- Torque Alternator Pulley
- Power Steering...should I be concerned about this noise?
- Mobil1 or Amsoil?
- 4.6 vac leak
- Lightning motor swap
- Help With Power Programmer!
- check engine light on reads code cylinder 1 misfiring
- Minor oil leak - Oil filter location?
- Add Hp
- High idle after cleaning throttlebody
- What kind of performance can I expect out of a 2000 4.6 F-150?
- Rattling when startup
- Hi Performance Accel Wires
- 1998 F-150 5.4L Cheap Mdifications
- Is high octane fuel bad for a stock F150?
- Shell Premium Gas "V-Power" -- Causing Problems with my engine
- 2004 F150 4.6L CAI recommendations?
- 2004 F150 5.4l
- 4.9 radiator hose pressure
- fuel transfers
- water leak help
- Puff Of Smoke
- 99 4.6 missing
- injectors and mass air meter help!
- Troyer Fans removed and reinstalled. Some information that may be on interest.
- Air Temp Sensor - A Dumb Question
- throttle body
- ADVICE PLEASE: 98 F150 4.6L V8 what's this noise?
- Engine Shapmoo...
- 94 I6 randomly has no spark...
- Questions about truck
- Question about gears and pcm
- 4.6 thrust bearing
- Fan Clutch
- Pulling a 5.4
- Worked on the truck again today...
- Gutless in Colorado
- 97 F 150 4.6 to 5.4?
- 2003 Ford F150 Supercrew Won't Start
- Wiring Harness Compatibility
- Erratic Idle 4.6 2001 f150 XLT
- check enigne light
- F150 XLT '02: Smell gas/oil & 12mpg
- Help! Engine missing when driving through puddles.
- Spark Plug Location
- If I remove the throttle body...
- Windsor vs. Romeo
- Flex-A-Lite for the 05
- 4.6L misfire fixed
- 2003 5.4 ping's
- Code P0401
- failure
- Power steering pump fried
- o2 sensor effect MPG?
- 5.4 diesel
- Intake Manifold
- spark plug gap
- throttle spacer
- Fault code P0191
- Theft flashing, odometer dashes "------", cranks no start
- Got an engine failure when accelerate
- 1997 Specs
- Code P1400 DPFE Low Voltage (No CEL)
- 1988 ford f150 dual tank problem
- Again, pinging with my 4.6 *pics*
- High RPMs when coasting in neutral - Help
- Help
- I think it's fixed
- Egr Question?
- hate to bust everyones bubble
- HELP! BBK Pullies Question
- Installing roller rockers, any tips?
- 94 f150, 4.9 I6 wont start! help!
- 5.4L engine missing
- Head leak & send , return oil lines?
- 2007 f150 diesel.....sure thing
- Fuel pump doesn't sound right
- DTC Help Open Loop
- P1131 and P1132 Trouble Codes
- rust in fuel?
- fuel system
- 89 4.9L problems
- K&N vs. Airraid intake systems
- misfire and code
- 94 F150 computer location
- Best Brake Pads
- 4.2 V6 vs. 4.6 V8
- JMC please help
- intake mod question
- Nuetral Safety Switch?
- ****ty****tybangbang--service engine
- 92' wont start HELPPPP!!!!
- TSB's can be found here...
- Tensioner replacement
- dpfe location haynes manual is messed up?
- EGR simulator?
- im searching
- p1132, p1152 and p0136
- Help on Adjusting Throttle Cord
- Engine keeps cutting out! Help!
- Fast Idle Adjustment
- code p401
- 98 Problems
- How to remove 5.8 fuel rails?
- New Guy
- Fuel Tanks
- Bad throttle body-new 5.4
- High idle fixed!
- 5.4L good engine or NO?
- Double Fuel Tanks
- quick question on EGR
- Service Engine soon!
- Quick question about serpentine belt...
- E150 Brake Failures
- ****! I kilt Mah truck! HELP!
- Some more details, engine ticking, please help.
- Slow Start
- California Smog Check; No Problem!!
- What wrench to remove center 5.8 manifold bolt.
- PLEASE HELP! Excessive gas usage!!
- gator back
- '99 Flareside BIG CHANGE W@W
- Low Oil Pressure Warning
- Engine popping sound...help appreciated.
- finally have money for new motor, suggestions?
- Flexplate- Converter clearance
- Strange Chambers
- 4.9 300 I-6 trouble HELP!!!
- V6 to V8 swap?
- Where to get a cheap used 4.2 V6
- air pump removal on 89 F150 4.9
- Another 5.4 Miss Firing Thread (Help please)
- Help! F-150 problem driving me crazy
- Pressure build up in the radiator ? Actually two questions
- need help
- Cluster Swap
- Heater Core Problem = New Engine Solution
- 97 4.6 romeo vs windsor question
- coolant flush, took half !??
- Eng Running Rough
- oil consumption
- Buzzing PVC Valve
- Underdrive Pullies
- Engine Info
- dies after warm start
- Removing neg. battery cable won't restart computer?
- P0402, P0171, P0174 Assistance Por Favor =)
- Engine vibration
- Knock at start up
- High idle in drive
- Replacing O2 sensors..?
- silicone dielectric compound?
- 1988 300/6 into 1992?
- P0401 for the 1000th time
- 1999 F-150 5.4 Head Gasket Leak!
- Engine Runnign "Lean"
- Porting Pics
- 302 Engine Swap
- air intake snorkle enlargement/removal...does it really help?
- causes of engine knock besides PS?
- Dropping my gas tank.......
- "Help" Engine Light
- Fuel Injector reconditioning?
- Can I go Synthetic?????
- updating ford computers?
- Oil leak?
- Please Help Me!!!!!!!!
- Timing Chain Rattle?
- Vibration @ 1400-1700 rpm's
- fuel filter
- Cam swap instructions
- Replace oil sending unit
- Throttle Body Upgrade
- LP Gas
- Smell Coolant Burning from Exhaust
- coolant leaking
- Bad gas
- 91' f-150 wont start
- Shortie or long-tube headers
- 1991 Truck Questions
- ford f150 cranks no trigger signal to injectors
- Installing a 460 into a 1992 F150
- water in oil
- 5.4 Misfire
- Service Engine Soon Light on 01 Navigator
- Coolant loss
- what oil?
- engine problem
- 4.6l to5.4l
- test
- Long Reach Spark Plug Socket
- Which 5.4s have problems?
- gas light
- Cubic inches?
- Fuel filter
- Engine Swap
- 95 F150 6cyl with reving problem
- Intake Heat sheild
- Tune Up Issues
- Will this make any difference?
- What engine do i have?
- True Flow intake on 97 F150 XLT
- no check engine light??
- Intermiitent no start - no code
- PI manifold on non-PI heads
- Power stroke running rough
- AWSF32P Motorcraft spark plugs...
- Horrible Fuel economy on 91 F150 5.8L HELP!!!
- Please help -- URGENT!! :(
- Fouled plugs
- has anybody used these for crossed threads?
- How much power can the stock tranny handle
- 2000 F150 4.6 missing issues
- Engine rattle
- BIG Sert Question
- 300 - 6 stutter
- Coalescent Fuel Filter Bowl
- 96 F-150 Engine Swap Questions
- Tune up time
- 4.6L Engine Leak
- Found my rad leak
- help with 2 trouble codes
- Coil On Plug replacement 5.4
- 1992 f 150 floods when trying to start
- transmission code
- and yet anothe misfire
- Coolant Leak from Air intake Area.
- I fixed it Today
- Torque spec. for 5.4 intake bolts?
- valves tapping
- Give me some ideas
- cam's for 98 4.6
- 300ci muffler suggestions
- Air don't work
- How to remove harmonic balancer bolt
- 300 6cly best way to get alittle more power?
- 87 F150 EFI IL6 no spark
- f-150 just clicks
- need help fast w/ ps pump
- Restore?
- Cleaned EGR ports, cool weather ping is gone.
- Mil not coming on was tape over it...
- po306 Engine Light After Glamis ???
- 84 F150 Won't Start
- 4.2L with 120,000 miles
- Won't start when hot
- 4.6 Misfire on #5 Sheesh
- exhaust manifold
- Ahhh High Idle
