- Pcm
- My $120 air filter
- code reader/engine diagnostic tool needed
- How to check for limited slip
- ProCharger Finally Installed On 04 SuperCrew
- 1986 F-150 vacuum line diagram
- 1986 F-150
- What do all of you do with your old oil?
- service engine on...... running lean
- erratic idle fixed(for now)
- Cab removal
- P113 code
- My Milege
- smog pump needed?
- 5.4L or 4.6L? and from where?
- Changed coils car idles rough
- supercharged 00 hd
- '95 f-150 fuel filter
- Engine idles for a couple of minutes and then dies
- Need adivse - mixed 1 qt 10w30 with 5w30
- '04 supercrew 4.6 v8 radio ignition noise
- 1990 won't start, then press accelerator, it starts
- Bosch & K&N oil filters
- going to take down my gas tank on 94 f150
- Problem Years
- 94 F150 TPS adjustments
- 1999 ford lightning heads
- Check Engine Soon
- F150 94 5.0L Throttle problems
- 5.4 milage
- curious if 5.4 triton engine cylinder placement is the same as older engines?
- anyone have a set of aluminum heads for a 99 5.4L ??
- Two different 4.6's?
- K&N
- 2001 5.4 misfiring. Code reader says #2 cyl
- Oil Leak in 2003 Supercrew 5.4 L V8
- driver side head needed for lightning!!
- 89 F150 5.0 starting idle problem...
- What Computer for my 01 f-150 SC 4x4 XLT
- Check engine light at highway speeds
- 4.6 heads-same plug launch problem as 5.4?
- Which coolant is best?
- Rear Main Oil Seal
- 4.6 with 3.55 gears
- F350 Diesel Computer
- A Question For The Idle
- Spark plug repair
- run away idle
- Clicking noise on 5.4L
- No Start Condition - PATS Activated
- 4X4 Issues
- Any larger oil filter available a 2004 Expedition 5.4L?
- Chevy 302ci V-8s kick butt!
- 01 F-150 Supercrew Xlt 4x4 5.4l
- Radiator overflow connection Hose.
- Engine stalls after warming up
- 4.6 rough idle...???
- random check engine
- ruff running '95
- oil dipstick tube removal on f250
- 98 cab off pics in shop
- Best Code Reader
- Throttle Body Cleaning
- proud of my triton 5.4
- master flow sensor
- Im stumped????
- another hesitation/missing question
- 5w30 or 10w30 in 97 F150 4.6
- Will not start
- 5.7 Engine oil type.
- simple, reasonably cheap performance mods for 97f1505.4, 4x4
- Am I screwed?
- 98 won't start - things I've tried...
- Oil usage question
- HELP! My 99's misfiring and electrical surges?
- 5.4 idle problems
- CEL fixed (DPFE; thanks!!). New issue: occassional vibration.
- Best recommended Performance mods '05 5.4L
- MIL lights up after 20 minutes.
- F-150 01 V8 5.4L 4X4 Rebuild
- As I thought, air box "mod" a wash
- Wanting to put a 4bbl carb on a 300 I-6
- Can Someone Tell me what part this is?
- Individual coil packs?
- Injector ticking
- Whining starter???
- Anyone else think of using ztech plugs in a triton?
- Firing order for '84 300
- '98 4.6 litre good or not so good?
- Someone Help me
- need engine gaskets replace help info
- superchip on 4.6?
- Rough Idle normal??
- oil filter relocator
- 4.6 engine oil
- Survey - 100,000 miles btw tuneups?, HEY RIGHT!
- Hot engine won't start
- 1999 ford lightning driver side head needed!!!
- Attn: Bluegrass
- operating temperature
- Fuel pump problem?
- Antifreeze smell coming through AC vents
- Pulled a stupid today
- 2001 5.4 Injector #19 To #24 Help !!!!
- Coolant Choices
- Hesitiation 5.4L
- 4.6 upgrade
- Mystery Coolant Leak
- a few quick questions
- 4.6 (MISS) "lord I apologize”
- Metal on Metal sound in drive, help appreciated!!!
- P.I. Heads??
- Under Hood Squeal
- need help with timing
- carbon in ehaust
- Engine Question?????????
- Oil Recommendation - hot desert summer
- 4.6, what side oil filter?
- noise
- Idle when stopped
- P0306 SES Code
- Fan clutch
- Distributor
- Low end??
- Ignition Trick???
- Mystery TSB
- idle problems
- Jmc
- Remove engine to change lower intake manifold gaskets
- Post Cat O2 Sensor
- 4.6 missing part 2
- oil
- Torque to Yield?
- Check engine Hell - too lean?
- Vortech Supercharger????
- pil pressure light coming on
- 1989 F150, problems keeping running
- '98 Starter wont disengage
- blown plug
- Idle rough problem (recall)
- 302 in Ford Ranger
- Do I have a bad seal?
- Neat
- Engine Miss
- Add me to the blown plug list....
- 4.6 107K 13.5mpg
- engine swap
- Idle Problem After Spark Plug Change
- Engine Startup
- Fuel pressure
- '99 5.4l
- Lean condition
- A comment concerning spark plug blowout
- Alternator Question
- nope
- bbk shorty ceramic headers
- Tornado?
- K&N Air filters
- 2000 L needs help
- Blinking CEL
- Transplanting engines.
- Engine conversion
- Have a weird noise
- What to do with old air filter and intake
- Stupid intake
- My truck did something strange today.
- 5w20 vs 10w30
- Guy put transmission fluid in my engine
- Gas cap problem
- 1997 Engine Upgrade
- Gas Guage
- K&n
- humming driver side
- The popular engine misfire
- Fuel Pump TSB 02-16-4
- respectable place
- Distilled water to flush out?
- GT40P heads on 83 f150
- Motorcraft Spark Plugs
- 4.2 liter highway surging
- Ported Intake Elbow
- Throttle Body Spacer
- 5.4 Oil sending unit leaking
- PO 171, 174 issue: Thanks!
- CLASS ACTION: Blown plug, damaged cylinder head
- RPMs high on 1989 F150 V8
- What Jack Stands???
- Ford F-150 Ignition Coil
- Will Cobra/SVT Crate motor fit???
- Starter? HELP????
- using oil
- 5.4 Plug Blowout
- Engine swap
- Idle Spead Control
- Bosch plugs any good?
- Throttle cable needs adjusting?
- hyperteck programmer
- my truck cab off pics
- power stearing 98 f150
- cleaned IAC & TB & now....
- How to remove old DPFE sensor?
- 5.4 was running rough, now cured
- 4.6-no power and 11mpg highway???
- 5.4 Spark plugs
- Turbonator.com
- Fuel Pump Inertia Switch - Disconnect
- My story
- 4.6 Lack of Power
- NO MORE MOTORCRAFT AT Wally World?
- Extra Power
- Service engine codes po153 and po171
- P401 with Shorty Headers
- Fuel Problem / 89' f-150 5.0
- 4.6L timing, do I have it right?
- loose steering wheel
- 5.4 Is A Dog!!!
- Check Engine light is OFF!!!! WOOHOO!!!
- Remote Oil Filter No More!
- removed cop's still wont run smooth
- hollow "tick" under acceleration
- PCV valve
- Engine fault help
- engine trouble??
- heater core, again?
- forgive me, for I have sinned
- running bad after offroading
- Run's now
- No spark
- 302 intake Q.
- engine onry about starting
- Fuel pressure Question
- 5.4 Smoking at startup intermittently
- Help, Service engine soon light on.
- Air Temp Sensor and the Barometric pressure sensor
- Odd engine noise in 2004 5.4L 3V
- 4.6 mis-fire
- What about the CAMS???
- read differential gasket
- Propane/NG/Hydrogen VS Gas
- 5.4l Cylinder heads
- 4.6 intake
- was this a good buy?
- surging
- need help finding oil pressure sending unit
- royal purple oil
- Check Engine Light ????
- Question on a 2000 f150 4.6
- What's the deal??
- Just Some Questions
- Torque Alternator Pulley
