine seized/blowout ???
- Flex-a-lite 270
- coil packs
- Question About 5.4
- tps sensor
- New plugs/wires - now rough idle
- 4.2 swap
- Same problems, maybe more
- Oil Presure Gauge Question
- P-1635 code unsure of meaning
- Ford F150 with P1151 engine code
- Anyone use an gas or crankcase additive?
- 97 7.3 Turbo tensioner adjustment
- New injectors, high idle...
- Running rough, but NO CODES..need help
- is there a better fuel filter than the stock?
- Throttle body spacers?
- DTC Code P0401 Gas Recirculation
- fuel injectors
- Need help quick - Fuel Rail
- 97 4.2L - what's the prognosis?
- Engine squeak
- Heatercore
- electric fan install
- 6.0L oil leak
- high idle after Flowmaster and Seafoam
- Help! Bucking under acceleration
- how to press fit heater hose back in?
- Engine Swap
- Bad Gas-poss. water-please help
- Pulling trouble codes
- Check engine 97 F150
- Simultaneous CEL And OD Lights
- dual gas tank problem
- DPFE or Vacuum Solenoid
- 5.0 poor low end performance
- 97 4.6 cylinder head removal
- 98 4.6L radiator leak
- 98 4.6 sprung a bad leak need help !
- 97 5.4L - Engine miss or hesitation, runs rough
- Oil Change
- motor skip or tranny shutter?
- Thermostat?
- cleaning EGR ports
- V-8 vs V-10 vs Diesel
- 2001 Supercrew idle problems
- filling coolant on 02 f150
- How many volts does a fuel pump need to run?
- cleaning egr ports??
