View Full Version : Engine
  1. penziol 10-30?????
  2. amsoil vs. mobile what
  3. 2000 5.4 dies
  4. EGR test on 88 f-150 code 33
  5. EGR Valve, Throttle Body & O2 Sensor Locations
  6. Engine Codes PO401 & PO133?
  7. truck won't start ????
  8. F250 NPI to PI when??
  9. 4.6/5.4/6.8 spark plug thread repair kit
  10. Surging and Smell of Gas
  11. Gas mpg has gone down, any input?
  12. Leak: radiator and heater
  13. engine 4.9L
  14. 4th Cylinder Skipping on 4.6L V-8
  15. power upgrades in a 5.4??
  16. Cold Air Kits For the 5.4 ?
  17. Crank bolts on 5.4 SOHC
  18. Aftermarket tach install - please help!! ECM?
  19. Altinator
  20. '99 Engine not turning over right away
  21. 99 F150 Won't Idle - FIXED
  22. need help
  23. TPS what voltage?
  24. Help
  25. under drive pulleys
  26. 300 mods
  27. Missing, shuddering, running rough? Heres what I did to fix it.
  28. sudden hesitation after battery problem
  29. Water temp gauge indicates overheating.. but NOT overheating
  30. RE: Jerking 93
  31. Ignition Switch Replacement
  32. i hear water
  33. strange jerking 93 auto
  34. NO Oil Pressure
  35. filter
  36. 4.6L Engine "skip"
  37. more power!!
  38. 4.2 to 4.6 engine swap
  39. Where is cylinder #6?
  40. Real world info needed
  41. Service Engine Soon Light Blinking/Missfire
  42. What are the similarities between the Cobra and Lightning motors?
  43. amsoil dual remote oil quality question
  44. Rebuild or Remanufacture,Suggestions Please
  45. cold air intake
  46. Help on OBD II Code
  47. Gas guauge going on the blink?
  48. No Power! shuddering.
  49. Swapping a 2000GT motor -> 98 f150
  50. Blown Plug
  51. Allen Supercharger
  52. Rattle
  53. rough idle?
  54. 97 5.4L PCV Valve rattles
  55. replacement of crank rear seal
  56. Superchargers
  57. 2005 5.4L Engine Problems @ Factory
  58. Spark plugs
  59. engine swap
  60. Starter issues
  61. Improvement of economical and ecological indexes of heavy-duty combustion engines
  62. Mysterous fluid leaking onto headers
  63. Which engine is better? 5.0 vs 5.8
  64. engine shutoff
  65. Nightmare.....Replacing o2 sensors....
  66. 5.4L Performance
  67. Skunky Smell
  68. Roller rockers on stock 96' 5.0
  69. Plugs & lights
  70. just orderd new goodies
  71. help please
  72. Didnt know where this belonged...
  73. Mileage Question
  74. 4.6 oil leak
  75. quick 04 5.4L Oil question
  76. Engine swap? 4.2 to 5.4
  77. 4.6L Misfire blown head gasket????
  78. Final blow, water in oil.
  79. Need code and egr valve help!!!
  80. Smell of fish.......
  81. IAC(Idle Air Control)
  82. Ford Expy running rough
  83. has anyone used the ignition upgrade kit from troyer?
  84. check engine light after 5.4 oil change..?
  85. Gas mileage on a 5.4....................
  86. My po303 code problem and fix.
  87. Starter Problems?
  88. Missfire fixed !
  89. '86 F250 acts like it's running outta gas...tanks half full.
  90. 98 F150 coolant leak mystery!
  91. pinging
  92. 2004 5.4 dies at idle
  93. 1976 F-100 engine info 390ci V8
  94. Fram or Motorcraft Fuel Filter?
  95. timing cahin cost for replacement
  96. truck wont start
  97. Serpentine belt
  98. why does my trucks speedometer read 100mph max?!
  99. i lost a race tonight, come comfort me and tell me why
  100. engine swap
  101. Gas Tank Noise
  102. Rough Starting V6
  103. Engine runs too cool
  104. Doesn't alway's start
  105. GorillaChipz
  106. 5.4 Smoken at startup
  107. A Different Kind of Blown Spark Plug
  108. Engine Clatter
  109. 98 4.6L with 108K, what to look for???
  110. ignition coils
  111. What Is Pinging?
  112. interesting night
  113. rear block intake to heater core
  114. Unplugging sensors
  115. Explorer lacks power on highway
  116. What viscosity should I use with winter nearing?
  117. Idle Problem In Park And Neutral
  118. They said get a new engine
  119. speed sleeve
  120. Starting the PI headswap in a couple of days . . .
  121. 1987 f150 351W running rough when cold and hot
  122. Air intake comparison
  123. Just one click when I try to start
  124. ODBC code PO401 Help
  125. 100K Tune - Up
  126. airbag code 27
  127. 302 to 4.6/5.4 swap
  128. 99 Mustang Engine Into 97 F150
  129. 97 4.6L short block
  130. Supercharger for 2004 F-150 FX4
  131. shifting into fourth gear,vibration
  132. Castrol Syntec
  133. Service Manual
  134. knocking
  135. Ford Tech's Fuel system help please
  136. Truck won't start after oil change
  137. Lightning blower/intake swap
  138. 2v to 4v head/intake swap feasible?
  139. 1990 f150 starts wont run help please!!!!!!
  140. Tornado Air
  141. Truck just clicks ??
  142. Spout Open code on 5.8W
  143. How to Check Oil
  144. engine removal hang up
  145. Heater not working
  146. What rear main seal?
  147. Am I and idiot or WHAT?!
  148. Locating an oxygen sensor
  149. replacing fuel filter
  150. 1997 2V 4.6L swap for 2004 Navigator 32V 5.4L
  151. How do I tell which coil-on-plug is bad?
  152. 302 mileage...
  153. Serpentine belt/alternator
  154. Free T-Shirt
  155. 99 Mustang Enginie To 97 F150
  156. remote starter
  157. F150 Gas tanks - largest size available?
  158. Help please!!!!!!
  159. just a ?
  160. Loud Metallic Noise
  161. p1451 obdcode
  162. Maybe getting a 2003, Need Advice
  163. stalls
  164. A Good One??????
  165. 89 F150 302 surging
  166. 2003 5.4L
  167. 97 f150 heater core
  168. Suggestions
  169. 120K mi maintainence
  170. DPFE sensor
  171. Viscosity
  172. 4.6 to 5.4 swap
  173. Battery Light @ High RPM??
  174. What is best bang for the buck?
  175. headers
  176. AlldataDIY
  177. K & N Filters
  178. black fuel canister before pump on 1986 4x4 f150??
  179. Check Engine Light
  180. Help!?
  181. Cylinder 5 Misfiring need help
  182. 4.6L exhaust manifold removal
  183. Coolant Hoses
  184. whats the bes year on f 150
  185. Noise during deceleration.
  186. Check Engine Light: Warr. Extension 02M01
  187. P1518 code/Need help ASAP
  188. Royal Purple Lubricants
  189. r6ugh Idle?
  190. check engine light, vac leak code
  191. what is a ....
  192. Old Engine Sound on a 2001?
  193. Love The Truck But Hate The Pinging
  194. check engine
  195. Rough Idle/ running
  196. spark plug loss 5.4
  197. Any Ideas anyone?
  198. Need help with hesitation problem
  199. What kind of oil should I use?
  200. Power mirrors fuse?
  201. Excellent Parts
  202. spark plug blowout
  203. I messed up (I think)
  204. no power 2000 rpm and up
  205. Funny noise ...
  206. 98 5.4L fuel mileage w/minor mods?
  207. this aint good
  208. engine swap 302 - 351w
  209. head gasket
  210. Service Engine Light
  211. SES goes away
  212. 1995 f-150 cuts out, comes back later...
  213. engine swap questions
  214. replacing spark plugs
  215. Performance (HP) & Efficiency (MPG) what is really possible?
  216. F150 jerking at constant speed 30-40mph
  217. Loud knocking
  218. Service Engine Light and Engine Running Issue
  219. I'm in the club now
  220. Can one output on a coil pack go bad?
  221. "Misfire" code on brand new plugs
  222. P0105 - Replaced wire.. coil pack or injector?
  223. Break in period....
  224. A little help?
  225. Price of a 30k mile tune up?
  226. mass air flow sensor
  227. Engine wont turn over
  228. How far on Synthetic Oil?
  229. altinater
  230. altinater
  231. Engine not running well
  232. What are some cheap mods I could do to my '87 5.0 EFI?
  233. spark plug?
  234. more horsepower
  235. Same question, when a new engine?
  236. 351 in my 97 f150
  237. Cam events info.
  238. PO402 Code and Missfire...
  239. Good Sled-hauler? 4.2 or 4.6? 5-spd or AT?
  240. new pump.... old problem
  241. Strange Groaning Noise
  242. Clean that MAF
  243. John Deere Diesel?
  244. Royal Purple Motor Oil
  245. P0402
  246. F150 351 W engine surge
  247. Question about synthetics and weight
  248. Help! Strange Idling & Stuttering Problem (2001 5.4L)
  249. engine info and tips
  250. 97 F150 Engine
