View Full Version : Engine
  1. Pi Heads
  2. Serpentine Bath Path URGENT PLEASE HELP
  3. oil pressure
  4. Engine starts hard, dies while driving.
  5. Bigger Tires - Chip for speedo/shift adjustment
  6. Serpentine Belt Removal
  7. 95 F150 hard starting
  8. Lots To Go Around!
  9. i want 14s
  10. Need a source for timing chains 4.6L
  11. AC / Heater
  12. What 4.6 would you use?
  13. Tensioner pully
  14. Pinging, Testing DPFE
  15. fuel filter
  16. Oil Change 7qts?????
  17. What years was the 5.4 5sp 2wd in a F150.
  18. 1990 F-150 Oil in air filter compartment
  19. Spark Plug part number confusion
  20. 4.6 interchangeability?
  21. Need new Engine...Should I swap with used or get rebuild?
  22. Valve cover gasket question
  23. For those of you that have TP Dual E fans installed
  24. Truck Burned Up!
  25. Sensor location on 4.9L ????
  26. 5.4 misfire after bath..HELP
  27. oil pressure sending unit
  28. Old problem, new fix?
  29. New Truck, Terrible Noise
  30. Getting started on TP e-fans and pulleys???
  31. 1998 F-150 Chronic Radiator Replacement Issue
  32. A website which has soundbites of engine problems?
  33. try this easy fix for engine misfire problem
  34. Help...dealer's suck...need someone who actually knows something about these trucks..
  35. done went and bought a 5.4
  36. 5.4 dies
  37. 302 Rpm Redline
  38. Truck Dies???
  39. 5.4L Cylinder Heads
  40. Rebuilding 98 4.6 Can't find a cam kit, Help
  41. Rattle in engine, please help!!!
  42. 5w-20 v. 5w-30
  43. Engine size of the 5.4
  44. no tach in a standard shift truck?
  45. Spark Plugs for 2k2 4.6
  46. SES light, fixed cause, light still on, now what?
  47. Engine missing badly - throttle body?
  48. P0171/P0174 & engine won't start
  49. Has anyone fixed the Engine miss/hesitation on The 4.6
  50. Torque Wrench Name Brand
  51. 5.4 with 4.6 rear end?
  52. K&N FIPK for 2004 F150 5.4L
  53. Motorcraft at wal-mart
  54. Poll: Which engine should i put in my 2000 Navigator? 4v or 3v?
  55. Which Engine?
  56. 97 will not restart in the summer
  57. I need help ASAP please
  58. Still stalling when hot outside please advise....
  59. Can a truck run poorly and not show codes?
  60. want to replace O2 sensors
  61. Off Idle Stumble??
  62. squeal
  63. Sticky Rings
  64. Denso Gapping???
  65. 95 v8 5.0 runs bad after an hour
  66. engine oil temp? whats normal?
  67. New Plugs, Wires, and Coil Packs
  68. OBD-II For 2005?
  69. Starting problem
  70. 4.6 L Broken Exhaust Maniflold Stud
  71. Injector installation
  72. Modified Or Not?
  73. More Spark PLug BLowout info
  74. Code diagnostic tool?
  75. Bad A/C compressor?
  76. gas mileage 2wd vs. 4wd
  77. Code P0136?
  78. 5.4 5 speed
  79. codes p1153 and 1133
  80. Taking out the govner
  81. Trying to Get More MPG Can anyone HELP
  82. 4.6l Intermittent High Idle. Why?
  83. crankcase breather filter full of oil?????
  84. What's your favorite auto parts store?
  85. Walmart Performance Products!!!
  86. Looking for Headers
  87. towing capacity question
  88. Need Help. Engine miss/hesitation with A/C on?
  89. 4.6 aftermarket intake manifolds?
  90. Modular V-8 in a Ford Ranger?
  91. Hurricane Officially dead!
  92. Air Force One intake problem
  93. Bad missfire.
  94. New engine - p0175 code
  95. what cam?
  96. chilton/haynes manual
  97. which intake for 2000 Expy?
  98. Estimate my HorsePower
  99. 95 4.9 SPOUT Location?
  100. stalling out....
  101. Pinging-What's Next?
  102. Can't get #3 plug out...
  103. anyone know anything about 4.9 I-6 engine?
  104. P0304 in 98 Navigator
  105. Washing the motor will cause the coils to misfire and fry?
  106. 4.2 V6 to a 4.6 V8???
  107. 460 questions
  108. Is my K&N air filter too far gone?
  109. SRT-10 Overrated!
  110. IAC Location 1999 5.4
  111. Squeel under hood at high RPM
  112. 1992 engine size???
  113. CEL/SES After New Plugs, Coil
  114. P1131
  115. Variable valve timing?
  116. OEM 5.4L IAC on ebay
  117. what is causing this missing in the engine??
  118. Buying new motor, what will work
  119. How much should a DPFE sensor cost?
  120. Best Engine Service Manual Opinions requested
  121. Worn-Out Plugs at 60K
  122. What does this engine noise sound like to you? Rod or carbon knock?
  123. Where is EGR on the 5.4L DOHC 32V??
  124. Starter/Battery question
  125. nitrous kit installed plugs burned
  126. EGR System
  127. MERGED: ULTRA FILTER, lifetime direct replacement washable oil filter
  128. noises!!!!!!!!!!!???????????
  129. Can bad coil packs make new problems?
  130. Correction- It's Frantz, not Franz. Sorry. NT
  131. Anyone remember Franz{not Fram} oil filters?
  132. what brand of cleaner?
  133. getting ready to do PI head swap, HELP Ted'98 you there?
  134. Canadian Octane levels
  135. New motor, change gas to midgrade, engine croaks!!!
  136. Engine knock.......Please help!
  137. Will a 2002 5.4L 32v DOHC engine fit in a 2000??? Please help
  138. f-150 idles to high?
  139. Can I get away with a 180 Thermostat????????
  140. Engine Oil Pressure Gauge Drops
  141. P0405 Code
  142. Key In Igniton Buzzer-continues To Sound
  143. Starter died last night
  144. O2 and Water Doesn’t Mix
  145. speedo problem
  146. A Biased O2 Sensor
  147. Grinding, rubbing noise from pulley
  148. check engine light on...Help!
  149. eng stumbles 35 and 50 mph when warmed up
  150. EGR code
  151. Pcv
  152. uncomfortable vibrations
  153. SWAPING 03 5.4 engine from an Expedition into an 03 4.6 Screw
  154. Another P0401 Question
  155. 5.4 won't idle
  156. 91 Ranger missing issue.
  157. New Radiator
  158. Major emissions flush? What is it?
  159. ***increasing standard hp***help
  160. this is strange
  161. '03 5.4L SCrew rough start when cold
  162. 87 F150 302 Fuel System trouble, Need info
  163. 5.4 eats coils?
  164. Spark Plug change
  165. Motorcraft Spark Plug Model Question
  166. Computer Question
  167. f150 cooling problem?..
  168. 84k miles, too late for synthetic?
  169. changing orig. plugs, which to get?
  170. gt40 heads
  171. PLEASE HELP:Starter prob.
  172. Dead Cylinder- Need Advice ASAP
  173. Vehicle 'Stumbles" just after I press the accelerator?
  174. ac problem
  175. code 0356
  176. 4.6 shake
  177. 04-05 3v swap
  178. what am I getting
  179. What Is It With the IAC
  180. Question?
  181. New Coil Packs?
  182. my mpg seems to low
  183. THE H.P FREAK'S "SUPER FREAK" 5.4 BUILD UP!! (pics)
  184. What are PI Heads?
  185. Cold air VS K&N
  186. running rough at low idle
  187. Truck hesitates alot in wet/cold weather
  188. Help !! Running Rough
  189. Code 23.........please advise
  190. #3 misfire code shop can't find problem
  191. Engine Rebuilds
  192. K&N filter will unscrew your plugs (says Ford)
  193. throttle body
  194. Check engine light after Sea Foam
  195. finally got a code!
  196. question about testing coils and injectors
  197. Rough idle due to puddle crossing...help!
  198. Ford dealer no help with misfire...Help!
  199. Power mod resitor
  200. Removing COPs
  201. My other car is.....
  202. 1# Spk plug wire jumps off dist cap
  203. Fuel Ecomomy and A/C
  204. Misfire on cyl. #4
  205. Power Steering Leak
  206. Oxygen Sensor Part Number?
  207. 99 4.6 valve clatter
  208. Help! Now Truck Is Lurching and acting weird
  209. I'm getting real PRETURBED with my truck..
  210. P401 code again
  211. Quick question: What's meant by "vacuum leak"?
  212. Synthetic Oil
  213. Idle problems?
  214. inexperience tells all
  215. what is this? (picture)
  216. not again...
  217. 4.6 OEM filter number?
  218. Plugging Away
  219. Recommendations for good independent garages in San Gabriel Valley
  220. Ping ping ping
  221. Keeping Oil Changes On The New 5.4 Neat -- Any Tips?
  222. A good oil additive to try
  223. Odd hissing sound
  224. cylinder misfire... and hello
  225. Looking for a bit more power...
  226. discount IAC's on ebay !!!
  227. Sea Foam
  228. Iac
  229. Engine starts and idles fine, but spits and sputters when in gear
  230. 02 F150XLT, 11.8mpg mostly hwy. MAF Cleaned. P0175
  231. 5.4 Head Gasket
  232. Just finished 4.6 to 5.4 swap
  233. Starter Relay Connections
  234. help help
  235. The Darned Electrical System Confuses Me!!!
  236. Compression
  237. how do you spell serpentine?
  238. Sending unit
  239. Do I have a 3v or a 2v 5.4?
  240. 98 f-250 codes 1131 1132 1133 0133 HELP
  241. Need some advice....
  242. Engine Problem
  243. Whos Got #'s?
  244. Exhaust Leak or Paranoia?
  245. Should I do any Engine Mods at all?!?
  246. It's that time again... For What's that part ?
  247. Chevy Vs. Ford
  248. Horsepower
  249. 4.6L to 5.4L on 4X4 - Need ASAP!
  250. O2 sensor removal
