View Full Version : Engine
  1. Check out this Ford for Sale!
  2. Intermittent starting problem after running
  3. How do you check and find a vacuum leak?
  4. What Gears
  5. Maintenance manual recommendations?
  6. 89 f150 flywheel problem
  7. Is this the correct plug #?
  8. Best Plugs?
  9. egr ports in the tb? egr flow?
  10. Running lean
  11. Engine Computer Purchase
  12. Oil Filter
  13. Oil Filter
  14. fuel milage
  15. Mustang intake?
  16. Gatorback belt
  17. 4.2 Engine swap
  18. need fault codes
  19. Blew spark plug right out of head!
  20. Head Gaskets
  21. rough idle,smoke??
  22. 4.2 to 5.4
  23. Shredding fan belts; need help!
  24. stalling when cold.
  25. 1997 starter?
  26. Gas Mileage
  27. 1989 F-150 5.8l/c6
  28. volant
  29. Triton?
  30. Is it too late?
  31. off the line jump?
  32. rod bearing replacing
  33. Lightning MAS in a Expy
  34. 1999 5.4 VIN L Engine Swap
  35. is chip mod worh it
  36. gas mileage 89oct?
  37. 1988 f150 engine popping noise
  38. Horrible lag when cold...please help!
  39. 300 to 351M engine swap
  40. Oil Filter
  41. 6.0l f150??
  42. air intake
  43. F-150 5.4 and 4.6 Throttle Response INFO!
  44. misefire #3
  45. 1990 egr tube rusted through
  46. Driveability Problem, Help !!
  47. Engine Noise at High RPM's
  48. What Could This Sound Have Been?
  49. IAC Location???
  50. which is #2 cylinder
  51. Whooping noise
  52. Rattle noise in intake.
  53. Enging Or Tranny Shudder ?
  54. 04/05 radiator removal questions
  55. New Accesories
  56. oil in coolant
  57. P0306 #6 cylinder missfire
  58. NGK Iridium Plugs?
  59. Rate the mods
  60. Houston performance shop?
  61. $$$ Cost to rebuild a 4.6L with some more muscle ???
  62. 97 f150 check engine light on
  63. Spark Plugs
  64. Should i invest in a grounding kit?
  65. lob-sided 302
  66. Testing 4.6 coil packs
  67. Extended Idling--Safe ??
  68. 01 F-150 with Cobra badge
  69. Rpm Problem
  70. A Good Oil Filter ?????????
  71. Engine misfire
  72. MPG increases
  73. Help please
  74. 99' F-150 4.6L Water Pump. WHAT BRAND. ASAP Please
  75. different oil question
  76. coolant temp rising, then falling...problem?
  77. enigine swap?
  78. Clattering 4.6 Sounded like a Diesel Engine
  79. Vacuum Line Removal
  80. Ticking/Clacking noise when in gear.
  81. K&N FIPK and throttle body spacer?
  82. decode engine label?
  83. High Mileage Oil?? and Tune Up Info
  84. 04' PCM Reflash for Rattle
  85. Kendall full synthetic oil
  86. 4.2 to 302 engine swap
  87. Serpentine Belt size problem
  88. Battery Light Flickers @ High RPM
  89. Acetone as a Fuel Additive
  90. 03 near end warranty,what to check?
  91. MAS Relocation...
  92. Air Intake Valve ?????
  93. '92 F-150 XLT with 4.9 straight six - advice
  94. New ignition system for my 2001 super crew?
  95. Callbacks
  96. Outside temp and cruise control switch...related?
  97. What's Pinging?
  98. changed plugs, missfire left, now back
  99. 2005 Underdrive Pulleys
  100. intake manifolds
  101. 02 HD stock rwhp?
  102. '97 F150 4.2L V6 Hydro-Lock Kills Motor
  103. 4.6 power loss in 4th&5th
  104. Ford recall....help me with temporary fix, plz
  105. turbocharging a 5.4l v8
  106. Ethanol Blend Question
  107. What Octane to use??
  108. Electric Fan Kit....Questions
  109. lower intake gasket making 2 cylinders not to fire??????????????????????????
  110. Ford Recall
  111. 97 4.2 i cant get the throttle body off
  112. will not start PLEASE HELP!
  113. Smoking at start-up
  114. Fuel Gauge on 2005 f150 supercrew
  115. 99 F-150 4.6L , best Plugs & Wires to use ??????
  116. BP Ultimate, Clear Gas, better perf.???
  117. Someone Please HELP!!
  118. 1998 F-150 5.4L - engine missing after washing.
  119. engine swap 4.6-351W
  120. Noob Tuneup question...
  121. Still running like poop
  122. Big Help Needed
  123. Diagnostic codes?
  124. Mobil one
  125. My engine doesn't like me???
  126. 5.4L engine problem
  127. cold detonation
  128. 94 5.0L check engine light!!! HELP!!!!!!!
  129. swapping a 4.6L for a 5.4L
  130. 1997 Ford Expedition - Won't Idle when cold
  131. 2005 f150 scab 5.4...300hp????
  132. 4.6L cutting out at full throttle ?
  133. gas brands
  134. Ford problem, any techs or attorneys out there?
  135. 97 Lincoln Town Car E-Fan??
  136. Recommended oil
  137. Normal Noises?
  138. pissed off
  139. anyone heard of this one?
  140. Gurgly Diesel Sound???
  141. CNG truck revs & stalls
  142. oil pressure
  143. Alternator Failure?
  144. Engine block Heater
  145. EGR Tube at manifold
  146. Rebuilt starter, now stalling, ideas?
  147. question?
  148. question
  149. Cam Seals????
  150. Are cool air intakes any good?
  151. 4.6L Could be bad!!!
  152. Another Spark Plug Question
  153. noise after turning off ignition
  154. misfire #1
  155. Pedal adjustments
  156. 97 f150 4.6 plug failure.
  157. besides alternator
  158. battery light stays on
  159. changed plugs now missfires
  160. Coolant leak before thermostat opens (?)
  161. For a used motor, what do you think?
  162. i'm new
  163. question on k&n filters
  164. Intermittent squeak from bottom of motor.
  165. Don't buy gas SEPTEMBER 10th!
  166. AAA approved garages
  167. 97 4.2 extremely hard to start
  168. 5.4 engine sounds
  169. I need some help - I am out of ideas
  170. Flash your ECU to run "Limited Cylinders" just like the new trucks.............
  171. Katrina aftermath
  172. better gas milage in diffrent climates/areas?
  173. Disconnecting battery for reset ECU ???????????????????
  174. how many in the MILLION MILE CLUB?
  175. Underdrive Pulleys & a/c Fan
  176. Turbonator Supercharger Info
  177. Headers, electric fan or ignition system
  178. K&N really WORKS!!!
  179. 4.2 Missfire
  180. How much will a K&N air filter help my f150 how many H.P????
  181. cylinder misfired, replaced coil pack, now will not start
  182. Engine problem - revs up at random
  183. crankshaft pulley installation
  184. Truck wont turn over
  185. Superchargers
  186. Header gaskets
  187. Anyone running MSD 7020 on their rig??
  188. Newbie on the message board
  189. #6 misfire
  190. Idle ?
  191. i know i will get sh*t for this but oh well
  192. Throttle Body Spacers for 4.6L F-150 / Do they work ????
  193. Need HELP getting deployed.
  194. Under hood temps?
  195. Turbonator feedback
  196. 4.2 V6 Engine Clicking or Ticking
  197. PI Heads, how can I tell if I have them?
  198. spark plugs
  199. Changing fuel filter ??
  200. heads question
  201. Difference in 04-05 5.4 f150 MAF sensor, or its mounting location ????
  202. Underhood part identification????
  203. coolant leak
  204. Am I to old to Flash?
  205. Fuel Pump runs constantly
  206. Lightning supercharger on a 2001 4.6 f150
  207. 401 EGR Insufficient Flow - Tried Everything!
  208. If You Don't Do Your Own Maintenance -- You're Nuts!
  209. Hot Days and Hard Start Ups
  210. Can't get the fan off..... Help!
  211. check engine light blinking
  212. 'Service Engine Soon' Light On
  213. PCM Update?
  214. TPS (issue)
  215. 2005 Lariat Screw 5.4 Engine Oil
  216. Smoking
  217. Ecu-ecm 5.0 / 5.8
  218. Where to start??
  219. Let me add my name to the engine shudder hat...
  220. Dual Fuel for F-150
  221. Spark plug issue
  222. 1996 f-150 stalls when turning
  223. Could my truck be miss firing?
  224. Out with the K&N FIPK, in with the AEM Brute Force!
  225. New Start Up Noise!
  226. what oil
  227. 5.4 and E85?
  228. Oil pressure sending unit
  229. Vortech S/C'd 5.4L Spark Plug issues
  230. help please
  231. Seem to have a problem with my PI head swap, help.
  232. Recomendations Needed as well as reasons..
  233. He who dies with the most toys in the end wins
  234. new member here i need help
  235. oil changes
  236. F150 Questions
  237. spark plug question on a 5.4
  238. Need help with hot blooded engine
  239. code 1507
  240. TP e-fan question
  241. Engine Swaping
  242. Swapping 5.4 into a 97 Expedition 4x4
  243. Light throttle shudder question?
  244. Lean engine condition 1996 4.9lt
  245. block heater question
  246. Get an Extended Warranty
  247. misfire
  248. Startups?
  249. How to repair code P0401.
  250. #4 Misfire
