View Full Version : Engine
  1. 01 5.4 vs 05 5.4
  2. A/C low pressure Valve
  3. P0340 Camshaft Sensor Malfunction
  4. k&n air filter
  5. 5.4 L Firing Order
  6. When to replace Fun Clutch?
  7. Need Help from the Gurus!!!
  8. rough idle & miss on light throttle
  9. Today's oil change.. <humorous>
  10. Code 0118 question
  11. For LABNERD.
  12. SERIOUS Help needed
  13. IAC solenoid
  14. Check Engine Light
  15. My tranny is really screwed up and may want to swap motor/trans while im at it
  16. Cool It
  17. off topic, but still a ford engine
  18. Low-RPM Clatter Under Load
  19. Well, I Finally Blew It Up!!!
  20. Egr
  21. EEC-V modifications
  22. a different type of MPG question
  23. no spark
  24. Will not turn over when hot?
  25. throttle body spacer/cold air intake
  26. Question regarding spark plug gap
  27. Great online help site
  28. engine code 0402
  29. Help Me!! I'm A Girl
  30. EGR solenoid bad?
  31. rich on bank 1 & 2 troubleshooting
  32. i think my truck is on its last leg.........out of nowhere
  33. 5.4l Help
  34. Truck won't start.
  35. Does it have P.I. heads
  36. New pump, injectors, and 90mm MAF are in, Help with Harmonic Balancer removal.
  37. 1995 F150 Tanks
  38. computer
  39. Question about overfilled oil...
  40. Turbonater....Worth it?
  41. HELP 1989 f250 will not start! HELP
  42. Canadian Exhaust advice.
  43. spark plug brands
  44. New Member needs help!
  45. airbag code 2-7
  46. Ford's aluminum block is throwing plugs
  47. Removing Fan Blade on 01 F-150 5.4L
  48. New (used) F150 owner question
  49. Ford fires
  50. What to buy and when?
  51. Where--exactly--is my air intake?
  52. How to Remove my Radiator & Transmission Cooler
  53. K&N pipe won't stay attached
  54. Where is the plug for a code reader?
  55. synthetic oil
  56. My Chase My 04 F-150 4.6/3000-GT (hit-and-run)
  57. Service Engine Soon light
  58. Crown Vic Engine in Truck?
  59. '97 F-150 swap out 4.2 6 cyl for 8 Cyl
  60. quick question
  61. DPFE sensor fitting replacement
  62. Gas Tank Connection
  63. My Truck is Eating Ignition Coils
  64. 351W bored .060 over, WIll it overheat?
  65. Power loss...Please Help
  66. 4.6 shakin' like mad under acceleration...?
  67. Help P0401
  68. Help, lost a screw, wasnt sure where to post...
  69. Fast idle when cold
  70. Restore Engine Restorer....Work??
  71. misfire detection
  72. Gutless 4.6 4x4 f-150, first timer
  73. V6 to V8 replacement
  74. Radiator Size?
  75. 2006 f350 powerstoke block heater
  76. Does my engine have primer?
  77. First time Ford pickup owner!
  78. Fan Clutch
  79. 4.6L plug change...pull fuel rail, etc?
  80. Blue / White Smoke - Shop Says New Engine
  81. Wont start...Just the click !! Help
  82. 351W Frost Plugs
  83. Changing Engines?
  84. Ford F-150 Needs Power
  85. Engine options
  86. The search for a louder loud pedal
  87. Flushed the coolant yesterday...
  88. Lightning Motor in 150
  89. Code P0401
  90. stretch that hose!
  91. starter protection??????
  92. Check Engine Light!!! this are the codes...
  93. 302 and 351W power
  94. Keep replacing coil pack on same cylinder #2, 5.4
  95. Oil Pressure on cam chain tensioner
  96. Wet Plugs??
  97. water leak after truck is shut off....
  98. do you need a lift for cab removal?
  99. Engine cuts out at times.
  100. lacking power
  101. 86 crown vic idle rolls up and down
  102. resistor chip
  103. relays 301 and 304
  104. need some advice on a 02 expy
  105. Intake Advice.
  106. Anyone ever change an O2 sensor read this.
  107. Questions on how to install new carburetor (pictures)
  108. Computer reset won't work...
  109. Whats the best way to clean the spark plugs??
  110. PCV location on f150 4.6
  111. I'm sick of the hesitation
  112. Plug blowout question
  113. Oil Pressure
  114. FIPK causing stall?
  115. fuel filter disconnect 3/8" (D) ???
  116. Belt tensioner question
  117. Weird "No Start" Problem...
  118. Help with three codes!!!
  119. Spark Plug and Wire/Boot Installation Made Easier (Maybe)
  120. poor throttle response(newbie)
  121. Shifts out of gear
  122. Too small
  123. PCV valve
  124. Starter Removal '98 F150 4.6
  125. Mechanic Say Coolant Eats Gasket?!
  126. Help with P0171 and P0174 System too lean codes.
  127. Spark Plug Wires. Getting a little annoying to replace.
  128. Warranty
  129. Help with EGR Code Problem.
  130. can i use this oil?
  131. Powerwashed engine, now truck chugs and shakes
  132. Gas Milage
  133. some motor questions
  134. Service soon light and battery
  135. 1989 F150 w/dead 351 engine
  136. spark plug thread count...
  137. Engine Flutter
  138. Lightning swap in a 97 4.6L 4X4
  139. Question about intake bolts torque.
  140. some squealing and a thump
  141. Hooting Noise
  142. Unleaded vs CNG
  143. Service Engine Soon Light
  144. ANY CHEAP, EASY WAYS TO GAIN POWER ON 4.6l??????
  145. info on cold air intake kits
  146. Where is the spout connector on my 95, 4.9 inline?
  147. a little advice please
  148. Another sparkplug question
  149. Lightning MAF on regular 5.4? Injectors #?
  150. 91 302 in a 94 engine swap
  151. Misfire at low RPM under load
  152. Extra Port On PCV Valve
  153. 1989 F150 w/dead 351 Windsor Engine
  154. 351 Marine Engine Popping through exhaust and intake
  155. 97-00 vs. 01-present 4.6L
  156. 5.4 rattle upon start?
  157. question
  158. 5.4 vs 4.6
  159. Fuel Gauge
  160. Cold Air Intakes. Advice please.
  161. Engine acting funny
  162. Oil Gauge And Light
  163. fine in neutral
  164. Tried Everthing no good
  165. Engine Treatments
  166. I need some input-Long story
  167. Chirping Noise?
  168. Oil Change Frequency
  169. trouble codes
  170. Vibration damper
  171. Ruined my 4.6 today...
  172. 95 F150 engine upgrade
  173. Milage saving tips.
  174. Fuel economy - Tailgate up or down?
  175. Worried about problems after Head Gasket Replacement
  176. Feul Milage had dropped majorly.
  177. dead spot on pull out
  178. truck died on road
  179. Help with a serious problem....
  180. Should I be worried?
  181. 302 to a 390 or a 400
  182. 5.4L 3V Throttle Oscillation
  183. having trouble with engine
  184. A gift from Ford, If you have a rough idle read this, its long.
  185. Slick 50 type additives on 2004 Screw 5.4L
  186. groaning EGR solenoid and rough idle
  187. overheating problem
  188. PCM reset while driving?
  189. Hard to start 1994 5.0
  190. lightning motor in explorer sport
  191. 1998 F-150 4.6L Misfire on # 2
  192. Tow Package?
  193. engine chirp
  194. Truck won't start
  195. 2004 F-150 Oil Weight
  196. THe old P0171/0174 code again, but trouble still
  197. 5.4 description
  198. Location of the coolant drain plug on 5.4L
  199. 99' 4.0 OHV Explorer - Injector Size?
  200. Time For what part goes in that hole on my engine.
  201. Threw rod through oil pan
  202. How do you check a fan clutch?
  203. Camshaft Position Sensor question---->
  204. Testing Ignition Coils
  205. Misfire problem on 4.6 PLease HELP
  206. swap
  207. 97 Expy 5.4 sputter
  208. Blown Plugs (revisited)
  209. does an air intake void warranty
  210. What's the difference between Chevy & Ford motors?
  211. 97 4.6 block coolant drain plug
  212. egr excessive flow
  213. Engine swap 5.4 01 to a 04 3 valve
  214. Looking for a truck
  215. Where is the temp gauge sending unit on an '87 F150 4.9L I6?
  216. swaping engines
  217. engie oil
  218. Bad gas cap
  219. Rattle, Only in drive?
  220. Rough idle when starting and start accelerating
  221. 5.4 Towing ability
  222. 4.6 2001 idle drop
  223. oil leak
  224. Engine Stumbles When Rolling To A Stop.
  225. STP w/ synthetics ???
  226. 350 Dually Questions
  227. Block prep?
  228. 88 f-150 won't start
  229. Check Engine Light!!
  230. 97 F150 5.4L Coil over sparkplugs.
  231. 350 Dually 4X4
  232. has anyone know of mac performance air intake systems
  233. k&n or air raid cold air intake
  234. 6.2L Hurricane engine update?
  235. Just thought I'd share........
  236. Locked steering and no windows
  237. What works to PLUG EGR holes in cyl Head?
  238. Tech Heads... I'm Timing a 5.4 and got ?'s
  239. removed smog pump - WHat Belt will fit?
  240. Its been a while, have some cash and need some help spending it
  241. What is a PCED?
  242. Want to replace my plugs in my 2004 Lariat.
  243. how much to expect for an engine swap
  244. 4.6 liter sputters??
  245. help!!! 96 F150 warms up then dies, wont start!
  246. 92 XLT Black exhaust smoke, bad milage-Need Help!
  247. What do I need for MSD ignition?
  248. Oil Help
  249. '99, 5.4 w/ 128k using oil
  250. Everything you ever wanted to know about the 4.6L
