- Location of fuel pump relay switch?
- Rough Idle Problem
- what motors will swap into my truvk
- harmonic balancer e-150
- 1996 5.0L Stall, Miss
- 5.0 Cammer Swap- Anyone Done It?
- 1989 F-150 Motor Swap
- P0443 code: purge control valve???
- Frost plug heater
- 01 5.4 intermitant idle problem
- Looking for piece of mind...
- Another Starting Problem Post 4.6L
- Help.....
- Tach lead on 94 F-150 5.0.
- 1989 F150 Won't Start When Cold
- help with chip info
- Where is the number 5 cylinder
- 2002 F150 Startup Issues: just a click
- Fires Related To Curse Control
- '97 F150 5.4 running rough all the sudden, please help...
- Troyer out of coil packs...options??
- Break-in period before synthetic oil?
- Coil Boots
- Anti-Drain Oil Filters?
- 4.6L top end noise
- wtb stock expy or navi pulleys
- Vaccum line problems on my '97 5.4....
- 00' Expy Missing
- Mass airflow sensor
- installed new goodies
- Coolant system question
- 97 oil type
- '94 F150 5.0 Stalling
- throttle Body spacer
- MAF on 95 300cid?
- 1999 4.6L - Changing Oxygen Sensors
- Is it a miss??
- Cold start problem 4.6
- P0401 (Haynes Manual)
- Coolant Engine Block Drains 2001 5.4L?
- Supercharger
- Moisture in plugwells on #7 and #8, any ideas?
- BBK Cold Air Induction System
- HELP! 02 F150 4.6 Coil on Plug problem
- Spark Plug Gap
- F150 with 180K highway--opinions?
- dyno sheets please for 2v 5.4L & L
- Codes P0171/P0174
- Need advice on 5.4 mileage
- Looking at purchasing 2003 XLT
- Alternator Madness
- 1989 F150 4.9 L6 sputtering
- How many HP in '01 Triton v8
- will not start or turn over
- 4.6 to 5.4 engine swap
- Napa 5W20 Motor oil
- ping (not the clubs)
- Question about my 86 F-150
- horse power
- Egr Valve ?
- Won't Idle After Startup When Cold
- Whistle/Chirping Sound
- 1990 f150
- 4.6 dies at idle
- Possible power loss
- 4.6 problem starting
- starting difficulty
- New engine noise
- 1989 F-150 302 Rebuild
- gas mileage
- Help-Tips on changing plugs
- Fuel filter adapter question
- Motorcraft Plugs the same as Autolite ?
- New Titan
- NEW MEMBER and 351 rebuild question
- bad gas mileage
- More Gas mileage and power for I-6
- Spark blown clear out of Cylindar head
- 99 F250 SD NPI to PI swap
- oil use
- Wrong Oil
- VERY LOUD lifter tick, need help-advise
- Laptop diagnostics
- misfire codes on 5.4 coil on plug
- Hesitation under heavy throttle
- Squeak at startup on cold/wet mornings
- It's dead, D. E. D. dead!!!
- 1999 5.4 rough idle and stalling
- must i replace the oil pump?
- 2001 5.4 terrible blue smoke at start up ?
- Fuel pump or fuel pump relay switch
- Mac cold air intake
- I need advice on a 100000 mile tune up
- oil usage
- Bye-bye 4.6 & Hello 454 Bbc !!!!!!!!
- Anyone Run a High Flow Header or No-Cat Exhaust?
- My King ranch has a mind of its own
- Synthetic oil?????
- Tab & Tad
- replacing alternator gets ugly
- High Idle
- hurricane 5.4
- Emissions line
- 1990 F150 with 4.9L...oil in air fliter
- 100K mile tuneup
- engine overheating.
- On the bright side....
- Engine has dead spots when on the throttle.
- 5.4 Bottom End
- 5.4L Spark Plug Launch
- 300 I6 Tuneup
- 97 4.6 (6) Miss & Idle FIXED~!
- aftermarket gauge installation HELP!
- Intermittent Engine Hessitation
- starting problem
- '98 f-150 timing belt question
- cylinder head problem
- rattling on cold starts
- 1995 F150 5.8 engine troubles...
- kreen any one used this
- 300ci valve sizes
- 1991 F150 Maf Location Please
- Extended Crank Intermittent Problem
- Squeaky Startup
- 2000 5.4L turns over but will not start
- Help... Loss In fuel Pressure
- Lightnin' blower
- f150 well maintained with bad hesitation
- Engine Programmers/tuners
- Tune up
- 98 F150 Engine died - Need Advice
- timming
- 5.4 Stahls Out Immediately After Starting
- Self Scanning Computer???
- dieletric grease
- help with installing coil cap
- New tricks for my old dog
- 4.6 rough idle & Miss
- Help Major Hesitation!!
- 98 F-150 Misses When Air Conditioner/Defroster is On
- How big is the 5.4 liter...
- Spark Plug Wires
- nitrous advice?
- Straight Six Gas Mileage
- 10 mpg normal???
- Ignition Switch Installation
- 4.6L gas mileage
- P0405 - EGR low voltage
- Number 1 plug 300 straight six
- installing new gauges
- No Good Deed Goes Unpunished
- the great plug debate
- hp/tq ratings
- Message for "jordan not mike"
- 1989 F150 not getting oil pressure when cold
- cam install
- 2001 F-150 SCrew won't start
- 5.4 3V vs. 5.4 2V
- Engine swap
- Engine Diagnosis
- Can this prevent dry starting?
- timing
- 94 F150 351 Oilpan
- Whats the best
- Milky Oil Cap
- PI headswap done!
- Burn outs
- wrench and engine light ,engine shudders
- Supercharger
- Remove air intake question
- Has this happened to you
- K&N Intake Filter Kits
- Testing coil packs
- 02 Screw won't remote start when cold
- engine interchange
- need some tips for getting some more hp out of my 96 F150 302
- Timing problem ..please help
- coil packs
- Engine Stalled, Lost Oil Pressure
- truck won't start
- water pouring out of exhaust
- ignition problems
- gas saving
- 4.6L Head Gaskets
- 4.9L Oil leak
- Ignition Knock: 2002 4.6 Engine in 1997 F150
- Got a miss
- motor swap misfire
- Ford replacing my PI head
- Horsepower and Torques rating help
- Need new PCM?
- PCV valve/ Air intake manifold
- Code descriptions
- Suggestions to hot rod a 2002 4.6 SCrew
- 65k mile maint???
- FIPK is moaning!!!!!!
- Break in before Mobil 1?
- Oil Sensor Problem
- No speed limiter?
- black smoke from tilpipe and majot hesitiation
- Low Oil Sensor
- Brakes smoking
- An alternator: how often?
- Engine Vibration
- Spark plugs change
- engine stall
- Stupid question
- Warrant Void??
- 2001 supercrew who makes the best supercharger.
- radiator clog or water pump?
- Synthetic Oil Switch Over Question?
- electronic 4x4 not working
- Misfire at high RPM
- Cold weather problem....>
- Pulling Spark Plug Boots
- Fixed - 5.4 V8 will not idle
- 2001 supercrew 5.4 wet engine
- lost power, stalls out
- 2006 rumor...
- Additional benefit of SuperChip!
- F250-bogs out
- gas mileage revisited
- Motor sputering!! Help Please
- 2001 supercrew washed engine runs rough engine light comes on and off.
- Grill Cover
- Ted'98
- K&N vs. Air Hog
- Engines
- Repair Shops In Hawaii
- Oil Pressure Guage Down / Warning Light
- Bad temp gauge?
- What kind of chip should I get?
- I Just Can't Get My Brain Around this Problem
- fuel pump inertia switch
- Tune Up....
- 2nd One In 3 Months
- Same Thing Here
- 2004 newstyle 5.4L F150 Engine Problem
- 1999 5.4l F150 Gas Mileage
- MobilOne B1G1 coupon
- Jingle sound?
- Oil in Coolant
- squeal noise at startup cold
- Where is the recall??
- idle surge, and trans shifting hard
- 97 f150 Steaming in the Cab
- '86 E150 hessitate/surge CRAZY
- 4.9 broke distributor roller pin? Help
- penziol 10-30?????
