View Full Version : Engine
  1. Factory Oil Filters
  2. Spark Plug question
  3. No Start Issue : My cure
  4. Blown spark plug - fix or new engine
  5. aftermaket warranty and what can I expect...
  6. Gatorback question
  7. is PS possible on 2002 5.4 exped??
  8. Cooling help please
  9. This is SUCH BS! Most Ford dealers are LIARS. NEVER HEARD OF THIS HEAD PROBLEM? bs
  10. Is Chilton Repair Manual for a 98' F150 the best repair manual.
  11. PI Heads
  12. OLD 5.4L and new 5.4L 3v QUESTIONS
  13. '89 - 5.0 Engine Removal
  14. 1997 5.4 miss
  15. Birthday Snow...Pic of my truck
  16. oil change
  17. CEL comes on, but goes away
  18. Aluminium 5.4l
  19. low idle/die out problem w/CEL on
  20. COP Check
  21. '00 Lightning PS whine & pulls to the R
  22. chaning a sterio in my truck
  23. I'm about to blow this Ford UP!!!
  24. engine swap
  25. Oil Change Observations
  26. Dual Fuel Guage Rage
  27. Holy Crap!!! Mod/Carbed 32V Crate Motor!!!
  28. 2003 Harley Davidson Engine
  29. Side Effects
  30. 97' 4.2 V6 Misfire HELP!!
  31. low voltage when i turn on heater
  32. oil question
  33. Engine rattle at startup
  34. oil replacement
  35. Misfire?
  36. Changing Fuel Filter
  37. engine replacement question
  38. skipping sound
  39. Won't start
  40. fed up..ford sucks..screw em
  41. 5.0 redline??
  42. Speed Pro rods...
  43. Starter cutting out
  44. egr?engine or exhaust
  45. EGR port cleaning
  46. 4.6 intercepter
  47. 180 Thermostat good idea or dumb?
  48. 4.6 5spd check engine
  49. How to get rid of governor
  50. Does anyone have the computer/harness schematics...it is that ulgy.
  51. Code P0307 Missfire detected in Cylinder 7.
  52. Drive belt
  53. 01 screw purchase
  54. Rebuilding '90 5.8, can I junk the smog?
  55. Puzzled about the Cloudy Oil on 4.8 Filler Cap
  56. Loud Noise at 3500 rpm
  57. surging/missing at 3/4 throttle
  58. knock,knock,knockin thru my doors
  59. 99 f150 5.4 chirping metal to metal sound on cold start
  60. How hot is overheating?
  61. racing cam??
  62. V-8 in short bed...
  63. Rough idle
  64. Engine stalls after warm up.
  65. Help PLEASE
  66. Very Deep Water, Engine flooded, Oil pump failed -tear down questions on 01 5.4
  67. '05 5.4 engine missing
  68. 4.9 code reads 556 ( fuel pump)
  69. Okay guys......
  70. 2002 F-150
  71. motorcraft plug #'s different?
  72. 97 4.6 First Tune Up
  73. Lightning Cluster In Reg F-150?
  74. "97" Triton 4.6 Wet Spark Plugs..
  75. 1991 F-150 5.0L question
  76. throw me a bone please
  77. schrader valve
  78. That 4-barrel sound
  79. differnce between a 351 cleveland and 351 windsor
  80. Cleaning the Intake. ??????
  81. Ford needs wheaties?
  82. upstream 02 sensors 97 F150 4.6L
  83. MAF and Injectors worth it now?
  84. Just bought a 98' 4.6l with 102k. Going to change oil what should I use?
  85. Running to Lean
  86. compression
  87. After pulling the Pos cable how long does it take the computer to reset.
  88. Rad for 97 f-150
  89. timing (help)
  90. Mustang motor swap into 1985 F150 Qs
  91. DPFE Question
  92. too rich for my blood
  93. 93 F150 5litre->nasty sound
  94. DTC code P0133
  95. Help! 1986 4.9L 300 6cyl. F-150
  96. oil leak
  97. Washout here's a list of Dodge and Chevy owners problems vs my Fords..all true.
  98. Ford Specific Acronyms
  99. How to Fix a freely spinning COP bolt?
  100. Power Steering Fluid
  101. Hesitation from stop and someone pulling on bumper....
  102. low gas mileage
  103. 1997 f150 4.6 engine egr problems
  104. Replacing O2's on a 5.4L
  105. Low Power on my 4.6l
  106. mustang 5.0 H/O Motor
  107. 96 f150 351 still has trouble starting
  108. another misfire story
  109. no power
  110. Head lights will not turn off
  111. 02 sensor trouble code
  112. Resetting the Computer Module?
  113. Strange noise in 97 f150
  114. '04 5.4 Low or Rough Idle
  115. Anyone have a guess(Educated or not)
  116. Engine Loud Starting Out
  117. misfire
  118. stop leak in coolant
  119. 1999 airintake manifold
  120. cool me down - please.
  121. rattling noise in engine
  122. performance upgrades 04 5.4
  123. Throttle Body identifications
  124. Ford Techs Please Help
  125. Ported throttle body pix
  126. New To The Forum
  127. '94 302 f-150 4x4 auto eats starters
  128. P1299 overheating?
  129. theft lights and misfires
  130. another stupid oil question
  131. 5.4 motor rebuild
  132. Oil Foaming
  133. trouble starting 89 f150
  134. head gasket leak
  135. Which O2 sensor is bank 1 sensor 2?
  136. '98 4.6L filter mount (to engine) o-ring size
  137. engine swap
  138. Fuel Injector life?
  139. is ford crazy?!!!
  140. lifting an engine
  141. 2004-2005 FX4 5.4L Oil Filter Change
  142. 4.9 litre pushing dana 60?
  143. High Idle
  144. Plug replacement when motor running fine?
  145. supercharger
  146. 4.6 engine
  147. Ruff running engine or bad gas milage got you baffled?
  148. How to do an Engine Compression test ( and what it all means )
  149. 86 F150
  150. Mobil 1
  151. Engine xchange
  152. Muffler Suggestions
  153. german castrol
  154. code p0420
  155. Hard Starting
  156. Engines
  157. 98 5.4 low idle (adjustment ??)
  158. little problem with heat
  159. Failing Hot Starts
  160. antifreeze causing #6 to misfire
  161. new fuel injectors gone bad
  162. missing out
  163. Service Engine Light
  164. "Service Engine Soon" light
  165. throttle body spacers??
  166. 99 F-150
  167. 02 Expedition P0401 code
  168. 2000 5.4L 4x4
  169. New Supercherger for the '04-'05 F-150
  170. 1990 4.9 won't run more than a few seconds
  171. Cracked Plugs
  172. Fuel Injectors, MAF, Tune worth it?
  173. K&N Airfiler destroying engine??
  174. 1995 F150 XLT 4x4 302 Extended Cab Problems
  175. A Few Minor Probs...help Please
  176. 2003 F150 4x4 5.4 leaking from rear main
  177. Misfire on UK based King Ranch
  178. Compression testing cylinder specs?
  179. Oil Pump Failure 5.4 2001 F150
  180. rough idle after cleaning throttle body, IAC, and EGR
  181. 1978 351w horsepower?
  182. Bad #4 coilpack RETURNS!
  183. 96 f150 won't start till fuel pump quits
  184. supercharging 5.4L 3v
  185. OBD-II readers
  186. Check Engine Light - Running Lean/Rough Idle
  187. lookeng to buy a ford need help
  188. Replacing my IMRC
  189. Need more Hp
  190. Need help with EGR diag ( 95 - 351 )
  191. PCV mod
  192. HELP!!! I'm losing gas
  193. How often do you oil air filter?
  194. egr bypass
  195. engine missing
  196. changing the #@$(*% fuel filter
  197. 98' 4.6w has coolant in plugs valleys.?
  198. DTC's Showing up on Instrument Cluster
  199. What is Exhaust Recirculation error?
  200. Engine Build Date
  201. Switching back to 5W30
  202. veci label
  203. Those new spark plugs
  204. ford motor or a jasper
  205. coil packs
  206. Trucks acting up any thoughts???
  207. 1996 302 stumble
  208. Do Billet pulleys really work?
  209. Lucas Fuel Treatment
  210. 1994 f150 351w Engine Question
  211. cleaning throttle body
  212. How do You Install Fuel Injectors
  213. Town Car intake and exhaust manifolds fit?
  214. oil again "hopefully its not a rehash"
  215. Hoses
  216. Surging Idle
  217. Engines fails to start
  218. Oil for a 4.6 4V Cobra Engine
  219. 89 5.0 question
  220. I cant figure this out
  221. Cruise Control Surging
  222. Doing some maintenence, need some input
  223. Has anybody tried AUTO RX treatment in their F-150 engine?
  224. air pump or egr???
  225. Water leak at heater hose fitting
  226. 03/99 5.4 engine...
  227. wrecked 5.4
  228. To stroke or not to stroke, need some information
  229. 4.6l loss of #4 cylinder?
  230. Engine governor
  231. po135 with new sensor...
  232. 88' Idling high
  233. natural gas conversion?
  234. Help on 91 ford
  235. E150 taken off the road
  236. 4.6 piston slap question
  237. no start
  238. Spark?, Fuel?, Something else???
  239. smokin': valves or rings, how to tell?
  240. havoline 5w20
  241. New mobil 1 extended performance
  242. 4.6 or 5.4
  243. 2004 4.6L F150 vs. 2005 4.6L Mustang
  244. My K&N / MPG Study
  245. Misfire problems resolved
  246. Stock Air Intake vs ??
  247. spit and sputter
  248. Loud Whiney screeching sound?
  249. ? ...about 4v heads
  250. Keep loosing a plug
