- mac performance
- V-10 Power issues
- codes codes codes....HELP!!
- Oil Pressure went to zero
- Oil pressure problem
- oil analysis
- 4.6L possible head gasket failure?
- Help with occasional starting problem
- hesitation
- FIPK vs. Aircharger (both K&N)
- 4.6 Vibration in Gas Pedal after Misfire
- Vibration when letting off gas at 70?
- radiator replacement
- V10 strange missfire (not like coil packs)
- 20% ethynol just passed in MN
- engine knock
- hey OE812
- Full Line Of Mobil Products At Wal-Mart?
- Squeaking belt!
- Starter ???
- '89 f150 block Flat tappet or Roller 302w
- can't find 5w20 oil
- Hard starting after sitting for an hour or 2
- HELP Bogging and Back Fire and etc
- There goes the Motor money
- well back to square one with the coil problem
- 99 f150 5.4 Head Problems again
- Rough Running
- 2001 5.4 Supercrew, Get A Supercharger, Yes Or No?
- 5.0 or 4.6 in a T bird or Mercury Cougar.
- F150 engine swap??
- pulley
- 5.4 into 4.6 truck
- 2000 4.6 with oil leak
- DFPE Sensor
- Ford F-150 550,000 Miles on it !!!!
- Electric Fan Kit
- Thermostat to make it warm up faster??
- 2001-2003 F-150 Recalls?
- F150 dead
- Code 22 and 122.. Help!
- K&N, Airaid,etc. Intakes, which is the best??
- Spark plug cylinders full of dirt
- Sudden loss of MPG??
- Help....need advice
- 2004 5.4L 2200 miles engine laboring/stalling
- mac underdrive pulleys
- 97 F150 engine help
- fuel mileage
- Trouble Code Help???
- Head gasket I suppose
- Volant Intakes questions
- f-150 oil pan removal
- misfiring
- 98 fuel filter install
- Schaeffers Oil to offer a 5w-20
- 94 f150 no power
- egr vavle
- 7quarts? Help
- want a 351....
- Just changed those coils
- Hurricane blows no more !!!
- code p1207 or p1507........i forgot
- missfire cyl #3
- Ford shelved the Hurricane engine...
- Price for 8 Coils on Plug?
- Trouble Codes P0171 & P0174
- Seafoam and plastic intakes
- Air filter
- which oil to use when????
- Preventative Maintenance Guidelines
- what next?
- Power upgrades for 4.9L-300
- finally!
- Vibration
- F150 5.4L 3 valve
- Iac Cleaning
- engine surge
- Coil on plug tune up kits?
- Oil Pressure Gauge or Worse>?>?>?
- electric fan conversion
- blower pully
- where to get parts?
- Help: Spark Plug Arcing
- high idle?
- Finally, my truck is diagnosed!!!
- DPFE sensors interchangable?
- Engine Oil Cooler
- normal RPM on idle ?
- Starter - more
- my F-150 needs a cam replace at 1352 miles
- fuel lever circuit error
- Starter
- Coolant light and oil pressure guage?????
- TritonV8 best engine ever
- question for Neal
- Fuel Pump Qestion
- Electric water pump...
- oil
- Engine cutting out
- 235hp vs 260 hp
- P0125 engine code???
- gentlemen please - CEL Light Flashing
- Wall Mart & motorcraft, no more
- How Long??
- Crankshaft sensor problems
- loss of oil pressure-engine "toasted"
- 99 F-150 V-6 4.2 Engine Dies
- going electric?
- Tachometer
- racing results
- 4.2l V6 versus the 4.6l V8--Which should I go for?
- 95 F150 Engine Noises
- A question about MAHLE after market pistons
- Question for High Mileage Club
- Please Help I Need All I Can Get.................
- New Fuel injectors
- Please Help!!!!!!!!!
- Motor no compression
- Penum swap
- Running very rough!
- Need help!!
- Help my truck keeps stalling !!!
- Leaking coolant plug around intake
- Did I Screw Up the Trani in my '04 Screw
- 4.2 V6 Performance????????
- Not running the same
- '97 5.4L vs. '04 5.4L
- PCV delete
- MAF sensor
- temperature guage and blown head gasket
- Which one?
- racing vs. silverado
- V8 Mileage
- Neal, Read this
- Dumb Luck?!
- the tornado
- COP DEALER Question
- anyone else has an idea?
- Motorcraft fuel filter FG986B for $8.66 + free S/H
- 2000 Lariat 5.4/Another COP story
- Mpg
- Engine misses after snow...
- Dpfe??????????
- horsepower on my 2001F150 SuperCab
- best oil and air filters
- missing at highway spds
- What are coil packs?
- High throttle at start up?
- 1997 F150 4.6 won't fire
- 1990 F150 motor miss
- Radiator Fan
- tps adjustment question
- My 98 F150 4.6 sounds like a tugboat!!
- Supercharger
- engine misses! HELP
- What Supercharger?????????
- High mileage engine mods...
- So...
- cylinder 6?
- coil problems??
- antifreeze specs??
- trapped water?
- bucking and jerking (GONE)
- Programming diablo chip
- is it worth it?
- 15,000 mile oil change
- Antifreeze/Coolant Replacement
- Synthetic oil
- 5.4L stalls at idle
- Oil pressure question!
- Highway travel and RPMS
- water leak extravaganza
- IAC pictures?
- oil gauge probolem
- Switching Engines HELP
- Engine Knock!!!
- New guy here, quick question.
- Suspect MAF?
- Which cams are better?
- synthetic motor oils
- Casting number on head reads 5.4L?
- coil packs
- Next Project?
- 90' 300CI radiator
- what is needed
- Coil packs
- Cylinder Misfire
- Engine Issues HELP
- High Pitched Whirring Noise
- Vibration/shake
- Low power caused by early timing?
- Blown Out Spark Plugs & Supertuner
- Cleaning the IAC
- engine code help???
- 4.6.....5speed
- Very disappointed in my new truck!
- 2004 AEM Intake
- 2004 Screw won't start
- Engine Temp
- Won't Start When Cold Out.
- New Motor
- 4X4 with no limited slip traction sucks, please help
- Red Engine Light - Cold Weather
- 89 F150 300 Inline 6 problem
- PCV Valve???
- New (have questions)
- Ethanol
- sepertine belt
- Knock after rebuild???
- 4.9L Waterpump
- two batteries?!?!?! Help snow is comming
- where to buy motor?5.4 or 4.6
- new f150 diesel?
- 1998 F-150 High Milage 4.6 Triton
- howling noises
- fuel injector cleaner
- Throttle assembly/cable/pedal lube points?
- After cleaning my throttle body......(help)..
- Throttle Positioning Switch...???
- 5w30 vs 0w20
- Hypertech Programer
- Hard cold starts
- idle fluctuating
- Nitrous
- High Idle_Bucking_Jerking_Fixed
- Code 1451
- OK. Again on the rough idle?
- heater repair
- setup
- High Idle
- coil pack # 4
- Engine Fail Safe Mode
- Noises help please
- Fuel filter
- 4.6 truck motor vs. 4.6 mustang motor
- Please help with "miss"
- Will it work or what do you recomend
- oil filter remote kit
- Lightning Into 4x4
- I have found the pot of gold!!!!
- 2001 Expedition 5.4 Cracked Intake Manifold?
- What is your average MPG?
- help! mileage concern
- Sea Foam in my truck
- Oil Leak.... NEED HELP
- Oil????
- code P0315
- Cold weather...poor idle...then stalls
- Mobil 1 VS Motorcraft Semi Synthetic
