- Knocking sound came shortly after start up?
- Pinging Noise...Not Internal
- 5.4 vs. 5.9
- Can anyone identify this?
- Hesitation..300 six.
- old gas question?????
- Quick Question...po420 code
- no acceleration at wot
- sudden acceleration
- 5.4 Engine Noise
- Piston Slap, or Not? Wondering about symptoms
- TPS Sensor Bad
- 4.6L Coils
- 5.4L Engine Differences between F-150 & Expy?
- 2002 Coolant problem
- 1998 NON P.I. Upgrades
- Too Lean?? (P0171 & P0174)
- Mac intake vs K&N
- 4.6 liter oil usage - 2001 Supercrew
- GMC 5.3 Vs Ford 5.4
- rad flush
- Belt replacement
- 93 150 XL questions???
- 97 4.6 overheating, any ideas????
- heater smells like maple syrup on startup
- Cobra R water pump on 5.4
- egr troubles again after less then 6 months. please help
- Unmerry Xmas
- Trouble code HELP!
- problem with idle
- Waterproofing my truck's engine-help!
- Where's my PCV valve?
- 5.4 Sound
- fuel pump issues
- 5.4 Plug Blowout-cani Drive It
- E-fan install??
- Spark Plug Blowout
- Noisy Lifters?
- 05 XLT Supercab
- Egr ??
- 4.6L V-8 what is in current F150's
- 1997 4.6 problems
- Cold Weather - whine (alt./belt?)
- What will it take to swap a 4.6 for 5.4
- Spark plug problem?
- Consuming Oil??
- Gas Mileage? How to bring it up some?
- Motor Swap
- 302 Engine Swap
- Poor gas mileage
- Questions about the 4.6L
- Can I do this??
- What are symtoms of a bad coil?
- Sparkplug Tread Problems in newer F150's?
- Flex Fuel engine...?
- Water pump symptoms?
- Premier Fuel Cell??
- What Gears
- water temp gauge
- At My Wits End
- Looking for opinions on new truck
- Enlighten me please
- Knock Sensor Question?
- belt change
- Gasoline prices going up AGAIN!
- 2001 f150 screw OBD port options for coil death?
- EGR Valve
- 4.6 hesitation problem solved
- 2000 F150 Stutters under load or acceleration
- New Truck questions
- weird noise by firewall
- Noise on startup
- Fanbelt noise driving me crazy!
- Hard start in cold weather - need help...
- Ethanol fuel in F150
- Spark Plugs, 1999, 5.4L
- Kenne Bell supercharger
- Top 3?
- 02 Lightning supercharger on a 04 5.4?
- Stumped... Service Eng light
- Still pings '87 5.0
- '89 f150 has no compression in #8
- 5.0 on its 3rd oil pan gasket-Why is it blowing them??????
- More Power!
- block heater
- 5.4L Engine Misfiring
- I Need Help
- ok one one more.
- reset computer?
- Pulley?
- poping the coil ?
- Changed plugs on 2001, 5.4L
- my heater is not hot!
- Extra HP?
- loping idle
- 2001 5.4L sparkplug??????
- Newbe needs help
- oxy sensor 1, bank 2, where is it?
- Vendor Choice For Plugs + Wires ..98 4.6
- Damn, these things are fast
- will this work with my truck?
- 1997 5.4L misfire
- Heads and Cams
- 5.4l Rebuild Kit?
- Im getting my cruise control fixed!
- Cams for 5.4 3v
- plug worries...advise
- Should I sell my 97 Expy?
- F150 5.4 liter engine pinging - should it?
- What the heck
- Truck wants to die when idling
- stock fan removel
- Missfire/Hesitation
- Misfire in cold weather
- Smog pump
- problem with Troyer E-fans
- Quick question
- My buddies 4.6 motor
- stuttering f-150
- 2005 F150 Black soot/Carbon
- whipple charger
- How do I disable the Cruise?
- Gettin' a sound...
- gas mileage
- Questions about intake manifold swap
- My first major failure
- What kind of oil
- Exh Manifold/EGR Tube Q's
- 1989 4.9 l timing
- Dumb Question
- Valve cover gripe
- Are there any chips that increase fuel effeicency
- Oil dipstick reading
- Misfire Or What?
- Engine Misfire or clutch slipping?
- Radiator problems
- 2005 F150---"engine shutting off" without warning
- Vibration F150 FX4 2005 Pulling, Towing A Trailer
- first noise in my 01 F150 supercrew
- Breaking in a New Truck?
- Misfire nr 2 and 5
- Ford's Best Engine
- cruise control recall
- Are there hidden codes with no CEL?
- head gasket
- Help needed
- CE Light ...its baaaaack?
- Need to clean engine
- bad idle
- Bigger Engines???
- Which heads have more than 4 threads?
- #1 cylinder miss fire code
- Best horsepower boost for 1997 F150
- Humming Sound
- Big Thanks, on blown plugs. Sensor ?
- 1990 f-150 I NEED HELP!
- Can plugs actually make a difference ?
- Whining noise...please help!
- valve cover and intake manifold torque specs
- My Old truck
- sub zero temp now VERY rough idle and missing (please help Bluegrass)
- Losing Oil. Is It Significant?
- 94 F150 Heater core problem
- For people using CAI's
- 5.4L Spark Plug Torque Spec...
- P0401 Insufficient EGR Flow
- Air only comes out from the defrost...
- yay
- Do I Have Piston Slap, Or....?
- need tips on improving gas milage
- E3 Spark Plugs
- Plug Blowout Prevention?
- Tapping noise for 1 minute at each start
- Idle Speed
- engine misfire
- newbie engine ID ?
- Head Bolts
- f150 5.4L K&N air intake replacement
- f150 flywheel- is it the right one?
- Engine light on, and idles high
- Oil pan gasket
- EGR Valve replacement?
- Anyone ever do a V10 F150
- Spark Plugs??...
- oil pressure issue
- Does changing spark plugs increases gas mileage?
- Fuel Pump On Ford Ranger
- F-150 not to my expecations
- Help
- Lubing chassis, changing brake fluid, etc
- pullies
- Truck shakes BAD! Help!
- granatelli MAF, any one using 1?
- Washing the motor...
- Engine Noise???
- Engine Swap
- RPMs at highway speed
- 4.6L 2v Life Span ?
- Temp Gauge Probe ( Coolant ) Help?
- When to change Spark Plugs
- F150 Starts/Dies
- Lightning into 4x4
- 2004 Ford F150 STX
- Turn signal will not work, flashers will work, 1995 F150
- Spark plug/tune up for 4.2 6 -- what the heck?
- Spark plug shot out while driving
- Installing power steering pully
- Something else to watch out for with block heaters!
- Tune Up
- Check Engine Light....????
- new heads
- 99 f150 doesn't like cold starts
- Do i need exhaust as well?
- 4.6 to a 5.4
- HELP my truck stalls cold weahter
- Ignition Switch
- Chip tuning w/o voiding warranty???
- Strange noise...?
- How about the 200,000 mile club?....
- Odd Heating Problem...
- ~2700 RPM = Loss Of Power?
- Tune-up
- Low idle on cold starts.
- Changed Fuel Filter -> Effing Dealership
- 302 longevity
- Carb Fuel Lines 94 351 F-150?
- Wire Set Ford Part Number
- vibration????
- Questions on passenger-side headgasket oil leak
- oil grade
- heater problems
- Coolant Temp sensor location ? 99 F-150
- Puff Puff Give
- Anybody Over 100000 Miles 5w20
- 1985 F150 won't idle unless in gear
- Help with gas
- supercharged f150
- 91 351 engine stalls
- F150 Reboot
- plastic vs alum. intake on 5.4
- Lgp
- Pcv Valve
- small miss in 4.6L??? Please help
- 4.2 V6 reliability
- 5.4L Blowing Ignition Fuse
- No Start Problem
- Coil pack or just a spark?
- Hard Start in the morning
- Air Filter/Adapter off Ebay
- Code P0153 - How to change sensor
