- Coil pack for 2000 expy 5.4L?
- Battery light
- 2001 5.4 Jerking / bucking on the highway
- Torque Converter Clutch Switch Error
- 88 f 150 starting problem
- Argghhhh!!!!!
- calling all true flow filter owners
- I need help from the hot shots
- Screeching noise when turning.
- When Should I Change the Oil?
- Got the slap on an 01 5.4 SCREW
- Gas Pedal sticks
- CEL light stays on, engine dies
- new or old?
- lean condition after a motor swap
- Reference Spark Plugs, how much did the.......Dealer or
- Fuel Pump
- 3 month oil change schedual??????
- 19.96 MPG on 2000 5.4 4x4 extended cab
- can i put 5w 20 in a 1999 v6 f150?
- Replace Fuel Pump
- 87 F150 302 Engine Swap - POOR mileage
- Help! Second time it Won't start
- Help. CEL, Leak Somewhere on Passenger Side?
- Confused! Is the 5.4l 3V a small block or big block?
- 4.9 litre 88 f-150 starting problem
- 2003 6.0L questions, okay to buy?
- whats youre take on air intake??????
- No Temp
- starter solenoid picture
- What is the REAL factory Horsepower?
- 4.6 stroker kits
- Pulley ? # 2
- 97 motor swap 4.2 to 5.0
- Fitch Fuel Catalyst??
- Not sure on oil
- 4.6L won’t start
- A/C Compressor Wire for EFANs
- Any news on the cold start rattles?
- Sensor for a 5.0
- k&n air filter question?
- Cleaning MAF
- bosch platinum spark plugs
- code p0155??
- Pulley ?
- cel data, need decyphering
- Check Engine Light, Codes P0442 + P0743 ?
- 1998 F150 wont start
- 4.6 info
- Fuel Gage Mystery
- What's the best repair manual?
- another MAF cleaning plug
- 7.3 L lays down at 2200 RPM
- code P0307 ???
- misfire maybe?
- 2001, F150, 5.4 liter - Engine Clatter
- Tornado Fuel Saver- Gimmick or Godsend?
- P0401 EGR- Fix How to
- check engine light
- Are these fuel injectors compatible?
- Driving Habits, Engine Sluggishness, and Computer Reflash
- At wits end- bank 02 lean, please help.
- stock performance?
- pvc and 02 sensor location
- Gibson Exhaust let me know what you think...
- '97 F-150 Stumbles on Accel
- gas mileage for 05 expy
- Anyone from Maryland that......
- K&N Air Filters, Good or Bad??
- whats the best spark plugs
- 1991 I6 stumbling on acceleration
- 13.5-15 mpg. Is this as good as it gets?
- New injectors!!!
- Advice on changing coolant
- ScrewOnBudnik20'S 32 valve screamer
- wants to die
- Fuel Injector Upgrade
- code
- heater core leak
- topping off your truck when filling up
- engine additives
- Cam Phaser questions
- Spark Knock
- oil questions 5w20
- What belt for UD Pullies
- Comp Cams for 4.6
- Need some help guys
- Trouble Starting
- 1999 4.6 Won't Fire--Need Help
- What would cause?
- Anyone need a 97-2003 manual?
- '98 F150 skips until warm
- Will my 351W bolt to...
- Anyone get the Premier Maintenance Package?
- SES on and flashing sometimes
- Problem with cleaning the IAC valve
- i got another f-150
- fuel filter leak
- Really, Extremely, Ridiculously dumb question.
- Engine Cooling Temp censor
- code PO443
- Codes P0401 & P0304
- 99 F150 4.6 Plugs/wires
- location #7 plug on 4.6L
- Slow beginings
- E-Fans and fuel savings
- special plugs
- royal purple to moble one
- CFM on stock clutch fan?
- 1990 F-150 bucking; lack of power
- Please Help, Radiator Leaking/Spewing
- a slight problem
- Synthetic Oil?
- Better gas mileage?
- What will happen?
- 1995 Straight 6 performance
- 351 will not crank
- Oil on plugs???
- 98 5.4 part throttle miss/bucking
- What PCM Version do I have
- Increase Gas Mileage
- CEL : Excessive flow thru EGR valve
- driver's exhaust manifold removal. 5.4
- Volant 19746 help
- Top Speed Limiter
- Motor Swap?
- ALLDATADIY.com ???
- How to replace fuel injectors on a 1991 F150?
- EFAN and PULLY INSTALL HELP
- K&N - Should I remove?
- forced air induction for the 4.6?
- Could someone run a carfax for me possibly??
- overdrive
- lean
- coolant flush confusion
- Stage 2 on order!
- info needed for beginner rock crawling
- 99 F150 5.4 wont start...
- Best Idea?
- At wits end
- Not much info.
- Ford needs a bigger gas motor!
- New 5.4L 3v - Timing Chain/Ticking Sound?!
- price of MAF sensor??????
- Pics or Diagram of Valve train- 4.6l
- Is It Possible?
- Bank 1 O2 up-stream sensor replacment 5.4L
- Basic Mods
- So i went to autozone...
- Oil Separator ?
- leaky intake
- Washed motor
- OK, Time for some MODS!!!!
- 40hp needed
- In depth motor advice needed
- Intake help
- shop manuals
- 4.6L Valve Noise
- Sluggish!!??
- Overtemp issues
- Testing Coil packs
- Anyone know what Exhuast manifold runner controls are?
- Freeze plugs?
- strong odor of gasoline
- So I killed the starter solenoid..
- I am in so much trouble
- anything harmfull with excessive idling????
- Clear'ssss
- Need Help!
- ECT sensor location?
- K&N FIPK
- 96' Bronco Engine Starting Problem
- Time for checking off monitors
- #6 cylinder missing in 99'
- Silencer Removal
- 99 F-150 4.6l...... Plugs - Help ??????
- Oil filter study.
- When will gas mileage improve?
- left and right bank
- New Recall
- fuel pressure regulator ?
- dead f150
- codes
- texas powerhouse f150 01
- Missing badly at 2k rpm
- Howling noise
- confused
- What else can I do?
- differences between 01 and 02 5.4
- Bi-Fuel
- Performance Wires & T-Stat Housing for temp sensor
- Chips
- Input needed
- 5.4 2003 Motor Noises
- 99 f150 idle problem
- 2001 screw not starting in heat
- Howling noise
- 4.6 l engine starts but dies after 3 to 5 seconds
- Mixing Dyno and Synthetic oil ok?
- Name that (fuel) hose..
- Engine Code 0455
- 87' 150 problems
- Drilling hole in T-stat
- K&N poor mileage ?
- Motorkote Oil Additive
- What mileage does your truck get?
- How many miles are on your Truck?
- PCV/Breathing your own farts
- Look: Please Read
- need help stuck in a rut
- F-150 Won;t Start
- 2001 5.4L Starts and Stalls immediately- intermittant
- Tune up
- Chip for Vortech? Need Advise
- Justice Bros. products
- couple of HP questions
- 5.4 plug change, not that bad.
- projector headlight wiring
- is this normal ? Mobil one oil
- What is better?
- Tire Question ...
- Motor oil in anti-freeze
- Check engine light on
- Time for an engin swap...need advice
- First Oil Change Advice
- 4.6 belt pulleys
- Steering noise question
- can they be hotwired?
- K&N or Airforce One?
- reflased
- fuel pump size
- trying to escape Rita, truck wont start!
- Did they really do my recalls????
- Missing & Knocking problem
- Sluggish after 5000 miles
- #8 spark plug wire will not stay on!-help
- PCM reset
- Look'n for bluegrass
- EGR Solenoid on an 87'
- Engine noise after oil and filter change.
- Turbonator
- quick air filter inquery ?
- Need help quick!
- Smelly white smoke, Power, Idle problems
- K&N FIPK with Sahara temps?
- Sea Foam
- combination of parts,advice wanted!
- Throttle Body Spacer
- Engine stalls at idle
- Truck would not start
