- Buying a F150 Tomorrow -- Need Advice
- Sea Foam
- block heater
- starter noise
- starter noise
- FNG with performance questions
- Air Force 1 vs. K&N FIPK
- 1990 F-150, not enough gas on one bank of cylinders on 302
- Ticking Noise When Started
- O2 Sensor/Check Engine Light
- Starting Problem
- What Do You Think?
- Bad gasmilage and not running right
- Ignition Module Failure
- It worked for my Harley!
- Mike Troyer and senior members please read
- 351w to 302
- What to do next?? (and a Ford suggestion)........
- spark plugs
- 2001 F150 5.4 engine cut out
- 5 Cans of sea foam
- v6 to v8
- UFO Crop Circles?
- New 4.6l 3v!!!
- Camshaft Position Sensor
- lower intake shroud
- When is it time??
- holy farkin hell....
- 1994 Inline 6 300cid-revs up when the cruise control
- please help
- Engine Detailed, Running Rough
- Valve seal question
- 2005 4.7 xlt supercab
- starting problems
- edelbrock intake manifold
- pdfe
- 97 4.6 keeps misfiring # 6
- 97' 4.6...#6 cyl. keeps misfiring..HELP
- Engine/Trannie/Clutch?
- I want to pull
- Where to Get Forged Pistons
- 01 ecu
- 99 5.4L leaking oil
- egr valve insufficient flow code.
- 351W damper and flywheel?? how to match them up
- We all need better gas mileage!
- whistling when given alittle gas
- 351W/302 harmonic balancer and V-belt pulley
- 2004 F150sc Performance
- Squeaking from motor with belt off?
- 5W or 10W?
- high temp
- Truck died while driving and will not restart
- spark plugs
- Stop leak in system, problems
- maybe someone can help..
- horsepower/torque
- Question about burning oil
- 94 inline 6 300cid-revs up when cruise control is engaged
- 01 5.4 inconsistent idle/startup problem
- Hesitation at 3100-3500?
- next mod
- engine hesitates while driving
- how many quarts of oil
- o2 sensors
- 5mm vs 9mm plug wires
- 95 F150 List of problems Please Help
- Coolant in #1 and #4 cylinder - '98 F150 4.2L
- Weak Running 302 in 1996 F150 4x4
- Ignition Upgrade 4.6
- 4.6 PERFORMANCE HEADS & HEADERS
- 4.6 Problems?
- 4.6 shakes during slow stop
- 97 F-150 4.2 Won't Start
- Converters Needed?
- 1992 302 - Idling fast now won't start
- Dry Start - 2004 5.4 Liter
- Don't Even Know
- 5.4 hp and torque
- code p1299 ,cylinder head temp. sensor
- Check this out
- Rough Idle and CEL on
- Whirring/Warbling Noise???
- Supercharger
- 5.4 Engine noise question
- '95 F150 Won't Start...I need help too!
- o2 sensors
- Next mod
- K&N return on warranty
- n00b- easy question for now
- 4.6L vs 5.4L?
- cylinder head temp. sensor
- o2 sensor?
- 00 f-150 wont start...need help.
- Water temp
- engine shuts off
- Update on the V6 diesel rumors...
- dealer says its normal
- Brand New Truck ... What Ocatane To Use?
- Does '99 Non-L 5.4's have same cams as Lightnings?
- Heater Hose Fittings
- Voltage Gauge
- Bad Ground
- mass air flow conversion
- How big? - Throttle body
- 97 4.6 heater line
- 1 more question...
- Help 4.6 Hesitation At Low Idle
- New Truck....Almost
- Honest Towing
- P1152 Emission Code
- 2002 SCREW 4.6L P0405 Service Engine
- 98-150 wont start?
- Oil Change Regimen - New F-150
- thanks!!
- 1994 F150 Engine swap question
- Help!!! Truck not starting after starter got stuck on
- 1988 150 problems
- oil filter help
- Question on engine
- '93 5.0 Idle Problems
- Should I buy this engine
- I A C Valve
- Oil Gauge
- Blown Plug. . . Where do I buy the Kit?
- Normal Engine Temperature...
- '05 F150 Sales Brochure
- Indy
- starting problems
- Fuel system not presurized?
- Codes: P0354, 735, 181, & E538
- Best way to flush a radiator?
- HELP! 8 rib pulleys / 6 rib belt
- Really Dumb question about Oil Filters
- engine starts then no idle help!
- Behind Axle gas tank leak help!!!!
- 95' F-150 Cutting Out
- All answers to P0171, P0174, rough idle, CEL
- air intake question
- Tank won't take fuel
- running rough
- 5.4L Engine Power
- How to get better gas mileage and horsepower
- radiator flush and fill????
- Problems with 2005 F-150 5.4
- Fuel Pressure Question
- "Bank 2 System Too Rich" - Which side is bank 2?
- 4.6l plug, wires, ox sensor replacement on 98'f150
- Drivetrain?
- Need some help with my new truck
- #3 cylinder misfire. Fuel injector wiring?
- Anyone dealt with PerformanceDistributors.com
- 1994 F-150 DEAD No symptoms
- 95 F 150 computer/power ?'s
- Used 5.4L SuperCab Pricing
- 5.0L died while switching tanks
- Installing electric fan(s)
- #1 Coil Pack - How much should I pay?
- Any word on 3V 4.6 F-150?
- Overheating
- Replace radiator hose...
- new to me truck, few questions
- Truck dies for no apparent reason.
- Radiator hose blew off again
- Rattle on cold start up
- Difference in Intakes
- Need help quick!
- Looking for 98' Navigator computer harness. Look inside.
- My 'installation' adventure
- code p-1299
- Vandalized Engine!
- 98 4.6 Backfiring under WOT
- 98 F 150 5.4L ? MAF Sensor
- Alternator ???
- radiator flush
- Going back to a TRUCK!!!
- P1000
- throttle body
- Performance
- GM 6.0 vs. Ford 5.4
- 97 F150
- 1998 F-150 Starting problem
- belt sqeaking
- P0141 1st, now P0136
- 302 wont start.. fuel problems
- Question for you Motor Heads
- Mark LT Vibration Problem like F150
- 4.6 Starts sometimes Guages fluctuate
- 1998 F-150 Code P0171/0174 & rough idle
- Oil pressure gauge in 4.6l F150
- Starting probs
- Cost to Rebuild 4.6L ? How to get more HP
- Air Bag Code?
- 4.9l 300cid
- Code P0175
- Unequivocally the best oil for your F150
- Help. Throttle body
- plug issue
- 4X4 Service question
- What is this and what does it do??
- Poor mileage 4.6L the order of the day.....
- I have a question about piston offset.
- Truck getting 12.57mpg city driving?
- what's dohc or sohc
- is it an engine problem?
- 4.6L Poor mileage and what to buy next help????????
- Should I Replace the o2's? If not, ??
- Increase fuel mileage
- Weird Sound to me
- Is 2003 5.4L 32v direct sap in my 2000 lincoln navigator?
- Engine choice, new 150 Supercab
- any one dyno a stock 5.4 3V ???
- smog sys problems
- when is a good time to.....
- Spark plug order 4.6
- Not too sure what's goin on here
- 45k miles and engine studders and misfires not really predictable...
- Power shortage and low milage
- Does the Turbonator work?
- code 0420 and 0430
- PCV Valve
- What are some good plug wires?
- Need help from all of you experts.
- How many Texans have blown a spark plug?
- Knocking
- 5.4 limited at the start?
- What is the best air intake system?
- Low End Growl
- 75mm throttle body worth it?
- Just installed TP e-fans...have questions.
- 92 Mass Air Conversion
- Engine fault code P1506
- Need more power!!!!
- i found some oil on bottom of tranny case. what does this mean
- Right octane gas for 5.4 3 valve engine?
- How to remove crank pulley bolt???
- Gas Milage.??? New 2005 Supercrew 5.4
- I Need Help!!!!!
- Goodyear Part Numbers
- 1st oil change?
- whistle
- I have some new parts too, but not as many as Neal.
- EFans, O2's, Throttle Body cleaning......
- I have a question for those who have been inside their engine Neal, JMC
- HELP!!! Busted my AC condensor
- questions about heads and a head swap
- Blew spark plug
- 5.4 Stumbles at around 1500 in neutral?
