- Dealer Busted Me
- 20w-50
- Off topic, torque specs for a 5hp briggs & stratt head
- 97F150-4.6 v8
- heater core question
- Maybe someone knows?
- vacuum leak
- Plz help!!!!
- White crap on oil cap
- extended warranty, CARS ???
- re-spark plugs
- Hard cold starts
- More Power!!!
- problems with accelerator
- Water in cylinder/spark plug tops
- 4.6 Engines - Burning Oil
- idle gets higher & higher
- Need CARFAX report for F150
- Where is my temp sending unit?
- Which heater hose is the supply?
- Oile Capacity 4.6L
- Serious miss, no CEL, produces codes,,,
- i have a bad miss under strain
- Starter solenoid . . .
- Which fluid to use?
- Where did all my oil go?!?!?!
- Buyer beware
- O2 sensor location
- engine warm up time
- Very rough idle...
- Codes P0320 and P1351
- Intake idle problem
- New Engine
- ok....
- 2000 lightning enginenin 97 f150
- spark plugs
- '96 oil change...what to use?
- Cold Weather Non-Start
- Engine miss
- Engine Noise?????
- What does this mean?
- just started whistling
- Oh No!!!
- 0w 20 or 5w 30???
- pics of fipk?
- Coolant issue
- Cold Starting Problem
- THE NOISES!!!11!!1oneoneon1!1eleven!11
- EGR valve Downtube???
- died and won't start
- 1997 4.6L V8 Triton... info please?
- Code 542
- another ? on fipk
- fipk and body lift?
- valve noise
- idle proplems when starting
- Part# for O2 sensors
- air intakes
- 5.0 mustang parts
- Odd occasional startup
- Another missfire........
- Engine miss under hard acceleration
- '01 5.4L Intermittant Hard Start
- Rough Idle
- Engine Trouble
- Oils & Acetone
- 85 f150 smokes bad
- 94 351 Throttle body
- Performance Module, Venom 400 Series
- no check engine light?
- overdrive?'s
- best exhaust system for 5.4?
- Blown motor
- engine swap
- 4.6 L Horsepower increases
- Help! I'm losing oil from the filter hose
- solenoid
- Which Intake System Should I Get????
- Advancing the timing on a 5.0?
- 98 5.4 Piston Slap
- Dies when lights are on
- Po401
- plug problem?
- problem starting - truck stuck in barn...
- 1990 with codes 32, 56, 64, & 67
- Air silencer
- Head Gasket leaking
- Best mods for stock F150
- Coil Pack Woes
- How much oil pressure are you seeing?
- Fast idle problem
- bucking problem
- replacing radiator > Problem
- supercharged
- 1996 5.0 Won't Idle cold
- 4.6 L Vapor Canister???
- whats your rpm idle?
- Oil Filter Change- 04' F-150 FX-4
- What is the firing order on a 300 6cyl
- Difficult Cold Start
- Sweet smell of success-not!!! condensation on oil filler cap
- engine blues
- Which Denso Iridium Plugs are everyone using
- blower pullys
- All done by 4,000rpm! Help!
- 1998 f150 cooling system problem
- help on aftermarket intake idle?
- Read this...
- Yah got a Hemi ?
- 5 Litre W to 5.7 Litre W ?
- engine squeak
- Ford "Octane Ratings" for the U.S ??
- Drops to 400 rpm at idle then dies.....
- Will the new 5.4L work?
- vibration problem at idle and low rpm
- 1994 F150 Thermal Problem
- 94 5.0 liter
- engine rufff idle then kills
- Spark Plug Blowout
- 2005 f-150 only
- oil filter change/2004 F-150 FX4
- broke EGR tube
- '97 4.6 L 12 MPG hwy. NEED HELP!!
- Overheating and funny temp solution
- Reough Idle - New Engine?
- 02 sensor locations
- Low Engine Temperature 5L Injected
- drive belt adjuster
- Help with OBD code
- Cylinder Order 2001 4.6l??
- Trying to stall when stopping
- I6 strange symptoms
- 4.6l = Cid?
- 7-Pin Wiring Harness
- Ford Dealer answer to 5w20 oil
- Wanted---Underdrive Kit for a 4.6 Auto
- Flex-a-lite 270 Update
- 5.4 Carbon Build Up
- Bosch Plugs
- Dual E
- Motor mount check
- Cleaning EGR Ports on a 5.0
- Engine Code 401 & 302
- Where to buy recommended oil
- misfire on eight!
- Help Overfilled OIL
- warm up
- Starter, Ring Gear
- PO141--O2 sensor,Bank 1,sensor 2,Which one is that n my lingo?
- Oil pan madness
- new transmition
- Coolant drain plug pics?
- Timing Question
- Mysterious clip in pcm plug in (dash)
- Battery indicator light
- Engine Codes
- 1990 shift on the fly?
- whaddu i got ?
- 1989 F150 High Idle
- x-plan
- 97 F150 XLT 4x4: Rebuild engine or get a 2005?
- E-Fans- Pro's/Con's Who has 'em?
- 97 4.6L > what is this?
- Got A Miss
- Definitive preventative on 4.2 time bomb
- Burning Smell?
- I have the famous P401 code
- Firing order
- using some oil?
- Spark plugs wires in Austin?
- Fuel to Burn or not to burn
- OIL consumption problems
- Another bad coil pack...
- Freeze Plug Woes on 1992 Flareside 4.9 I6
- engine HP and TQE specs?
- 2000 F-150
- Please help where's Ignition Coil "D"???
- Engine replacement
- 2001 5.4 Developed a DEAD MISS
- 4.6 fuel mileage
- NY emissions law??
- mustang question....
- keep tank half full
- 4.6 Power Options
- i hear water in the dash
- Changed plugs -service engine light on
- 89 f150 wont start
- 1989 302 firing problems
- Where is the temp sending unit on 4.9l?
- anyone do a 4.6L head cam upgrade?
- '89 F-150 I6 oil pressure
- 2004 F-150 Underdrive Pully Install
- 5.4 threw a Service Engine code
- Help With Installing Intake
- 97 F150-V6 Starting Problem
- 98 F150..high idle..what do I do next???
- gas smell from exaust at start-up
- f150 runs bad when just a little hot
- Engine Misfire
- How Well/Long Do Helicoils Work?
- Water/Oil ?
- What exactly is the check engine light for?
- 96 5.0l Egr??
- 5.4 fipk system
- Cruise control no-workee
- Power Programer // Dtc 5284 code ???
- F150 with Diesel Engine???
- Oil Pressure problem with 1991 5.0
- MAF sensor pinout diagram
- Help, what does this code mean!!!
- 351W crank-case problem??
- Oil and Battery question
- Underdrive Pulley Install
- EGR SENSOR Problem,, dfpe to be replaced by Ford?
- unpredictable engine stop
- Is something wrong with my s/c?
- Need advice on 3:73 gears
- 98 f150 iac code 1506
- coolant lock-off?
- High idol?
- truck dies on start-up when cold
- F150 4.6L vs Mustang 4.6L
- 4.6 running rough
- fuel pressure question
- 97 F150 Engine kills at startup
- 3V Heads on 99 5.4L F250?
- Mustang MAF?
- creative intakes?
- Power steering pressure switch?
- 2003 5.4L Cylinder Misfire
- Maybe misfiring and burning oil...
- egr?
- Rough Idle / engine shuts off
- Engine noise (ticking)
- 1993 loss of power, please help!
- New To Forum. Need your opinion
- Bad miss on my '97 5.4 F150.....
- help
- Found some stuff on Ebay
- Best Spark Plugs
- 5.4 supercharger
- Engine Trouble! Did Something Blow?
- Cold start, put in reverse, LOUD humming
- howling sound/check engine light
- High pitch whinning noise at start up...
- Thanks I Laugh
- Rough Idle and Throttle Response
